View Full Version : Conversions & Hybrids
  1. LS1 swap in a Jeep Cherokee
  2. putting ls1 in a 2003 sillverado with 4.8
  3. Manifold Photos
  4. LT1 Rear Calipers,,
  5. Wiring Help - 98 LS1 in 88 TransAm GTA
  6. need help with 1997 silverado 4.3 to 5.3 engine swap
  7. LS1 Swap in 59 Chevy panel New or Used???
  8. what pcm's interchange
  9. LS1 Into S10
  10. LS1 in a Pontiac Fiero?
  11. 3rd gen and ls1 02 sensors?
  12. how much with fit
  13. CAI on '78?
  14. Speartech vs Painless vs S&P
  15. S&P vs BRP vs ATS, '78 T/A
  16. Ls1 Swap In A Fox Body Mustang?
  17. Guage Cluster in Mustang
  18. Hooker Chevelle LTs
  19. ls1/T56 in a mustang? ls1 swap questions.
  20. battery junction block
  21. How Does A Relay Work?
  22. Definition Of HVAC?
  23. Regulator?
  24. Fuel Pump Wire Size?
  25. 500 HP LS2 in a Boyd built '54 Corvette
  26. Well the car started today.
  27. colorado ls1
  28. 1970 body on a 4th gen frame
  29. 1st-gen Camaro body, should I install an LT1 and S/C it, or get an LS1?
  30. LS1 fuel tank (Plastic 99-02 style)
  31. 5.3 with a 700R4
  32. How about this for a Hybrid!!!
  33. Mid engine project...Lotus Esprit S1...Transaxle?
  34. 8-71 Ls1?
  35. pics of my ls1 fox
  36. "H" pipe, yes or no
  37. Project "Exorcism" has begun!!!
  38. T56 Into 98 Z28
  39. Carb LT1 240sx idea.....!!!!!!!
  40. TPI fuel pump on a LS1?
  41. does the PCM need the O.E. low oil and oil pressure sender?
  42. fan wiring
  43. 5.3 swap into a jeep with ford manual tranny???
  44. ls2 vette pan VS ls1 S&P pan PICS PICS PICS
  45. LAST fuel system hurdle, the corvette filter outlet to rails..
  46. taking bids on 240z
  47. Pick An Engine
  48. Hybrids and the 1/4 mile
  49. vacuum port
  50. FS:67-69 Camaro SFC & Moroso Trick front coil springs
  51. Clutch won't bleed
  52. LS1 into Fox header question
  53. vehicle speed sensor question
  54. 853 heads on a 6.0 with Gm hotcam Compression?
  55. It has begun, 5.3L swap into 3rd gen
  56. skinny line for A/C comp.
  57. 5.3 swap in a 1970 chevy truck questions
  58. LS1 engine operation trouble
  59. John B
  60. Who makes headers for LS1 > Malibu Conversion
  61. LT1 to LS1
  62. Aluminum or Iron 5.3??
  63. where to get custom axle shafts made?
  64. probably been seen before
  65. CTS-V Manifolds on EBay
  66. I need info on LS1 into Chevy II conversion..
  67. corvette swap
  68. going to pick up a 5.3 tomorrow..... heres my idea
  69. LS1 in a 78 Z28. Need help
  70. LS1 swap surprises...what else is coming
  71. Ls1 Headers For G-body?
  72. 1979 Tran Am?
  73. CAI's
  74. Any body running a carb style fule injected set up?
  75. LS1 in 1988 MK1 MR2
  76. corvette fuel filter fitting question,
  77. LT1 to LS1 swap ??????
  78. FS: ASA LS1 Racing Harness + PCM
  79. Turbo Nova finally runs
  80. Need advice on swap-79 camaro
  81. "ls1" in a grand national!!!
  82. LS1 + 4L60E -> G-body elcamino conversion??
  83. ? spacer for corvette bracket
  84. 59 Twin Turbo LS1 Impala update
  85. Power Steering
  86. Manually lock torque converter?
  87. ls1 into a 99 blazer
  88. 6.0/4L80 into 70 Impala
  89. LS1/T56 in 69 El Camino Tricks!
  90. How do you guys liscense your cars?
  91. ls1 wayne due sub
  92. what are the most frequently asked questions regarding LS1 swaps?
  93. speed-o help
  94. help with wheels for my 67 camaro
  95. Flexplate Help!!
  96. C1 C2 computer connector pins
  97. anybody else running a CARB
  98. ok fox stang, 4l60e shifter, something less bulky?
  99. Picture of my ls1/smooth firewall
  100. Dash/chassis wiring harnesses
  101. Any Pics of Pacesetter LTs in A Body?
  102. which way do transmission cooler lines go?
  103. 1st gen F body LS1 questions
  104. Will HP tuners remove vats?
  105. FS: LS1 ECU for swaps/conversions
  106. 58 Chevy body on Vette Chassis
  107. Issues
  108. Help! 2001 Fuel system issue in 55 swap
  109. CTS-V Oil pan accesories part numbers needed
  110. Adapter companies
  111. LS1 Jeep?
  112. LS1 swap into a caprice?
  113. Adecuate air flow for LS6 ? Filter size?
  114. few connector 220/230 questions
  115. max lift cam on yellow ls6 springs
  116. Pics of fuel tanks and firewall...aluminum
  117. SBC vs LS1 exhaust manifolds?
  118. headers for 67-72 chevy trucks
  119. Wiring and programming for T56
  120. 3rd gen F-body LS1 guys come in....
