- eating up alternators???
- my explorer turbo sport
- Ls swap a/c questions
- how do i make my factory sending unit work with high pis EFI
- Fuse block location with hydraulic clutch
- Help wanted with Cooling Fan relay/wiring issues
- 95 BMW M3 Katech LS3 swap
- Need help identifying a cut connector on LQ9 harness
- Anyone doing a LS swap into a 1978-1981 G-Body?
- LSX hats, shirts, decals & other gear
- 4.8 Build Suggestions - 5.0, stout, boost ready?
- what spring rate on aje kit should i get?
- temp gauge ?
- Best ls swap
- Porsche 914 LS1
- Anyone taken a truck PS pump apart?
- Help! Start-up; am I ready?
- Shop in California to do LS Firebird Conversion
- 6l80e swap in Thirdgen Camaro
- minimum exhaust manifold clearance?
- Running on 4 or 5...
- 68 a-body ls swap going smooth
- ls swap list question
- 2003 Toyota Tacoma LM7 Swap Todo/Source List
- 2003 Toyota Tacoma LM7 Swap Build Thread
- Intake Manifold Difference?
- '84 Cutlass JY5.3 Tick Stage 2 Cam S400SX4-75 4L80e -10.0 Index Build
- NSS Wire ??'s
- Oil Pan Clearance
- 95 v6 camaro 5.3 swap
- Anyone done an SSR on a TB-AWD chassis?
- LS Swap- Sanden & Denso AC Relocation Brackets...
- help.. program problems now will not run.
- Grinding down grove on motor mount
- Ignition (Spark Plug) Wires - LS2 + Stainless works Headers
- Yoke U joint size. Camaro t56 + Corvette 69
- ZR2 with an LS1
- Charles Ridinger SCAM alert. Builds LS harness and never ships
- corvette c5 or camaro(ls1)
- Converting to 'Vette filter with return-style rail
- LS2/T56 into 69 camaro
- The 79Malibu Video is Finished
- Difference between Corvette, Camaro, and Truck Accessory drives
- Rotating the intake on an LS1
- bought the PSI f body cluster pigtail but....
- Ls1 c4 swap
- Water/Dust Proof Fuseblock Housing- Need Your Suggestions...
- pinto rack turning radius? pic request
- Vortec Engine Cover (top/cover/lid/what-do-you-call-it) Question...
- 02 vette ps pump + 71 camaro gear box, what hose?
- Fox and SN95 ECU Mounting
- wiring autometer gauges
- 99 mustang 5.3 t-56 swap
- Horsing around today in my L33 5.3 swap turbo xtreme... ---> Video's inside
- engine slow to rev
- Possible 03' Ram 1500 swap--->Need help on wiring.
- radiator fan wiring with a/c on c10
- 52 Studebaker Truck - Studevette
- Will LS9 fit under stock '62 Corvette hood?
- 1968 camaro 4.8 swap help please
- Carb problem
- anyone with digital dash display?
- 84 cutlass with lq9 and 4l60e
- Cross member for A-body
- 1972 Nova SS - 5.3 Swap
- What are you G-Body guys doing for driveshafts?
- 5.3 swap coolant in oil
- ls1 gas tank swap
- LQ4/T56 70 Chevelle Cam Specs?
- HELP!! 5.3 obs silverado starts than dies
- 89 Iroc-Z 6.0 LS swap
- Can HP tuners change needed vss input signal?
- Components needed for LS style ignition system
- Choosing a LSX for a 75 Pontiac Grandville?
- Which radiator hoses for A Body cars
- Need help!! 93 foxbody coupe lq9 swap
- Vararam on a Chevelle
- Help hooking up a 5.3 power steering pump to Mustang rack and pinion
- Supplying Power and Ground to PCM
- 72 chevelle factory wire elimination
- Merv's 1984 Monte Carlo Super Sport
- 88 mustang 6.0/tc78 start up video
- Just got an LS1 - Harness question
- 93 foxbody coupe lsx swap!! need all the help I can get please!!
- Needing help with ls1 swap to a 94 v6 mustang
- Need help with removing column shifter
- Alternator styles used
- Auto parts store plastic tank radiators ?
- crazy alternator wiring issue
- '70 Chevelle LQ4 swap....severe headache!
- power steering 71 c10 lsx
- Wiring In A/C Recognition Circuit
- Mass Air placement
- 1998 Trans Am temp sensor resistance to work with original 1970 gage
- lq4 in 71 Camaro; will truck intake clear hood?
- Marine Engine Development
- Hot Rod Hydraulics master cylinder bracket
- 96 Miata, LS1 T56 conversion build thread
- '48 Diamond T/LQ4, FIXED!!!
- Edelbrock ignition box
- G8 L76 vs G6 ECM
- Crankshaft spacer question
- '89 Caprice - fuel tank for conversion
- ls1 g body build
- 5.3 in a 1966 F100
- Need some opinions!
- Anyone in the Sacramento area want to share ideas or work with our swaps?
- JCG Customer Builds
- 5.3 Swap-Older Style Brake Booster-How to Hook Up???
- Ls1 swap into thirdgen, need advice
- Bmw e30 m3 ls1/6spd
- 3 fuel lines WTH?
- "Public Enemy" 1968 Camaro Build
- Few new videos of my Turbo 5.3 Blazer
- Cold air intake help 67 A-body
- Junk Yard - Craigslist 5.3L
- ls3 two-wire alternator hooked to ls1 single wire plug on engine harness???
- LS1/E36 BMW, lowering engine, need headers I can mode if I must
- Land rover defender - ls3 engine, manual trans & transfer case
- What is this?
