View Full Version : Conversions & Swaps
- Rev & choking out
- Corvette fuel rail and filter #s?
- why mods with gas tank with 56??
- What a difference 4 degrees makes!
- Fuel pump - External or Internal - Pros, Cons??
- aha, another silverado conversion....with a twist
- TVR packing LS6 Rubber burning Launch
- O2 Sensors.....Identification
- Flywheel movement
- some updates/a ? on wheels
- LSx into 93-97 F bod
- 240SX V8 Help
- start and stall ls1
- is anything interchangeable between an old 350 and an ls1?
- What sizes are the actual LS1 starter bolts?
- 3/8 Fuel line fitting
- 1975 450 Sl Convertable W/350 Ho Cid
- Wrecked 2006 Z06 Corvette
- SBC in a fiat?
- 5.3 swap questions
- ls1 into a 54 chevy pickup won't start
- 69 Camaro Rear Shocks Question
- iroc with 98+ interior??? triing to find member
- LS1 For 67 Malibu
- What's a car i can put an LS1 into that's cheap on insurance?
- anyone converted to drive-by-cable have pedal assembly for sale?
- Need a complete LS1 for your swap?
- 68 firebird ls1 t56 swap help
- O2 Sensor
- LS2 Z28 track results
- Took the 5.3L third gen out for a spin, spin, spin
- 6.0 in a 96-98 ?
- 95 v6 bird..new project, new questions!
- LS1 into a 79' Corvette?
- my camaro pics
- 2000 C5 auto Dash wiring harness
- Torque Arm mount Bolt size
- ? rims for '67 corvette hybrid
- PCM pin output voltage issue, could the PCM be bad?
- 62 Chevy II Project
- 470hp LQ9 from turn key engines?
- No spark or inj pulse. LS1 Volvo Wagon.
- New Project
- Lifting points
- oil pan plug
- Transmission Bolt Size
- Will this knacker my engine?
- Tanks Inc kit?
- LS2 57 Chevy
- Anyone know how to install this tube nut?
- Truck intake manifolds
- John Bzdel is famous in "Pro-Touring Street Machines" book....
- Any write ups on 2 Gen Fbody LS1 Conversions?
- 69 Vette Power Plant
- Exhaust Flanges?
- Starter--Really?
- What radiator are you using
- Interchange - 3 plugs for the engine harness
- fuel line question
- Wiring Harness Question
- LS1/6 '88 BMW M3 daily driver
- Idea's for Air intake setup
- engine mounts ls1 into 94 camaro
- Just another LS1 2nd Gen RX7... 56k beware...
- Someone please lay it out for me. Fuel system! 68 c10 lsx motor
- 68 camaro with ls1 supercharged?
- Photos - Year One Experience 2006
- Low and high speed fans...
- LS2 280Z Exhaust done!
- Motor Mount--Really??
- mustang ls1 headers?????
- I need to make a custom plug wire
- New source for gauge adapter fittings
- Ready for a heart transplant but don't know who to give it to...?
- Starting issue no spark no fuel
- LS1 in a fox coupe
- TT LS1 in a Volvo Wagon! NEED HELP TOO!
- 69 Camaro / LS1 Rear Brake Caliper Question
- need a picture of F-body wiring harness routing on passenger side near exhaust
- 02 SS to 69 Camaro Hybrid
- cooling
- Cruise control with Drive-by-Wire issue.....
- Need some LS1 ---> SBC mount adapter plate specs
- Online parts database?
- LS1 swap in 94 z28
- Restoring a 2001 Z28, worth the trouble?
- what to keep from fc chassis
- In need of advice
- What Size Fuse With F-Body LS1 Fans?
- ford 9 inch in s13?
- putting 408 into my 93 T/A
- Well I tried starting the stang today
- different engines
- Wiring Harness info.
- LS7 engine swap in a 4x4 truck
- Need Suggestions for an alternator
- Ok spill the beans....
- Hi Flow Cats
- $ to convert LQ9 to F-body accessories?
- power steering delete
- Anyone ever build a kit car??
- Dodge Shadow swap?
- Vibration?
- 3rd Gen Guys - Need Wheel/Tire Input
- Pictures of aluminum floor, fuel tanks, and suspension
- 6.0 4L80E computer
- Clutch master cylinder??
- Thinking of selling swap parts
- Help with 95camaro engine swap
- Shopping for take-outs at salvage yards
- Headers for ls1 in 98 silverado?
- LS2 Swapped Porsche 911 Widebody. Project<Pics.
- 88-98 silverado LSx swaps? how many?
- oil pressure???
- Cold Air Tubing
- C5 vs CTSV balancer
- Anybody successfully extended their wiring harness?
- Air Intake Tubing Question
- Hyd clutch problems, v. strange. please help.
- Can a 700R4 handle 6700 rpm ?
- Standalone Harness?
