PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 [144] 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172
  1. 72 Olds 350 Cutlass
  2. Lexus IS300?
  3. does "Mr.Know-it-all" know this?
  4. LS1 in a cherokee???
  5. Ever heard of a Mazda Navajo LS1(or other) swap?
  6. sbc in a fox-body, please help
  7. ls2 - 69 Camaro - NY
  8. Picked up my motor set tonight.
  9. Crankshaft Pulley Removal
  10. 2nd and 3rd only in 4l60E trans?
  11. Gen III Land Cruiser
  12. Fuel pumps/regulators- carb feeds
  13. Porsche 914 LS6
  14. any wiring harness from a v8 engine 99-2000 will work on ls1?
  15. Lamborghini Dress kit for LS1
  16. 6.0 L 408 going in a 67 camaro. looking for someone to install
  17. Without PCM, these works?
  18. Need Transmission Help!!!!
  19. modifying an oil pan
  20. '99 5.3L Into '96 S10 4x4 V6??
  21. Mallory 5110FI pump
  22. throttle body mod for TV cable
  23. LS6 in my 56 Chevy
  24. drop a LS6 in my 56
  25. post swap pre-reprogram hp?
  26. Block mount locations?
  27. Foxbody conversion parts...
  28. GTO Oil Pan
  29. Project LS14-T
  30. Low profile individual runner intake for LS motors
  31. LS1 to LS6 swap....any advice??
  32. BCM and fuel pump relay question
  33. How many S13 LS1's are there?
  34. rear end
  35. Fuel Pressure Regulator help....
  36. Chevelle guy: MWPE Firewall smooth kit
  37. More 240SX Clutch Master Questions...
  38. LS1/ 4L60E trans crossmember for 1968 Camaro....
  39. LS1 motor plates.
  40. FS:Eldebrock LS1 ignition control box for carb set up
  41. LS1 power steering pump with older steering box.
  42. 5.3 valve covers and headers
  43. Video of radixed 72 K/5 in the snow
  44. wiring harnesses?
  45. I Need A Computer/pcm/ecm
  46. I Need A Computer/pcm/ecm
  47. engine stumbles and dies if altenator is connected?
  48. LS1 and T-56 SWAP INTO 71 RS CAMARO
  49. Analog speedo, oops
  50. S14/S13 LS1 swap.... driveshaft and rear??
  51. Carbed 6.0 combo ??
  52. Infiniti G35?
  53. skip shift
  54. Starting my S13 LS1 project.
  55. Chevelle Pro Touring Guys, New Hotchkis 68-70 GM A-Body TVS Kit Available
  56. LS1 powered DeLorean
  57. Good sites for E36/46 BMW
  58. Need your advice Chevelle 71
  59. Engine advice for offroad truck
  60. 69 Chevelle Swap
  61. LS1 swap over an 94 LT1 camaro
  62. length of stock fbody clutch line
  63. Entire Engine Wiring Schematic
  64. How to make up a 5.3 & NV3500 5 Speed?
  65. LS2 into a 3rd generation camaro
  66. 95 LT1 in 95 V6 Compatibility Questions?
  67. Corvette Fuel Filter/Regulator and Quick Disconnect Fittings
  68. frame building
  69. Any body know? LS1 install
  70. Have a Olds Motor/Trans/Rear..
  71. Converting a LT1 to a LS1
  72. PCM connector pin part number
  73. LSX conversion - harness info
  74. Info on Swapping LSx into 93-97 Fbodies?
  75. AC system on 98 Ls1 swap
  76. Quick Engine Mount/Boss quesstion
  77. Mercedes Conversion anyone???
  78. Best car for conversion
  79. How does a 496 compare to a LS1
  80. 1976 camaro / 02 LS1 swap
  81. Help with Walbro fuel pump fittings
  82. People running 4L80E's please come on in..
  83. LT1 Into Intrepid
  84. Help with Russel Fittings
  85. Attn Rob, Relay Wiring
  86. Video of my TT LS1 Volvo Wagon!!!
  87. Did I order the wrong k-member? MUSTANG
  88. Which mounts for 69 camaro?
  89. Chevelle T56 clutch bleeding
  90. 79 T/A rear end rebuild
  91. Welp the Camaro's gone
  92. anyone have a LS1 F body evap tank they are willing to sell?
