View Full Version : Conversions & Swaps
- Engine Harness Plugs
- Pulley alignment problem
- LS1 into a 70 camaro
- carb setup computer questions.
- Sponsorships....
- New diff mounted to subframe
- Direct swap LS6 headers - do they exist?
- Merging new and old wiring
- Car not running right??
- 2000 Vette LS1 in 81 Vette
- Does my car have a cam? vid.
- Better performance LS2 or LS6
- What is everyone doing for gauges?
- water
- what can cause injectors not to fire?
- when you use the impala tank, which FP?
- HELP wont start!!!!!!!!
- Harness
- SBF headers Converted to LS1
- Radiator
- Single vs Double (fuel line, that is.)
- another quick alternator wiring ???
- PCM reflashing
- In tank pump wiring?
- corvette mounts wtb
- Update on project LS1Bandit
- 1955 56 57 Conversions Post here
- Oil Pan Measurements
- a tragic loss
- Hooker Adapters
- help getting engine started
- 91 Z28 LS2 S/C stroker FINALLY done!!!
- LS1-LS6-SBC- BBC engine weights
- altenator locations..
- converting brakes 1st gen ?
- LS1 in a 79 WS6 TA
- how does a brake booster work?
- 65 Impala swap
- F-body Vs. Corvette A/C drive
- Couple brake setup/brake line questions...
- VSS Sensor questions
- T-56 experts, have ?s
- fan diodes
- What is everyone doing for power steering hoses?
- how much would you build and sell a third gen ls1 for?
- PNP switch question
- THIRD GEN Formula LS1 SWAP
- Idea for my chevelle chassis...Am I crazy??
- Ls1 Coupe With T 76
- My LS1 in a '69 Z/28
- has anyone tried the chevelle or firstgen fbody headers on a thirdgen?
- Fired up the Camaro on Saturday.. vid
- LS1 Fox body suspension question
- ls1 swap air lid question
- LS1 RX7 project in classifieds
- 3rd gen f-body request.
- Paging John McGraw: LS2 Oil Pan ???
- Ls1 E36 Bmw
- Best pan/accessories for a third gen camaro swap?
- Who wants to help me wire my LS1/Mustang swap?
- swap ls1
- What headers with ATS mounts?
- Alternator and PS pump differences
- Starting Problem - Help trouble shooting
- Do I Have to cut the frame
- My next hump in the road, gauges.
- C6 instument cluster in older car
- location to pick up tach signal?
- Fuel Gauge HELP!!
- LS1-LS2 Corvette alternator bracket
- Where are you guys getting all your parts for the swap?
- Truck power steering Variable orifice solenoid
- grounds at the top of the harness
- Which headers for 71 Chevelle
- more progress
- Do I need to ground my battery directly to my block?
- ls1 t56 into a 2000 v6 auto
- Project '98 S-10 drag truck....
- Another LT1-LS1 swap here!
- LS1 oil pan swap, exactly what needs to be changed
- LS1 Catera
- THANKS everyone
- Speed sensors (VSS) on transfer cases???
- 3rd gen guys COME IN!!!!
- Ls6 ??
- Anyone convert...
- Do I need a specific PCM??
- A/C clutch engaged but does it signal the PCM to increase idle?
- Steering Wheels & airbags?
- LS1/ 84 T/A runs and drives-and it's fast!!!!!!!
- Anybody have a Pontiac 400 they pulled out?
- LM7 91 S-10 questions
- Intank pump or external? Tank questions...
- Clutch not disengaging
- It CRANKS!!!
- LS1 Emblem on Ford Logo
- ls6 into an 99 trans am
- f body 98 to 02 computer motor swap?
- 240Z Headers
- Manual and auto harness differences
- honda w/ tq
- Megasquirt & MSD 6010 Box to control everything to run LS1? (no factory harness/pcm)
- 1991 Corvette w/ LQ4/LS6 hybrid is ALIVE
- my 71 vega GT LS1/T56
- need help putting ls1 in 88 swb 4x4
- What LS based dash in my 70 Chevelle??
- Last wiring question (hopefully)
- ls1 and auto in 71 nova
- Will This Work?????????????
- Question about 4L60E
- 68 PT Camaro Banks TT SBC or ls1
- V6 swap for LT1????
- Quite muflers with LS1
- ls1 t56 into a 71 chevelle?
- any one put an ls1 in a 350z or g35?
- Wiring up a chevy keyed ignition, help
- All this talk about a T56 in a Fox, so here's my swap thread.
- fuel tank question
- priming the gen III
- intake elbows
- My Nova getting an LS1
- more electrical gremlins taunting me
- Crank trigger
- diff in harness ?
- LSX engine placement Question
- Painted my camaro the other day...
- LS1 bellhousing bolt pattern or drawing NEEDED!
