View Full Version : Conversions & Swaps
- Any One Do A Ls! S10?? Or Know Of Any Threads
- Anybody want to trade their ls1/t56 car for a GSXR 600?
- sn95 stang conversion(trans ????s)
- 2006 GTO LS2 into a 66 Nova
- Shifter Cable needed
- Ok, so I read up on the Alternator stuff in FAQ sticky #13, BUT
- Need help wiring up my 98 LS1 in my 1996 Z28. Thanks
- Stock and Conversion Parts for sale!
- LS1 Camaro headers for an A-body swap?
- CSR Tstat housing and heater hoses
- Help ! Looking for a 98 Instrument panel wiring diagram
- a cool conversion video
- S10 swap guys
- t56 in a 79z
- Driveshaft....steel or aluminum?
- need pics of ls1 fuel lines please!!!!!
- It's alive
- 1967 chevelle clearance/engine,trans -angle questions
- what do you need to hook up stock f-bod gauges?
- Street and Performance Harness
- What do you Think About a LS1 Mustang?
- Norris Motorsports Website Is Up (Finally) & SEMA
- Coolant Expansion Tank Hose Routing.
- Serpentine Belt Dust???
- 1500
- GTO oil pan -- Help -- is there an oil-pressure relief valve in it
- LS1 in a early stang?
- LS1& T-56 into a 1969 impala wagon.
- fuel line
- Carbed swap guys.....Alt question
- Nissan 240SX S13.5
- Look what i just found
- 4.8l Swap To Ls2 Crate Engine In A 07 Silverado
- Real Time GPS tracking for stolen cars
- The more I research making power w/ a Ford the more I want an LSX.
- Lowe radiator hose
- c230 plug????
- In need of 1996 and 1998 F-Body PCM Pinouts!
- Transplant shop in Gardena, CA?
- Coolant air bleed in rear radiator pickup?
- 1966 Chevelle LSx?
- Need help with my LS1 in 1996 Z28!
- LSx in 86 Monte Carlo
- LS14 swap?
- LS7 throwing belts
- Just using WP and Alt how to route belt?
- Truck 6.0 Into LT1 Car....Can I use ECM?
- 6.0 & 4l80e conversion
- Twin turbo headers...goin cheap
- keep or kick the EVAP on a returless fuel system
- Solved my exhaust manifold problem
- ls1 mounts for 2nd gen f-body
- Killer 71 c-10 STOLEN!!!
- First Gen Camero LS1 swap headers
- LS1 in LX Mustang 89 but need some help................
- What is the purpose for a fuel sump?
- Anyone need a conversion harness
- What car to use... what do you think?
- A/C pump relocation? 5.3 LM7 into a Jeep.
- wiring harness
- c4 corvette swap
- Truck oil pan
- LS1 Pricing question.
- LS-s10 drum vs. disc brake upgrade.
- my ls1 engine progress
- Lt1 into 87 Supra
- Hinson LSX s13 240 pics?
- 65 Riviera
- Part # for top covers-98 LS1 Camaro
- 3rd Gen Question
- some parts i have for sale...
- C6 Z06 brakes are on 2nd gen
- '95 Extended Cab S10/2004 GTO LS1
- clutch connector
- Air Conditioner Compressor question
- LS1+fox w/ QA1 k-member?
- 4l60e with a SBC
- Questions about JY pull-out vs. stroker short-block (LQx)
- Putting LS2 in 2000 Firebird
- Mkiv
- will wrapping intake pipe w/ header wrap keep it cool?
- Fuel Injection on a 5.3
- LS3 ECU's & wire harness reprogamable for conversions?
- what do you think it will run with a 300 shot!
- LS1 Pullout Question
- Poly Motor Mounts with LS1 swap?
- LS7/LS1 Factory5 Kit car
- Where to get trashed LS1 for fabricating?
- questions about gauges, LT1 to LS1
- LS1 kit car project pics
- New school muscle old school tech
- 89 Firebird with a carb'd LS1
- LS1 in a 72 Grand Prix Questions
- 68-82 Corvette conversion
- Valve covers with coils inside
- Carb Conversion MAP sensor
- Hot Rod Rule Change
- I'm confused about oil pan, fuel and steering clearence with certain mounts - 68 bird
- LQ9 in a 1957 Bel Air
- Radiator & Air Bleed question
- ls1 4l60e swap in 76 c3 stingray shifter linkage help ?
- Anyone package ECM flash with new cam?
- Odd pcm behavior in conversion
- Corvette LS1 mounting bracket\ear
- FAST EFI setup for sale (perfect for an ls1 swap)
- cts pan in an "A" body
- 2003 ZR2 issues
- First start video.
- Need help with alternator wires
- Newb ?
- Swaping an Ls1 into a 94 5spd. rs camaro???Anyone know how???
- LS-1 in a 1977 vette
- did your hooker LS1 headers come with O2 bungs?
- Some pics and blower questions.
- No Spark please help!!!
- Top covers not working out.
- Few pics of my 240sx
- Conversion twin turbo setup....
- 5.3L with a 4l60E S10 V8 swap.
- sticking a 02 vortec 6.0 in a 84 bagged and body dropped 4 door dually
- Another "Painting the Fuel Rail Covers" Question
- conversion help
- where to get a balancer installer
- injector question motor ID
- What about ls1 swapped skyline r32 ??
