View Full Version : Conversions & Hybrids
  1. 6.0L Silverado engine fire questions
  2. Any 2nd gen lsx guys here?
  3. Need pinout for 2010 Camaro engine harness connectors
  4. ls2 in 79 camaro alternater hitting pitman
  5. Swap 6.0 from 2001 Silverado to an F-body
  6. STEERING WHEEL PEOPLE or any body with great info!!!!!!
  7. Parts you found out you didn't need for your swap afer you bought them?
  8. LSX Datsun Guys, COME ON IN!
  9. LS2 2005 GTO motor......DIPSTICK ISSUE
  10. LS1 Harness Connection Map
  11. fueling questions for a V6 camaro--->ls1
  12. new plan for jet boat build
  13. LS2 Nissan 350z Turbo Stage 3 =)
  14. cost of a conversion
  15. BMW 357i - Startup
  16. 5.3 T-5? How to?
  17. 65 nova wagon 5.3 questions
  18. school me real quick on swap
  19. wiring harness routing
  20. Y pipe for third gen LS1??
  21. kwik bracket
  22. 1987 Monte carlo Luxury Sport LS1 6spd (Camaro Dash and Features)
  23. Starting a 71 Chevelle LS3 swap
  24. Truck water pump, twisting the outlet?
  25. pcm???
  26. lockup switch wire
  27. Lsx 6sp in a 89 s10 2wd
  28. mustang coupe with ls1 questions
  29. adapter for four speed?
  30. 67 chevelle conversion ls2
  31. 05 5.3 LM7 charging module?
  32. spark plugs question
  33. Wiring Harness Question
  34. Completed LSX Monte Carlo Swap
  35. E-Rod Questions
  36. Gotta see this one...
  37. I made the cover of Hot Rod magazine!!!!
  38. Park/Neutral switch wiring
  39. Power steering to gear box question for 79 camaro
  40. 99 Camaro to 69 Camaro
  41. Full length Volvette Video
  42. Please help me decide...
  43. Congratulations Steve Verplank!
  44. No turning back now... 1969 Camaro convertible w/LS-2, 6spd from 2006 GTO
  45. SBC mount question
  46. ls7 swap in 2000 trans am
  47. LQ4 into a 1963 Plymouth Valiant
  48. Fox Mustang ls turbo question
  49. LS7 Question
  50. Making my Stock Ford tach work with an LS1...
  51. Trans Insight
  52. ls bell housing
  53. 4l60e shift cable question
  54. DBW cruise control
  55. f250 swap or not
  56. swap guys griffin 22x19x3 rad and fal 2500cfm low boy PUSHER 16" fan
  57. My 67 Camaro Build/Photos
  58. 67' GTO LSX Swap **4L65E Problems** *TCC Solenoid refuses to disengage*
  59. Trans compatibility questions...
  60. Foxbody LS swap longtubes/exhaust FS
  61. LS6 vs BBC 396 I need HELP making a Decision!!
  62. LQ4 which heads should I use
  63. 79-04 Mustang LSX/T-56 swaps just got a whole lot easier!
