- GMPP LSX build?
- Thanks!
- 67 cutlass conversion
- edelbrock exhaust
- stock ls1 ac compressor block? need help
- Anyone get factory Tach working?
- Truck fuel pump/sump question
- Exhaust for best power 240sx single exit??
- 5.3 in 67 Chevelle - Have questions.
- 2000 S10 with 5.3
- LS1 to TH400 trans. What flywheel to use???
- Anyone used the Unisteer rack yet on a Chevelle??
- oil cooler removal in an lq4
- e40pcm...adding t42
- Starting buying parts for my swap, a few questions.
- cs 130 conversion LS1 harness
- 1966 gto with ls-1
- oil pressure sending unit leak?
- How do i bypass unneeded circuits in PCM?
- LS1 - 700r4 torque converter HELP.
- AC Compressor Manifold Lines
- 5.3 with ls1 intake
- Need a list of ALL the Accessories and Brackets for an LQ4 - LS1 Accessory Conversion
- g-body, truck acc,no power steering
- lq4 year and wiring ?
- Fuel system
- Initial Start Up Exhaust
- 96 Impala SS Ls1 swap questions.....
- Thinner flywheel?
- Who was the guy.......
- ECM reflash and 4l80 to 4l60 wiring info?
- Any LSx 98+ S-10 turbo's out there? Looking for some pics of exhaust.
- Metri-pack assembly question
- Anybody used a Windstar radiator?
- Does anyone know the weight of a 4l80e
- New holly ls swap oil pan and swap parts
- 5.3L on the cheap what to do?
- 2004 GTO donor questions
- Wiring for 79 Camaro/LS1
- ls into a Ford E250 van
- LS1 Truck harness swap into z28 question
- Where to mount computer in 68 Camaro??
- anybody know wher I can buy the LS1 PCM Male 80 hole Connector?
- 57 Chassis C4 Corvette Front and Rear, Stage 4 + SS Kit + 32 Gallon Fuel Tank by HRJ
- Spectre Gas Tank Update: Concerning Baffle
- Fox Mustang/ LS1/ Air conditioning sway bar fitment?
- VSS question.
- ls6 intake swap
- 5.3 LM7 into 83 Coupe DeVille
- 70 c10 ls1 turbo swap pics
- engine angle and engine supports longevity
- Truck Fuel Pump question
- Dual Fans Running All the Time?????
- transmission swap question
- 71 c10 lwb turbo 5.3
- sbc mustang headers?
- Dual Electric Fans---Two Relays...Or Three Relays?
- 5.3 into a gm h-body 78 sunbird
- Just another 1988 Mustang Lx with an LSx swap
- Installing Cruise Control w/DBW
- Help! F body and X body frame stands and mounts and adapter plates
- Where to buy a 0 or extremely low mileage, complete pullout?
- Installing a Ls3 engine into a 1977 Trans Am
- rx7 build thread
- Which lines for lq4 power steering pump to third gen iroc box?
- dynatech mustang swap headers
- Tube on intake/ oil lines/(lq4/68 camaro swap questions)
- For those that have the room...$120 Twin Turbo Headers!
- 80 Trans Am 6.0 swap
- trnsmission linkage 4l65
- 99 LS1 in an Airboat. First timer help!!!
- 06 LM7 harness Generator Battery Control Module - Delete
- dont shoot!
- Project lsx 74 impala back in full effect
- where to buy carbed intake???
- 98-02 f body front brakes on first gen camaro? how?
- New Gauges? Help!!
- LS1 Swap BLOWN HEAD GASKET?
- LS2 S10 doesn't want to crank up!!!
- best oil pan for an LS1 into 70 Chevelle???
- 03 lq4 iat sensor?????
- 08 ly6 in a 2000 Sonoma
- 1969 Firebird L92 4l80 slow-build
- World's 1st LS1 Bison!
- Does anyone have an lsx Vega?
- 280z swap
- 2009 5.3&4l65 wiring... stock fuse box?
- My homebrew accesory drive
- exhaust port
- 96 4x4 5.3 swap
- Mis-Year Corvette (66).
- wiring up speartech harness
- 3rd gen ls oil pan
- 1964 Nova LS project
- Fuel regulator
- Need some help on a couple of points please
- TH200-4R To 5.3L Flexplate Clarification needed
- Best 6 speed LS combo for swap--LS3/6060 or L92/T56?
- cold air intake
- Car Craft Engine Swaps Magazine Issue
- advice anyone?
- 87 TPI Iroc,LS1 swap,PF relay wiring ? help
- LS1 fox project questions?
- ls1 harness connector part numbers
- already had return style efi system... how to plumb to lq4
- L92 Casting #'s - what's the diff?
- Throttle cable
- ls1 rad in other cars
- What power #s do you think Ill get???
- 240sx swap and c6 ls2 headers?
- Anyone here us the autokraft ls1 oilpan???
- LQ4 / LS2 weight differences...? T56 Question
- LS1 in 2004 GMC sierra
- LQ4 from a van, need a hat!!!
- Ly6 brake booster vacum
- throttle body bolts
- swapping LS1 into 88 camaro need help!!
- Please help! Oil pressure guage pegged and lots of clatter!
- 98 Camaro ls1 into Lola T70 replica
- 1985 Trans am lq4 swap questions
- 2000 firebird 5.3 swap?
