- 89 mustang gt...lq4 or turbo the 5.0?!
- Testing Cam and Crank sensor
- stupid easy 73-87 chevy truck exaust mod
- Who has a TH350 bolted to a '99 LQ4
- p0113 on lq4
- 6.0lq4 or ls1 compressor .help!
- Gen III or Gen IV? OBDII electronics? DOD?
- LSx swap wiring trouble..
- Putting everything from a 2002 TA into my 69 Camaro
- lq4/ls2/ls3 in a gmc s15!
- squeaking belt
- 87 Chevy LS swap which trans?
- 2003 Marauder Lq9 H/C/I & 4l80e
- Mustang swap BRP mounts
- 64 Chevelle turbo project
- Difference in low/full markings on GM LS2 Transmission dipstick
- 2001 6.0 and 5 speed swap in mudtruck idle issue and timing sticking
- chevy c / k 73-87 truck gas pedel mod for DBW
- e40 ECM DBW -> DBC?
- 1990 Nissan 300ZX LS1/T56 swap
- V8 swap into 03 v6 truck, wiring question ?
- 67 Firebird conversion.....clutch pedal?
- LS Crown Vic?
- Fuel mileage thread?
- Stock coolant temp sensor in upper radiator hose?
- Harness connectors/sensor differences?
- LS1/ monte carlo fuel pump problems
- LS Camaro Cluster for my Swap ???
- New to ls engines
- Jag re-conversion?
- Fan Relay ?; edumacate me plz!
- Converting truck intake to returnless setup?
- Power Steering hookup advice....
- Limp mode? Car ignores me going down the highway!
- 4L80E harness to a 4l60e ? See post# 19
- LQ9 or LQ4 + 243 + Z06 cam?
- LS3 t56 swap into a 94 transam problems
- Use original 3/8" hardlines for LSx EFI?
- A dumb question about fuel return lines.....
- New Personal Best for the Studebaker
- LS motor in 02 mustang
- Lq4 / T56 starter problems (240sx)
- My 64 Impala LS1/4L60E swap
- Mustang/t350 reverse light wiring
- Any conversions going on the Hot Rod power tour ?
- Simple O2 Sensor and Wiring help
- LQ4 408: 1970 Trans Am Motor Mounts?
- Well I found the heart! g-body (project FINNISTER)
- DBW pedal mounting
- Comparing Coolant Temps
- LM7 into '86 C10
- 1982 ford fairmont
- 1969 chevelle turbo 5.3 swap
- Old Chevy swap.
- AJE K Member ????
- radiator overflow tank
- Where do I find harness for LS2/LS3 cam sensor?
- 66 Chevelle LS1 Instal Questions
- wiring help
- LS Swapped Notch Mustang
- First time at the track with my sleeper project: 10.75 @ 131
- Emissions delete...HP gains?
- 2012 5.3 truck engine question
- LS1 intake with truck DBW TB
- Ford Fairmont carbed 5.3 swap, odd noise, need some other opinions
- 6.0 lq4 swap
- 0 sets of Kooks 1-7/8 LS into GM A Body/F Body in stock!
- Russell AN to Quick Disconnect Problem & Fix!!
- LS2 swap in 62 impala wagon
- 2002 Firebird V6 to V8 wiring harness question
- Turbo 5.3 Monte Carlo
- Best pully system for LSx in a 2nd Gen Camaro
- some newb harness questions
- Truck Manifold with LS1 DBC throttle body
- 1962 Impala LQ4/700r4: EDIT now going LS2/4L60e
- 4.8L LR4 swap into 04 Colorado Clutch line help (same as T56 LS1 clutch line fittings
- Injector adaptors
- 65 Impala swap
- Can you identify this plug?
- need some help no spark 5.3
- lsxr manifold on a 6.0 lq4
- alternator charging light
- best flowing manifolds?
- Buy LQ4 pullout or piece it together?
- ls376/515 First Fire
- 5.3 g body
- TR6060 to a 5.3
- need some help on what to do
- 4.8 in a Gremlin
- Which one guys?
- P0053 AND P0059 (Both O2 Sensors)
- Can I reuse oilpan gasket?
- 1965 A-Body, Headers? Headers? Headers?
- heater hose help
- 95 ls1 240sx forsale 10k
- How long to run engine and tranny before first drain?
- Project: LS1ick68
- low mount AC comp in A body
- i need help with the swap
- bbc water pump question
- AC Clutch Cycle
- LS1 w/02 PCM + LS2 TB
- What pan to use for First gen?
- Pontiac Ventura LS1 Build
- help with gauge cluster wiring
- Mock up of my new old 5.3 in a '37 Chevy
- Turbo LQ4 1970 Camaro RS
- gen 3 motor ?
- A few electrical questions
- Classic Car wiring and LS1
- New-ish-be (searched / read a lot) g-body l33 / 7oor4
- 408ci, Pro Mod 88 turbo, 93 Mustang coupe.
- ls376 into 95 camaro
- finding a complete t56 harness
- LM4 with GTO ECU Base Tune Advice
- Car intake on a truck with a truck water pump
- torque converter spacers? help
- 2004 GTO LS1 Alternator Need confirmation on Wiring
- Will C6 corvette accessory fit LQ4
- oil pan for 3rd gen fbody
- 5.3L with 4.3L A/C & F-body accessories???