  121. LSx engine swap into a '93 - '97 F-Car.....
  122. The '69 saw some light today...new pics
  123. Please help me with LS1V T56 crossmember 78 Camaro
  124. Connector Views
  125. LS1 swap into a 2nd 1980 TA
  126. Motor Dimentions vs standard SBC?
  127. Temperature Sender
  128. 3rd gen swap question-manifolds
  129. fuel system
  130. A was to not get custom lines for power steering in fox stang
  131. SolidWorks or Pro-E files - LS2 + T56
  132. Tach pulses per revolution
  133. Many questions...3rdGen conversion
  134. Harness opinions
  135. ls1 grand am
  136. LS1 in a '98 Jeep Cherokee???
  137. viable locations for LSx computer?
  138. Converting my 1996 Trans Am to 98+WS6 Ram Air I NEED PARTS!
  139. power steering cooler
  140. 6.0 Jeep wrangler throttle cable
  141. LSx in a 58 Panel/2nd Gen Camaro
  142. v6 to v8 convert
  143. 01 gas tank in 68 bird???
  144. Bore and Stroke of clutch master cylinder for F-body
  145. Accessory belt question
  146. ls2 solstis
  147. Boy was I bored today....
  148. ? stock camaro tank measurements
  149. Good first swap?
  150. I have cried UNCLE.. I am gonna swap reluctors.. question.
  151. 95 chevy TBI
  152. LS1 A-body Cars
  153. need to order a harness today..feedback
  154. LS1 radiator hose sizes, conversions
  155. Light cars good for swap??
  156. need help with heat .
  157. help on gto ls motor............
  158. More update Pictures on my 73 Camaro LS1 swap
  159. 2001 V6 to LS6
  160. FS: Tubular suspension setup to bolt LS1 in mustang
  161. Hedman LS1 in S10 swap kit
  162. LS1 pullout eBay scam
  163. gto ls1 motor into a-body
  164. v6 to v8 swap
  165. Thermostat Housing
  166. Computer options to control 58x LS2..
  167. LS1 package output
  168. Power steering hose to PS pump
  169. Thought I would add mine here
  170. LS1 C4 swap pics.?
  171. sanden comp. for sale
  172. Pics of my LS1 into 73 Vega conversion
  173. LS1 RX-7 FD Won't Crank
  174. parts FS
  175. ready for LS1 harness...need input
  176. LSx into DSM Conquest/Starion
  177. AC Cobra with LSx/T56
  178. LSx into '67-'69 Camaro, the basics.
  179. LSx into '67-'69 Camaro, the basics
  180. 4L60E / 700R4 dimensional differences
  181. Mounting a 4th gen radiator in a 3rd gen?
  182. ls1 into 95 ta staring problem and etc...
  183. ls1 into 95 ta staring problem and etc...
  184. Updates to my 1st Gen Swap
  185. LS1 into 87 silverado
  186. FS - 1985 jaguar XJ6 w/ a CA smog legal LT1 conversion
  187. UpGrade to LS!
  188. Steering shaft resolution for 4.6K member in fox
  189. bcm required?
  190. The new project car comes home tomorrow!!!
  191. custom indicator lights? airbag, CEL, etc?
  192. ls1 into 95 flamed 3.4l (check it out)
  193. Mack daddy wiring thread
  194. What A/C parts do I need?
  195. Power steering leak
  196. ls6 cam&intake in sto 6.0 help
  197. FS: Foxbody/LS1 Conversion parts
  198. Accelerator pedal? Hooker Headers?
  199. Marine harness as a simplified, inexpensive harness?
  200. Ssc ??
  201. will an ls1 harness work for an auto and t56?
  202. to be or not to be
  203. 1st pic's of the LS7 sitting in my G-body!
  204. 99 ls1 power steering pump meets 94 rx7 rack
  205. anyone do a swap and get P1637 Generator L terminal circuit?
  206. 5.3 thermostat
  207. Electrical diagrams & pinout schematics
  208. ok guys my speedo still wont work!!
  209. Blue and white connectors through firewall?? help!
  210. True Dual X-Pipe on 55 Chevy truck?
  211. cowl induction w/backwards LS manifold
  212. Viper Engine!
  213. Anyone actually used a non-LS1 tranny?
  214. what is every one running for exhaust?
  215. Push Button Ignition
  216. ? C2/C3 transmission mount
  217. Stainless steel compression fittings
  218. fuel pump always running?? help
  219. How to get mustang gauge cluster tach to work with LS1?
  220. LQx Accessories/oil pan in third gen
  221. LS1 into a 62 Corvette
  222. LQ4 into a Jeep CJ
  223. MAF end screw size
  224. 1995vert To Ls1 98 Small Problem?
  225. 06 silverado ??
  226. LS1 in 58 Chevy Panel/70 Camaro Hybrid
  227. LS1 in 58 Chevy Panel/70 Camaro Hybrid
  228. Auto to manual harness
  229. LS1 into Vauxhall Firenza
  230. Wiring Issue in a Hybrid
  231. a/c control w/ 2003 pcm
  232. Some pics I took today..
  233. 72 Nova temp gauge??
  234. FS 93 rx7/lsx forged procharged +700rwhp
  235. Getting conversion radiator made? few questions re air bleeds etc.
  236. Stock exhaust manifold flanges
  237. Oil pan swap?
  238. How to tell the difference between 98 and 99+ interior harness?
  239. shifter pix
  240. 1st Gen Fbody Headers
  241. ls2 oil pan into 69 camaro?
  242. headers for a ls1 97' sonoma`
  243. Twin Turbo LS1 in a Volvo Wagon!!!
  244. Do I NEED this sensor?
  245. ls2 into silverado
  246. little help w/ mustang swap, having issues getting motor in lol
  247. FS: RX-7 front/rear suspensions for LS-1 swaps
  248. CTS-V and FWD oil pan dimensions?
  249. Corvette brackets
  250. Fuel Plumbing question 92 Camaro/Ls1