  93. Any 1st. gen ls1 700r4 swaps
  94. pics of progress on 69blackwidow
  95. ls1 in my 94 truck
  96. Rx7
  97. 71 blazer conversion
  98. oil pans
  99. 94 LS1 swap Fuel sytem setup
  100. Fuel system Q
  101. Corvette Alt. bracket
  102. built a new exhaust for the 240
  103. mercedes ls1???
  104. Racing season has come to end...
  105. Taurus 2 speed cooling fan
  106. neutral safety wirring
  107. Tranny Cooler ?'s
  108. Test fitted the motor today
  109. obd1 to obd2 adapter (lsx swap)
  110. Flywheel help please 92 K15
  111. ls1 f-body accessories vs. corvette accessories
  112. 3rd gen radiator questions LS1 swap
  113. SS 454 Chevelle Convertible/LSX T56 hits the streets
  114. Antique/Classic Insurance
  115. S10 TBI swap...
  116. firebird / camaro ls1 fuel tank/line question
  117. Guy's need some help on conversion. (newb)
  118. ls1 size compared to Ford 302 and gen1 sbc
  119. Picking up a Notch
  120. mustang vs. rx-7 vs. 240sx
  121. Which year does smog test exempt kick in in Cal? 74 or later?
  122. 4th gen camaro fuel tank on first gen
  123. First Gen F body guys whats your 1/4 and MPG?
  124. Custom valley cover
  125. 1994 Z28 Lt1 To Ls2,ls6,or Ls7
  126. Twin Turbo 71 Chevelle Pics
  127. LS1 to TH 350
  128. Happy Thanksgiving All!
  129. Northstar in C5/C6 or LS1 F-Body
  130. ls1 into 90 vette?
  131. LT1 to LS1 T56 swap
  132. Custom LS7 Valvecovers!
  133. 99+PCM with 98 harness?
  134. 69 Camaro Brake Booster Clearance
  135. LR4 --> LS1?
  136. Oil level sensor question
  137. anyone here have a FBody header handy?
  138. 4l65e wiring??? please help
  139. Need some help with LS2 starter
  140. PGN: 2000 Jimmy from Pleasanton,tx
  141. Ls1 swap headers for mustang... Will these work?
  142. F to Y body accessory swap
  143. LS1 motor plate
  144. 6.0 In 72 Vega RaceCar
  145. Q's about conversion wiring (clutch sw. and tank level)
  146. '04 Mustang GT 6.0/4L60e swap questions...
  147. 04 2wd Silverado wire diagram
  148. 69 camaro LS radiator/fan/w dccontrol pics
  149. quick question on ls1 project
  150. LS1 PS pump or orig Chevelle pump?
  151. Any '60-'66 Chevy truck swaps done?
  152. s10 shifter cable/4l60e?
  153. sensors question
  154. do i HAVE to get ls1 camaro/ta wiring harness?
  155. What kind of spark plugs and gap size are working well with carbed LS1?
  156. Intake options/advice?
  157. 5.7 Ram Jet '02 S10 Blazer 4X4 Conversion
  158. 05 5.3 into 86 z28? smog laws (ca)?
  159. 67 RS/SS getting a little LS2
  160. 2nd Gen Camaro LS1 Long Tube Headers
  161. 2000 5.3L tubro s-10 project !!!
  162. Pictures of my new LS1-powered Rx-7
  163. Anyone did a LS1 swap into a 300zx??
  164. 5.3 or 6.0
  165. lsx 2 fox motor plate
  166. for all you gtech fans
  167. Can someone explain the differences in the LS-1 fuel rails for me?
  168. For Sale: SFC's for 67-69 f-body
  169. trans bellhousing bolt question.
