- Valve Cover Mods
- thirdgen ls1 swap questions
- coolant lines
- Accel ecu and spagetti wiring also updated body pics
- Ls1 240sx for sale
- Next up.. dropping in the LS2
- Injector seals LS1
- Another VSS question
- tunning question regarding a swap
- Opinions
- Installing a LS2 in a Older GTO with FI
- FD RX7 LSx conversion
- 6.0L oil pan ?
- lt1 help
- Gas tank vent
- It Lives
- Carroll Shelby did it first...
- 3.8l V6 Qs...........
- Looking for a temp sending unit
- Truck High mount A/C compressor bracket
- Temp Gauge
- Engine Harness
- To Notch Or Not To Notch ???????????
- LS1 into 87 T/A WS6
- LS-1 Swap
- Stock fuel pump 12v wire
- Tell me why my car runs like poop if I have the TPS connected
- Lokar Steel Braided Dipstick Tube Question
- VSS in Muncie 4 speed
- Moved Alternator - Need Custom Length Serpentine Belt
- monte carlo?
- LS1 swap into 95 v6 camaro? help
- What pcm to use with my hybrid engine.
- T56 VSS Sensor
- Smaller flywheel on Gen III?
- LS1 on engine stand
- Wiring harness question
- Ground wires points and or connection
- Difference between fbody and c5 steering pump
- Will a 6.0 out of a 2004-5 van work for a swap? Is it LS1 or LS2?
- Dry Sump LS1/T56 into E30 BMW Conversion parts on ebay
- Engine not fitting right
- ecm question
- Alternator wiring question
- LSx/T-56 in a '97 BMW 328 vert?
- power steering pulley underdrive
- lack of truck conversion headers, forcing me to use my brain
- what would you do?
- Turbo Nova running video
- Who makes IAT and MAF wiring extensions?
- engine mounts dumb question of the day
- Transmission wiring ques - shift selector
- converson wiring harness LS1 to LS2
- How to Convert LS1 To LS2
- XJ LS1 swap...
- 90 RX7 vert chassis 4 sale
- What LS? will yield the best fuel mileage?
- is this 67/68 RS SS worth anything?
- Starting the Swap
- Oil Pressure is 60 psi at idle and I puking oil
- progress
- 5.3 to turbo 350
- 5.3 wiring basics
- what do you guys think of the 2nd gen trans am for a project car?
- LS6-LS2 questions
- 10 questions and a few answers
- is the necessary to run stuff the same on a 01 5.3 harness to ls1
- exhaust for ls1 converted car...
- Think i found a roller...What should i look for?
- Wiring up my Monza, a few questions
- Any LSx motor on a motorcycle?
- Soooo...close....
- weird ignition problem??????
- V8 in yota pickup
- my 1st gen swap
- LS2 GTO oil pan, windage tray and pickup
- lt1 to ls1 convertion
- [fuel pump] should I be worried?
- I need a simple step by step on Conversion of LS1
- Silverado to LS1
- can anyone identify this spindle (pinto?)
- Is this ok?
- Need Tach help
- Uber LS1 Newb Help
- anyone fab headers for swap?
- 8.1ltr swap into 3rd gen camaro
- 85 k10 5.3 swap
- Longer plug wires?
- Pic of the motor in my previous thread
- Swapping an LS1 into a 94 Trans Am GT?
- LS6 power steering delete
- LS1 into 94 Z28 (No stupid questions)
- 5.3 LM7 into 1988 Supra project
- LS1 into RX7 - Battery/fuse question
- Removing TCS cruise control cable
- Moped Engine Swap....seriously
- Finally...the LS7 Monte SS vid's from the track!
- Shocks/Spring for optimal ride height?
- Best way to clean block
- Can keys stop ignition and spark?
- Stock or aftermarket computer/harness?
- LS2/57 Belair needs fuel lines
- swapping ls1 in to lt1 car
- LS1 Notch(PICS)
- Newb needs assistance in fuel filter selections
- wrecked LSX's
- Progress BMW e21
- Wiring and trans questions
- Installed Fast 90 and Ls2 TB today...
- datson z cars
- I got a lot done and blown away this weekend
- 86 S-10 Project
- Convert LS1 Tach output to 4 cyl tach?
- Pacesetters width.
- LS1 into a 94 Formula
- GMPP/Wegner distributer drive VS MSD/Edelbrock controller
- 4th gen fuel sender ohm conversion question
- Anyone ever consider doing an RX-8?
- Best source for 1971 Camaro fuel tank
- Pic of the ls2 stang
- Coolant.....
- c-10 motor alignment help
- general newb question
- triumph spitfire conversion?
- specific year of block?
- V-8 S-10's
- My new project.....Turbo Ls1 in a RX7
- 402ci Stroker...need piston advice
- low refrence
- Engine Level or narrower transmission?
