View Full Version : Conversions & Swaps
- C5, C6 ECM's
- My first AutoX shake down with the Ls6 miata
- 2006 LQ4 Swap Electrical Questions
- 1972 Camaro LS1 conversion Questions
- Pictures of completed autocross race-street car
- What header in an A-body
- socketless hose on stock fuel rail?
- 4.8 or 5.3??
- LS1 In A V6 HELP!!!
- s10 a/c lines
- 92 camaro ls1 wiring...PLEASE HELP?!?!
- air intake?
- 2000 harness with a 02 engine and 03 trans?
- New LS364 ignition system problems!
- fuel line
- s10 throttle cable for ls1????
- 2nd Gen Camaro LS1 Vids
- Thinking about an LS1 swap into my fox...
- LSx in a plane
- Going to put an LT1 in a 72 camaro but...
- LS1 heater hoses to 3rd gen heater core...
- Which Oilpan for LSx in a 1st or 2nd Gen Fbod
- Convert Corvette Flexplate for 4L60e?
- DBW question
- 69 @ newtech performance shop!! ...waiting impatiently lol
- Problem solved. LS1 with C5 PCM first start up
- Radiator hose help
- 55 chevy ls1 conversion
- One step closer
- Which one should I convert 1981 CJ5 or 1998 TJ JEEP?
- How many O2 sensors in Fbody?
- Bunch of conversion pictures
- Homemade VATS bypass box...
- LS1 in a 79 Trans am
- Corvette c6 control arms and uprights?
- A few pics from a UK show on sunday.
- is the saturn sky RWD if so will it fit the LS1
- Do I want the wiring harness or not??
- Anyone know how to Photoshop?
- What's everyone doing for driveshafts?
- ls1 in an 94 ta
- Very Loud Walbro In Tank Fuel Pump????
- Couple vids of my first start ups!!! mmm..open headers...
- first gen chris alston and supercharger and camaro
- New Fuel Rail Covers are here
- Speedometer conversion
- 4L60 Crossmember???
- 2005 Suburban 5.3 Underhood fuse box
- Which Headers
- 6.0L Bravada RUNS!
- Rewiring 2001 Camaro harness with questions
- mount plates for '68 Camaro
- ls1 mustang almost done
- Gas tank question
- The big lump finally arrived!!
- Started on First Crank
- mounting the PCM
- Wonder if it would be possible to..........
- LS1 Toyota pickup
- interchangabe harnesses
- wiring
- 77 Nova pan
- Low mount AC on a 72 Stingray?
- LS1 wiring harness for 94z?
- 12558899 vs. 12558762 Oil Pans
- 3rd gen camaro headers?
- HELP ME....Please
- Where to get fittings?
- one more S13/LS1 swap in the works
- 240sx-ls1
- Anyone Willing To Trade 99 Ls1 Engine Harness For 99?
- CJ5 with LQ4 6.0-intermittent start problem
- Tell me what u think about this
- Project 346SX - "KA24 to the power of 2"
- 6.0 in g-body
- Best place to find engines
- 02 truck pan work in 88 bird?
- 88 Monte 6.0 headers??
- correct flexplate for 400 transmission w/ls1??
- russell fuel rail fittings
- Seven Stock 9
- Pinouts for 2005 5.3 Suburban
- Trashing the LS7 idea. Opinions? Here is the car too.
- LT1 wiring reference
- Weld going chapter 11
- A/C in a 73 Z/28 w/ LS1 ??
- For Sale!!! Stuff you need for your swap!
- 67 chevy II conversion????
- My LQ4/spray 1986 RX7...
- 59 Impala LS1 TT nearly complete
- 4l80e conversion in a 98?
- The Next 240sx S13 With LS1
- 4l60e question
- strange idle?????????
- 65 belair
- Ls2 into 94 camaro
- HELP with Master Cut Off Switch
- O2 sensor prob in 3rd gen
- Alternator Question bout the v6 alternator
- Pacesetter long tube in 67 Camaro
- Wiring the 5.3 up in a 96 S10 Blazer
- first gen wayne due in a second gen?
- 1968 Camaro SS ls7 swap // HELP!
- 01 LS1 and 6-speed into a FJ40 LandCruiser?
- Source For Delphi Connectors?
- 2001 LS1 into a 94 Z28
- Hooker engine plates "mount adapters"
- 2001 Camaro LS1, What Octane ?
- where is the best place to get ported heads
- Hot fan relay
- 04 GTO wiring diagrams (66 nova)
- Shipping Weight on a 5.3L?
- Few pics LSX Mustang
- nyone know of long tubes that will fit a 98 Silverado?
- 78 CJ5 Jeep swa[ to TPI
- Power Steering lines
- Looking for info on a gen1 sbc into late model S10 swap
- Frustrated with Speedometer
- wanting to put a LS1 into my 95 caprice (newb)
- Crate LS1 lifting plates...
