View Full Version : Conversions & Swaps
- Needed for LS1 LT1 Swap??????
- 63 Chevy II Header Question
- LS1 into 97 f-body, what does it take?
- questions about LS1 in 97' Formula
- Which Headers good start for Vega swap
- Extra amp draw?
- Help identifiying harness plugs
- ls1 into honda s2000
- Best year for LS1 swap?
- Underhood Heat Issues?
- Not that I would, but ... LSX/T56 into a Pacer
- Calling thirdgen LSx Swap guys
- Chevy Ii Fuel Tank
- 6.0 (or similar) into a thirdgen - what parts?
- LS7 Ultima Driving!!
- is my autometer tach (needle bouncing) gonna break?
- How hard or easy would this be??
- 79c10 procharged ls1= need lots of help!
- diagnostic port help
- Is this worth it for mock up?
- LS1 Not Start-> Gas contiues to pump
- Doing LS1 - BMW swap - need bleeder line info
- LS motor in a 96+ 2 door tahoe
- ac high pressure switch
- Who wants to put a LSx in a Porsche 944? Start here.
- Need Help
- a/c pump
- Check engine light grrrrr!!
- Anyone using the Street and Performance Trans crossmember?
- Fuel pressure not adjusting...???
- Opinions! (since everybody has one)
- Swapping LS1 into BMW 325 -- PCM questions
- Would an LSx fit in here?
- Dreaming....APS TT LS1 in RX7
- Running fuel line, have questions about the fittings
- LS1 going in, but which one?
- ls2 in 3rd gen question???
- difference between the 2 coolant temp. plugs on the ls1 block?
- throttle body swap
- LQ4 swap into a 68 GTO A-body: Questions
- oil pan ?
- LS1 in my wrangler won't turn over
- question for you guys looking to use 'vette fuel filter/regulator setups...
- Fuel Tank Swap Problem
- Ls1 in a 1997 Chevy 1500
- Whats Up Gonna Be Doing A LS Swap Into An Early 240Z
- It's ALIVE!!!
- why would I make a vette look like a viper?
- S10 pro street
- Non-LS1 fuel pump options
- 4th gen Fuel Pump work in a 3rd gen tank?
- Where to go? 1979 Silverado
- Impala Sender question
- ls1 engine install guide pdf file
- PCM fan relay control question
- ls1 240sx question
- Few lil problems with first run
- A-Body Hooker headers and F-body Oil Dipstick
- LS1/3rd gen f-body coolant hose
- 04 GTO Motor and 6spd in 69 Camaro
- Creature Comforts question
- Putting 99-02 fuel pump in 95 Z28 ?s
- looking for a mustang
- Help installing a LQ4 into a 65 Chevelle
- Old Dog Z31 300zx LQ9
- looking for some insight on a toyota swap...
- LS1 5.3 into an '82 k10
- WHOOHOO !! My LS6 Mustang has PAINT !!
- Street & Performance ?
- Where to connect coolant crossover line?
- 5.3 carb swap
- smog on a LQ4-9
- Help
- 5.3 in a 2wd 72 blazer (oil pan problems)
- 550 rwhp for 68 Camaro
- Built rear-end in C3 Vette. Looking for possibly 750whp with n2o...
- LS1 to LS2/LS7/LSX conversion
- 98 F body harness, how to hook up my volt guage?
- Does anyone have shorty headers on a F-body
- Water Pump question??
- LS7 in a Silverado SS?
- Fiero with ls1 or ls2
- 2nd Gen Camaro
- LS1 to LS6 Conversion....HELP!!!!
- would shorty headers work?
- Twin turbo ls1 foxbody...? You can have it...
- Pacesetter Franken-headers
- fuel filter?
- LT1/T56 into 2nd Gen Swap
- Project Progress Report - 72 Chevelle
- Headers or OEM exuast manifolds?
- 67 c-10/ ls1 headers
- L92/L76 Intake to TAC module Wiring HELP!
- Anyone using AFCO swap radiator, F/A body
- converting from 3-wire MAF to 5-wire MAF???
- Anyone using the trans dapt motor mounts on their 67 camaro
- A-body crossmember pics
- 3.8 to ls1 will standard trans bolt up?
- Washing the LS1?
- what intake to use on 4.8
- Harness Question
- Ls1 into 240sx____PICS
- LS1 Mustang new times again !
- Invading Germany: LSX into BMW E34 525/535
- LS1 84 Vette just needs a little work to be complete
- I need a new driveshaft right?
- ls1 won't start?
- Wrecked my baby....
- Switches for Cruise Control?
- Year One Bandit shaker scoop
- LS1 swap in 75 Camaro HELP!!!
- LS1 swap HELP!!!
- cruise control
- gas tank
- Electric fan choices
- 5.3 in a 69 camaro, will the alt clear a cowl hood?
- Ls1 into a 97 S10,Need To know a few things
- T-56 6spd in s10 for under 2K?
- No signal from VSS
- Stainless Works Headers $650
- Need help with F-body front acc's on 5.3
- Starting from scratch
- LS1 into 73 corvette
- Variable valve timing
- Interior swap?
