View Full Version : Conversions & Hybrids
  1. Advice needed.installing vvt ly6 6l80 in a hot rod.
  2. 5.3 or 4.8? cant tell
  3. Wich headers for LS1 BMW conversion ?
  4. 1998 LS1 C230 pin H? Th350 ??? to.
  5. What model LSX (size & year) is best for a BBody.
  6. LS1 / T56 DD e28 BMW Build
  7. conversion question
  8. Working on my wiring harness I have a couple of questions.
  9. Danny's Miata. Self Built Badassery
  10. Want to build a LS notchback...where do i start?
  11. Swap question
  12. Air Conditioning Bracket # 10118751 -Truck Engine
  13. 2001 s10 2.2 flex/auto to V8 ls/t56
  14. S10 guys inside
  15. 86 cutlass need help with LS1
  16. LQ4 PowerSteering Pump Fitting Size
  17. 92 coupe with ls1 fast 102 235/239 pat g tune
  18. Help with 64 Impala 5.3 Swap !!
  19. 5.3 will not run!
  20. 99-2000 truck dbc bracket wanted
  21. Fuel System Limits
  22. fox body which oil pan?
  23. conversion with 700r4 question
  24. Help with fuel line...
  25. LQ9 to replace my LT1
  26. New clutch, what size?
  27. SLP MAF question
  28. Trans Bell Bolt pattern
  29. 5.3 swap in a 55 chevy
  30. DBW to DBC conversion?
  31. Bug+ls1 ?
  32. Part out or sell without motor/trans?
  33. Got a Cooling issue.... need some opinions.
  34. 86 k!0 swap.
  35. LS1 swap
  36. does this look normal?
  37. Drain in a radiator hose??
  38. Plastic Fuel Line???
  39. Truck dipstick replacement for 5.3 ?
  40. LS powered early Bronco
  41. Build thread...LS1 / T56 into 1975 Corvette convertible
  42. Has anyone ordered an GM oil pan?
  43. Need pinout for f body fuel pump bulkhead connector
  44. 5.3 power steering pump ?/Oil filler neck
  45. Starting my 5.3L Vortec conversion (need advice)
  46. Mustang and AJE users come in please
  47. Jaguar Xj V12
  48. Need a Transmission segment swap
  49. Just got my 1772 miles 79 malibu ALL original time capsule
  50. F.s , ls / foxbody alumimun driveshaft
  51. totalled my z
  52. LT1 to LS1 fuel question
  53. Wrong water pump??
  54. Difference between 78 a body and 82 g body?
  55. 01 firebird motor swap?
  56. Strange SES behaviour
  57. Pontiac GTO hood tach and HP tuners "tach output" setting
  58. 98 Firebird Disk brakes on 67 Camaro
  59. Engine placement
  60. LS1 to t5 questions...I searched
  61. 05 BMW with TT LSX
  62. newschool72 build pics....DONE !
  63. Help Electronic Throttle pedal not working
  64. Not LS related, worlds smallest V12 engine.
  65. 6.0L harness and pcm
  66. 69 camaro ls1 swap a/c, th400 and oil pan questions
  67. DBW Pedal Bracket & Placement
  68. noobie clutch question
  69. 92 F swap. Odometer not working
  70. 88 Mazda RX7 TII LS1/T56
  71. conversion mount/plates
  72. driveshaft questions
  73. ECM location?
  74. Tach Hookup
  75. A-body swaps ... Are you happy?
  76. 1986 Caprice Coupe LS Swap
  77. Fox body Mustang/4L60E Drive shaft Options
  78. Inches of vacuum from a 2006 LS2?
  79. common question....engine swap to LSX
  80. Anyone ran reversed passenger manifold on e36 driver side?
  81. ABS Sensor as VSS Source?
  82. BBK LSx swap headers
  83. Corvette accessory drive
  84. Parts question gentlemen???
  85. Why does everybody recommend converting to drive by cable?
  86. how much to do 6.0 swap in my coupe?
