View Full Version : Conversions & Hybrids
  1. injectors/fuel rail selection, 6L LQ4/LS6 intake
  2. Trailblazer LS2 AC Compressor TRSA12
  3. Overwhelmed.. LY5/T56 combo in a "hot rod"
  4. turbo gbody swaps?
  5. 67 camaro what motor mounts for my lq4 th350 set up
  6. GM LS3 plug and play harness questions
  7. whats the fastest LS swapped IRS car that u know of?
  8. Standalone Wiring help
  9. Custom Trans Coolant Lines?
  10. LY6/4L80e from rough van into rough 69 camaro
  11. fs: turbo kit for ls mustangs
  12. LQ4 iron to aluminum heads swap
  13. Water pump heater core ports to be moved?
  14. starter and alt wiring question...
  15. Another no oil pressure thread!
  16. Chevy Express van question
  17. Oil pan options.. help!
  18. Pre-pump filter for LSx engines
  19. oil pan oil passages
  20. Going to start a new project
  21. LS1 dash/gauge cluster what gauges can I use?
  22. Spectre fuel injected tank
  23. ls1 swap in 67 chevelle questions
  24. LS1 in 3rd Gen Camaro, No Start, Please Help!
  25. People with aje k members inside!!
  26. Did 5.7l come in 1996 Silverdo?
  27. LS1 66 Nova Swap, TCI pro-Touring Subframe
  28. Engine Management Computer Reprogramming
  29. No Oil Pressure
  30. LS6 to T56 graft for Miata Qs
  31. ls coil question
  32. figured that since this was the hybrid section
  33. 350z LS1/Th400 Swap Completed!
  34. Jaguar XJ8 with LS1 Conversion
  35. Jaguar XJ8 with LS1 Conversion
  36. Jaguar XJ8 with LS1 Conversion
  37. come in first gen camaro's gotta ? for ya
  38. turbo third gens
  39. Car wont turn over.
  40. iac wiring for 5.3
  41. o2 wiring help
  42. Just wondering about sources for LLT engines
  43. question about fuel system in a ls1 converted fox body mustang
  44. P0704 bad clutch switch?
  45. Newbie in need of a little direction
  46. Grounds?
  47. Coil Relocation on a 55 Chevy
  48. ls2 oil pan for 68 camaro
  49. 1968 Firebird LQ4 Touching K-Member, Looking for ideas
  50. ID this MAP - LS3? B2101 settings?
  51. Where is a good place to find cheap/used TKOs?
  52. My '85 Camaro LSx swap project...
  53. LSX swap in a ford ranger?
  54. 4l60 Tranny Pan Part Number
  55. Fuel line help
  56. A-Body fuel tank PICS ADDED/Updated 11/24
  57. alternator cooling duct interference?
  58. Another first start video '68 C-10 LQ4/T56
  59. LS1 Mustang guys.... Need help using stock auto shifter.
  60. Ever hear of these guys ???
  61. lt1 to ls1 mounts
  62. looking for plu and play stand alone harness for f-body harness
  63. What PCM are you running?
  64. 86 Notch LQ9 Swap..K-Member/Headers/Intake Questions
  65. want deep exhuast note ls1 67 camaro?
  66. Anyone going to the SEMA Show
  67. RE: Mounts for 70-81 F-body
  68. 71 bird Spectre gas tank question
  69. 6.0 crank question
  70. Alternator F-body vs Truck dimensions
  71. Electronic Speedo hook up to 4l60E, what wire?
  72. 3rd gen swap
  73. LS1 Miata swap. Bossfrog vs V8R kit....
  74. oil pan sensor
  75. Syclone clone
  76. 40 Ford Coupe engine swap?????
  77. Pedal not responding "p2138"
  78. 4L60E auto shifter options
  79. Factory Five GTM..
  80. Walbro intank noisy??
  81. survey: engine cooling system
  82. 4l60e into 68-72 gm A-body shifter linkage
  83. 1964 Chevy Covette LS1/Turbo "PICS"
  84. LS1 1995 GMC 1500 conversion
  85. Aluminum Fittings on Stainless fuel line?
  86. Help! LS conversion won't start!
  87. Thinking about buying my buddies caprice and doing a swap?
  88. vendor help
  89. Stand Alone Wire Harness
  90. fuse/relay box used on LSx swap with stock harness
  91. questions on swaping 6.0 and 4l80e into v6 firebird
  92. took my swapped cutlass to the track
  93. LS seies engine/tranny source
  94. Newbie O2's wont read
  95. Jag to gto conversion
  96. Possible Alternator Problem??
  97. I tried search.... 5.3 in K5 questions.
  98. LSX 376 or 454
  99. Finishing up my 98 firebird v6 to 2000 LS1 swap
  100. tb heating hose solution
  101. 48 Chvy Truck 53L - vid
  102. Anyone got a Dakota Digital SGI-5?
  103. almost ready to roll
  104. megasquirt questions
  105. Using PowerGrip hose clamps with fuel line
  106. Ls1 sn95 with 4l60e shifter question
  107. Alternator Wire Gauge?
  108. FS: Edelbrock A-Body Adapter plates
  109. LS3/4L65E Swap into '67 Chevelle Completed!
  110. auto shifter connection
  111. O2 sensor question
  112. exhaust manifolds for 91 rx7 5.3 swap
  113. conversion kit
  114. LSX 1970 Chevelle Conversion
  115. starting build... ls1 c-10
  116. 1991 SBC fox speedo question
  117. GMPP ls2 engine controller, case learn ?
  118. Quick wiring question
  119. L92 needs smaller 2 wire alt
  120. 1st try at rod build '41 Willys/5.3L LM7
  121. Swageloks long term?
  122. Help! I need radiator hoses for 65 Chevelle...
  123. LS1/A4 GTO on my 73 camaro Finaly ready!!!!
  124. 4L80E Price
  125. Alternator charging problems
  126. Storing a motor question
  127. Oil Pressure/Coolant Temp sensors...
  128. Anyone swapped into 99-04 mustang street car?
  129. 1990 Nissan 300zx, What should I do?
