- can a 2002 pcm handle lighting a bulb instead of an led?
- 8.1 in a second gen Camaro???
- Just A Heads Up
- '65 Chevy II
- mechanical speedo on T56
- 2nd gen headers
- 1957 Chevy
- Anyone using VDO speed sensor?
- LS1 Transplant won't start
- can this work? 1990 Eclipse GS
- Fuel Pump Help!!
- Mercesdes with V8?
- LS1 in 77 Corvette - Help with questions
- 93 fullsize chevy 1500 ls1 conversion need headers
- Fuel Delivery Questions
- MAF's interchangable for my 6.0?
- block hugger/street rod headers pics?
- shortest water pump- Meziere- LS2?
- ls1 RX7 11.4@121 cam only
- Got one!
- PCM Connector Pins
- ditch the electronic throttle?
- Gauge ???????s
- Is there a better way out?
- Las Vegas weekend for the "project"
- Thinking of an turbocharged LS1 Mustang Notchback
- LS1 spotters guide
- spy pics
- nice ls1 s10
- Is it possible to make a 96 LS1 Lumina?
- plug and play harness
- Its Alive!!!!
- 240z Lt1/t56
- Options on Fuel System -- Return Style vs. Non Return
- Anybody need an electronic throttle?
- SpearTech TELE#
- edelbrock ls1 carb kit question ???
- 2nd gen T/A
- LS1 into 02 v6 firebird
- how difficult to swap ls1 into bmw z3?
- Who makes converter for 4 cyl to 8 cyl tach signal conversion?
- Anyone know a company that can make custom lines/hoses?
- LS1 with LT1 T56 and clutch, possible?
- Who cna do a plug and play wiring harness? LS1 into 97 V8 Camaro
- HP and TQ numbers
- My Baby
- I need some actual f****** torque specs
- I did IT!
- ls1 in a bonneville ssei
- ls1 in a Prelude?
- cruise control...
- LS1/T56 into '64 Chevy C-10
- Using C5 Vette suspension. How do I get all the factory pickups to retain geometry.
- 355 in rx7 - headers?
- PCM question
- 4L60E Camaro Trany VS Truck
- LS1 into 1993 4cyl Camry
- LS1 in 240sx..help
- Block hugger headers
- mustang guys help
- third gen upgrade to a fourth gen
- Which gas tank was it that swaps into a Chevelle?
- pinion angle
- Ls1 in to LT1 body
- 355ci Help.
- For Sale??????
- LS1 86' Monte..would u do EFI or carb ?
- Thinking about the M6 swap I am going to be doing.. Questions..
- Finally....IT'S ALIVE!!!
- cooling system
- turbo ls1 in an ultima
- LS1 in a RX7
- 1st gen ls1/t56 conversion
- I've got an idea in my head.
- Some swap related parts for sale
- Camaro posi in S10 truck rear ?
- Ok, VERY wierd problem...need help
- second gen headers
- Might be selling/parting out my LS1 powered Regal
- Motor mounts in 95 chevy 4WD pickup
- driveshaft swop 3rd gen
- Wiring questions, just real simple.
- MSD Shift light hook up
- 2wd to 4wd
- Anyone have the part # for the S-10 PCM mount?
- If I convert my 68 Camaro Vert to
- s&p motor plates
- 2005 6.0L in iroc-z
- Any one ever Try 4th gen camaro headers on A first gen swap??
- ls1 3rd gen headers
- Turbo LS6 Power into a 1992 AWD Typhoon ***Pics 56k beware***
- Interior Wiring Diagram
- bell housing???
- Anyone been able to use the Electronic T.B.?
- LS1 in a 63 impala
- Yes, its a talon with an ls1.
- LS1 vs. LT1 conversions
- Need part # for EGR plug
- E30 M3 LS1/ls6 emissions...?
- what to do 1st? Computer or heads,cam,etc
- Bmw M3 / 02 LS1 T56
- ls1 ecu on caddy motor
- Please tell me if I am crazy
- vortec to ls1 manifold?
- 02 camaro brakes on 69 camaro
- Fuel return info
- carbed ls1/new model s10
- Cheapo air filter to connect to MAF
- New best of 11.73, but.....
- LS1 mini starter motor, same as SBC?
- New Style LS1 and Gen three mount
- 3rd Gen Ls1 Tubular K-member and Spohn Tubular A-Arms
- Quick Change Rear's...?
- Need Opinion LS1 BMW 5/7 series
- LS1 in a Miata???
- steering column wiring question
- LS1 in a 93 Vette
- C5 Torque Tube, who can lengthen one?
- Got myself an LS1!!!
- LS1 conversion via 928 Seen any?
- MERCEDES Benz W114/5 CE/8 ls1 swap
- LS1 into a Lotus?
- 2002 6.0L LQ4 installed & running on Megasquirt! 1967 chevy pickup
- pics of my ls1 240z swap
- Video of LS1 944
- mercon III or synchromesh
- T/B Bypass hose question???????