  87. Best drag radial for LS6 Cobra kit car
  88. Ls1 in notch!
  89. ls1 to 5.3 swap
  90. Mating an old SBC Manual trans to LS engine?
  91. GTO Gauge Module ABS Fault
  92. LH8/GM Muscle Pan, Holley oil pan, windage tray and bolts question.
  93. 3rd gen auto to manual question
  94. 71 Chevelle+LY6+T56,
  95. Best "Roll Race" Speed/MPH? NON-locking Rear End [Stock LQ4/4L80E 1965 Chevelle]
  96. MAF Harness Extension (how to?)
  97. using LS1 harness on 5.3 questions
  98. ls to 700 questions
  99. TSP 233/239 in a lq4
  100. 3.8l pinout?
  101. For anyone interested in Speedhut gauges
  102. Individual Connector Pinout
  103. '62 Nova with LS1 finished
  104. Anyone install a F-body console in a Foxbody?
  105. LS-1 use in Airplanes
  106. please HELP my install 4l80e on ls1
  107. Fyi
  108. donor ls1/4l60/pcm/harness into 2nd gen TA questions
  109. Parts needed for long block
  110. Not another 240sx build...
  111. LM7 vs LQ4 in C3 Vette
  112. My turbo 4.8l 87 IROC build
  113. Project Ugly Betty LQ4 with a 4L60E into a 1966 Mustang
  114. Wiring thoughts on powering pcm relay or no
  115. Can you do away with the vinyl roofs?
  116. Notchback LS1/A4 swap question
  117. S&P MAF & Fresh Air Intake
  118. Are there any tried and true Chevelle LSx Header/Mount combinations?
  119. TEA243s on LY6?
  120. BMW E46 converted to LS1 - Wich gearbox ?
  121. 5.3 swaped into an 84 ae86 corolla
  122. LSX Questions
  123. Ls3 376/480hp swap
  124. anyone familiar with 2005+ grand cherokee computers?
  125. Tarus fan size
  126. fuel sender with built in pump for 68 camaro
  127. Is there a site with parts diagrams w/part numbers?
  128. 4.8 c/10
  129. What mufflers do i use????
  130. I need your input on a single exhuast design, please.
  131. Exhaust Manifolds
  132. LS1 radiatior in 69 GTO
  133. Stand Alone Transmission Controller
  134. Trans Question-94 vette m6
  135. Jeep YJ with a 5.3 needs Air Conditioning need suggestions.
  136. 78 camaro lsx swap
  137. Budget Carb Vs. Budget EFI
  138. L33 help for swap into Porsche 944
  139. what wiring harness to go with for ls swap?
  140. 4.8 to 4l60E questions
  141. What exhaust manifold for a 65 chevelle
  142. what diff ratio??
  143. Anyone use Chevy Thunder harnesses for their swap
  144. dbw to cable driven?
  145. 95 z28 ls swap ?'s
  146. LS1 Swap Candidate?
  147. wiring harness help needed
  148. Fox body guys, anyone running a TH350?
  149. Kooks vs. Dynatech in Fox body swap..
  150. 1978 911SC Targa LSX Swap
  151. Those with a PSI coneversion harness, have a question
  152. LS Swap Questions
  153. 65 Nova Wagon Ignition
  154. The Most Tucked LSX Manifolds that I have seen
  155. recommened fuel pressure
  156. el camaro LS1 t-56
  157. 2.2 swap into a Vega
  158. Cam recommendations wanted for LS1
  159. ok thinking of using a 8.1 here
  160. Painting an LS1?
  161. 5.3 shortblock differances??
  162. c3 lsx side pipes
  163. finally it's alive
  164. Best lsx foxbody swap kit? Opinons welcomed!
  165. New Edge Mustang LS1
  166. Just purchased motor and Trans for my swap
  167. what size AN is the factory power steering hose on a LQ4? can i cut it and...