  64. ls1 engine connector pinouts
  65. Fbody- V6 to LSx
  66. C105 question pin H
  67. How do you tell if the engine harness is a 98?
  68. Anyone Looking for Shop Space in Sacramento area? Co-op Fabrication Shop?
  69. 99 Firebird L36/A4 to LS1/T56 Formula Firehawk
  70. clutch master cylinder location
  71. LS-1 crate motor
  72. '63 Short Fleet
  73. pcm codes
  74. 1981 Trans Am LS project
  75. T-5 speed + LS1 anyone done it
  76. LS2/TKO-600 1971 Chevelle
  77. My Turn...No Start!
  78. My 1967 dream machine
  79. ?s Windstar Electric fans
  80. Fuel pump wire question C101
  81. ls1 into 85 c10
  82. 4L80E controller or not
  83. Winter storage question...
  84. 1992 525iT LS1 Swapped Station Wagon For Sale
  85. LS! crate motor
  86. LS1 intake, EGR plug and PCV port
  87. New guy with lots of questions
  88. Great coolant fan switch adapter - lousy price
  89. LSX Ranger all info welcome
  90. Bitter Sweet Day
  91. LS1 into 95 mustang k-member decision help!!
  92. turbo gbody
  93. my bird needs an engine
  94. Need help with wiring harness install
  95. Testing the LSX Willys MB
  96. LSX swap, cannot decide on 6speed or Auto?
  97. wont't go into closed loop
  98. New to LS swaps
  99. LS-1 crate motor
  100. LSX - 1967Firebird
  101. Electric water pump
  102. 94 camaro ls1 swap( NEED SOMEONE TO DO MY LS1 HARNESS WILL PAY)
  103. Which One?
  104. $312 Spectre FI fuel tank
  105. on the fence old school or new school
  106. Camaro/Nova 1/2" forward with Autokraft pan + Dougs headers
  107. drive by wire to cable ecu changes
  108. ls1 water pump
  109. Ls intake manifold
  110. Quick wiring help
  111. 1969 LS1 chevelle gearbox?
  112. Lq4 powered 1977 cadillac coupe de ville
  113. LS1 Powered 98 Toyota Tacoma (will update with pics)
  114. Need a quick measurement
  115. 5.3 vs. 6.0 on a budget
  116. DBW help
  117. SPEARTECH- quote
  118. ls2 engine and harness and gauges in 68 camaro help issue!!
  119. LS1 foxbodies come in here.....exhaust questions
  120. Stock Balancer to go with 19155066 kit?
  121. Needs the best links for 1998 V6 Camaro ls1 swap ASAP!!
  122. reprogramming ecm same as tuning?
  123. Range Rover LS Swap
  124. LT1/LS1 T-56 6speed question.....
  125. which lsx swap kit into a fox is best?
  126. Drive Shaft / Crossmember Question... LS1 / 4l60e in 70 Camaro
  127. Turbo parts for A-body
  128. ls1 swap into fox body. need help
  129. Street rod conversions-advice
  130. 2008 5.3 Vortec installed with T5 WC/66 Chevelle
  131. Trans Selection Help
  132. Looking to sell my complete LS1/4l60E or part it out
  133. electric fan wiring testing
  134. Few Noob LY6 questions that i cant answer with the search
  135. Anyone running C6/Vette style Engine Mounts?
  136. Porsche Conversion Flipped PCV Question
  137. My 1987 Jaguar XJ6 swap thread
  138. brake pedal switch purpose
  139. LS1 to LS3 swap in a 98 T/A?
  140. Mustang diff ??
  141. 1969 GTO Judge Clone LQ4 turbo 4L60e
  142. LY6 mated to a T56
  143. 2005 5.3 pinout/diagram?
  144. o2 sensors not working
  145. Clutch bleeding frustations
  146. Need Pinouts/wiring diag for 2003 Express Van
  147. Is this engine swap worth it?
  148. UMI Performance A-Body rear control arm brace design
  149. Pics request, ls swap in a fourth gen monte carlo ss
  150. HELP! sbc swap in v6 fourth gen firebird HELP!
  151. Question about LQ9 Accessories
  152. help on brake light switch!
  153. 4l60e questions
  154. Something a lil different.
  155. ls1 in 68 camaro coversion questions? (basic newbe)
  156. fuel line sizes???
  157. Need some help with A-Body clearances
  158. Edelbrock mounts/headers on a 67 Camaro w/F-body pan
  159. fuel pump wiring
  160. Pcm controlled electric fan (2) wiring schematic
  161. "Chirping" Lq9 - Need advice
  162. virtual dashboard, oil pressure, hp tuner questions
  163. Looking for another Monza for an LS2 swap...
  164. g-bodys keep your digital dash speedo
  165. Experienced tig welders please chime in!
  166. fuel pump relay lq4 swap
  167. 1990 notch swap throttle question
  168. Distant Future LQ9 or LQ4 Swap in '82 C-20?
  169. found a mustang roller, looking for a vin check
  170. e-bay grand national fuel tank and sender????