- what size bit and tap?
- MSD 6LS-2 failure
- 5.3 240sx build questions
- Has anyone installed a lsx 376 in f body.?
- 93 coupe LS2 swap
- 2001 silverado fule pump question
- Mustang guys step in
- Ls3 swap what trans
- Air Inlet Temps are High
- C4 Corvette T56 ls1 adapter bracket
- Diamond T project, 6.0 runs poorly, MAF low input code, placement of MAF an issue?
- 57 vette on craigs
- just fired my 66 vette...ls1/2004r
- TPI Fuel Pump
- 5.3 INSTALLATION IN 72' CHEVELLE 'help'
- wiring LSx help/DIY Harness
- k5 5.3 swap
- Charcoal Canister ?
- 3rd gen fbody conversion parts
- 240sx ls1 Problem...shift hard and car holds constant
- New to LS1 Tech
- LQ4/t56 Fox Question
- LS1 vs SRT-10 vs something else ? Drifting
- 2001 Porsche C4 LS2 conversion w/RH kit (project)
- GMPP harness instructions
- V8 swap 2 seater ideas
- Wont start?
- ???VATS deleted car ran all last year now dies after 3 seconds???
- BUDGET (and I mean BUDGET!!!) 5.3 into 1970 Buick Electra
- need ideas transmission cooler location ?
- Modern AC fittings for your old lines
- LS swap in a 57 vette
- Fuel System
- Aftermarket Dash/Lights Harness for Fox?
- A nice write up on LS swapped 3rd Gen's that we somehow sneaked into.
- V12 LS1 Build
- 5.3 Vortec- Temp Sensor Wire Cut Off by Accident - HELP!
- Trying to decide on exhaust. Borla muffler options.
- ls swap wiring.
- 2011 HSV clubsport LS3 conversion
- 94 Firebird Engine Swap
- Rebuilt L92 question
- ECM Ground
- 89 Formula - Speedo
- S10 swap question? Please post pics
- TT SN95 365 with a 6spd
- Water pump question
- Another Alternator Wiring Question - Confusing (Yes I Searched)
- fuel lines
- What years 6.0 to go with?
- Bump steer correctment steering arm ends?
- V6 to LSx Conversion
- '67-'69 Camaro T56 Crossmember
- T56 + original 81 corvette driveshaft
- 96 impala ss 5.3 swap
- Rockland LT1 to LS1 t-56 kit
- 5.3 into 94 Chevy truck. Help with wiring options and 4l60e control?
- 5.7 to 6.0
- 2004 6.0 build sugestions
- mustang headers
- Any JK Jeep owners here with LSx engine swaps?
- LSx In a chevelle - sacrilegious?
- Dumb question about GTO oil pan swap
- Finally starting my build 1966 lemans
- Coolant leak
- Microsquirt Harness Layout Vid
- 95 mustang TT L92 4L80e
- 04 vette ls1 in 68 camaro
- Do I need a bigger alternator?
- Help in Oklahoma
- 1 wire vs 2 wire oil pressure sending unit
- Which fuse panel to use from this LQ4 dropout?
- 1995 z28 ls1 swap from 2002 pontiac trans am ws6 doner car
- vats disable box?
- 97 vert TA full ls1 conversion
- 2010+ Camaro Caliper and Rotor setup on a early A-body
- Brain Storming Twin Engine Truck Concept
- 5.3 "truck" computer/harness powering "car" engine?
- Solid Motor Mounts being a nightmare for install?
- Ls1 vs lt1 fbody gas pedal
- question on mating engine to transmission
- Fc rx7 won't start
- Buying my 5.3, what to avoid?
- Cracked or ratty set of LSx heads needed in NJ near Philly
- Fuel System Question
- New Option for Fox Body LS Swap Headers
- Exhaust is pretty close to fuel tank
- Blue Monte Carlo 5.3 Swap
- water pump and accesory advice needed for lq4 swap
- Can I swap a '94 lt1 subframe from a TA with a '01 v6 camaros?
- I need one piece to finish my motor swap
- New to forum, diving into a Fox LS build
- LSX with turbo... California loove.
- fox wiring questions again
- terrible squeal on startup
- Anyone willing to share their base HP Tuners "LS1 Swap" tune with me??
- 68 chevelle ls swap
- 1975 C10 LS swap questions
- Project El Salvador - 72' Chevelle Build Thread
- C10\LQ4 swap still f'n up
- 78 LS1 TA build
- 1997 Camaro Owner Here
- another 570sx build and swap
- LS1/4L60E, 1964 Impala swap to date: Lots of pictures!
- shipping engines
- Fox guys..what did you do for drive shaft?
- Straight thermostat housing found
- o2 sensor wiring help
- Convert 99 C5 DBW to DBC
- C5 LS Swap DBW to DBC
- losing injector pulse
- Ls1 swap fuel lines
- Clutch choice for LS2/T56
- What does it take to put a carb on a l92
- recommendations on cam upgrade on 5.3
- LSX into fox body opinions
- bottom mount ac comp. in Chris Alston subframe
- CTS - LS1 swap?
- 04+ harness with 01 PCM and engine
- 1967 Camaro Power Steering
- Advice on picking the right engine. Experienced swappers
- 1964 rambler 660 5.3 4l80 twin s300s
- has anyone done an ls1 in a dodge magnum wagon
- LT1 radiator in a Mustang
- ls1/lt1 wiring
- Power steering pumps ls1
- 15 volts at idle - GM 1 wire
- whats needed to swap a 6.0 into my 98 z71
- 68 c10 shortbed 2004 5.3l/4l60e DBw swap
