View Full Version : Conversions & Hybrids
  1. any one running a BRP kit on 1st gen f-body?
  2. Your Build Thread May Be Lost or Damaged
  3. ls1 __ ls3 questions
  4. 5.3 swap info needed please
  5. z bar clearence...
  6. 4l60e help
  7. Electric fan SES help?
  8. 98 LS1 Wiring Harness - Alternator Exciter wire what should the voltage be.
  9. air temp sensor
  10. 69GTO/LQ9-4L60E project update.
  11. LS senaor locations
  12. LS1 Brakes vs. GTO brakes for an A-Body
  13. How to Modify Spectra EFI tanks to prevent fuel starvation?
  14. 5.3 headache
  15. Starting the LM7 / volvo 245 wagon swap
  16. ls1 into a c1 vette
  17. Deleting the GBCM, 2007 5.3
  18. LSX In 91 C4 Corvette My Swap
  19. 1973 vs. 1974+ 2nd Gen Camaro
  20. oil pan ?
  21. 82 Fox Body 5.3 swap
  22. 5.3 throttle body help
  23. Plug identifications
  24. HELP!!! 98 pcm and harness into 00 fbody. gauge issues.
  25. A body LS swap
  26. 68 camaro ls swap need help help help
  27. CT525 Circle Track Controller
  28. Inovative Gauge Option
  29. S14 240sx ls1 harness ?'s
  30. ls1 ps pump too much pressure for IROC box?
  31. V6 Silverado 5.3 Swap
  32. 4L60E TCC lockup switch control?
  33. 85 Chevy Truck with 390ci iron stroker
  34. LS6 powered 240z charging problem
  35. LS6 in 79 Trans Am question
  36. 95 s10 lq9
  37. best header fit and ground clearance?
  38. 1995 s10 5.3/t56 swap
  39. Project M - AKA Emmy - 1968 Bel Air Wagon
  40. LSX/4l60 in 97 Z???
  41. Corvette pump, fox body gt rack HELP
  42. Trans PIN out for 99-02 F-body PCM/Harness
  43. LS1 into a 1984 K10 Chevy truck.
  44. fuse block/relay
  45. Oil prelube new engine
  46. FAST-style sheet metal intake?
  47. Ls1 swap harness info
  48. 1995 camaro ls1 swap ?'s
  49. Best priced t56
  50. me confuzzed
  51. Quick relay question.... Double check Removed Pins PLZ..
  52. ly6 flywheel help
  53. P1336 DTC Necessity?
  54. 5.3 Alt / PS Bracket & Tensioner P/N's
  55. Aftermarket Harness - Oil Level Sensor - Oil Pan
  56. Which injector plug do LQ9's come with
  57. ls into a 95
  58. 65 chevelle ls2 turbo dyno finally
  59. ordering my ls 1st gen f-body swap parts this week,suggestions please ?
  60. Intermittent DBW problem
  61. corvette regulator users
  62. What to do what to do.....
  63. Anybody want to fab me a 72 A-Body 4L60e Transmission Crossmember
  64. buying a used engine what to check?
  65. crossmember modification- need your input
  66. steering shaft trouble after AJE kmember install
  67. '48 Diamond T pickup with 6.0/4l60E IS ALIVE!!
  68. fuel system Questions?
  69. My cam choices for 2010 6.0L VVT L96--watcha think?
  70. eddiecate me on harnesses!
  71. Help! Need pinout for '04 Vette harness with blue green PCM.
  72. L96 flexfuel injectors--do I need to swap out?
  73. "intake hoses" on LS2
  74. Tick adj Clutch MC--ok to point down?
  75. BMW 840ci with LS Engine
  76. Th350 kickdown cable for ls1 swap??
  77. Putting 99 L S1 in my camaro, what do I need?
  78. Putting 99 L S1 in my camaro, what do I need?
  79. 65 Nova 4L60E transmission crossmember
  80. Chevelle Wagon is on the road
  81. MSD Fuel pump kit from Speedway, Anybody use it?
  82. 71 nova ls1 t56 cam only
  83. e38 ecm out of what vehicle?
