- truck harness and fbody harness-same?
- Can a mustang pump, say intake 255LPH support the LS1 at 60 psi?
- LS1 T56 in a SEC gen Camaro...
- what do you guys think of this??
- Any Turbo Kit for Hybrids
- Happy LS-1 Holidays!
- My buddies 72 Chev Shory progress
- Car wont start, no fuel
- 2000 S10 LS1 swap exhaust sound clips and pics
- LS2 crate engine into 94 Z28 Pictures
- 98 harness with a 99+ pcm: can I modify the harness?
- LS1 in a 64 Impala SS
- What are your guy's thoughts on this?
- cut through fuel lines on engine?
- LS1/Notchback Conversion Costs?
- 5.3L into Third gen
- LS1 Mustang Project
- max lift 6.0 valve springs
- location of IGN 1 relay?
- Exhaust manifold help needed
- V8 Miata pictures at:
- LS2 Fuel Return necessary?
- Ls1 ? toyota pu 4x4 46" tires & 1.25 ton cucv axles, crawlratio 427:1!
- STS Turbo kit question
- Will the length of plug wires affect anything?
- 5.3 /4l80e wont start
- Ls1 Blazer Dvd .... Ripped Off!!!!!!!
- More on '78 T/A LS1 conversion
- LS1 to third gen queston
- 4th gen LS1/2 swap - which springs/struts?
- LS1 Questions
- Problems with exaust/fuel lines?
- s10 ls1ers
- firehawk hood noises???????
- Gauge Swap
- second gen guys
- Part number for oil pressure sensor fitting?
- Never-ending Fuel system problems
- LS1 in '78 TransAm
- Classic Instruments
- Midyear Corvette LS headers
- part numbers? # for oil filler cap?
- any problem using mustang starter solenoid
- question re: tach signal out
- Project finally finished!
- LT1 into a 71 Camaro
- How many Turbo 3rd gens?
- Finally my LS1 has arrived - teardown?
- f-body PS pumps???
- anyone using a ls2 waterpump?
- Are there any full wiring diagrams floating around for a 99 firebird?
- new style aluminum blocks, using methanol?
- will vortec 6.0L intake clear a s-10 hood?
- mustage swap questions
- Anyone else modify pans besides S&P
- Where did you guys doing a fox body swap mount computer?
- Suppliers for GM Weatherpack Connectors and wires
- LS2 + Light Car = >>>>>>>>SPEED
- Fuel Pressure drop causing lean problems?
- Pictures of ATS Engine Mounting Brackets
- 8.1 into 84 K10?
- F-body LS1 to 72 Chevelle
- LS1 ignition on old Pontiac engine?
- Where's the harness come through........
- question on 4.8 from Silverado into 66 Le Mans
- 69 LED Sequential Tail Light System - watch the video!
- LS1 into 1990 GMC
- Some pics of my Fox Mustang conversion.
- 6.0L Carb & Distributor Conversion
- Replacing pulley
- done some research, still question LSx 87 corvette 4+3..input please
- Auto V6 F-body to manual ls1...
- Some updated pics..
- Where can I get a fitting for the C5 fuel filter/FPR?
- My new IRS picture
- LSx -> 700r4 tranny
- Stock fuel lines too small?
- swaping a 98 ls1 into a 98 firebird v6 car
- not a ls1 but engine swap into fbod.
- OK to use 4.6L kmember and arms in a fox mustang?
- FREE Shipping from American Autowire
- fox ls1 swap. anyone use Fbody long tubes?
- Oil temp & pressure senders - where to install them?
- 98 PCM swap
- Ls2 Datsun 280z Update!
- help with block vin's...please
- 95 trans to ls1 98 complete overhaul!
- LS1 in 56` Chevy Wagon
- few motor mount/oil pan/trans x member ls1-mustang swap
- Warhawk!!!!!!!
- ls1 in 97' sonoma
- my ls1 swap project has officially begun :) Got my notch
- LS1 Cranks, but doesn't start
- Where are the tuners?
- Carfax
- gear ratio suggestions
- LS1 swap motor mounts A,F,G bodys
- GenI acc. drive on genIII block...
- Mounts, Exhaust, Trans, etc. Pic/Info Request
- 2002 8.1 into 52 Chevy Panel
- ? Dean Haskins, D+D Corvette
- what to do with LS1 fuel lines?
- Hooker making 1st gen LS1 swap headers
- Injector Problem
- Mazda RX7 LS1 with ATI ProCharger
- turbo kit for an F-body in a A-body?
- need an ls1 and t56
- Does Power Steering Pump have a bracket, etc?
- ls7 swap possible for V6 f-body?
- LS1 OBD2 requirements?
- ? power window unit
- 240sx Swap!!!!!!
- TPIS wiring harness, or who to go with
- HELP!! Do I need a MAF or not??
- C.A.R.B legal LS1 RX-7 swap?
- Electric fans
- 71' Vette with ls1 Motor & Late Model Vette Susp.