- 65 Chevelle Swap pictures
- Advantage of 5.3L over 4.8L?
- t 56 conversion
- Where do you install youre oil pressure sensor?
- looking for help with TH400 transmission and NA LS1 in a 70 Nova
- 3rd Gen Tach - Strange Problem
- LS1 swap candidate car 87 Turbo II RX7
- ls1 240sx up and running and killing tires
- An introduction...And my build...
- 73 Nova
- T56 ==> C4 corvette bracket
- LS1 Dragster...why not?
- Trailblazer swap???
- Looking for a bit of help regarding C4 corvette swap...
- Making 1 out of 2
- how vss pulses on a 1988 third gen
- yup it was wrapped in plastic...
- headers/swap parts for 6.0l S-10
- FWD 383 is Finished!
- help
- What psi radiator cap for LS1 with old school radiator?
- my ls1 powered rx7 gets mini tubbed and caged
- sump oil pan infomation
- Should the starter crank the motor without a harness?
- WTB - f-body oil pan, widage tray, tube and dipstick.
- Twin Turbo Ultima GTR
- 1st gen S10ers
- need wiring help
- What will it look like with an LS1
- Eliminate the power steering pump
- Six months and she's back on the ground.
- With ZERO tuning the LS7 Monte SS rocks the dyno rollers with 487/470 RWHP/RWTQ!
- Headers on an LS1 98' Silverado
- corvette harness
- LS1 into a TT 300ZX
- Fueling the 68 c-10
- ls-1 or carburated s-10?
- 6.0l for my s-10 xtreme
- The Day Has Arrived!!! It Runs!
- How to make a 700r4 work with an LS1?
- LQ4 into C4 Vette build is getting very close to completion
- LS1-1970ElCamino-Th350-will it work?
- What year camaro is this????
- 2 Plugs I have no idea what they're for...
- LS1 & T56 in 1985 El Camino questions
- LSX into an BMW 3 series!
- T56 mount...rubber or poly
- LSX Conversion Car Websites - Post Yours Here!
- Shifters
- Wiring harness sensor wires
- LS1 in Foxbody need help radiator hose
- Taking off for Viva Las Vegas
- teaser
- Junkyard Gen II Iron vs Aluminum
- Need help.. pics included
- Ls1 Fox Body Mustang?
- TH400 into 3rd gen ls1
- The ultimate LS1 sleeper . . . .
- LED Sequential Tail Light Install Video
- 66 nova LS1
- LS1 into LT1 k-member
- T56 bolt to 8.1L 496 big block?
- Ls6 383 Powered Miata
- It is getting so close to "Fire Time"
- started detailing the ls1
- Trying to test gauge to see if it works
- LS1 booster/master to a 67 brake pedal
- t56 clutch bleeding. stumped.
- Bosch 02 sensor interchange
- Wiring upgrade for older cars pics and ideas.
- Crap
- 4.8 trans am.
- what to buy?
- Chevelle Fuel Tank
- LS1 Stroker FWD - Tuners Beware!
- G-Body LS7 swap complete and running!!!
- Viper T56 to 99' LS1
- Air intake.... Who is interested?
- LSx into my 65 Vette
- LS1 S10 pro-street project for sale
- C5 PCM same as F body PCM?
- Need picture of IAC Valve
- 8.1L 496 pass emissions for 5.7L TBI?
- IROC Camaro finished pics
- Need help wiring pop-up headlights
- F-body motor mounts.....
- catch can for pcv -oil in intake
- possible conversion
- Normal Idle speed?
- VATS Removal?
- Want to swap 3.8 to 5.7.....
- ls1/t56 combined shipping weight
- Ready to start but.....Help!
- Throttle Position Controller
- 4th gen harness labeling?
- LS2 Throttlebody
- What to put it in???
- Fuel Pump pressure test and other ?
- EFI Sensor Suppliers
- Truck 5.3 HP question
- LS1 master question
- 3rdgen LS1 Swap, Engine not running on all 8...
- twin turbo headers and downpipes are done!! ...
- Lt1 T56 Onto Ls1???
- ls1 into 96 s10 blazer 4x4
- LS1 Chevelle Induction
- Converter Louckup/Unlock?
- Auto to Manual trans harness
- Going into a 79 camaro
- Source for LS1 information?
- kit car assembler
- First Gen Hooker Mounts with t56??
- Toyota Corolla GTS
- gm guide
- S&P mounts positioning
- '68 Lincoln Continental + LQ4/4L80E
- Wiring question pertaining to old voltage regulator.
- A/C Question
- looking to do something diferrent
- Anyone ever delt with these bozos
- Carburated 6.0L swap
- front sump oil pan
- Cold Air Filter
- LS1 chevelle headers
- LS1 Converted Chevy Silverado
- GTO windage tray w/F-Body oil pan?
- Wiring Question
- For those of you who have done the V6 to LS1 swap..
- A/c condensor