  130. I need a little help on knowing what all I need for a motor swap
  131. LS2 / 4L65E Swap into a Buick T-Type
  132. Electrical Question
  133. Need help! 69 Camaro/Procharger
  134. propane injection setups and blow threw?
  135. 3rd gen fbody,ls1, procharger help!
  136. random misfire p0300????
  137. Anybody try this.."Sharkhide"
  138. 2000 S10 LS1 swap info??
  139. steam vent tube hose
  140. Exhaust questions
  141. Where to buy an LS3?
  142. 1/4 mile times - what are your thoughts. . .
  143. ls1 in 94 firebird
  144. Some questions about doing an LSx/T56 Mustang...
  145. I scored a doner
  146. L92 Cooling in 1969 Camaro
  147. power steering pump line leaking
  148. Carbed LS
  149. L92 wiring a generic O2 sensor
  150. 03 5.3L G-Body race build questions??
  151. ls1 dlc question
  152. I want to change all the gaskets were oil can leak from
  153. 6.0 fox opinions
  154. why not use a batwing oilpan
  155. LSX 454 controller question.
  156. Dakota Digital SGI-8 + Ls3 480 controller + 90 Camaro Tach
  157. concerns about MAF
  158. Anyone mod their water pump??? Need advice.
  159. Putting an LS1 into a 68-72 A-Body. Need a good message board...
  160. Fly by wire pedal has very little play
  161. Help with common trouble codes LS3/92 into 68 camaro
  162. Does a TBi tank work with LSX FI???
  163. What kind of motor is this?
  164. LS6 into an '87 GT?
  165. Fuses on charging & main electrical system
  166. Drive by wire pedal pictures?
  167. perplexing clutch issue
  168. motor mount problem
  169. what does stock ls1 throttle cable (pedal end) look like?
  170. LS3 burping coolant from radiator cap
  171. Pontiac electrical problem
  172. Pro-Flo xt stiin on my 39
  173. LS1 Chevelle exhaust clips
  174. 5.3 Build ????
  175. Motor washing and taping advice
  176. in severe need of help..and part #s
  177. My almost finished 84 LS1 Cutlass
  178. power Steering Resovoir Dimensions
  179. Fuel filter for a system with a return line?
  180. Wire harness basic ?
  181. Oil pump priming
  182. starter relay wire y/bk
  183. Can I use a 5.3 ECU on my 95 TA?
  184. newer 5.3 intake on lq4
  185. LM7 W/LS1 Heads
  186. Which LS motor??
  187. Low drivers alternator belt squeeks
  188. 5.3L/4L60E doesn't fit in 64 Chevelle
  189. headers...
  190. PS Pump Install & Removal w/ or w/o pulley?
  191. BRP Conversion Kit Updates
  192. boring out a LM7/5.3 Vortec
  193. Grand National LSx swap
  194. ls2000 v8 s2000 @ track on new set up
  195. NewB and need help in HoustonTX
  196. 200+MPH at Fall 2010 Mojave Mile event: turbo LS3 FD RX-7 :)
  197. 1977 Monza 6.0 build
  198. Posted this in the pcm tuning section and section and no one aswered
  199. How to run fuel pump wires through top of sending unit?
  200. keyless ignition w/ momentary start
  201. 94 4l60-e behind a SBC temporary till 5.3swap
  202. LU3 V6 Install in 75 Monza
  203. My LS1 in a coupe Mustang
  204. Cranks but wont start
  205. 1998 Camaro: 3.8l/T5 -> 6.7l/T56
  206. A little wiring help please.
  207. LS engine in 5th Gen Mustang???
  208. Stock intake question, is this fixable?
  209. LSX Notchback Build
  210. First Gen Camaro Tic Toc Tach
  211. subframe catera v8
  212. help
  213. Which FRCs would you use?
  214. evap system diagram
  215. Jaguar XJ8 / LS2 4L65-E
  216. wiring question
  217. Cruise control fro GMPP engine controller??
  218. Finally Got the Malibu up and running (vid inside)!
  219. Help with DBW 496
  220. 68 Chevy C10
  221. 1993 Camaro LT1 to LS1 conversion
  222. Make your own mounts vs. brp kit
  223. Few last things before i hit the start button? Help me id a few connectors
  224. Need help with LS1 swap that is running to hot
  225. neeeed hhheeeeeeellllpppppp!
  226. help with intake selection
  227. What is the thread pattern in genIII heads for the temp sender?
  228. mustang ls1 swap with t56 6speed
  229. Alternator wiring
  230. LQ4 oil pan in a 74 camaro f body
  231. lq9 PCV
  232. I want a build thread too....'63 Chevy II Wagon.
  233. Maggie in 92 C1500?
  234. car shop conversion plates
  235. G Body 5.3 Swap Questions
  236. Throttle body coolent line?
  237. ls1 swap
  238. need measurment on header
  239. Electrical Issue.
  240. Tach ??? Swaped 95 T/A
  241. help with lq9 in 67 bird
  242. Lm7 & lt1 engines opinion
  243. x-body or first gen f-body with ls1 oil pan
  244. LS Swap into Fox Body Mustang
  245. Volvo Hits the Dyno
  246. 12V Power Supply
  247. LQ4...............408 or not?!
  248. Weiand 300-111 ls1 intake on Lq4?
  249. fs: fox body aje motor mounts
  250. LS1 Porsche 928
