View Full Version : Conversions & Hybrids
  1. Help with oil pan selection 1968 ls1 camaro
  2. Help me figure out this crap harness
  3. Hooker 8501HKR Headers?
  4. Swapping a L31 to a LM7
  5. ls options
  6. 55 Fairlane Dilemma
  7. 1965 Pontiac Lemans 4 door 5.3l/4L60E Build Thread
  8. Help: Need ideas
  9. No Rangers, no Mazda B2/3000 LS swaps?
  10. '71 C10, LS swap in the works
  11. 5.3/4L80E into fox body Mustang, trans cross member??
  12. 4.8 truck intake in lt1 to vortec swap?
  13. New here have questions about a serpentine set up for 6.0l
  14. Taurus elec fan
  15. LS2 with LS3 heads valve clearence question
  16. Drive by wire vs 200 4r , my solution
  17. Old School Small Block into 4th gen
  18. Need recomendation for harness rewire in OC
  19. NewB 1980 Caprice Coupe
  20. need this part if anyone has an extra one.
  21. ls1 240sx s14 harness help
  22. Questions regarding a bone stock 5.3 swap into a 90 k1500
  23. Anyone Cut trunk for access panel to in-tank fuel pump? If so, Please post pictures.
  24. wiring inj2
  25. Short Block swap
  26. t56 tailshaft speedo housing mod
  27. zr1 colorado
  28. Best A Body axle and gear set brand
  29. planning a project - lotus 7/locost
  30. Problems finding A/C fittings
  31. 4l60 question
  32. Anyone have engine bay pics of a 68-74 Nova with an LSX?
  33. Dakota Digital VHX gauges into ls1/4l60e Chevelle
  34. Question for mustang th400 guys
  35. Cooling a blown 1000hp motor. Opinions??
  36. 71 Nova LQ9 MS3 holley hp swap
  37. 78 280z 5.3 T56
  38. Wiring Harness Help
  39. 08 5.3L swap into 86 sierra
  40. 6.0 mustang
  41. Stumble/miss at part throttle/cruise
  42. shock part number locator?
  43. Anyone Interested in a Ironblock?
  44. LS1 Rear brakes installed into 2nd Gen - Shock relocation NOT needed.
  45. LS2 Miata CAI Opinions Wanted
  46. 5.3/6.0 in 1987 chevy suburban 3/4 ton questions
  47. LS1 Swap into 72 Camaro- Help!
  48. 1980 Trans am future LSX swap
  49. New to the LS, in a Malibu...
  50. Developing LS conversion headers for 1st gen F-body
  51. Sticky About Accessories?
  52. 350z ls1 swap problems
  53. 1972 el camino ls1 swap
  54. Two LS Swapped Mazdas :) (RX8 GT1 Build)
  55. 05 5.3 into a 95 blazer 2 door need help
  56. driveshaft measurment??
  57. lsx in a 59 el camino
  58. 1965 impala into the 11's?
  59. 82 C10 5.3/4L60E Swap
  60. HELP! Where do I post about a 5.3 swap?
  61. 93 Sonoma swap
  62. Swap question....?????
  63. Modified fox steering shaft
  64. Project 79 ls bu begains...
  65. No oil pressure :(
  66. Need help with a swap :)
  67. LSX coils
  68. Foxbody swap
  69. wire harness
  70. One Member's "New" harness woes, PIC HEAVY
  71. LS 2 6 pin TB to 8 pin harness
  72. the best motor mount adapter plates for ls1 swap for 67 chevelle?
  73. Flywheel spacer issue
  74. 99 tahoe 4l60e
  75. Headers for a 1996 SN95 Mustang
  76. short style alternator ?
  77. 63 Nova build Ls1 A4
  78. Easy harness question? What to do with this connector to fuse box?
  79. LS Mustang transmission?
  80. Using an Express van harness
  81. corvette alternator in a 99 camaro
  82. corvette front drive alternator placement issue
  83. any smallish fuel sending units that send out same signal as f bodys?
  84. 5.3 to 350 trans ???
  85. track times from totally (or fairly) stock Fox swaps?