- LQ9 to TH400
- Where can I find a good deal on a 6.0L
- help with a plug
- 1968 Firebird LS1/BOP TH400 will it work?
- 0-60mph=7.67sec. should i be happy? jeep wrangler conversion
- ls1 headers for g-body
- hooker headers in an "A" body(chevelle)
- mustang ls conv. headers and exhaust
- Tri-five Fuel Milage with LSx motor?
- LS1 swap in suburban???anyone done it?
- LS1 in place of a LT1. In a Jeep. kinda.
- BRP Kit + LQ4/4L60E + '72 A-Body = ?
- LS1 Oil Pan on LQ9
- Doing Some Research!!!!!
- LS1 race car wiring with batt/alt disconnect
- LS1+third gen
- 98 alt. wiring
- Exhaust Manifold for 5.3 in a 1947 Chevy car
- How 2 Mustang LS1 Conversion?
- exhaust manifold flange help
- man, i am about to give up
- effort to get 1st gen LS1 headers into 2nd gen?
- LS1 into a Reg. Cab Silverado?
- Anyone done a Mercedes 90's SL LS1 swap?
- Anyone ever used Entropy radiators?
- 2003 5.3 Yukon Wiring
- need help to emissions obd II
- who makes the least expensive t56 master moutn bracket?
- Aftermarket Throttle Cable?
- how did you clean your ls1 before the swap?
- where is the cheapest place to get a start up tune? 99 ls1
- 1st gen f-body quarter or eight mile times?
- Am I crazy to sell my F-body and convert a G-body?
- "massaging" the trans tunnel on a fox.
- Doing LS1 swap in Washington State -- what are State Requirements
- 66 Nova 6.0l Alt Wiring Problem
- 6.0L swap???????
- Looking for 2007 ecm pinout with DOD and knowledge of DOD
- Vortec Lq9 With Low Profile Intake (???)
- Stock 5.3 manifold fit...
- 04 GTO Throttle control module-Bypass?
- 98+ LS1 S10 Guys - Pics?
- Exhaust for LS1 68 cutlass GM A body
- ls1 into WRX...... can it be done???
- Multi-swap & s10 Front suspension rebuild
- PCM issue w/convertion
- Swap a 6.2L into a 2007 4.8L Silverado
- Megasquirting your LS engine??
- What would my setup run if i transplanted it into a FD rx7?
- 69 camaro disc brake conversion HELP!?!
- 1997 240sx with LS1
- Need a FWD manual transmission for an LSx
- Running on a stand...
- s&p headers in an a body w/4l80e
- over heating LS1 in 35 chevy sedan
- Help!!!
- LSx into a '99 BMW 540 E39
- Which Sensors Do I need?
- VSS to Speedo????
- Any RX7 1st gen conversions?
- 1964 Chevy II Exhaust Manifolds or Headers
- 96+ S10 LS1 guys - passing the OBD2 Inspections?
- Going Carb'd on my Third Gen LS1
- Newbie here.. please help with wiring question
- How many think we should have a "Conversion Parts Only" for sale area???
- Guages...
- 911 LS1 convesion
- factory gauges and ls2
- 5.3L into a 1995 Silverado
- which is the VSS connector?
- Gto Ls1 Oil Pan Gasket Part Number?
- lt1 to ls1 guys... i have a part you really want :)
- t-5 transmission
- harness power question.
- Diagnostic plug??
- LS1 help and your opinion on wiring the harness
- LS1 alternator hook up
- odb1 to odb11 plug changeover
- Problem with 240sx / ls1 swap fuel issues I belive
- Hey I need help finding
- S13, LS1. Pic's!
- ls1/t56 swap. which gauges?
- lq4 and bellhousing bolt holes
- what is the best way to ship a complete engine?
- lq9 into 98 z28
- How much should one pay for a engine and trans?
- Driving impressions of my LS1 powered Seven...
- early 70's pickup conversions
- Distributor Question
- Another newb with another different vehicle
- which stall for my LS1 Silverado
- LX + 408 + thumper (pix)
- question guys ls1 to 6.0 conversion in a camaro
- Looking for ways to build a quiet exhaust?
- Advantage of running a Ford style TB
- 1970-73 camaro swap
- 99 pcm with 05 harness---NOT
- ls1 into 68 camaro
- 66 Nova SS/ LS/ Procharger - intercooled
- 1967 nova ss LS1 swap help....
- Wieghing 86 Nissan 300 ZX - LS1 project
- Few pics of the LS1 going into my 95 Z
- LS1 swap running like S**t
- will the stock 69 console with with a T56?
- ls1 in 94 z28
- corvette engine covers w/4 barrel intake
- First post - Installing a Gen III/IV in a 1991 caprice
- Ecu???
- Identifying a LQ9......hopefully not a LQ4.
- 5.3 What is this sensor and can I lose it?
- Vortec swap help
- 6.0 w/carb, Need Help
- Q's about walbro 255's
- Good GM online supplier ??
- v6 ac bypass belt
- need some help, please, long...
- Need to find out if my new steering rack is indeed a LS1 rack
- L92?
- Power steering on right side ?
- Anyone have a carb'd third gen?
- BMW E36 LS1 Swap Video
- Help planning fuel system on first Gen
- LS14 catback?
- HEI & Carbed LS Motor
- Can I Swap?
