- Junkyard engine came w/o MAF. What replacement should I get?
- Manual vs PS
- Will a LSx/4L60E fit in a 97 Ranger?
- ls powered blazer
- Oil pressure gauge ?
- ls2 wiring harness
- any 1st gen ls1 guys running autokraft pan
- PCM Fuse/Relay question or opinons ?
- 62-67 nova CBR header for stock steering
- Too many choices
- 1999 camaro pinout (HELP)
- can you use a rear O2 sensor as a front O2 sensor?
- Ls1 in my cj
- DBW Aftermarket harness???
- Broken connector on 04 GTO column
- gauges for ls conversion
- Stupid DBW, which one?
- 5.3, howell harness and a tbi truck
- Electric Fans On/Off ls1 in 68 firebird
- LH8/Muscle Car pan vs. stock truck pan
- Please help with first startup codes
- Fox body guys, need a little help.
- ?s 2nd gen F-body rearend
- Provisions for VVT in oil pan
- 79 malibu lq9
- 411 pcm pinout help
- Fox front accessories
- ls2 into a 2002 assesories drive help
- Initial startup, no O2 sensor, open loop?
- Just for Clarification
- ls into a ranger?
- Should an automatic valve body th350 manually shift normal with no vacuum source.
- LY6 throwing codes please help
- O2 sensor question
- LT1 to 6.0 w/ LS3 topend???
- Conversion running like crap. Super rich on passenger side with hot primaries?
- LT1 to LS1 fuel system???
- LS6/T56 67 Impala SS
- LS1 S14 240sx build
- Power steering pulley help please.
- Mustang hydraulic clutch conversion
- Friday Night GTG in Concord, CA
- Simplest EFI harness?
- 1976 Vega Wagon
- 2000 Camaro Ls1 into 1970 Chevelle SBC
- Interesting Header Fabrication Videos
- 5.3 with TH350, but want 4L60e
- 5.3 cam bearing replacement
- LS1 alternator wiring
- Mock up block?? Anyone use one?
- 2010 camaro manifolds for a fox swap?
- fuel regulator on vans/trucks
- Help with Powering ECU 03' 5.3 vortec
- Pre Lube tool
- Anyone running these headers on a A body?
- Drive by Wire TAC Pedals
- What would you do?
- it could be worse
- Transmission for LS1?
- How to remove ECU connector pins?
- 98 firebird with a 99 and up ecu conversion - Fuel level gauge inop
- Ls6 question
- Transmission help
- 2000 Firebird V6 to L33
- 01' camd v6 Firebird to a 01' LS1 conversion
- LS1 E46... maybe there's hope?
- Truck harness o2 wiring help.....
- LT1 to LS2(stock) to LS1 (heads and cam) to LS2(stock)... cant make up my mind!!
- oil pan questions
- Engine cover pictures
- Lets talk about chevyII headers(again)!
- Lots of ??????
- what are you 1st gen camaro/firebirds running fo oil pans
- Mounting 06 gto dbw pedal in 79 camaro?
- o2 sensor bung location on headers...
- Harness differences
- LS3 Install into 1991 Camaro
- question about headers for 82 c10 ls motor swap
- cluster help
- lsx oil pan Qs
- Chevelle steering shaft
- 5.3l cranking problem
- oil pressure sensor adapter
- Difference between ls1 and ls3
- Donor vehicles for O2 and MAP sensor? Flat or Square connectors?
- suggestions, who to use for ls1 harness in 68 camaro
- VVT Harnesses
- LQ9-Fox
- LS1 camshaft in a 5.3 LM4
- oil pressure releif valve
- Dynatech headers out of stock!?
- Is there an easy way to spot the 4L70E?
- coil covers w/truck coils/
- What crossmemeber for gto t56 in fox?
- DBW Cruise: Dummy Tail Light
- Chevelle Cowl flapper vacuum source???
- LQ9 to LS6 intake. What to do with the valve cover tubes?
- How much strain is put on the starter remote wire? (Purple 12 gauge wire)
- 2007 v6 4l60 to a 2009 5.3?
- steam vents?
- Lq4 or lq9
- Ls3 intake in a f-body throttle cable question
- they sent me the wrong cam... should i just go with it?
- LS1/T56 Fox Coupe Build Thread**Update with vid**
- LS swap personal license plates
- Cooling fan switch ??
- MSD plug wires
- 72 Chevelle - 5.3/ 4l60e/ full suspension
- Exhaust Manifold Selection
- Parts suggesion?
- What is this sensor? Pic inside
- 69 Camaro motor mount and oil pan using a t350???
- GM A-body chassis rewiring--who's done it? EASIEST kit to install?
- 2000 Chevy S10/GMC Jimmy 4x4 LSx Swap?
- 4L60E - What trans do I have here?
- Is this a DBW ?
- LS2 in 07+ 1500
- lsx into a fox body
- extending O2 sensor wires????
- Oil Pan Bolts 98 LS1?
- LS/vortec engine rebuild kit??
- ls3 injector pinout
- Missing Parts. Should I go Carb or stick with FI ?
- Fellow Dynatech foxbody swap header users, how they holding up?
- reasonably priced EFI regulator ?
- 96 Impala SS & LY6 + 4L80E
- 03 cobra theft recovery: lsx or termi swap?!?!
