- new project need parts
- "World's Quickest Mini" is coming together (pics)
- 408 Swap Header Question
- >>>Paging MrDude_1<<<
- LS1 w/4L60E fit problems in 76 corvette
- Ls1 Maf In Tpi
- lt1 wiring
- LS1 swap and emissions...
- BRP mounts for 71 Chevelle
- LT1 in a Cobra
- 3rd Gen F-body LT Headers UPDATE
- Holy Crap!!!
- Vette filter/regulator ?
- Chevy Monza Swap in progress
- Hose sizes?
- Engine number etched on front passenger side
- 1969 Camaro LS1 T56 Swap !!Eye Candy!!
- hey rudy at hardwired
- Glowing headers!
- Fuel tank, sending unit, and fuel pump for '86 Elcamino LS1 swap
- Those that have done full aftermarket gauges. got some questions
- cant find fuel rail to 3rd gen fuleline adapters?
- Air diverter Sol question.
- g-body conversion parts for sale
- Everything for sale
- fabing ls1 motor mount adaptors sae or metric???
- Oxygen sensor wiring qurestion:
- runs 5 seconds and dies
- 5.3L aluminum in G-body Malibu?
- exhaust flange help
- 98 5.7L or 99 5.3 swap?
- camaro v6 to LS1
- Its Alive!! Finally
- sub 1000$ motor
- oil pressure hookup?
- Steerin Colunm
- FS: CableX speedometer adapter
- speartech phone#
- ebay
- hose routing
- LSx swap question!
- 2nd Gen headers
- 2001 complete LS1 w/98ecm and parts 4-sale
- Out of Space Harness???
- For Sale: LS1TECH Project 1969 Camaro SS
- what does TCC stand for in the pin outs?
- 5/16" fuel line instaed of 3/8" for LS1
- fuse box wiring diagram
- Few more questions about cooling and first start up
- radiator hose info
- LSx harness
- Unidentified harness connectors question
- lt1 engine swap for ls1 engine
- what material to use for oil pan notch?
- Oil pan mods for s10 swap
- NP241C Speed Sensor
- LS or ZZ383
- How do I tell it's a '98 LS1
- anyone using the LIM?
- LS1 weight vs Standard SB 350?
- Engine Harness Question.
- LSx swap help with th350
- Anyone installed a BW Super T10 behind an LS1?
- V6 Radiator Compatibility
- clutch don't feel right
- Can someone run my VIN?
- Anyone used the Edelbrock Carb intake kit?
- Throttle Cable Question.
- Conversion parts for sale Knock Sensors and covers
- DSE weld in tranny x-member. anyone tried it?
- LS1 swap in 944 turbo
- 69 corvette ls1
- fuel systems...
- Any T56 Fox LS1 conversions yet?
- Supercharged 2nd gen
- Help!!! My tranny (A4) rolls off when in Park! Drives in Neutral!
- Who makes a 396 LS1 kit in MI?
- 1st gen S&P mount users, how far from the firewall?
- 99 to 76 conversion pictures
- 5.3 in Rock Crawler, won't run smooth
- LS1 in supra
- hows this for a hybrid??? HOLY $H!T
- LS1 thermostat inlet or outlet hose?
- Which year harness/PCM preferred?
- Cleaned up the wiring, routing question
- Help... Ls1 identification!
- ls1 rx-7, won't fire, help
- LS1 in 1967-1972 Trucks
- what mount kits can I use for my 68 C10?
- Converting LS-1 headers to LT-1 use
- LS1 pace setter headers in a 67, who has tried it?
- What about the alternator?
- LS1 idiot light
- LS1 swap - Chevy G20 van
- Jaguars Anyone?
- Ok new problem
- 5.3 going in Jeep
- stock ls1 exhaust doesnt line up.
- I think I want to cry...
- its done, completed, finished, finito....
- check out my newest girl
- To swap cams or not to swap cams....
- Some pics I took tonight..
- LS1 in a 61 Vette...Ever been done?
- Advice on project car
- Just exactly HOW MUCH of my 4.8 could be used on a ls1?
- LS1 VDO oil sending unit.
- Into to the hybrid forum
- does anyone have a pic of ls1 modified for headers?
- PCM Mounting
- Tremec M10 question
- LS1 instalation price???
- 69 Camaro LS1 Motormounts
- The perfect camaro for the Beach!
- Anyone have the harness pinouts and etc for the 99+ GM truck motors?
- question aboot the porsche hybrids
- Power Steering Delete
- LS1 Swap FAQs
- Admin, we need some stickys!!!!
- What year is my motor?
- ls1 into 90 c4 vette?
- Grand Prix to LS1
- wheels up! photos & videos from the track
- AFFORDABLE custom fuel tanks?
- LS1 powered RX7 convertible on Ebay
- Dimensional differences between LSx oil pans?
- 4l60E and converter
- conversions?
- painless first gen question
- stcok k member with ls1 motor???