  84. Drive by wire throttle question
  85. Another LT1 departure, going turbo LM7
  86. twin lq4's in formula
  87. Green pin 59? Crank Voltage? Needed or not?
  88. C6 LS2 manifold flanges?
  89. Ls1/t56 clutch issues need help
  90. Aftermarket AC w/GMPP Corvette Accessories?
  91. Stock LQ4 water pump with dual pass rad
  92. doing ls1 swap and need help.
  93. ls to old style manual trans...flywheel?
  94. ls1 into lt1 car
  95. My 86 cutlass 5.3 build trend....slowly but shorely
  96. LS7 Syclone
  97. first time with swaped 7 at the track
  98. ls2 cam choice?
  99. 67 Firebird w/ BRP engine kit and Unisteer steering kit, any problems?
  100. did i do something wrong?
  101. carbed 5.3 upgrades?
  102. filter prior to fuel rail
  103. 3rd Gen swap. Wiring harness?
  104. LS-1 steam pipe
  105. Swapping GTO engines - help sought
  106. 2002 v6 camaro swap
  107. Headers A-Body
  108. "SSAWD" Project Camaro
  109. fuel tank welding
  110. speedway high mount brackets
  111. 1987 Iroc-Z LS1 conversion
  112. fuel flow/pressure question
  113. Red/Blue Oil Pick-up tube O-Ring??
  114. 5.3 ECM to LS1 intake & harness compatability
  115. 03 truck alternator..what voltage regulator do i need for one wire setup?
  116. gas filler tube mod
  117. 74 Nova LS swap questions
  118. CTS-V mani's-01 Camaro A.I.R relocation?
  119. LS7....in a Prius!
  120. Project: LS197
  121. caprice gas tank
  122. What are my MAF options for L96/LY6?
  123. I need a wiring harness for my LQ4 swap ***SpearTech.com WTF?
  124. what plug is this?
  125. Car Built For Mileage - need input
  126. headers
  127. My 83 Chevy Pickup conversion - a few questions
  128. 69 camaro ls install kit
  129. Need info on toyota truck lsx swap
  130. Running on 5 cylinders 1,7 and 8 aren't firing
  131. anybody use Kooks G8 mid length header/cat combo in a-body?
  132. '61 LeSabre LS3/6L80E
  133. Can VATS be disabled on the late production E38 ECM's?
  134. 67 LS1 Nova to 73 L92/TKO 600 Camaro swap
  135. 93 coupe 6.0 swap need to knows lol
  136. Best way to swap a 240sx?
  137. Radiator cap
  138. Dlc?
  139. 07 toyota x runner ls1 swap!!!
  140. PCM tray?
  141. LS engine with early transmission
  142. 89 Sierra RCSB 6.0
  143. '98 Nissan 240sx from Florida.
  144. Truck throttle body... sensors needed?
  145. 04 LQ4 to th350
  146. Wiring harness plugs and cant find their home.
  147. LS2 Syclone (finished)
  148. Couple ls questions
  149. pcm connector disassembly
  150. anybody have ls4 pinouts or wiring schematics?
  151. Injectors not pulsing
  152. How do I set my fuel system up?
  153. Alternator wiring - diagnosis?
  154. Gen I S-10 Blazers
  155. SBC accessories on LS motors?
  156. 5.3l into 79 Chevy K10
  157. ls engine w sbc radiator?
  158. Newb here and ? about price for LS1
  159. How to decrease the power in a LS1
  160. sbc to lsx motor mount adapter
  161. 1994 s-10 turbo bucket.....
  162. front springs 1966 GTO
  163. LS in a stang
  164. F body alt bracket on a 5.3 question
  165. Foxbody mustang...which auto transmission
  166. 2001 4l80e to 2006 lq4 - crank spacer?