- 5.3 or 5.7 in mustang coupe
- Turn Key Engine Supply
- Removing Transmission Cooler Lines
- Contemplating new Project - Need Advice
- LS1 in 87 IROC Z
- ls2 rx7 drag day
- data link connetor
- anyone have a 98 specific harness you can look at for me?
- What will a 4L60E hold?
- ls1 into v6 car
- Performance Racing Industry 2005 Photos!
- Is this worth my time and effort
- LS1 in a ranger???
- 10's baby in 93 rx7
- ls1/t56 swap into 90 model coupe
- T56 Conversion - clutch pedal question
- making a 2006 LS4 Monte Carlo rear wheel drive ??
- 6.0L in a '72 K/5 Blazer... fired it up tonight!
- Crankshaft Sensor Test
- Energy Suspension Mounts for sale (3.1114G)
- Can a Tech 2 disable VATS??
- LS2 throttle body option..
- need some advice
- how to block heater lines
- LS1 oil pan in 71 nova...
- LS1 oil pan for 1st gen F body
- Updated pics of the 55 LS1 Truck
- 3rd Gen Lower Radiator Hose
- Straight-Up Thermostat Housing
- T56 On 5.3L An Option?
- LSx Conversions - Oilpans
- Small Block Chev. into 90 GT.
- Cruise Control plug: 7 wires or 10?
- plug for the evap line hole in intake?
- Anyone make a 6.0 intake look good?
- okay will the ls1 fit in a 2000 4x4 S-10?
- IAT in EGR hole?
- LS1 Miatas represent
- ecm #'s vs. year model
- LS1/MN6 in G35 Coupe?
- looking for pics 2nd gen firebird with ls1 front subframe
- LS1 RX7 E.T. Streets
- What do I put my vortec 383 in?
- A/C Bracket alterantives
- 4.3 to Fuel Injection mercruiser conversion.
- V6-v8
- 5.3 truck juction block (underhood)
- RX7 with LS1 Drift Car @ Buttonwillow
- Noble LS1?
- How to make a frequency divider?
- LS1 Wiring Confusion!?! (Into 92 Camaro)
- unplug PCM when welding ?
- 3rd gen LS1 swap ?
- LS6 Cobra
- Torque Arm Mount?
- Convert V6 f-bod to a 402 Stroker couple reasonable questions!
- Need wiring help
- 5.3 or 6.0 and where?
- NEED HELP: 1968 Camaro LS1 Swap
- 3rdGen Exhaust Routing
- 6.0L swap and the use of factory guages
- 5.3L Fuel Gauge Wiring
- electromotive tec 2 help please
- pros and cons
- Adapter for Water Temp Sender
- Conversion gas Tank (Pics)
- Transaxle alternatives
- LQ9 or similar in '02 S10
- 95 to LSX
- Few pics of suspension and radiator etc
- Yet another fuel question
- 67 hardtop
- LS1 in a Delorean?
- LS2 Accessory Brackets
- LS2 Convertion Motor Mounts?
- Need pics of LS1 in Mustang/Cobra...
- Displacement on Demand in a conversion
- Taylor Spark Plug Wires Part#?
- Starter motor problem - HELP!!!
- TPI in Chevelle....bolt right in??
- Gauge help
- What causes this?????
- Finally got the project rolling
- S&P shorty headers
- FOR SALE: LS1 set up for stand alone
- Can any So cal resident disable vats for my 6.0
- Anyone have an LS1 with a 5 speed?
- Wiring diagrams
- LS1 powered RX7s
- Possible ecotec swap
- Turbo350 in 4th gen camaro
- Pontiac Solstice
- Ls1 S10
- S10 Rear End
- 67 camaro t56 conversion
- Converting to an electronic throttle
- Stewart Warner Gauges...
- 91 rs with ls1
- What mounts for a true "bolt-in" .
- lq4 shortblock
- Yet another LSx RX7 video
- Ls7 Gto???
- New Moderator and project intro.
- my 68 ls1 shortstep
- Hey Oscar, Saw your '35 in Hot Rod Mag
- Can we talk transmission mounts?
- How many TWIN TURBO LS1 Chevelle???
- Fuel return line???
- small video compilation
- 3800 to LS1 swap in 02 F-body, Tranny same?
- New forced induction option for some of you hybrids
- ls2 402 rx7 tuning help
- Cooling fan question
- Guess the sensor game
- How fast will a 6.0 be in my car?
- Headers for LS1 swap
- 6.0L LQ4 and 4L60E for your swap!
- any data on 3rd gen w/ ls1 greatly appreciated! cost? parts? labor?
- PS Pump w/ Reservoir
- need help with 3.4l to 5.7 lt1 camaro conversion
- LS1 wiring in 1st Gen
- Fuel pump sitting in tank for 2 years, still good?
- Oil pan clarification
- $ to convert 350z
- LS-1 to a 700R4 ???
- 6.0 Truck motor into my 78 Camaro Type LT
- Year ones 69 camaro mounts and crossmember ?
- LS6/LS1 oil pan swap question
- 1994 Camaro v6-v8 swap Questions.
- More pics of my suspension pieces
- FASTEST carbureted LSx?
- 69 camaro LS1 cold air intake (Help)??