- Clutch Problem
- v8 swap
- Gto Cluster Pinouts ?
- here is a LS1 retrofit schematic
- POLL: What is best engine for a conversion?
- 4th gen radiator into 1st gen - how much fabrication
- 6.0 LQ4 in a 98 Camaro. Been done before?
- Serpentine Belts? One Better Than The Other?
- Some pre-start questions
- s10 ls1ers prt. 2
- Got a Problem
- for all third gen ls1 owners..
- Throttle Cable Linkage/ '66 El Camino
- Does anyone know ....
- Relocating shifter rearward?
- Carbed LS1 Anyone?
- Ls1 Chevelle Burnout Video!
- lq9 going in 88 firebird need few questions answered
- 95 V-6 Camaro SWAP To LS1 Questions
- Offroad Rock Buggy w/LS2
- plumbing returnless fuel system?
- Anyone know a reputable place to do harness conversion for LS1 into a Caprice/Impal
- 3rd gen swap radio question?
- Tach question
- Quick easy engine "BAY" harness question.
- need
- Initial Startup Checklist...
- Those wanting to use cobra t56 in fox mustang
- Radiator sizing?
- Couple of questions
- It runs!
- FAN wiring Poll
- Fly-By-Wire Questions
- and so it begins
- Couple wiring questions (EVAP/FUEL TANK)...Check my work...
- Location for 2nd coolant temp sensor?
- ls1 help someone
- Grrrr! Water temp adapter...
- Drove my '67 today for the first time on the street...
- T56 speedo sender to Autometer elect. speedometer
- need pcm connectors
- OBS truck LS1 motor mount;
- LS1 RX7 fuel pump problem
- ls1 mustang wiring question
- '97+ 3000gt?
- Are these Fan relay connection correct?
- 3rdGen Starting Issues
- LT1 Conversion, what do I need!?
- O2 sensor
- Corvette regulator/filter
- pcm question
- Kooks On 3rd Gen?
- Motor and Trans Mounting Questions
- Any idea's on what i should ask for this stuff
- rx7 ls1 motor swap
- LS1 alternator on LS2
- transmission does not work...truck wont move
- Any A/C Experts out there?
- What else could be used?
- Plastic LS1 clone
- what to shut off??????
- LT1 into Split bumper Camaro style
- S10 LS1 and towing.
- New LSX Valve covers from GM
- Wiring question
- LS1 Wiring harness used...specific one needed?
- Adequate cooling for a LS2 or LS1
- Almost Ready To Fire the LS1 (Suggestions)
- air intake tube
- JohnB's website
- was planning on a 5.7 but...
- motor swap
- swap 6.0L to 2000 Trans am
- Wanted: Mazda RX7 front and rear suspension pics
- Which engine to buy for the camaro?
- Egr
- LS1 PS Pump and older box
- Taking my Nova to the track tonight
- Park Neutral Switch
- 1st Gen Camaro + LSX + 200R4... anybody done one?
- LS1 1968 cutlass, i hope
- LQ4 questions
- 1950's full size chevy/lsx?
- electric fans
- LS1 Motor Mount U- Brackets (Where to get them)
- electronic trottle to cable throttle
- fuel pump relay issues
- Got my Speartech harness :-)
- 97 Corvette fuel rails
- Well, my LT1 to LS1 is complete *happy*
- ? on 01 SS Throttle Body and 01 Vette Harness
- AC Hoses Help
- 1970 Firebird Hood Clearance with Carbed LS1
- what is this fuel connector called
- New dyno numbers on the 383 ls6 miata
- IT'S ALIVE!!! After a year and half.
- 56 Chevy, LS1, and Power Booster
- Fuel pressure
- thinking bout putting an ls1 in 94 95 stang?
- LS6 SPark Plugs
- WRX LS1 swap, had someone really done it.
- LT1 swap to LS2
- anyone have a v6 for sale
- Whats a good price for a Ls1/t56?
- Map sensor connector pinout needed
- Oil Pans
- GTO LS1 in a rx7 fd?
- a/c questions
- Another ls1 startup video
- rewiring two sensor connectors
- European going to California, help me list some LS1 related shops?
- LS2 2006 GTO in a 69 Camaro
- Radiator Hoses
- what's the mustang sister site?
- what wheels and studs fit?
- 6.0 in a 94 firebird v6 body
- Getting an LS2
- Hey guys, need some opinons.
- Look what happens to the FAST intake when your LS2 backfires........BOOM!
- VSS pulses per rev.
- Using a tach as a speedo
- It Wont Shift Out Of First!!!
- 68 firebird ls1 / T56 help (simple questions)
- Finally in business! LS1 into 84 TA
- LS2 Datsun First Drive Video!
- exstended cab s10 drive shaft????help please
- 94 Honda Prelude LS1
- Mount hole offset?
- please help