  86. what causes gas pedal to die out? gen IV lsx
  87. Truck waterpump converted to F-body.
  88. stangtraders 93 turbo ls6 notch build
  89. 5.3 swap in s10
  90. Ls1 swapped 240sx, no fuel or spark. Any Help???
  91. Matching the Components
  92. Electric power steering pump options
  93. LS3 Camaro Manifold vs. Hooker Cast Iron
  94. 66 nova stock front end ls1
  95. Fox Header question.
  96. 99 suburban k1500 ls swap help
  97. LS motor and tranny swap into muscle car
  98. GEN4 to GEN3 help
  99. 78 Nova 5.3/m?
  100. Vetteworks LS1 Fuel pump assembly tank modification 2nd Gen Fbody Write-up
  101. chevy clamshell mount ???
  102. Don Nguyen | Driving the Passion - BMW E36 M3 V8
  103. Ls1/4l60e swap into a 1981 Corvette
  104. anyone tried running the alternator with the 4 rib belt? fbody setup
  105. Help finding solenoid plug for newer starter
  106. Speedway Motors TruRam LS1 manifolds - I can't find any installed pictures
  107. pic request: fox body LSx swap headers
  108. Trailblazer SS LS2/4L70E AWD Swap into 1984 C4 Corvette 4+3
  109. '95 Camaro LS swap...I tried to tell ya I was doin it
  110. Ls2 emissions delete?
  111. 1" setback plates ???
  112. 5.3 in my little 'ol S10
  113. Truck oil pan ???
  114. LQ4 Starter Wiring
  115. Ls1 swap
  116. S13 240sx
  117. Fan on with key and not by temp?
  118. 1997 Ford Crown Victoria LX, Turbocharged 6.0L Swap - Grandma's Bingo Cruiser
  119. 92 camaro conversion.
  120. Lq4 swap 98 c1500 RCSB stock gauge wiring
  121. help foxbody swap: headlights power/fuel
  122. fbody dbw to dbc
  123. 92 TA with Magnacharged LS1: Dyno Results
  124. Got some issues with my Muncie to LS kit. Need some help!
  125. Tach problems
  126. swap 5.3 in s10
  127. 5.3 wiring
  128. Out with the old...in with the older, 89 GT foxbody build
  129. Help Needed - Clutch Fabrication Issue
  130. LSA into gen III 'maro
  131. 1966 Ford Thunderbird "Grand Touring Bird" Project
  132. Mike's 53 Chevy Bel Air build
  133. LS powered 65 Impala
  134. Smallest LS1 alternator?
  135. Won't run with MAF plugged in
  136. 03 6.0 fuse box conector pinout.
  137. LS1/LS2 in Hyundai Genesis Coupe
  138. Can I mount the A/C compressor there?
  139. Need donor vehicle advice
  140. TV Kickdown Cable Adapter for LS Swap...
  141. 5.3 turbo temp reads high
  142. anyone have an extra autokraft oil pan
  143. Vac Lines for LS in '69 Camaro
  144. 4l70e or 4l80e for my 6.0 Chevelle swap
  145. S2000 Build - LS1 - T56 - 8.8 - Turbo
  146. OBD II Error
  147. 78 Skylark Lq4/4l80e
  148. 2012 5.3 out of Tahoe engine code 0 lmg fit 08 silverado 5.3 lh6 if I
  149. BUDGET Custom Console, Digital Gauges, GPS Via Android Tablet.
  150. Using Truck Accessories
  151. pcm tune for pin 34 questions 4l60
  152. Need 4L60E wiring help
  153. Relocating throttle body?
  154. Questions on R34 Skyline Turbo 5.3 swap Nissan people please help!!!
  155. Speedhut
  156. LQ4/L92 cam
  157. Can 0411 pcm handle future growth plans and Gen IV (or V?!) motors?
  158. 75 Camaro getting LS1/T56 need advice
  159. exhaust manifold specs? list? 40 ford 5.3 install
  160. need 99-04 5.3 swap info
  161. Home brew budget nylon fuel line tool
  162. Plug wires that work with Doug's headers?
  163. PVC Part numbers?
  164. Clutch petal stop to prevent non-adjustable master cylinders? What did you do?
  165. Turbo foxbody intercooler question
  166. Donor truck or parts?
  167. questions on boost
  168. will an 04 GTO computer work on 99 f-body motor
  169. 4L60E pnp switch
  170. Will a Ford shifter work a TH400?
  171. Thank you LS1Tech It's finally on the road
  172. yet another Mustang coupe LSx swap!
