- EPS Cammed LQ9 in Christine ...Many Videos inside.
- Is their a way to verify miles on a LS2?
- Tvr Ls1, pcm clicking on cranking
- LS1 miata race video - battle with MazdaGT
- 4l65 bellhousing what happened?
- Lokar Trans Dipstick ?
- Pink wires and orange wire question
- DBW only getting 70% tps in 68 nova?????
- LS2 G35 Dyno Numbers In
- 5.3 into a 1st gen s10 project questions
- A Body Chevelle Oil Pan Problems Solved
- Strange Coolent issues Please give info.
- Harness testing, what on engine gets ingn voltage.
- first gen firewall hole
- '67 Z21 Camaro 5.3L/4L60e Implant
- PCM Capabilities
- 89 lx mustang going 5.3 then turbo.. .
- DIY Cold air intake
- 66 Impala Convert LS2 Conversion
- 05 LH6 in a 91 S-10
- Can't find pcm
- Ls6 RPM won't go past 3500
- *** Important info for those going to run a Super Victor carb intake P/N 28097 ***
- Using the engine fuse/relay box
- starter relay is grounded
- Ls1 in a Nissan 240sx?
- 6.0 in 99 mustang
- ls style motor plate??
- LS1 vs. LS3 intake manifold bolt patterns
- LS2 swap\computer question...
- 5.3 vs LS1 alternator wiring?
- Conversions and Hybrids welcome at LSX Shootout
- hickup / hesitation
- New Conversion--81 TA
- pcm and harness help (Will this work with my setup?)
- Lt1 fuel pump and 4.8 vortec
- nylon fuel line
- LY6 cam swap. Dont need to pull heads??
- What crossmember for 4l60e in a second gen?
- o2 sensor
- LS3 Fuse Box Hook-Up
- LT1 Fbody to LS1 Fbody Conversion Motor Mounts
- l92 malibu 10 seconds
- 01 Firebird cmad v6 to LS1/80e swap completed
- Alternator wiring help :[
- v6-v8 NBS Silverado
- lq4 truck harness questions
- Need wiring harness recommendation.
- shifter cable for ls 60e 95 stang
- radiator hose help stock 69 camaro
- ls1 swap headers
- ford power steering pump on 95 F bod?
- Need 1 3/4" 304 stainless LS1 header flange
- ecu switched power/ecu ground
- DBW Cruise on a Mustang? Factory cruise buttons? Anyone done it?
- Move coolant temp sensor
- A-body guys with T-56 and remote bleeders in here
- Rev limiter wont change
- Having a DBW issue, could use some help.
- Big Inch LQ9 Stroker ?s
- F body pulleys help
- Mr. Sixtoes1313 having some fun...
- A body LS1 hooker headers
- who's car is this?
- New Member Needing Opinions
- LQ4 70 Firebird conversion questions
- found a shitty "camero"
- Filling dry 03 LQ9 with coolant
- Swap to f-body accessories
- 2005 gto wiring schematic?
- 1952 studebaker commander swap oppinions
- Header build for LSX in Chassis car
- Anybody sell a PCM extension harness?
- BMW e39 540i LQ4/T56 swap project
- Any A-bodies using BRP 3/4 length headers? Opinion?
- Project: "Barter Build" (96 Silverado)
- exhaust issues, suggestions needed
- LH6 5.3 build experiences
- cons of a 98 ls1 computer?
- Can I do this?
- G-body oil pan
- CBR's 64 Nova Wagon
- Mustang T56 Guys..... What rear gears are you running?
- Mustang guys with AJE K-member
- Can I do this?
- LH8 Oil Pan machined for Bypass Valve
- Fuel return
- Trans / clutch noise during deceleration !? 01 c5 z06 ls6 swap 93 mazda rx7 fd
- lq9 swap 02 ceta!
- lt1 F-body swap question
- foxbody auto trans swaps
- Fox guys with lsx ,i have a ? about aje mounts
- Can A Crank Pulley Be Put On Too Far?
- 2006 GTO LS2 w/4 speed auto in 87 Buick GN
- Clutch Chatter issues
- 4x4 6l90 into 2wd?
- LQ9 Cast Iron Block with H3 Pan which dipstick
- LY6 Conversion - ECM/TCM/DBW Pedal Question
- Thinking about a 370z...
- Fitting for power brakes part number 12559760
- Cheapest Vette fuel regulator I've seen $15
- 2010 LS3 and TR6060 in a 68 Camaro
- F/BODY accessories with LY6 timing cover,VVT
- Project Emmy Lives!!! 1968 Bel Air Wagon L92/6L80E
- 93 LX Mustang 4cyl to LQ4 swap questions
- LS1 F body brakes on a Chevelle or other older car?
- Functional Ram Air Hood....Nova
- 72 Chevelle with LS-1 411
- Starter /crank rpm question for hi compression 408
- LQ4/4l80e/241c in my 88 Grand Wagoneer
- cammed 5.3 in 87 camaro. Take off issues
- Turbo 400 to LQ4?
- Tach signal help.
- g-body swap info needed
- Mustang dynatech vs kooks
- LQ4 into my 68 Chevelle build
- Car porn alert: 'Orange Crush' - New LS6 w/ TVS Magna Charger
- 81 vette LY6/6peed build. need lots of help!!
- Possible engline swaps
- Lsx iroc z
- 2000 Fbody charging woes!
- Motor starts and then dies? Sounds like VATS, but....
