- Front ride height going from all iron to aluminum motor
- GF822 fitting size
- carb conversion kit
- Paddle Shifter Options?
- Cam Options Cutlass 6.0 Swap Questions
- chevette???
- Missing anything?
- gmc s15 lq4 swap
- 5.3 will not run part 2
- how to remove (external) snap rings on the Slip Yoke without damaging them?
- List of questions: 69 A-body Brake conversion
- c6 corvette swap ?
- adapter for a t56 to old style speedo
- Gen III Electronic Pedal on a Gen IV?
- Ls7 exhaust manifolds modified to fit narrow chassis
- LS1/4l60E 67 Pontiac Tempest
- Keep the DBW or convert to DBC?
- Time to de-pin my swap
- Ls harness questions
- all performing 5.3/4l60e
- 3rd Gen Camaro LSX swap LOTS OF PIX(going to take a little bit)
- 1950/2001 chevy truck
- What Tranny Fittings?
- 1970 GTO LS1/4L60e Swap Check List - Do I Have Everything Covered??
- Need help with my Trans Am
- Getting Cruse Control to work with a 6L80/L92
- 1982 Corvette??
- SN95 LS Swap Headers
- wiring tachometer
- Which race harness for LS7 and AEM Series 2 ECU?
- Quick-Mod on how to mount a 11" Brake Booster into a LQ4 A-Body
- 98-02 Camaro Motor Mount Bolts
- Project 600zilla - LS2+T56 350z swap
- Has anyone used the factory center console gauges on a 69 Camaro conversion?
- Grinding ribs on a GTO oil pan for clearance???
- ls-1 oil sending unit cinverision
- is it possible???
- Wrx
- Psi website updated!!!!!
- 2010 Camaro Exhaust Manifolds
- looking for fuse box wiring diagram for 99 z28
- Need some input
- LS1/T56 in third gen
- ly6 engine start/run wiring
- another Lsx mustang
- LS starter fitment to BB Bellhousing
- ls1 miata race car build.
- Dynatech LSx Mustang swap headers
- 1988 chev pickup speedometer
- ls1 s10
- 6.0 In 71 Chevelle, Pulley Q's
- 97 ls swap have some questions
- Wiring LSX!!! how-to VIDEO INSIDE!!!<----
- Need help with harness
- Ctsv 6 spd auto help
- Advice needed.installing vvt ly6 6l80 in a hot rod.
- 5.3 or 4.8? cant tell
- Wich headers for LS1 BMW conversion ?
- 1998 LS1 C230 pin H? Th350 ??? to.
- What model LSX (size & year) is best for a BBody.
- LS1 / T56 DD e28 BMW Build
- conversion question
- Working on my wiring harness I have a couple of questions.
- Danny's Miata. Self Built Badassery
- Want to build a LS notchback...where do i start?
- Swap question
- Air Conditioning Bracket # 10118751 -Truck Engine
- 2001 s10 2.2 flex/auto to V8 ls/t56
- S10 guys inside
- 86 cutlass need help with LS1
- LQ4 PowerSteering Pump Fitting Size
- 92 coupe with ls1 fast 102 235/239 pat g tune
- Help with 64 Impala 5.3 Swap !!
- 5.3 will not run!
- 99-2000 truck dbc bracket wanted
- Fuel System Limits
- fox body which oil pan?
- conversion with 700r4 question
- Help with fuel line...
- LQ9 to replace my LT1
- New clutch, what size?
- SLP MAF question
- Trans Bell Bolt pattern
- 5.3 swap in a 55 chevy
- DBW to DBC conversion?
- Bug+ls1 ?
- Part out or sell without motor/trans?
- Got a Cooling issue.... need some opinions.
- 86 k!0 swap.
- LS1 swap
- does this look normal?
- Drain in a radiator hose??
- Plastic Fuel Line???
- Truck dipstick replacement for 5.3 ?
- LS powered early Bronco
- Build thread...LS1 / T56 into 1975 Corvette convertible
- Has anyone ordered an GM oil pan?
- Need pinout for f body fuel pump bulkhead connector
- 5.3 power steering pump ?/Oil filler neck
- Starting my 5.3L Vortec conversion (need advice)
- Mustang and AJE users come in please
- Jaguar Xj V12
- Need a Transmission segment swap
- Just got my 1772 miles 79 malibu ALL original time capsule
- F.s , ls / foxbody alumimun driveshaft
- totalled my z
- LT1 to LS1 fuel question
- Wrong water pump??
- Difference between 78 a body and 82 g body?
- 01 firebird motor swap?
- Strange SES behaviour
- Pontiac GTO hood tach and HP tuners "tach output" setting
- 98 Firebird Disk brakes on 67 Camaro
- Engine placement
- LS1 to t5 questions...I searched
- 05 BMW with TT LSX
- newschool72 build pics....DONE !
- Help Electronic Throttle pedal not working
- Not LS related, worlds smallest V12 engine.
- 6.0L harness and pcm
- 69 camaro ls1 swap a/c, th400 and oil pan questions
- DBW Pedal Bracket & Placement
- noobie clutch question
- 92 F swap. Odometer not working
- 88 Mazda RX7 TII LS1/T56
- conversion mount/plates
- driveshaft questions
- ECM location?