  173. G-body swap **having issues**
  174. Short Starter Body / Mini Starter
  175. Fox Body Swap with Stock K member
  176. ls1 conversion for 66 impala info req,d
  177. My 1968 Camaro LQ9/4L60E build
  178. 1977 Oldsmobile Cutlass Sedan (6.0 4l80E)
  179. Throwout bearing LS2/Lakewood/NV4500?
  180. 04 mach 1 ls swap
  181. BMW e34 Touring LS1 swap (BMW 5 series wagon)
  182. MicroSquirt Harness Mess
  183. 5.3 Alternator with LS1 accessories?
  184. autometer. gauges
  185. LS3 into a STOCK 63 CORVETTE FRAME QUESTION
  186. LT1 to LS1 trans am front end conversion help needed!!
  187. 6.0L LQ4 core price???
  188. need ls1 ecm pin number
  189. New 6.0 coupe build
  190. Swap Question?!?!?
  191. LS1 3rd gen headers. Anybody use these?
  192. 08 Yukon BCM pin out
  193. Planning for upcoming project. Some parts questions...
  194. 70 camaro ls or lq4 build?? Im new to this stuff
  195. 5.3 swap cold start problem
  196. is this a good start?
  197. FUEL LINES: Nylon vs. Stainless braided vs. Hardlline
  198. L92 and 6L80e
  199. Questions about which 4.8L (LR4/LY2) should I swap into my 1989 Toyota Landcruiser?
  200. V6 to LS3 Swap
  201. ls fox motor mounts
  202. LQ4/T56/HX55 Turbo Into 1986 El Camino...
  203. th350 ls1 problem.
  204. Another LS swap
  205. too much radiator or too many fans?
  206. mustang swap throttle cable
  207. Alternator Wiring Issue...need help
  208. Tanks Inc pump module work in stock 57 Nomad tank?
  209. HELP - Any manifolds or shorties that "kick out" more than 2010 Camaro?
  210. LS3 Chevelle thread - Oz Style
  211. Header Hang-down- 69 Camaro- Dougs vs Dynatech
  212. Need help finding exhaust components online
  213. 2000 540i GMW LS1 6 speed
  214. programmer for a 70 chevelle lq4/t56
  215. 5.3 swap VATS question
  216. Ls6 vacuum
  217. MAF Sensor Interchangeable???
  218. Front spring recommendations for GM A body
  219. Oil pan mystery
  220. what do with the stock engine harness with a LS1 powered '73 Camaro?
  221. Engine mounts won't line up
  222. Youngest to do LS swap?
  223. Well, I'm starting to take the plunge
  224. My slow and steady lt1 to lq4 swap
  225. 93 camaro V6 swap to 2000 LS1
  226. corvette filter fitting leak
  227. Radiator Hose Question - Radiator Swap
  228. Fuse Box Design
  229. LS1/T56 1971 Firebird Project
  230. It's Time. Custom LS2 in 1972 Chevelle.
  231. Anybody that's into early Novas
  232. Don Nguyen | My Porsche 911 V8 Build
  233. 66 Catalina GEN IV 5.3/Muncie
  234. 6.0L LQ4 w/L92's & 4L80e in 1970 Buick GSX
  235. Drilling LS2 water pump?
  236. Project ls swap c10 *update post 48*
  237. getting a factory 69 tach work with a ls1?
  238. LS2 into FC RX7: Power steering elimination?
  239. 94s10 v8 swap?
  240. LSx w/ TH400 into 1967 Tempest – Complete Parts List
  241. Holley Hi-Ram intake mani on LSX S-10
  242. Transforming a tired Nova
  243. 5.3 mustang swap wiring issues
  244. Fox body swap
  245. 5.3 swap
  246. PNP NSBU Switch 4L80E
  247. t56 shifter issue
  248. 6.0L oil question.
  249. 1966 Mustang LS1/Powerglide
  250. turbo 5.3 build in a 67 camaro motor mount question.