  171. ls2 in 68 camaro swap kits and options?
  172. Turbo 5.3 Ford Focus
  173. Hummer pan dipstick
  174. ls1/th350 mustang help
  175. 96 v6 to either a ls1 or a lt1
  176. Chevelle good deal?
  177. LSX 454 swap
  178. 1986 cutlass 5.3 build topic .
  179. E-Rod Program
  180. gas tank question?
  181. Motor mount relocation advice.
  182. LSx conversion with Cruise Control, want a cruise control "ON" light.
  183. Have 2 harmonic balancers - which one?
  184. High current fan relay with PCM ground.
  185. mustang 408 stroker ls1 swap with kooks headers
  186. 996 w/ls1 swap - kaput thanks to California
  187. trans crossmember 79 camaro?
  188. Another 240SX with ElEsJuan
  189. gas tank question
  190. Ls1 swap into an a body
  191. LQ9 swap into 1956 nomad
  192. Edelbrock pro flow intake height?
  193. question
  194. anyone do an ls swap into a 92-96 f150
  195. 1961 Parkwood Wagon starts and runs
  196. LS6 1991 Camaro speedometer hook up
  197. brp standup guys
  198. AC, mixing old and new?
  199. Your thoughts
  200. 350z LQ9 Swap
  201. Aluminum 5.3 block engines
  202. ls1 powered ford five hundred?
  203. Does it matter where I put the oil pressure sending unit?
  204. 69 camaro procharged ls7
  205. Fox Body K-Member Questions
  206. Good Source for Jeep Mail Order Tune
  207. What would be better?
  208. Autokraft Mount Adapter Thickness
  209. Mustang Guys
  210. Ls1 Brunton Super Stalker
  211. Can I use the F-Body cluster with my swap?
  212. Fast Ez Efi Multi-Port with MSD 6010?
  213. Turbo-LQ9-T56 96 Blazer
  214. anybody done a 5.3 jeep swap?
  215. cheap CH-R or CH-R replicas for a 74 chevelle
  216. Lq9 z28
  217. alternator not coming on
  218. BMW Z3 - LS1 Conversion For Sale
  219. GTO wiring harness
  220. Will a 2005 Gto rack and pinon work in a 68 camaro?
  221. 06'Mazda Miata/MX5 Swap
  222. First Dyno run before any tuning
  223. LSx conversion for 94 3.4
  224. LSx conversion for 94 3.4
  225. 85 z28 wanting to do a 5.3 carbed swap??
  226. 1984 regal, single turbo 5.3
  227. Which ECU for swap
  228. Temp sending unit mod
  229. engine not sitting level in chevelle
  230. TKO into a 73 Camaro
  231. Carb Manifold EFI/Gen IV Repower
  232. F-body ls1 pan... will it work in a 68 camaro with no modification?
  233. What would you do
  234. 5.3L LM7 and T-5? Parts questions!
  235. Anyone running a blow thru Pro system Carb?
  236. LS1 in early 3rd gen w/carb
  237. More LS1 Miata track footage - Thunderhill
  238. LS1 vs. M62 in BMW E38/E39
  239. Starting over, mustang swappers come on in!
  240. Crazy!!!!05-06 blue gto gauges in 68 camaro??????
  241. 4l60e shifters
  242. LS1 to LS3 swap questions?? what can I keep and swap over?
  243. Chevelle Hooker swap headers, hitting floor?
  244. which mounts are good and which mounts are bad...
  245. 74 GTO 6.0 turbo air ride
  246. LS in chevelle, are you happy you did it?
  247. Is BCM or Speed Input Required for LS1?
  248. Another ls1 Fox
  249. advice needed LT1 going in 94 Sierra
  250. Another jetboater