- 5.3 Vortec out of 2001 Tahoe?
- '71 Chevelle - LS1/T56 - In progress
- Gas pedal doing nothing
- 91' LS1 Fuel fitting
- 1987 944 Ls1
- Electrical Bulkhead /Wire Crimping Question
- Chevelle Update.
- crate engine
- AWD 2000 Xtreme
- 5.3 vortec with t-56
- 94-96 B-Body swap?
- Is LT1 worth using for conversion?
- 05 colorado ls1 swap
- original wiring harness or aftermarket and dbw question??
- Help with finding an engine for conversion
- is this a good price on a pulled LS1 motor?
- 2000 bird v6 to ls1 car
- 6.0 Vortec to 5 speed Trans
- Does anyone else think about swapping an ls1 into....
- For those that want a simple fuel line connection, I have a dual feed line for sale
- PCM guides (red & blue)
- ls1stangs?
- RX-7 LS1 swap
- What is the best way to build in Anti Theft?
- ls1 into 1995 325i
- Camaro V6 engine mount setup
- fabricating big bock headers to fit ls1??
- LSX engine in a SY/TY
- resources to do swap
- gauge cluster question
- ls1 w/ EDIS8 and megasquirt
- ATS and Hooker headers
- Undertaking my first conversion...
- any other dry sump options besides LS7 and ARE?
- 98 guages vs 99+
- impala ss transverse mount 5.3 size
- PCM Outputs - High or Low?
- Mercedes Rear Steer for LS6 exhaust
- Oil level, coolant level, and cruise control questions...
- PCM pin removal
- Rolled the 69 out of the Garage Today
- Have you swapped an LS1 into an 02+ S10?
- 6.0 into '79 El Camino
- ls1 into lt1 z28 body?
- New Brake System recommendations
- 95/98 ls1 video finally has NOS
- My LS1 wiring harness.
- ls1 in my s10?
- 6.0 in Chvelle 71 question
- inline pump question
- Wire harness conversion Q's
- new header choice
- Limits of a 5.3L iron block? (LM7)
- A chronological history of my 3rd gen Trans AM LS1
- ls1 fuel line question.
- EVAP removal
- Picking up LS2 for 69 Camaro 2DAY :):):):):):)
- ls1 240sx S14 chasis?
- C4 vette conversion....cheapest a c4 can be had for?
- ls1 mix and match???
- little wire help please
- 3rd gen guys?
- First LS7 conversion track results!!!
- MAF location question
- LS1 fuel rail adapter..???
- C4 Corvette LSX Headers
- T56 Crossmember for a First Gen Camaro
- solid mounts versus flexible
- Transmission mounting
- how to mate 93-97 4l60e to to 98 motor
- Relays for EFI conversions
- fabricating own motor mounts for ls1 in 56 chevy
- LSX into a 56 chevy
- headers that are compatible with ls1
- LS1 in a CRX
- merging 62 vette wiring w/ LS1 harness
- ls1 and turbo 400??
- Fuel evaporation system?
- Something new - Ford Probe!
- 357ti is finished
- Speartech Phone # ???
- will 01 camaro radiator fit in a 68
- Crank Spacers and Extended Pilot Bearings
- Noob here: What V8 in Z3 coupe
- LS1/T56 in 93+ RX7... Costs? Parts needed? Difficulties?
- BMW E36 LS1 VS C6 Corvette and Ferrari F40
- Ls1 Instructions
- LS6 Heater lines - wich one to heater first??
- Reversing the Intake Manifold
- 69 camaro whats it worth?
- LS1 mini cooper update (pics)
- can i put a ls1 in a mustang body and keep fuel injection?
- Ls2 stang times
- Passenger side altenator
- Egr
- Engine cutting out on idle
- Hooking up to a third gen tranny?
- Wiring diagram for LS2 ignition coils?
- supercharged in V6 body
- Starter Question
- truck vs F-body oil pan?
- LT1 Jeep conversion
- Truck/Vette/F-Body Accessories ?
- Drive By Wire Setup ???
- LS1 swap into my 3rd gen issues
- need recommendation for aluminum rad in 1st gen camaro
- 98-02 v6 to LS1 questions
- 3rd gen ls1/t56 motor mounts
- Auto Meter Elec. Speedo / 6 Speed Questions
- install of a LS1 into a 68 camaro - Oil pan measurements? any other tips?
- One of the nicest conversion/hybrids I have ever seen....
- Remote door locks
- Can I do this?
- Computer Questions
- 1940 Dodge w/ Chevy small block - update (pics)
- 98 Silverado swap. Need help
- C5 dash in a C4 vette?
- 4l80e swap info
- "Speartech Type of Guy" for V8 Benz harness?
- Can we get a weight list?
