- Nissan 350z LS1 Swap!
- Need some help
- Upr k member and flaming river steering shaft no work on my fox
- ls1 fuelrail fuel hoes fitting hitting coilpack
- 6.0 into 94 Mustang GT started!!!
- How did you wire your hot in run & start relays?
- waterpump,alt,crank.....
- What stall converter
- What Are You Doing For An SES Light?
- My 79 Z28 project
- 94 v6 firebird lsx swap questions
- Corvette torque tube modification
- England Green Cams
- Jeep TJ on Tons/40's- LS Conversion
- had a engine fire today while driving down the road :/ i'm going to need some help
- Turbo lsx fox body questions
- Installing 2008 trailblazer ls2 in 68 camaro
- Help!!How do you make your own 3rd Gen Nova mount/oil pan conversion
- has anyone seen complete ls1 + BMW Getrag hybryd
- 70 camaro ls swap questions.
- Overheating in my daily driver.
- I just started my LS for the first time have no coolant fans.
- How are you mounting all your relays on the engine harness?
- Put the LS1 in the wrangler?
- 6l80e ls3+1964 caddy
- i have been driving around with no mech/digital water tempature sensor
- Lsxfox torque converter lockup questions
- 65 Mustang- 404ci lsx, 8.8, tubbed and caged UPDATES 12/1
- Header building tech help for LS1 going in Jeepster
- anyone done a chevelle, LS, and maggie supercharger
- New guy- LY5 + 4l60e ?'s and power upgrades.
- 71 El Camino 6.0/4L60E
- edelbrock ls engine controller rev limiter question
- My swap is running (video)
- Lq4 swap 95 mustang
- LS series sender adapters
- Noob and Proud 11 Hyundai Genesis Coupe
- LQ4/ 4L60E into 77 Jeep Cherokee Chief
- LS hot rods
- Unknown GM help
- I'm looking for the best books...
- My project for the GF
- Turbo Conversion manifold help
- 2010 camaro ss exaust manifolds
- How can I find out what parts mix and match??
- Steer me in a direction here
- How much of a drop can i get on a '00 ws6 w/ 19" rims
- 98 v6 fbody to LS
- carbd ls to efi conversion
- BMW Swap - Sticking Clutch Pedal
- HELP 3rd gen conversion to 4th gen (everything!)
- Mustang LSX Swap K-Member Question
- any other lsx swapped imports in here?
- OEM style nylon style fuel lines?
- ls1 to ls3
- A -Body T56 MS plate with tick MS
- 2nd P/S pump making noise???
- 69 Camaro: Mean geen build. LS3/L92's?
- Using LS1 alternator with LS2 E40 PCM
- Never use regular fuel line on a LSx build...
- Oil in intake, SMOKIN!!
- RS Coils and Injectors not firing
- close to starting my Nova LS swap need opinions
- jasenz's 5.3 turbo gem
- Clutch master cylinder size
- Need a procedure to check TPS and APS.
- Those with 4th gen Cluster swaps.
- 95 mustang 5.3/60e swap trouble codes
- Gbody mounts?
- mild AT trans recommendations?
- 01 Harness and computer to a 99 car. Now I have low voltage any ideas
- new guy, new swap lq9 into 89 firebird
- Need Help with Cruise Control Add on 2nd Gen Camaro LSx Swap
- IS there pcm UART serial data on my 99 ls1?
- Help with swap
- swap help
- gmc sonoma tc78 lq4
- Mystery trans connector
- 55 belair ls1 will not start need help
- at a loss with my lsx
- A little help ????
- 4.8 in '90 Isuzu trooper
- WS6 power steering cooler?
- 68 c10 5.3
- Question on fuel line size
- lq4 into 94 GT
- Test-N-Tune
- Fuse Block Wiring
- D581 coil wiring...
- SBC Clutch on the LS1?
- g-body conversion kit
- 97 3.8 swap to 97 lt1 need advice
- air conditioning
- L33 Valkyrie, 1800 LBS 310 horse 330 FPT death machine
- Anyone use the Hooker cast iron mani?
- ls6 swap tranny linkage issues
- LM7/th400 1967 Mustang - factory suspension
- A/C & Cruize wiring help needed
- Engine for turbo Mustang swap?
- quick steering wheel question
- 84 Monte ss Ls build
- Jmac's L33/t56 S14 240sx build
- Burned LQ4.. Pretty much all plastic and wires will need to be replaced. Need advise
- Any 1968-1972 Chevelle with Turbo LS and AC??
- 71 Pontiac Lemans
- LS1 swap p0300 error
- Motor mounts for LTx --> LSx conversion?
- Oil Pump Pickup Tube.
- Brake switch mod for 72 Cutlass
- possible 2003 cts swap???? possible?
- compatibility question
- Can a 2002 truck PCM and harness support hi and low speed electric fans?
- water pump
- 05 5.3 with a 04 comp and harness?
- L92 into Rx7
- S-10 Headers?
- To much torque
- 700r4 behind LQ4/LS1
- Need smaller P/S pulley for C6 pump
- PCM programming
- Vacuum source for charcoal canister on LS3 intake?
- 69 Buick GS 415/T56
- Will 07 alt for a 2002 5.3?
- 2010 ls manifolds
- 5.3 fox finally runs!!!!!
- t56 crossmember question
- LS4 + Classic Mini?
- Motor mount problem
- Please help!