  167. Wiring harness placement and positioning in engine bay
  168. Exhaust pipe size ??
  169. 5.3 turbo/t56 in notchback
  170. New guy with some manifold Q's
  171. Want to see shifter placement on LS1 Foxbodies
  172. ls-1 plumbing
  173. Some Conversion Questions
  174. Edelbrock Conversion Headers No More??!!!
  175. 5.3L in 95 GMC 4x4, need advice and guidance
  176. 89 iroc 6.0L swap
  177. Where to get computer programmed?
  178. C320 Ls1 Swap questions
  179. ls-1 painted intake
  180. 5.3 or 6.0 price diff.
  181. Ly5
  182. Daft Innovations wiring harness trouble
  183. need help with lower radiator hose for g body swap!
  184. LM7 regal misfire help
  185. My project, a 1968 pontiac catalina with a C5R 427
  186. Wire harness
  187. Lm7 Hybrid engines for a conversion...
  188. Yet another 6.0 question
  189. Oil pressure Mxx to 1/8 NPT adapter? Autometer Mechanical gauge.
  190. how to pre lube a LS7 before start-up?
  191. Parts value
  192. 1987 Monte Carlo SS Aerocoupe LSX conversion
  193. Help, low oil pressure in new swap
  194. LQ9 injectors in LS6 intake
  195. question about autometer guages in a ls1 foxbody swap
  196. 5.3 in amc
  197. I made Jalopnik!
  198. 68 camaro LSX Swap fuel questions.....
  199. New mechanical speedometer drive solution
  200. Need pics, PLEASE!
  201. 65 chevelle ls3 & t56 conversion
  202. Another LSx S-10 headr option
  203. 6l80e stuck in 3rd
  204. Anyone swapped an LSx into a late model dodge ram?
  205. Throttle cable
  206. ecu question
  207. full LS1 swap on ebay?
  208. lsx swap ?
  209. 4L80 behind sbc in 66 Chevelle?
  210. Who has a Mach 1 with a LSX conversion? I need some help/recommendations.
  211. Can someone put my ls1 4l60e in my hot rod? Im in dallas,tx
  212. ls2 into 67 camaro swap questions
  213. 4x4 cam
  214. My Grand National LQ9 build
  215. LS2 engine harness 05 GTO to a O2 LS1 ??
  216. Fuel for chevelle
  217. Lq4 into 1966 Chevy c10 stepside
  218. LS carbed Fox Guys Less wires is better
  219. lsx swap in a g body
  220. Enable EGR and AIR Setting in HPTuners
  221. Need swap headers for fox body
  222. T56 Wiring harness question
  223. Cost to do an s10/ls1
  224. Looking for a Motor swap soon
  225. My wife always wanted a Cadillac !
  226. How do you measure for drive shaft length??
  227. Universal tank straps
  228. Lsx/T56 Mazda Rx8 Build Thread.. Pics inside
  229. Not sure I posted in the right section
  230. What AC Compressor to use
  231. 67 RS swap Questions
  232. using GM ls3 controller for 5.3
  233. LQ9 Mustang Coupe
  234. 427ci LS1 project Help Please!
  235. 6.0 LS truck motor in a 93 suburban???
  236. 66 chevy II nova ls1/76mm
  237. Whats inside this?
  238. 64 impala ls1 radiator question
  239. Turbo LM7 72 240z: The Quest for Power!
  240. 1967 GTO LQ4 (L92/LS3) swap
  241. What engine do I have 4.8 or 5.3
  242. 95 s10 ls1 build
  243. Anyone used GMPP Harness/Controller kit?
  244. 04 ls1 motor in 2000 z28?
  245. 5.3 swap wiring 4L60e to 88 NP241 - VSS/OSS?
  246. Engine Swap Going Wrong need pointers
  247. IAC started acting up.....
  248. Engine prelube problems w/L96 (LY6)--wrong port?
  249. 1966 Nova build??
  250. 1964 Buick Skylark T-56 crossmember