- Another A-body header thread
- fox stang team z k member ?'s
- New to the LS world and intimidated...
- attn: 3.8L to LS fbody swaps: Looking for v6 parts
- 81 el camino
- what starter to use 5.3 or 5.7
- Swapping A-body on C5 vette frame?
- LSx/LQx in a 97 GT?
- 1966 Mustang Ls1
- charging system
- Quick questions about engine wiring
- Best place to buy E38 ECM and Accel Pedal
- thinking about getting rid of these turbo headers..wanted to check here first
- LSX Fox TH400
- Radiator hose sizes?
- New FOX body build..
- PSI Standalone Harnesses On Sale
- Oil filter for F-body pan?
- Early mustang headers for an LSx Chevy II swap?
- 98 LS1 Intake with out return line
- wiring madness
- Driveshaft diameter
- EGR Block Off Plug
- lsx into 83 regal T-Type
- lsx in 95 firebird.
- truck intake EGR
- 4l60e or 4l80e
- de-code a LQ4
- Fox Body LS Swap Radiator
- difference between LS1 f-body and LS2 truck harness????
- what year DBW
- Fueling my car? 80 Trans Am LQ4
- Edelbrock Exhaust Division Stopped?
- LQ4/4L80E 88 Suburban Questions on VSS
- 2001 6.0 Pinouts
- P0120 P0220 P1516 P2135 Codes
- ls fox body oil pan
- Build questions
- ..:: The Flying Mattress.1964 Caddy Coupe.TT-LSx Conversion ::..
- 65 chevelle ls2 turbo, 4l80e, airride finally done
- any recomendations on a two speed pusher fan????
- AArrgh! Water--lots of water--in the oil pan of my 3k junkyard L96. What next?
- LQ4 into a 1968 chevelle question
- LS2 + east cost novi/ 87 Buick T-typ conversion, Motor is in
- Pics of coil pack relocation please!
- My History And The Building of my "LS44"
- LQ4 questions
- 6.0/5.3ls1 swap into 96 chevy Truck. worth it?
- 2000 chevy truck 4.8-ls2 swap
- any running a spectra gm32 tank in a 1st gen
- Wiring Harness from Performance Systems Integration PSI
- motor mount recommendation for 1980 Z28
- LM7 240sx
- Throttle Body Difference; What Year?
- What mods to my L96/LY6 harness should I consider before rework?
- 6.0l lq4
- 1967 camaro I need a little help
- Budget 1994 S10 L59 5.3 swap
- 2007 vortec max
- 65 Nova Wagon 5.3 help!
- need help finding out what these came off
- Transmission Question
- what do you do with the fuel tank purge....
- Carbed c2
- plugs too close to headers?
- Plug on Power Steering Pump
- Gen III harness on a Gen IV?
- LS-1 with T56
- 71 Cutlass Conv L96/T56 build in Dayton OH
- 5.3/LM7 Cam for Porsche 944
- Sensors on rear of lq4
- nova & 4l65e shift linkage
- small tube on rear of LS6 intake?
- 89 Trans Am GTA LS1 t56 swap
- ls1 intake on 5.3
- aje fox k member help...
- Where to mount the Abbott Cable X on GM A body
- intake bolts size
- Caprice tank in 72 A body....vent?
- Fox Mustang Budget Swap/ Motor Mount Questions
- Flex Fuel E85 Question
- 02 Sensor Location
- No Oil Pressure Wire on Conversion Harness!
- which o2 for 2005 6.0?
- Price on trailblazer 6.0
- 5.3 truck heads
- The New Guy
- Stock Gas Tank
- 4l80e swap question
- L76 Intake & Throttle Body GM Parts kit
- wiring f body wiper motor to univ. wiper switch
- PSi harness an O2 sensor
- Where to find 90 degree silicon elbow for throttle body
- 88 Coupe 5.3 Swap ?s
- Anyone who has instaled the 5.3L please read...
- 1992 GMC Typhoon 6.0L turbo swap running
- 10's in a 6.0 Chevelle, what's it take?
- Should a LS pump water like a old sbc?
- Need 67 Camaro turn sig METAL contact plate
- Harness and PCM $ difference
- Kooks Stainless Headers 1st Gen Camaro/ Nova
- LS headers for a 75 Corvette?
- 66 Chevy ll wagon 5.3 swap
- hooker headers and plates
- 1st gen ls swap ?
- interior harness fused circuits, what can I group together?
- Using Stock F-Body Fuel Sending Unit: Fuel Line Configuration Question
- 67 Chevelle/6.0L - building mounts/pan/headers
- Electric fuel pump with Lq4?
- ls swap fuel pump relay problem
- water pump issues
- How to tell a 5.3L, and which accessory brackets?
- Will a 1.5" cowl on a fox-body clear the truck intake?
- 2008 powertrain on a jeep, random failure
- Truck to F-Body Water pump Conversion ?
- Automatic to 6 speed swap
- converter/trans
- hooker headers
- Project 66 Hell Camino lq9/th350
- AFCO A-body swap radiator
- Headers for a 1972 Chevelle?
- 93-94 4L80E to LQ9/4 6.0 - Anyone Done This?
- Operation " Big Red One " 70 Chevelle LS3/SC