  168. drive shaft length question
  169. LS4 in a '00-'04 monte?
  170. Lexus SC300 6.0/T56 swap first start up
  171. Time for another build...2001 Miata L33 w/t56 conversion
  172. Neat new product at SEMA
  173. Camaro/G8 and CTS-V and or bad angle trans yoke options for swaps
  174. Mid 90s truck swaps
  175. C6 header fit a foxbody?
  176. 1981 Second Gen Camaro Berlinetta BUDGET build
  177. LS1 Conversion, what is this pin?!?!
  178. LS3 Crate into a 93-97 F-Body
  179. Are 5.3L & 6.0L exhaust manifolds the same?
  180. How many miles is the LS good for?
  181. Need G-body frame notch pics
  182. anyone have a fluttering issue at idle with autometer tach?
  183. Ls into a colorado
  184. 5.3/4.8 fuse block question
  185. Diesel Trans Am?
  186. scored a chevelle
  187. Are oilpressure release valves universal between sumps
  188. LQ4-Mustang....Alternator/Starter Wiring??
  189. Where to source relay sockets and connectors
  190. What should get the LS1 80 Camaro or 70 Chevelle
  191. Do iron brocks brake at the mount?
  192. LS1 Turbo 240sx All Done *vids and pics*
  193. Need some help with my 02 Denali. Simple DBW stuff
  194. steering too soft !
  195. info on converson
  196. What car should receive the LS1?
  197. s-10 underhood fuse box?
  198. Source for a full GM vehicle schematic?
  199. Headers & catback
  200. BMW X5 wiring diagrams??
  201. Exhaust question
  202. Motor Swap??
  203. Opinion's needed!!!
  204. 5.7 LS1 Wiring Harness Question. Does the year 98-02 matter?
  205. ac bracket
  206. looking for: pictures of a specific 68-72 GTO
  207. 2nd gen F body with Tick adj M/C??
  208. I have a performance goal...should I go Turbo or N/A?
  209. LS into a-body...header/manifold recommendations
  210. vega lsx info.
  211. LQ4 in a 1965 Chevelle - What stock exh. manifolds fit?
  212. camaro dash in a gbody
  213. LS3 in 67 Camaro
  214. THREAD UPDATED!! 87 Chevy Silverado short bed 5.3 vortec,4L60e trans swap
  215. what gear to run?
  216. 89 camaro lh6 swap questions..
  217. Corvette accessories?????
  218. LQ4 water temp gauge problem 98 TA
  219. Ls1 1989 Iroc No power steering?
  220. Neutral Safety Switch
  221. 1969 camaro Pillar post
  222. Fuel Mileage, Reliability, for a Buick A-Body
  223. Need a smaller PS pulley - What donor vehicle?
  224. Help! 5.3 into a 71 Chevelle...
  225. X-body Nova LSx questions related to truck engine
  226. 5.3 into 96 2 Door Tahoe light resto
  227. 1967 Camaro Ls1/t56 Next Stage- Poor Mans DIY 3 Link Rear Suspension
  228. project barn find ls2/magnacharger
  229. Camaro Front Accessories parts list (99-02)
  230. L92 into BMW E46 questions
  231. a/c compressor in a Fox Mustang with swaybar. With pics!
  232. Opinions on 1 5/8 long tubes on a LS1
  233. DBW vs DBC...does it matter which one?
  234. 66 GTO Convertable 6spd
  235. LQ9 PS Pump with Delphi 600 Box
  236. LQ9 IDENT fast!
  237. lsx chevelle conversion Q?
  238. Speedo Quit working.
  239. Harness ?'s...
  240. Any header/midpipe that bolts up to Mustang cat back?
  241. I have a couple LSX questions...
  242. Planning LS2 into 68 Camaro. Comments welcome!
  243. DBW in my boat?!?
  244. LQ9 swap with 4l80e Trans help
  245. 4l60E & Dakota Digital gauges
  246. LQ4 oxygen sensor plug
  247. V6 to V8 swap,both cars are 99
  248. Does mileage matter....5.3 for Turbo project
  249. Advice needed for 350z ls1 project
  250. Turbo LSX Powered Fox Body