- where to buy replacement harness connectors
- 6 liter into my 63 buick lesabre
- Drive by cable throttle body with DBW PCM?
- Anybody done a LT swap on here??? 2nd gen Fbody
- Power to 02 silverado cluster: 5v or 12v
- mcleod aluminum flywheel
- ls in 71 stepside
- 1978 GMC 3/4 Ton 4WD
- LSX Mustang radiator hose options!!!
- Gauge swap questions
- Anybody use a stock mustang tach?
- 5.3 in 96 impala
- newb harness question
- whats this car worth thread.
- Frame stand question
- My c10 field find ls tremec 5 speed project
- 5.3 swap question
- My notch is in the Car Craft Engine Swap Guide
- Where to buy reflashed computer? (4 questions)
- 98 ls1/auto into 2000 Camaro
- park / n switch wiring ?
- Electric fan relays/wiring
- 5.3 swap in my 78 nova
- Thermastat not opening
- 2003 truck 5.3 alt wire pinout info
- Jeep cherokee swap kit???
- Clutch issues
- OVRMYHD GTA gets paint
- 02 wiring
- OEM Exhaust manifold gasket part numbers
- whats it worth
- Ls2 radiator cooling fans
- Fox UPR K / rack clearance issue
- 1996 d-body sender with which pump?
- Intake Air Temp Sensor
- A body diy motor mount plates
- Ford Alternator on a LS1 motor?
- LQ9 to TH400
- Project Twin Turbo 83 S10
- OBD2 not working
- DO LS2 and LS3 accessories interchange..?
- trans tunnel - chevelle
- parts truck version 2.0
- 1971 C10 with 5.3 L59 and 4l60e A/C questions
- Lm7 and other ls questions
- build planning - cheapest way to 400-450hp?
- lsx EVAP into wrangler advice.
- nut/bracket
- L92 to LS3 Swap info needed
- New fuel tank setup - 2010 camaro pickup
- Oil pressure light
- Highest power handling transverse manual trans?
- Does anyone make a vortec fan spacer?
- C5 vs C6 vs F-body alternator
- 1970 Chevelle LMG 5.3L 6L80e Swap
- 5.3 into a 3.4 camaro
- LY6 Stand Alone Harness?
- LQ4 intake vs. LS2 intake
- LS1 going into a 99 Dakota R/T
- Open Loop or Closed Loop for swap?
- LQ4 swap in v6 firebird-some questions
- LS1 1998 Oil Pressure
- 99-04 Mustang shifter with 4L60e
- 1981 C10/5.3L Build Thread
- LS4/L33 hydrid
- Troubleshooting Vehicle Speed Sensor / PCM
- Custom Motor Mounts
- Rear O2 sensor delete/mod without retune?
- Doing my 1st Ls swap, Need advice....
- Question about CATS
- ECU selection = crucial or no?
- Which A/c compressors fit truck FEAD?
- Hooking Up Paddle Shifter 6L80 Transmission
- why wont my truck start?
- Help On LS2 Swap into G35
- 400 horse gmc canyon
- 5.3 vortec
- 3rd Gen F-Body 6L90E Install
- any one running or have run a 4l80e in a fox mustang?
- 6.0 into my '84GT
- Trans. Help
- OBX Headers??? For A body swap???
- 5.3 turbo swap in a 98 mustang gt
- ls1 longtubes in 5.3l lsx swap
- Who Makes/Sells This Motor Plate For a Fox?
- LY6 in a 70 c10
- 5.3 in a Jet Boat
- LS1 Delete Power Steering / Serpentine belt Question
- ls1 240sx ac lines
- Camaro Radiator Question
- ls1 into Lt1
- VIDEO LS swap into an Older Car on a budget
- Cable or DBW?
- 1966 El Camino LS swap complete
- F150 swap for Pre-runner
- Wiring Woes - LQ9 '92 S10 MSII/CAN/MSD
- 1998 LS1 Longblock + 99-02 harness/ECU
- Connecting... Need help on lt1-ls1 electric
- where to buy corvette FPR
- What Differential are you using.
- Name that Bellhousing!
- LS1 fuel lines
- Can a Sanden Compressor spin the other way??
- Vacuum Leak
- Crossmember install fail
- SUMMIT has F-body headers for $50 off this week
- What year 4L60E trans will work with 2010 5.3 motor
- california smog?
- NOOB...5.3l SN95 Swap
- 5.3 S10 Build
- 1969 chevelle ls swap
- 98 5.7 vortec wiring
- Impala fuel tank
- What's a decent price on an LQ4
- i need help finding this intake, has anyone seen this before?
- 3.8 to ls1 no a/c
- 3spd shifter\4spd auto
- Official- Where did you get your engine/trans
- 99 sonoma build
- Clutch Input to PCM
- gen 4 5.3/6L80E into 92 mustang questions
- 3 motor mounts compared side by side
- hydraulic clutch adapt ques
- 70 Chevelle LQ4 swap with a Turbo!
- Holley Oil Pan fit
- 99-02 4.8L piston ring standard specs
- question for bczee and AC experts
- Accessory drive types?
- 5.3 Engine Question