- '98-02 F-body LS1 fan/shroud dimensions?
- whats shakin fellas - 78 le malibu ls1 conversion
- voltage range on ls1 oil pressure sensor
- s10 what tranny?
- Finaly the swap has STARTED
- 93 silverado engine swap?
- 3rd gen LS1 air cleaner
- fan and a/c hookup questions, Speartech harness
- 66 Nova LS2/T56 project
- LS1 in 86 LX Coupe
- Ls1 S10?
- HPTuner question
- 6.0L Swap Cost Help
- '03+ throttle
- 55 chevy LS1 transplant
- Tb Question
- Project "LSZ"
- Attn Renegade: ever considered a G50 for your LS1 swap kit?
- has anyone tried the LS1 HVAC box in a 67?
- 3rd gen Throttle cable
- From start to finish...what's a good gameplan?
- Paging John at speartech!
- 1986 RX7 -> LS1/4L60e swap *Big Pics*
- straight water necks
- Carbed LS2?
- HPTuner
- Some wiring questions to throw out there...
- How do you make an LT1 IROC-Z??
- 68 C10
- What year do I have?
- 2005 Chevy Silverado
- clutch disengagement problem....
- 10.9@124 ls1 rx7
- looking at doing ls1 in 64 nova need more info.
- what are yall doing for fuel tanks/pumps?
- who has modified their own ls1 harness?
- Front Springs
- LQ4 6.0L swap into my 67 chevy pickup, pics at link inside
- Just picked up a nice 92 Fox Coupe
- belt size when no PS or AC
- 3rd gen LS1 guys... what front springs you running?
- LS1 into a cutlass supreme?
- 5.3 Vortec swap in 98 S10... with a twist
- 1997-1998 Corvette Fuel Rail and Regulator Part Numbers
- how to wire ignition early GM ignition switch
- Look what just came back from the paint shop!
- Please don't laugh
- Rear 4 Link Clip for unibodys?
- Twin turbo LS6 in a sandrail
- TRANS DAPT motor mounts SUCK
- How hard to mate a T56 to an SR20DET or RB25DETT ??
- Whats the best route?? Need info please!!
- trying t56 trans w/ 99 tacoma 4x4
- LS1 swap in a 3rd gen- AC line question
- fueling help please
- Im F*&^%D, look inside Texas people.
- LS1 in a thirdgen with a twist
- Can I use a 700r4 with 3rd LS1 swap?
- Viper conversion question
- 87 regal grand national clone ls1 swap
- 98 LS1 into 94 Chevy pickup
- how to wire up alternator
- What fuel tank to use in rear of 64 chevy pickup
- Looking to do a Jag XJ6 > 5.3/4L60e swap...
- Engine Question
- LSx to Replace SBC - General Questions
- Need Feedback on Conversion
- Want to Convert to LS1 Engine
- For those of you running 01-02 LS1s - question -
- Is there a smaller coil available for an LS1?
- 240z with ford 9" rearend for sale
- 5.3/4L60E in a 1983 coupe deville (RWD)
- If you have done a LS1 into Fox body stang.. come in
- Swap questions
- Needed - K&N FIPK AIR pump filter
- 98 V6 Camaro to heavily modded LS1
- Extreme gauge conversions?
- 67 camaro/LS1. where did you mount your computers? PICS??
- 6.0l and 4l80e are in the Chevelle
- Who's gonna be the first??
- Starter problem
- Ls1 into 1992 S10
- mid mounted ls1 with t56 transaxle
- Its alive!
- FINALY LS1 3rd GEN HEADERS!!!
- 72' Chevelle with 5.3 questions
- LS1 fuel pressure...YIKES!!
- searching for a non-ls1 hybrid...
- Who here is buying a Solstice/Sky and putting an LS1/LS2 in?
- A/C Compressor wiring
- Just bought a 99 Z28, what should i keep?
- I screwed up, forgot temp sensor
- 1972 monte carlo swap
- LS1 Karmann Ghia
- 2nd gen camaro pcm mounting ideas
- ls1 rx7ers here...
- Thinking Of LS1 into a notchback mustang?
- air intake question-'67 el camino ls1m6
- Brake Servo connection to LS
- 1991 Oldsmobile Cutlass Supreme
- 91 swap Q's
- super lightweight sleeper?
- Exhaust question!
- LT1 to LS1 conversion
- Need some info..
- MIL bulb or LED??
- T56 into a non LS1 1st gen Camaro??
- LS1 3rd gens
- LS1/LT1 into A 93-97 Firebird
- can a 2002 pcm handle lighting a bulb instead of an led?
- 8.1 in a second gen Camaro???
- Just A Heads Up
- '65 Chevy II
- mechanical speedo on T56
- 2nd gen headers
- 1957 Chevy
- Anyone using VDO speed sensor?
- LS1 Transplant won't start
- can this work? 1990 Eclipse GS
- Fuel Pump Help!!