  170. Anyone with Novas? any websites?
  171. Carbed LS1 guys please HELP
  172. My LS1 RX7 Build
  173. Whats a good offical reference on LSx emission systems?
  174. LT1 to LS2 conversion
  175. v8 swap into v6
  176. tranny cross member
  177. Should I go efi or carb'd?
  178. Question about venting a carbed LS1
  179. LSx into S chassis, clutch idea
  180. Reading ODBII data. Homemade scanner/tuner.
  181. in order to use ac with ls1 in wrangler, cut frame?
  182. Help convertign OBD-1 to OBD-II
  183. T56 shifter over a bench seat 71 Chevelle
  184. LS2 Datsun Z Testing Traction!!!
  185. Which Engine GTO, FB or CTS-V in 68 FB
  186. LS1>Toyota alternator questions
  187. Edelbrock 7118 carb kit problems and questions.
  188. ls6 into 2000 camaro help
  189. 1990 supra
  190. Wrangler guys
  191. malibu worth
  192. 'Vette accessories in 1st gen F-body?
  193. OK I'm cornfused here
  194. A/C question?
  195. takeout / junkyard engine or from scratch?
  196. Carb setups
  197. venting fuel tank?
  198. Fuel EVAP needed?
  199. 5.3 truck motor bolt to a 4.3 4l60e in an S10?
  200. just playing with the idea
  201. Gm parts...best prices?
  202. LS7 + BigStuff3
  203. ls1 s13 240sx completed
  204. 4 speed to a 1999 vette ls1
  205. '74 GMC sprint
  206. New and need advice...
  207. 1.75" to 1.5" radiator hose adapter?
  208. Took my Camaro out for a spin
  209. S10 Swappers - Better Brakes?
  210. Ls1 350z
  211. LS1 focus
  212. 1993 RX7 R1 w/ LS1 T56 in for sale section 442 RWHP/408RWTQ 10.9 1/4 mile
  213. With all the oil pan issues, why not go dry sump?
  214. LSX MUSTANG 05+ Vid
  215. New thread about my LS1 mustang... NEED HELP!
  216. HOw much is a 71 Chevelle Ls1 T56 conversioin
  217. help: trying to find computer & engine harness off a 2000 or 2002 m6 T/A
  218. Volvo LSx swap
  219. Flywheel Torque Specs?
  220. 5.3/5.7 Hybrid
  221. LSX into mid 90's Jaguar
  222. Updating a Tahoe
  223. Question On ls2 Swap
  224. regal 1/8 mile times
  225. stang lsx motor plate and headers mass produced
  226. 6.0 into a 73-87 truck header question
  227. wiring help.. 3.4L V6 to Ls1
  228. M6 wiring harness
  229. Ecotec + T56?
  230. Clutch Line conversion Fitting solved!
  231. New GM 454 LS Based Engine Available...
  232. It's started
  233. BMW E36 or E46 Chassis
  234. Got the car today e36 BMW
  235. Battery wiring question (starter, ground, alternator, etc)
  236. LS1 into LT1 car?
  237. Ls1 In Shelby Or Ac Cobra
  238. Fox LS1 swap headers....
  239. LS1, 4L80E, range rover, questions etc etc
  240. LS1 coilpacks/loom/brackets- suppliers?
  241. What is this called?
  242. HELP!!! LS1 into 78 Camaro mid install issues
  243. Just thought you folks would be interested!
  244. Anybody done an LS-1 into a 73-87 Chevy Truck
  245. 1986 Jaguar XJS w/ LS1
  246. Photo's of Steward Reverse Rotation WP
  247. ls1 accesorie interchange
  248. LS1 Mustang on eBay in Michigan...
  249. LS1 in a Jeep!! pics inside
  250. swap out 5.3 for LS-1 in 4x4 crew cab