- not enough vacuum
- Ls1 Fj40
- Revcounter Problem
- 240sx + T-56 = what master cylinder?
- Autometer Speedo
- lost a thread pls help
- 6.0L LQ9 Swap questions after days of searching
- LS1 in 94 Z28 won't start
- LSX Mustang air?
- Hot Import Nights - Chicago
- engine dies immediately but fires off great.
- Completed E36 LS1 swap total weight and corner weights
- is four inches too much?
- Complex wiring questions
- FS: Richmond T10 4 speed
- Engine frame bracket- Which one?
- current performance wiring
- New S13 hatch owner wanting to do an LS1+T56 swap
- why carb an LSx?
- 66 Chevy II, 70, Camaro or 68 C10 truck for a swap?
- Corevette LS1 in '87 RX-7, transmission question.
- fresh swap, no start
- For Sale : LS1 Foxbody swap Headers
- Help on converting a 98 harness
- Help please, on lower alternator brackets!!
- whats everyone useing for a brake switch
- what lt headers for an rx7 ls1?
- 6.0 in a 82 Chevy silverado
- S10 Sanderson S10 ls shorties what gaskets to use!!
- LS1 3rd gen swap
- Question: Thick White wire, what to connect it to?
- Extreem LS1 project
- Try to start-> Click
- LSI in 69 Camaro --- A/C mounting problems
- reversed/flipped truck manis on s10??
- Opinions on HP Tuners
- Can anyone recommend a good fuse panel
- Compressor Brackets
- throttle body coolant line, bypass and necessity?
- Speed sensor for 4l60e
- Corvette Drive By Wire
- Year range of GenIII equiped trucks?
- LS_ in to a G-body drag car
- New F/A/X body swap pan??
- looking for s10 swap headers for ls1 longtube
- "Search" Feature In "HyBrids & Conversions" Help Please!
- ECM mounting bracket
- 6.0 4l80e in a '94 rcsb 1500 need info
- I need the "Project Orphan" articles from Popular Hot Rodding
- a quick radiator question
- 1981 Corvette - LSx Anyone?
- Aussie LS1 conversion
- 68 Camaro/ T56/ LS1 driveline angles - noise
- ls1 rock crawler
- LT1 to LS1 fuel questions
- 6.0 LQ4 pin outs
- what to do for dlc ls1 engine
- Moroso oil pan?
- Best fitting motor mount?
- R12 in R134 system
- Removing dipstick tube
- StoneOfFire's 98TA guts in a 96 Firebird project
- balancer ?
- wiring harnesses?
- Need Merv or Blahsters help here :) Wiring Question
- stealth with ls1 swap
- What is the best way to hook up a th350
- ls"x" exhaust manifolds...
- Would this oilpan work?
- Can I MAKE a car?
- Starion/Colt/Conquest LS1
- write up on ls1 into lt1 car...harness and shitt
- Need Help! Swap won't start!
- 1988 And Earlier LS Shootout!
- Any ideas how to hook up TH400 tranny to cable driven speedometer?
- It LIVES! 85 Vette with a LS2
- Wiring OBD-II using GM pinouts or using Nissan/import pinouts? emission questions
- Ls6 Supercharged Bmw M3 T56 6 Speed
- t-5 into 240sx PROBLEMs
- Do You think this engine will fit into my car?
- LS1 foxbody swap-- Difficulty level
- Motor mount Q for the experts
- LS1/5.3/6.0 in a 1965 Chevy truck
- Hummer H3 Alpha 5.3 motor and oil pan
- LSX in a Crown Victoria. Anyone tried it?
- killer 71 c-10
- wiring help!!!
- f body accessory part numbers
- ls1 vacuum diagram..
- Question about using LT1 gauges
- LS7 into a fox body?
- My LS1 FD build, no kit.
- 9.96 at 139.5 on the LS1 Stang!!
- looking for shops that do LS swaps
- 69'camaro W/ 4th Gen Dash
- 67 chevelle header question
- Need Info On Lt1 to Ls1 Swap
- New Project: 1968 Cutlass Convert LS1
- 96 S10 Blazer AC
- Houston, we have lift off
- 5.3L is it worth it?
- LT1 to LS1 k-member problems
- LS1 Intake on a 6.0L Truck engine
- How to get the AC working?
- Opinions on LS1 in a '70 Monte Carlo
- Question about p/n and tcc(Speartech wanted) lol
- Modified f-body oil pan, is the oil capacity ok?
- 98 v6 A4 to 01 ls1 A4
- wiring
- PCM re-flash Seattle area
- any Sponsors stock Edelbrock #71181
- 99 v6 to 99 ls1 swap
- alternator and idle problem
- Removing a fan
- Black Obsidian Update!
- Opinions on Heads and Cam for LS2
- Video of my car
- harness extensions...
- LS1 into a 97 T/A - A/C problem
- ls2 in a 1969 camaro
- needed for conversion: interior wiring for stock camaro gauges
- CAD LSx oil pan rail dimensions/diagram?
- For Those Wanting to do a swap!
- clutch line adapter/fitting leakage
