View Full Version : Conversions & Swaps
- Procharger on my S13/LS1?? Would it fit?
- So what did it take to swap your LS in to a 73-87? (Chevy/GMC 73-87 specific)
- Equus gauge adapter problem
- 1967 Camaro with Katech Street Attack 427
- Mustang 90 conversion kit question
- GMPP crate eng. control system with GMPP auto trans control system
- Fuel pump parts. Where to buy?
- EGR Block Off & Manual Oil Pressure Fitting for LSX
- 6.0L to th400
- socket size for oil pressure sensor?
- Help me build lq4 turbo 240sx :devil:
- drive by wire question
- Mazda RX7 with LS1/ATI ProCharger D-1SC back at EPP again for more updates
- year one las1 engine mounts
- Derale heat sink
- Edelbrock shortys for mid 90's gmc with 6.0 conversion
- Mast Motorsports L92 HO F-Body with VVT
- ProCharger P-1SC from GTO for sale $1,300.00
- lq4 or lq9
- Is any of this harness of any use ?
- LT1 to LS1 swap...how hard?
- Think this block is cracked? Help
- Getting motor/tranny tomorrow - Check list?
- Will a Camaro a/c compressor fit on a 5.3 with truck brackets
- Corvette filter/regulator
- Datsun 280Z and an LS1
- fuel pump for ls carb/fi
- need radiator for my "A" body/ls
- how to identify a 5.3
- Bad News on the "Badman" Intake from Barry Grant...
- ls1 or lQ9
- First timer for LS engine swap
- Aftermarket Fuel Rail Plumbing
- 02 Camaro LS1 into 98 Nissan 240
- flywheel and clutch question
- Exhaust Type for 94 LSx Conversion
- Help: What's this?
- 73-87 Swap
- 700-R4 to LSx Convertor Questions.
- Which sump is better?
- Chevelle swap
- What fuel pump to use?
- no spark please read
- LS1 Conversion Complete 72 grand Prix
- Whats up with the AC, hope you have the answers
- anyone legthen their factory harness?
- How did you do your crossmember when using s&p plates?
- Need Help On Ls1 Motor Mounts Adapters
- LS Platform w/t56 into a 68 Firebird
- Mustang swaps w/ T56 and T-bird pedals...
- lambo LP640 vs.RX7 LS7
- coolant steam tube with carb intake
- Where to relocate Coils?
- Mustang 4.6 swap to Chevy 5.3
- P/S Pump - Still need help with low pressure line.
- engine ID question
- cheap HID lights?
- Torque Converter choice for the 4L60E tranny
- Most Blockhuggingness headers?
- relocating fbody alternator to upper driverside for free
- 5.3l from 2005-6 to a 71 chevelle
- data link question
- Build a V8 240SX in 24 Hours? (SBC)
- 6.0 and a stock 5 speed
- ls2 into s14(240sx) advice
- 88-98 chevy fullsize headers?
- 3/8 quick disconnect for vette fileter/regulator...
- Anyone done an LS4 import swap?
- Good deal on new LS1
- 70pontiac tempest LSX swap need insight and advice.
- 5.3 oil pan swap for ls1 f body
- 2006 5.3 price
- Pro 5.0 shifter for mustang, in my 240??
- Header to idler arm clearance issues
- 2000 F Body harness/LQ4 into 65 Chevelle.Who do you recommend for harness mods?
- What does your 1st gen LSx swap weigh?
- S10,370,T56,twin GTK550's
- Salvage LQ4???
- ls1 radrambler update
- Acc. Help
- 5.3 into a 50 chevy truck
- my swap is alive!
- Built 427 CID LS7 in an ML 350 !!
- Picking up my 6.0 truck motor and 4l80e
- 98 Ls1 racetronix kit on a v6 to LS1 car
- other options besides 97 corvette fuel rail for 98 v6 to 98 ls
- LS1 Hooker super comp headers and intake. Any interest?
- Fox body swap parts for sale
- iam getting riped off
- Trans Dapt Motor Mounts in a G Body???
- carbed alcohol 5.3?????
- LS1 F body vs vette flywheel/clutch
- 3rdgen 1/4 times?
- 70 nova 5.3 700r4 project thoughts opinions
- Anyone who has swapped a LSX motor in a 70 A Body?
- help me build an ls1 powered s14 240sx!!!!
- Will this fan wiring with 2 relays work?
- t56 with a sbc?
- 4l60E torque converter problem
- 450 hp LQ9
- engine storage
- ignition lights?
- Custom wiring harness
- nissan 300zx swap questions...
- Is this an LS1 computer?
- EFILive, to remove VATS and tune?
- Another fuel line question...
- Apologies in advance. s10 blazer v8 swap
- Question about an LS1 swapped LT1 car *dash question*
- lq4 into a 96-98/99 fullsize 5.7?
- A-body guys, fuel sender alternative
- 2005 GTO LS2 alternator wiring? (pictures included)
- carb size
- colorado ss is almost done !
- LS1 swap into a 3rdgen fbody
- Need air intake help on LS1 swap
- safety neutral switch wiring question
- Need Acc/Wiring Help
- 90 Mustang LX with LS1 carburetor...need help
- LQ9 in 1984 Cutlass Supreme
- I'm always surprised when I browse this forum
- Help!! LS7 first startup procedure??