- New discoveries for LS1 into Mustangs Swaps
- Ls1 and Wayne Due subframe
- Rear Brake Question?
- Help- No spark PUZZLER
- 98 m6 to a4 swap
- Cooling question
- 1968 LS1 Camaro
- how hard and/or realistic is an ls6 in an 88 iroc
- Help! Can I swap a 5.3 into a 4.3 truck?
- 300z Ls1
- LS1 with a carb setup
- Anti-Rice
- oil cooler line plug
- ls1 c4 corvette conversion, some questions
- Vortec 6.0 to 87 Monte LS swap
- 2100lb roadster built for under 20k?
- LS-1 Swap Parts Needed.
- Fuel Regulator on return line of 5.3 Gen III?
- removing excess wiring
- lt1 to ls1 swap
- questions about 98S-10 to a 5.3L??
- Which should I go for LS1 or LS6
- Slowly but surely
- Might be doing LS1 in thirdgen conversion, any tips or warnings?
- 96 Tahoe to LS1 conversion questions
- 6.0 motor swap
- Are these conversion motor mount plates similar to the S&P plates?
- ls1 conversion kit for 67 gto $530 ??
- LS-1 Porsche 944 Racecar - Fired up and running
- Oil level sensor and PCM connection?
- Fox Stang LS motor guys...how much room to hood, and what accesories?
- 98 Ls1 Pcu
- Best spot on engine to check for angle?
- Old Flywheel on 5.3
- Can any 4L80e go with a 6.0?
- Swapping LS1 into V6 Camaro
- What to do with LS2 throttle body?
- 6.0 conversion in 95 Caprice,,=UNDER WAY!!
- LS1 AC Question!!!
- notched oil pan for 2nd gens
- truck headers on s-10?
- storage crate for motor
- 2001 camaro power rack in 69 camaro
- Low Oil Level Sensor
- 87 firebird gta f/s
- Gto Dash Wiring Help!
- 68 birdls1 for sale
- clint
- So it begins...fox conversion
- GEN III swap into early S10/Blazer
- exhaust manifold help
- 70 El Camino...Lt1 or Ls1
- header help for ls1 in 69 camaro
- Trailblazer straight 6..
- 95 Mustang + Gen III (6.0 fox body)
- hehe.. GREAT use of LS1!
- Need a little 98 ECU Help/NO SPARK
- need help engine want stay running, will pay for help
- 5.3 to 98 rcsb
- Sweet S-10 conversion on Ebay....
- Needed HELP hardtop to t-top conversion
- couple of swap questions
- LS1 Engine Running Poorly
- 8.8" in Nova
- fuel/mounting questions for 1st gen camaro
- 69 camaro ls1 harness and computer
- LS1/Vortec radiator hoses
- Rim ideas for my 73 Camaro LS1
- Anyone make a kmember for 66 gto-ls1
- 281 F-Body
- few questions on astro vans
- crate zO6 Motor in 94-95 Camaro or T/A?
- fuel pump control
- PCM mounting
- Hurst Pistol Grip Quarter Stick will it work with a 4l80e?
- Questions on Conversion
- looking for those LS1 grandsport pics
- 93 Rx7 sick of Rotaries
- GMPP Trans controller?
- 3rd gen LS1 computer ?
- LS2 Third Gen Project has begun!
- abs?
- automatic shifters
- fuel relay not getting power so......
- Need help on purchase of LS1 engine
- 5.3L/t56 in a 98 camaro
- help identify LS1
- Options with hydraulic clutch?
- Keeping my baby cool
- ls1/t56 first gen swap.....
- Third gen PA tubular k-member and MACs
- Has anyone used these LS1 to AN fuel line adapters?
- Can you use LT1 hydraulics on LS1 six gear
- 76 LS1\M6 in May HP Pontiac
- someone who's been there
- Question on LS1 swap.(Fuel System)
- gen 1 sbc swap pictures?
- FD RX7 w/ 4l60e?
- LS1 header measurement
- I`m looking for a complete LS1
- ls1 swap
- Corvette Gas Tank dimensions
- Third Gen LS1 conversion motor mounts for sale.
- Wasn't feeling good today.. Sooo
- heated seat conversion
- my exhaust sucks, please give me input
- 1st. gen to 4th gen brakes
- Estimated cost of Fox swap?
- Cruise Control Wiring Questions
- inline pump question
- Removing Tranny Dowel Pins how to?
- Buying a ls1! what to look for
- tunnel clearance on a ls1/68 camaro conversion
- Fuel system conversion!
- 5.3 LS1 in a third gen
- 2nd gen fbody ls1
- WTB 2001+ PCM or trade for my 2000 PCM
- Data Link connection location
- Chevy 2 headers
- Headers for 2nd Gen? Anyone?
- Here comes another Third Gen LS1 car...
- Good price for a ls1
- vette gauges