- 2006 Pontiac GTO LS2 w/4 speed automatic in 1987 Buick GN
- Does E40 ECM need to control cranking?
- LS1 in my 79
- s-10 radiator and condenser???
- Need help from y'all Chevelle swappers
- 67 Impala ss 6.0 swap
- Carb to FI Swap, already LS
- Chevelle/GTO/Cutlass with B-body EFI tank questions in progress
- 1968 ss camaro procharged LS2 m6
- 4.8 Vortec - radiator, MAF questions
- Flex plate confusion
- Boosted ls1 240sx pcm power question
- Flywheel spacer for early 80E TQ on 6L80 flexplate?
- Power Steering Question
- 67 camaro/ls2 headers clear clutch z bar?
- 2010 ls3 stock exhaust manifolds - pic request
- lq4 guage cluster swap?
- Help! LS1 swap complete but car vibrates
- 6.0 S10 Blazer died and wont start!
- GlowShift Elite 10 in my Ls1 Buggy
- Can dbw be converted to cable driven?
- Modern AC in Chevelle
- BMR K-member problems
- 1976 nova ss (4th gen)
- 1984 chevy pick up dual tank
- can any oil pan be swapped onto a 03 5.3L?
- Fuel pressure regulator to plug fuel damper hole
- Throttle body question
- Anyone running upr a arms on there aje k member?
- LSX Noob needs install direction
- Help me identify these plugs
- Need advise on which LS set up to use on 67 C10
- 2008 2500 6.0 with 823 heads. 81 vette swap!
- a/c wiring question
- Ls1 cluster
- flywheel and spacer
- Fan does not come on with the a/c
- 2001 camaro v6 convert to ls1 swap questions
- 1998-2002 Fuel tank fitting
- c101 connector, extra wiring
- Good price for 6.0L/T56 pullout combo?
- 1970 Chevelle LS1 Conversion
- S-10 potential project question.............
- Question!! engine code and hp rating!!!!
- Chassisworks Mounts - Which Headers?
- walbro pumps
- Car won't turn over
- 5.3 for e30 bmw swap
- LS1 swap intermittent hard start / rough idle
- can an ls1 radiator cool a turbo lq4?
- 99 olds intrigue 5.3 abs with trac control
- ECM/harness recomendations for LY6 needed
- newschool72 vid
- 2004 LQ4 VSS diagnosis
- Has anyone done an SN95 with an LSx?
- Engine Swap 5.7L to 6.0 L
- Issue with starter after swap in 76 Camaro
- LS1 mustang w/a TH400, no VSS & won't idle?
- 1996 camaro 3800 engine harness removal??
- LQ4 carbed swap questions
- 3.4 to 5.3
- what parts are needed for a ls1 or lsx swap into a foxbody
- Fuel Injector connection ????
- motor swap options
- Project "White Lightning"
- G-body steering box - Truck Power steering
- lq9 fuel injectors + aftermarket rail
- LS Conversion
- LQ-4, T-56 S-10 build
- 81 Malibu Budget 5.3 swap!!
- LQ4 Oil pressure problems!!
- Having trouble starting new motor
- 46 Ford Pickup, S10 Chassis, Air Ride, 99 LS1
- accessory belt question
- How do I wire this 02 connector/alternator wiring ??
- LS1 350z Drift Build 'Nuff Said'
- Psi launches new website www.psiconversion.com
- Just a thought, curious if it will work.
- 5.3/auto swap has hesitation..dbw ?
- A/C Guru Question...?
- Sensor delete/fuse double check
- fuel system question need to hear from the experts
- LS Motor radiator question
- LQ4 Horsepower Question!!
- LS6 Cobra swap Speedo and Tach hookup tips
- 1967 Camaro + 2006 GTO LS2 + Autometer Tach: How do I hook up my Tach????
- Can a TPI Ecu & MegaSquirt II run a LS engine??
- Cable TB cruise question
- Border Patrol Buggy
- LQ/ LS Swap Guide: 47-54 Chevy Trucks
- 1959 GMC Fleetside Truck
- I need some LS SCHOOLING!!
- pcv help !!
- OBD II Connector with light
- Need help for installing th350 to ls1
- Vette C4 dana 36 & 44 or viper dana 44 rear end traction?
- Spectre Tank Help Please!
- e38 standalone, starts and dies after 2 seconds max
- Radiator Hose Help (a body) w/ 99 camaro radiator
- Is their a way just to run an alternator?
- LS 376/480 information
- Help with initial ECU programming
- Miata swapper
- LSX in a '68 Javelin
- Mustang Clutch Master Location???
- LSX in '93 Silverado
- LS1 amp question
- CTS-V vs fbody accessories
- I got a rear gear question
- just starting with my swap
- 1995 4.8/4l60e project
- 81 malibu ls1
- LSx nova project
- OBD2 port and tuning issues
- Any experienced welders out there? I need some help.
- Help! Video- Car idles and revs but not in gear
- 93 firebird xmember?
- 07+ Van Engines
- Fuel/temp gauges inop
- 94 s10 LSx swap accessory drive
- LS1 Miata Swap...
- 88 Annav. TII RX-7 Ls1 swao
- 1998 F body fuel pump in lt1 car?
- 3rd gen fbody ls ac compressor
- lq4, fbody pan what all has to be swapped?
- ProCharger LSX Transplant kit for sale - ALL brackets, LS9 cam, injectors,
- No start and need help on swap
