View Full Version : Conversions & Hybrids
  1. Announcing a "newish" LS-Swap and Retrofit publication, finally!!!
  2. Ls1 Blowing fuses
  3. Any 1 use Jiffy-tite fittings?
  4. LS motor in 53 Chevy 2 door.
  5. Not having much luck finding a tuner.
  6. Fuse Block Pinout
  7. LQ4/T56 into 05 Subaru Legacy
  8. 1947 Chevy 3100 5.3/4L80E
  9. Chevelle is getting a monster!!!
  10. 78 trans am motor swap questions?
  11. Project Volv8
  12. how about these shorty headers for fox swap
  13. what radiator did you guys use in your fox conversion?
  14. 5.3+T5=91 Camaro?
  15. 6.0 flywheel
  16. Fox LS-swap k-member options...
  17. 89 fox gt semi built lq4 swap!
  18. Project low budget
  19. EFI 383 LS1 powered Liberator jet boat - IT LIVES!
  20. Wolfe Race Craft pre-notched 10 point cage 1991 Mustang install and review
  21. Ls into a 92 burban
  22. Fuel question
  23. Anyone done a ls swap into a GTA?
  24. Need 97-04 Corvette wiring diagram
  25. G-body LS swap and a/c: my solution
  26. LSX Jet Boat..
  27. Trouble getting stock tach to read correctly
  28. o2 senser adapting ?s flat black,white squared.
  29. Can you run a FORd C4 with a LSx.....if so how?
  30. 2003 S10 L33 5.3 Swap
  31. 94 z
  32. fast xim or msd 6010??
  33. LS swap into '78 Power Wagon
  34. Wiring Help! Coil and rear defogger
  35. LS Swap into '78 Power Wagon
  36. Good deal on a lq9?
  37. no water cirrculation?
  38. Lq4 fox body engine mount question???
  39. Installing autometer gauges into foxbody
  40. 85 mustang coupe ls1 t56 swap
  41. Kooks vs Dynatech for mustang
  42. LQ4 A/C Compressor Fitment Question
  43. what does mlp switch actually control
  44. 1968 Firebird 400 - H/C LS1 swap
  45. LSx prep; electric fans
  46. 69 opel GT
  47. is mlp switch required ?
  48. 02 S10, Heads/Cam/Stalled 5.3 /4L60e
  49. '85 C10 LS radiator HELP!!
  50. 64 impala LS1 power steering help
  51. engine decision help
  52. 2000 Sonoma 5.3/t56 swap
  53. K member for 95M6 going LQ4
  54. Stock K member in Foxbody
  55. Opinions Wanted - what year 4L60e / 4L65e
  56. transmission help
  57. C5 EXHAUST on lSX CUTLASS
  58. V-Belt Crank Pully
  59. New project, need some ideas for 4.8 ls.
  60. Niiiice..... "7" with an LS!!!
  61. what year 4L60 / 4L65 ?
  62. Please Help Me With My WS6 LS1 To 69 Firebird Swap
  63. E38 ECM Brake Switch Wiring
  64. A.c. Wiring help
  65. Ls front assessories not in line?
  66. looking for info on installing LS in 71-75 GM Body
  67. which clutch disc
  68. swapping a 06 4.8l to a 6.0L what is interchangeable?
  69. Alternator wiring again!
  70. HP tuners question, VATS and Rear O2 sensors
  71. Any information on this car? 79 Malibu
  72. I need a MAF for my 6.0L - which one?
  73. Holley cast iron exhaust
  74. Y-body or F-body belt spacing? One any better than the other?
  75. Seriously thinking bout doing a twin midmount setup on my s10
  76. Dropping in an LS1 in a mustang
  77. LS motor in a boat?
  78. 5.3 to t56 tranny clutch and flywheel ?'s
  79. Confused on drive by wire
  80. 65-70 impala swap $$$
  81. any success using speedhut tach w/signal from ecm w/o using a resister?