- LQ4 oil pressure sender, LS1 F-Body harness
- Fuel line questions
- LS6 Drive by Wire
- P/S Pump, Am I missing something??
- Bolt On LS conversion for the 1955-1957 Chevy with the LH8 GM oil pan
- LS1 for sale from 35th SS LE #1989
- what ECM do i have?
- Everything need for ls1 swap??
- 67 lincoln continental
- 67-69 Camaro Firebird LS1 Swap headers
- Alternator Bracket
- want to swap ls1 6spd in 79 camaro
- Help with connector ID
- 240sx 408 build
- Incon Twin Turbo For Sale
- Ignition wire supply???
- Input & opinions on fabricated Chevelle crossmember:
- march sepentine pully system
- LS1 Into 3rd Gen Guidelines and help.
- LSx into thirdgen question.
- My brothers sweet 94 Z28..You guys must check it out
- Carbed LQ4 mated to D&D Viper tranny in 72
- The Poorman's M5, E60 w/LS7 V8
- 3.8 conversion
- 3.8 conversion
- Which headers for a 86' monte/G-body swap
- Can anyone help with LS1 computer values?
- Installing T56 in my 68, pedal/crossmember questions
- TAC Module
- smog legal
- My '86 mustang project .........
- 03 truck 5.3 pinouts? where?
- 5.3 or LS1?
- 99 Cobra - Ls3 conversion help
- Dot 4 fluid in brake MC too?
- Fuel lines -- Steel to plastic ???
- Clutch line Rollpin?
- T56 Swappers: CAGS & Reverse Lockout Delete
- LS? in a 51 Chevy
- LSx retrofit to a Lotus Elise or Exige. Who's gonna be the 1st? Parts needed?
- 99 ls1 into a 98 six cylinder questions
- OBD2 Diagnostic Plug Wiring
- Duramax in an F-Body
- ? for LSx gurus
- 66 chevyII nova ls3 twin turbo
- Sonoma GT 0071
- Nascar Iroc
- ? about a 240sx swap
- Emissions, egr, pcm, harness question
- CTSV flanges
- Lsi Inro Corvtte 1977
- ls1 into a lt1 frame
- LS1 Car Intake Backwards on an LQ9
- Looking for (97-04)C5 Corvette Accessory Drive Parts
- Thinkin about Fox Ls1 swap.. few ?
- tips on a 95 camaro conversion to ls1 motor
- ls2 into a 72 cutlass
- 1979 malibu wagon!!!!!!!!
- 4 Cyl Mustang Ls1 Swap List?
- so ive been searching...6.0 in a 96 forumla
- interior harness???
- LQ4 into S13
- Prices on used LS1 and LS2 motors
- ? about Radiator
- Chevy II guys...Progress on LT's in stock clip
- LQ4/9 truck intakes and HP
- Only 300 HP out of a LQ4?
- attn Walbro 225 owners.
- What would need to be upgraded?
- i think im going to throw my ls1 in the dumpster
- 4.8 to 5.3
- GM LS6 and M6 Build up on T/A
- fuel pump problems
- 96 tacoma -04gto ls1
- GTO oil pan
- New Idea!!! Ls1 In A 92 Toyota P/u
- lt1 to ls1 swap
- Rx-7 Ls1 swap
- have a GTO pan for sale for some of the swap guys
- under hood wiring schematics for the LS1 Silverado
- 04 Zo6 swap into 04 Z71?
- anyone tried the machinehead alternator relocaton kit
- SS wheels on a 2wd S10
- "NEW" LS1 Billet Alt Relow Brk
- Who makes and/or sale wheel hubs??
- LS2/2004R/Gbody
- 1966 GTO L92 / 6L80E / Street Challenge Project
- A ball park et for A 5.3 powered sonoma
- Intake plumbing
- 98 Ls1 6-speed Harness, Computer And 2-step
- V6 to LS1
- What years LS1 are DBW?
- 67/6.0 chevelle
- Iroc Z Camaro
- 96 ss M6 tranny into a 93 A4....????
- Serial data VATS bypass.
- What to do with the radiator?
- Anyone put an LS7 into a F-body yet?
- How many have used an LS4 in their project?
- Need To Delete Vats
- 6.0 Swap in a 240 SX
- 97 camaro 5.3 swap
- Help Needed With a Connector
- Crank flange to bellhousing flange relationship of Gen III/IV
- carb intake
- motor fires only on one side?
- LS1 In 95 Mustang
- lt1 fuel pump with ls1
- 91 lx notch swap project for sale
- New LS 96mm and 101mm throttle bodies
- Air Intake plumbing
- ls1 into chevy2 with corvette suspension
- Demon Carb- throttle cable help?
- No spark on the #2 coil
- A little video action from the other day..
- Shifter options
- 98 V6 to 00 LS1 Swap..Input needed
- ls1 to old school 350
- 72 Gto??
- CARB/Cali Legal LS2/LS7 Swap?
- c10 swap headers f/s
- 4.8 to a ls1
- Engine Mount Question
- Looking to get started
- Help With Rad
- i need a power steering pump!!!!!
- Truck Pan vs F-Body Pan for 2Gen
- 5.3 in a 240sx