- electrical problem
- F150/5.3 Vortec Fuel line help
- 93 Z28 LSX conversion w/ aftermarket gauges
- CTSV tranny conversion
- LQ9 600 lift cam -vids
- evap on intake wont clear my hood...delete??
- how do these places that sell engines get the aluminum so clean?
- Steam port -AN adapters
- 6.O twin 60s on e85 in 67 Camaro
- LS1 in a 86 K5 Blazer
- BMW PCM flashing?
- Has anyone seen an ls in a 2005+ Mustang?
- SEMA 50 state guid to car titling
- which DBW pedal for foxbody
- what do i need from a doner 99 silverado
- 73 caprice vert getting ls6
- Fox body guys, what oil pan?
- just starting my lq4 TT build in my 67 camaro
- 68 camaro ls3/t 56 header question....
- ls3 chevelle runs, need help with the codes
- fuel pump relay remote wire 12v or ground
- foxbody rack n pinion
- lq4 in 68 camaro.
- cadillac 1987 - 1999 4.8 Vortec
- LQ4 in my Jeep, now throttle problems
- I need some help with a fuse/relay block
- What does it take to get the Corvette accessorie dress on an LY6 w/VVT?
- center link bumping pan
- dynatech o2 bungs?
- TCC stop lamp switch and brake torque converter switch
- S&P 68 camaro modded oil pan?do u use windage tray??
- 5.3 starter on 6.0
- Spun Cats Question
- Ford Probe Turbo 4.8L :)
- Alternator/battery light on Camaro alternator
- Tried search, need help
- LQ4 top-end build help in 69 camaro
- Going rate for low mile LS2 and 6speed?
- 6.0 carbed 4eye with 4l60
- Best Affordable Parts for conversion
- flex fuel swap but don't want flex fuel.
- Just got 618 Hawk balancer tool
- 4.8 or 5.3 for gas millage
- Newer 6speed console in 2nd gen f-body?
- LS6 or LS2, cannot decide...
- Crank but no start!
- wtb stand alone harness ls1
- BBC headers w/ lsx flanges?
- LS3 into LT1 questions?
- A-Body Upper and Lower Radiator Hose Part Numbers?
- Ebay SS Shorty Headers - Crap?
- project identity crisis
- lr4 vs lm7... how do i tell what is what
- 4L80 swap
- Turbo 4.6 bird
- need help ls1 in 1st gen camaro
- Same temp sending unit for fan and gauge?
- Where to get FBW throttle body?
- Help! What trans to use?!? 5.3l carbd engine.
- What is everyone using for a lower radiator hose on LS-Fox body swap w/4th gen rad?
- cast 1255135 what motor
- What master cylinder and proportioning valve for LS1 F-body brakes?
- 69 GTO gearbox/ LS1 Alternator clearance problems
- VVT rev limiter from comp cams
- 5.3 LS1 SWAP A/C and Cruise working?
- Conversion resources questions
- LQ4 injectors w/ .600 lift
- No TOSS signal to PCM?
- Reasonably priced large injector to use in truck rail/manifold?
- What mods should I have done on my ECU/PCM?
- whats a 2003 zo6 engine worth
- Injectors?- pcm ?
- I need an aluminum 5100cc LS
- 69 GTO 5.3 4l60 swap
- REPOST: Need a little help...
- Avenger GT 12 ls1
- BCM/Security Question
- 81 camaro project
- hlep please
- Need help-Electrical and throttle questions on LS3 in 2006 Lotus
- Vacuum nipple on end of IM by MAP sensor
- Donor 99 camaro to 63 impala
- thread pitch on stock lq4 manifold flanges
- 2000 Jaguar S-Type 4.0
- 2003 C5 complete dropout swap
- Magazine feature on stands today of my car
- TH400 gurus, school a ford guy.
- Drive by Wire conversion....
- Anyone with a LQ4 swap dyno the car stock
- VSS Question/98 harness and computer
- Rear O2 sensor ???????
- LS1 with Muncie M20 in Chevelle??
- LS3 into a 2010 Silverado 5.3
- Vehicles that will clear truck acc and intake under the hood?
- Does someone know if DOD will work with manual trans?
- V6 to LS1 Swap
- G Body M6
- Truck Manifold
- Who has extra plugs/pigtails
- LS-1 with T56
- Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ? PLEASE HELP.
- Best breathing header for 68 Camaro??
- 5.3L - 91' Mustang LX Swap
- DBW pedal HELP
- Quick question about what starter to use.
- Alternative Conversion Headers
- What is this wire for?
- Lokar Midnight throttle cables?
- the smell of gas
- Edelbrock mounts location
- ls2 in 79 camaro radiater and hoses?
- Help with prepping a 95 mustang for a LS1
- ECM programing questions, and another "what's this thing? question...
- Are 4L60E year specific?
- Cruise Control Problem
- Fox Body LQ4/L92/T56 swap
- 78 C10 w/ LQ4/4l80E swap
- Can you reuse the steel gasket for the water pump on a LQ4
- 86 T-top Monte SS / LQ4 Build
- Does anyone have T56/FOX driveshaft measurements?
- 9 inch gear ratio
- The Elusive Parts
- 5.3 Pilot Bearing Hole
- ls1 conversion motor mounts.. 1 inch back vs standard
- 68 camaro with ls2... what coil springs should i buy?
- VATS???? Cranks then dies
- ls1 ps pump to 3rd gen iroc box
- 4L60E into Chevelle Wiring Help