  82. 2001 4.8 to 2006 6.0 Swap
  83. lq4 trouble codes
  84. What's the best handling car to implant LS1/T56?
  85. Can ecu control a spare wire as a signal wire to a relay?
  86. Can PCM be setup to control TH400 kickdown?
  87. 2003 express 5.3 wiring diagram
  88. any one made GEN II headers fit a GEN III/IV???
  89. 4L60E Trans wiring
  90. Lq9 in tj?
  91. Opinions wanted on lsx swap canidates
  92. What year 5.3 do i have?
  93. Ls1 brake swap help
  94. IS300 LSx Build / Initial Startup
  95. 99' Truck PCM which pin is TOW/HAUL?
  96. Trans Question
  97. PCV routing question
  98. 1972 Nova LQ4
  99. ls engine time/A-body
  100. Post pics, dreams, & ideas!
  101. Next build 2001 BMW 325Ci 4.8 or 6.0?
  102. New Jaguar LSx Conversion Gallery
  103. Ultimate Hybrid.
  104. 85 mustang ls1 swap
  105. What Throttle Cable For Fox Body?
  106. LQ4 low RPM, high load misfire and turn off rattle
  107. LS1 T56 Slave on TKO 600
  108. LS swap info, missing parts
  109. will my ls2 bolt up in my 95 z28
  110. 5.3 in 1993 T/A
  111. 94 Cobra swap to 5.3ls with th350
  112. Looking to trade CNC work for LSX wiring help
  113. ls1 ws6 too ls1 camaro z28 engine swap help/info
  114. no gauges!!!
  115. turbo s10 gen 4 5.3 build questions (read carefully)
  116. Who's solved the 158 MPH VSS input to E38 ECU for T56 swaps?
  117. cts-v
  118. Ctv-S
  119. New Website: '37 Chevy build
  120. chevelle NW 92mm throttle body air intake
  121. Foxbody Fuel system using stock tank and lines?
  122. Another accessory drive question
  123. Has anyone made/modified their own harness?
  124. Where to find OEM electrical pigtails/connectors
  125. Wiring Harness Plug Question
  126. power steering question
  127. Truck is giving me hell
  128. New LS1 compressor with G-body/Regal Evap/Dryer/system w.modified lines?
  129. Ls swap ac help
  130. Mustang Swap Fuel System
  131. 66 mustang proje ls1/4l60e
  132. 4L60-65E conversion to 4L80-85E using T42 TCM
  133. Help! Hydraulic Clutch Options
  134. LS1/4L60E into a Factory Five 33 Hot Rod -Need Help
  135. Help wiring problem on ls swap
  136. Anybody Need a Build Art Carr Overdrive Trans For Their Conversion? Link Inside!
  137. ANother third gen lsx swap
  138. p0740 after m6>a4 swap
  139. Stand alone wiring harness
  140. Help with finding wiring diagrams
  141. Lsxfox track times
  142. Tsquared 69 Camaro Build
  143. What does VATS do?
  144. Mount question
  145. Temp sender re-thread
  146. 67 Camaro using 4th gen radiator?
  147. Help!
  148. LS1/LS6 Injector EV1 connectors
  149. CBM LS7 Porsche 911 Swap + LSX TV
  150. Fuel line help
  151. 91 5speed trans on Ls engine
  152. Calling T56 swappers w/A-bodies!
  153. New A/c Bracket option
  154. lm7 startup issue
  155. 5.3l into 95 z28
  156. 71 Impala Twin Turbo LSX 440ci
  157. Fuel pressure to high?
  158. Help lt1 to ls1 alt wiring!!!!!!!
  159. Wild ride in my LS Daytona (autocross)
  160. v8 in s10 questions
  161. LS1 F-body headers
  162. fox headers?