- Drive-By-Wire Gas Pedal Compatibility
- Alt. wiring problem,,
- Ls1 C3
- buick 3.8 turbo motor in a 98-2002 camaro
- Cleaned up the wiring some more...
- Conversion won't start... baffled
- Fuse/Relay Panel - Junkyard
- whats it take to hide the power steering resivour?
- Any Chevelle guys running hydroboost?
- Low profile fans needed for my 55 ChevyTruck
- Its Alive!!!
- pics of my 69 camaro blackwidow in progress
- Tanks inc. sump
- ??? Fair Price For Low Mile LS1... & T56 ???
- 5.3 intake & cam options
- Found a motor have some questions
- wtb 1998 ls1 f-body engine harness
- Drivability problems have me stumped! Please help!
- 02 Sensor question for my LS1 swap
- Here is a really stupid question
- LT1/T56 into 98+ s10
- New to the forum, couple of questions
- Accessory Drive pictures
- ls1 into '56 bel-air?
- bellhousing boss ?????????
- lt1 pinouts
- LS1 Wire question??
- wiring size for the harness that goes to the CPS?
- LS1 240sx Hit the dyno today.... Its all Done!
- Need some help,68 chevelle th350, ls1
- buick century
- Harness connectors
- Old School LS6
- making it idle??? Ls1 all wired fused and relay
- turbo LS1 fox ideas
- Ls1 Rwd In A 93 Prelude Omg-
- Another wiring question? Please help!!
- My 93 04 LS1 mustang, mating MN12 ?s.
- Cj7 Finally On It's Way
- Lengthen PCM harness... what size wire?
- A few in depth questions
- HELP LSX in 67 II...
- Opinions on custom dash arrangement...
- are TAC modules interchangable?
- 91 Z28 Lives, first Video done.
- 3rd gen or 98+ v6
- 2003 Silverado air intake temp sensor part#?
- Electronic throttle woes... need some help
- Who does wiring harness mods?
- anybody have pix of an lsx in a 93-97 camaro?
- LS1 in a 72' Datsun 510 has it been done ?
- fenderwell mounted pcm cover
- Thread pitch and size of the F-body AC pressor sensor
- Need help on PCM and Harness
- Ideas? What Color for my Fuel Rail Covers?
- need direction
- Stumbles when I get on it?
- 92Z LS1 project (come in)
- New Engine Choices for S10 swap!!
- ls1 6sp in a 74 nova
- fuel tank return line
- Ready for LSX swap
- 4L80e GURU's I have a question for you..
- 5.3 Wrangler Picutres here!
- Here's a question
- LS1 into Nissan Pickup?
- Remove VATS from PCM??
- 71 Chevelle hooker header pics
- 78 Trans am LS1-turbo set up?
- C5 fuel level sensor
- Dual post coil wiring?????
- LS1/2/4/6/7 Fiero???
- Oldschool LS1 (71 Camaro)
- harrisburg pa hotrod tour
- Pic's of my 5.3L swap in an S-10
- Big Block Headers on LS1 Motor???
- LS1 swap issues- starter isn't working
- fuel issues
- another one lives! but with issues :(
- Revised ATS oil pan
- t56 to 4l60 ???
- 81 camaro ls1????
- KATech Tensioner Install
- 1993 1500 silverado guage cluster harness
- my hybrid...
- Conversion to TurboLS6 Powa' Part Trois
- S & P High Mount AC installed
- Looking to install a manual trans in the 2000 and up
- 72 c/10 ls-1 install?
- more progress
- LS1 driveshaft to 12-bolt
- Another hybrid clutch story!
- ls1 stang questions
- LS1 240sx....
- Another bug fixed
- Anyone need P-Ayr replica LS1?
- is return fuel line needed, can regulator be placed next to tank?
- 5.3 LH6 DOD conversion questions
- Volvo 5.0 or LS1
- headers for ls1 s-10 swap...f-body?
- GTO LS1 into a 72 Malibu
- Flex-a-lite Electric Fans??
- After 12 years, finally motor swap time, need advice
- Custom bending for intake tubing
- Help very strange annoying problem.
- Help, short O2 sensor? (stock one doesn't fit)
- LS1 install. Fellow Chevelle's help.
- any ls1 manifolds that clear 56 chevy 605
- LS2 E40 Engine Control Module J1 Pin Assignments
- What is the thread pitch and size of the oil sending unit?
- Walbro Fuel Pump
- GM 4th gen camaro w/ ls7
- websites/resources for moving brake master
- ls1 rx7's for sale... (?)
- Ls1/t56 in a e39 5 series?
- Change vin after swap????
- trying to put LS1 in 92 Camaro RS
- LS1 crank and cam snesor types?
- Pleae Help an Old F*rt... SBC, LT1, LS1... WHICH ONE?!
- the new numbers-ls2stang
- 1999 tahoe possible?
- Valve Cover Mods
- thirdgen ls1 swap questions