- Tach Hookup
- A-body swaps ... Are you happy?
- 1986 Caprice Coupe LS Swap
- Fox body Mustang/4L60E Drive shaft Options
- Inches of vacuum from a 2006 LS2?
- common question....engine swap to LSX
- Anyone ran reversed passenger manifold on e36 driver side?
- ABS Sensor as VSS Source?
- BBK LSx swap headers
- Corvette accessory drive
- Parts question gentlemen???
- Why does everybody recommend converting to drive by cable?
- how much to do 6.0 swap in my coupe?
- Best drag radial for LS6 Cobra kit car
- Ls1 in notch!
- ls1 to 5.3 swap
- Mating an old SBC Manual trans to LS engine?
- GTO Gauge Module ABS Fault
- LH8/GM Muscle Pan, Holley oil pan, windage tray and bolts question.
- 3rd gen auto to manual question
- 71 Chevelle+LY6+T56,
- Best "Roll Race" Speed/MPH? NON-locking Rear End [Stock LQ4/4L80E 1965 Chevelle]
- MAF Harness Extension (how to?)
- using LS1 harness on 5.3 questions
- ls to 700 questions
- TSP 233/239 in a lq4
- 3.8l pinout?
- For anyone interested in Speedhut gauges
- Individual Connector Pinout
- '62 Nova with LS1 finished
- Anyone install a F-body console in a Foxbody?
- LS-1 use in Airplanes
- please HELP my install 4l80e on ls1
- Fyi
- donor ls1/4l60/pcm/harness into 2nd gen TA questions
- Parts needed for long block
- Not another 240sx build...
- LM7 vs LQ4 in C3 Vette
- My turbo 4.8l 87 IROC build
- Project Ugly Betty LQ4 with a 4L60E into a 1966 Mustang
- Wiring thoughts on powering pcm relay or no
- Can you do away with the vinyl roofs?
- Notchback LS1/A4 swap question
- S&P MAF & Fresh Air Intake
- Are there any tried and true Chevelle LSx Header/Mount combinations?
- TEA243s on LY6?
- BMW E46 converted to LS1 - Wich gearbox ?
- 5.3 swaped into an 84 ae86 corolla
- LSX Questions
- Ls3 376/480hp swap
- anyone familiar with 2005+ grand cherokee computers?
- Tarus fan size
- fuel sender with built in pump for 68 camaro
- Is there a site with parts diagrams w/part numbers?
- 4.8 c/10
- What mufflers do i use????
- I need your input on a single exhuast design, please.
- Exhaust Manifolds
- LS1 radiatior in 69 GTO
- Stand Alone Transmission Controller
- Trans Question-94 vette m6
- Jeep YJ with a 5.3 needs Air Conditioning need suggestions.
- 78 camaro lsx swap
- Budget Carb Vs. Budget EFI
- L33 help for swap into Porsche 944
- what wiring harness to go with for ls swap?
- 4.8 to 4l60E questions
- What exhaust manifold for a 65 chevelle
- what diff ratio??
- Anyone use Chevy Thunder harnesses for their swap
- dbw to cable driven?
- 95 z28 ls swap ?'s
- LS1 Swap Candidate?
- wiring harness help needed
- Fox body guys, anyone running a TH350?
- Kooks vs. Dynatech in Fox body swap..
- 1978 911SC Targa LSX Swap
- Those with a PSI coneversion harness, have a question
- LS Swap Questions
- 65 Nova Wagon Ignition
- The Most Tucked LSX Manifolds that I have seen
- recommened fuel pressure
- el camaro LS1 t-56
- 2.2 swap into a Vega
- Cam recommendations wanted for LS1
- ok thinking of using a 8.1 here
- Painting an LS1?
- 5.3 shortblock differances??
- c3 lsx side pipes
- finally it's alive
- Best lsx foxbody swap kit? Opinons welcomed!
- New Edge Mustang LS1
- Just purchased motor and Trans for my swap
- what size AN is the factory power steering hose on a LQ4? can i cut it and...
- drive shaft length question
- LS4 in a '00-'04 monte?
- Lexus SC300 6.0/T56 swap first start up
- Time for another build...2001 Miata L33 w/t56 conversion
- Neat new product at SEMA
- Camaro/G8 and CTS-V and or bad angle trans yoke options for swaps
- Mid 90s truck swaps
- C6 header fit a foxbody?
- 1981 Second Gen Camaro Berlinetta BUDGET build
- LS1 Conversion, what is this pin?!?!
- LS3 Crate into a 93-97 F-Body
- Are 5.3L & 6.0L exhaust manifolds the same?
- How many miles is the LS good for?
- Need G-body frame notch pics
- anyone have a fluttering issue at idle with autometer tach?
- Ls into a colorado
- 5.3/4.8 fuse block question
- Diesel Trans Am?
- scored a chevelle
- Are oilpressure release valves universal between sumps
- LQ4-Mustang....Alternator/Starter Wiring??
- Where to source relay sockets and connectors
- What should get the LS1 80 Camaro or 70 Chevelle
- Do iron brocks brake at the mount?
- LS1 Turbo 240sx All Done *vids and pics*
- Need some help with my 02 Denali. Simple DBW stuff
- steering too soft !
- info on converson