- A little tuning help
- Need a little help
- 5.3 swap into 1991 camaro rs help!!
- Racecar 300zx Ls2 *video*
- Project lsx, supercharged ls1 into a 79 vette
- Has anyone looked at or used the SUR&R Nylon Fuel Line Kits?
- 3rd Gen X-Body - Vette FPR location ?
- 1985 c10 shortbed frame off resto mod 5.3/4l60e swap UPDATED post #45
- A little help Please
- Just for Fun, LSX into race airplane. Vid inside :)
- Radiator needs
- 2008 5.3l c2 block question
- Fuel pump relay control lsxfox
- Truck MAF housing busted; options?
- 1970 firebird lq4 t56
- ls2 gto wiring help in 68 camaro.
- 5.3l 64 chevelle just got it running but has issues
- got a few questions L92 related
- 97 gauge problem!
- 2002 Camaro Oil pressure Switch
- Abody accessories for A/C?
- 32 Ford LS1/4L60 - suddenly won't start after running the battery down
- '37 Chevy 4 door/ 5.3 & 4L60E
- oil pan question on 5.3 swap
- Swap 2004 gto into 66 lemans
- Exhaust manifolds or headers
- 98 donor car for 95 swap info
- Vintage Air Wiring Question
- Another video of the LS1 dakota RT swap
- F-body dual fan wiring question - what size fuse, contact ratings, etc?
- 96 z28 lt1 to ls swap
- Autometer Vss/dakota digital/turbo 350 questions
- LS3 5.3L and Transmission from Grand Prix into Bonneville?
- Altered Truck Oil Pan Capacity
- valley tray gasket question
- Coil pack year and application
- vintage air pulley change
- Another electric fan problem...
- Donor Car
- Help with 01 s10 2.2
- LQ4 Turbo Build
- One Master Brake Question ?
- 67 Camaro 5.3
- 6.0 swap into 85 c10
- Accessories??
- Need help: Ls1 in a 94 lt1 trans am
- Trans-Dapt 4575 Motor Mounts Engine Swap Mounts 1.00" G-body question?
- Wiring troubles on ls fox
- Ignition won't turn off after LS1 swap
- slack in throttle cable
- Fuel line quick disconnects to AN
- 240z LS1 Exhaust - new exhaust system
- Are LS3 springs comparable to LS6 springs...
- Intake,throttle body, and pcv routing questions
- 1991 Mustang LX L33/MN12 in the works
- LS6 Cobra test run with video
- Basic 5.3 build for Notch Fox Questions
- 2002 Firebird V6 to V8 K-Member Questions
- 5.3 carb into foxbody help
- What Air Intakes are you running on your LT1 to LS1 swapped Fbody!!
- Help Gear Selector Switch Wiring Questions
- LS1 and Autometer guages
- Lincoln LSx
- World's easiest 5.3 swap--Dodge Dakota
- Need Mark VIII Fan wire diagram
- Lost power to injectors?
- LS2 s10 project
- S10 guys....is there room
- check it out, 96 V6 to L92 build
- Save an LS1...Help me get this thing started!
- Daytona Coupe LS1 conversion
- ? about AJE motor mounts in a mustang
- 1986 Elcamino Project-Pending 2006 GTO LS2-6 speed
- BBK headers?
- Audi RS6 + LS1 retaining AWD (Project Judas)
- '95 240sx LS1 swap, need a no bullshit est.
- Recommend a swap shop!
- '61 Chvy Parkwood Wagon LS1 4L60e 411 gears
- LT1 to LS1, tach reading off
- What A/C line setups are used?
- 1955 Chevy Convertible LSx Rat Rod Project.
- 1996 Formula LT1 to LSx conversion
- 8 pin DBW TB connector
- Need HELP with LT1 to LS1 swap!!!
- how did you guys block off your hydroboost?
- 90 lt1 fuel tank and 65 impala fuel gauge
- 1948 Ford Pickup LS6 4L60ESwap, another question
- pics of f body headers in g body ls swap
- Operation faster than you: 96 TA 5.3 conversion
- crank spacers??
- A body guys: anyone found a way to do over the radiator intake?
- ls2 4l70 swap wont shift & no speed
- LS Willys jeep dyno Video! its finally done.......untill winter
- montie crarlo fuel sender for g-body swap???
- My Swap So Far
- Poll/Cencus Intake
- LS harness swap
- Someone tell me what a Corvette cooling fan PWM module is...
- 57 belair 4 door --> 5.3L/4L60E build thread
- fuel tank sending unit
- 86 L92 Notch
- Automatic 3.8 V6 to Manual LS1 swap
- Third Gen Camaro LQ4 Swap
- 8.1l conversion
- Fuel Vent for Vaporworx tank, what are you using?
- Which 4L80e Trans?
- water temp sensor mech gauge
- 2000 ford mustang gt ls1 swap help
- Reverse lock-out not locking me OUT, When I need it to...
- 5.3 foxbody fuel filter placement
- 5.3 flywheel/starter?
- What kind of numbers?
- LS2/LS3 Build in a 1994 Trans Am...4year project COMPLETE PT2
- 5.7L Swap from a 1999 Chevy Express Van into a 70 Chevelle...?
- vapor lock wix
- VATS bypass circuit frequency measurement
- 2006 'Burban L59 A/C lines...
- lsx wiring harness fuses
- Nova header question
- 97 Kouki 240sx LS1 build/clean daily --Lots of pics--