  163. Harness help??!!!!
  164. LSX Jeep opinions?
  165. Exhaust for LS engines?
  166. 2000 Mustang Turbo 5.3L Build
  167. LM4 dip stick options?
  168. I must be missing something.
  169. Colorado lsx
  170. lq4 in 68 firebird 400
  171. '70 C10 truck engine initial startup
  172. DBW pedal/TB question.
  173. 1964 impala lq4/4l65e conversion
  174. cai pipe size
  175. MY foxbody..(warning...ford content)
  176. Electrical gauge options
  177. Help....blowing coolant out of radiator
  178. Regal 5.3 to ls3 swap?
  179. 4.6 motor mounts on 5.0 K-member?
  180. So why did you put and LSX in your mustang?
  181. Can anyone make power steering line?
  182. 2006 L59 won't pull past 4000 rpm
  183. Exhaust for 65 chevelle
  184. DBW pedal not responding to tb
  185. AZ Smog and emmisions Questions
  186. My LSX foxbody turbo hotside
  187. Jaguar LSXJ6
  188. Quick fuel rail question (LS1)
  189. stock tbi lines
  190. 92 chevy truck 4wd
  191. Losing MPH input @ ECM
  192. stock truck headers in foxbody?
  193. Fox body Header problem...Help
  194. Lets say I wanted AC
  195. Mustang LSX Swap Power Brakes and Steering Question
  196. DBW issues
  197. spectre swap intake on 67 camaro
  198. Alternator locations and options (Foxbody turbo 4.8)
  199. In tank fuel pump.....
  200. 9th Gen Square Body... To swap or not to swap..
  201. LS1 Daytona Coupe finally on the dyno
  202. Adding aftermarket fuse blocks to modded LS harness
  203. just another ls FD
  204. fuel filter with bracket
  205. Converting LS2 DBW to DriveByCable???
  206. Motor Mount HELP!!
  207. anybody not use LY6 oil pressure sensor connector on your harness?
  208. injection issues
  209. rear mounted 3400 engine in a 36 chevy low cab
  210. Couple pictures of my nissan 240sx 5.3 turbo build
  211. Need help on decision making??
  212. My dream conversion/build
  213. ford t-5 behind a lsx
  214. '94 Chevy S10 Blazer LSX swap
  215. help: positive crankcase pressure, oil problem
  216. Damn 98 guages
  217. cutting primary tubes off header flange
  218. 5.3 question
  219. Fuel pressure on the return side?
  220. Engine cover assistance needed
  221. Does anybody make a set of 2" Stainless Longtubes for a Foxbody Mustang Swap
  222. pcv system w/ ls6 valley
  223. Registration Problems in Missouri
  224. How to connect T56 hydraulic clutch lines to MC and reservoir ?
  225. Knock Sensor Location?
  226. Need some help on my '95 TA
  227. Someone to tune?
  228. ignition wiring ???
  229. Hot August Nights
  230. what gauge wire for alternator?
  231. arp vs katech rod bolts
  232. Corvette filter/regulator 3/8 outlet fitting
  233. Lsx bg turbo kit with aje k member in fox mustang
  234. Gauge options?
  235. Initial ECM power up on LY6 shows P2138 DBW pedal code. Thoughts?
  236. no tach after lsx swap dakota vhx 67 camaro
  237. 95 Sonoma - LQ4, 4L80e, 76mm Turbo
  238. Trans crossmember?
  239. 5.3 ps pump pully on ls1 fbody ps pump???!
  240. Does anyone know how to get a hold of the guy from mc-machine?
  241. starter turns over slow
  242. LQ4 timing cover w/ Corvette Balancer
  243. Best price on dynatech mustang swap headers?
  244. g body power steering lines
  245. 1980 c10 6.0 swap
  246. G-body mounts ???
  247. 2005 lq9 s10 swap AC serial data/request?
  248. LS1 1992 TYPHOON project
  249. Is my racetronix walbro fuel pump DOA?
  250. LS1 a/c compressor mount?
