View Full Version : Conversions & Hybrids
  1. Idea
  2. Pull engine + trans or engine only
  3. I'm swapping an LQ4 & 4L80E into an '84 Monte SS & need help
  4. E39 BMW 540 LS Swap Completed
  5. DBW pedal in Nova
  6. grey wire truck alternator
  7. TRex in LSX
  8. new caddialac blown motor will it fit a F-body
  9. LQ9 and T56 in my 67 firebird
  10. LS1 Brake Dimensions
  11. Noob here!! Need help pls
  12. FYI Harness Sale $349.99
  13. My LS1 Jaguar XJ6 runs!
  14. Checklist for Purchasing a Donor Engine
  15. fox 83 whit 6.0 questions
  16. Carb'ed guys with sumped tanks and external fuel pumps...
  17. Trailblazer SS
  18. Anyone in Texas to have do a swap?
  19. 5.3 alt plug
  20. Looking for online Air Filter Catalogue with Specs
  21. LSx to SN-95 advise needed
  22. Block Heater plug?
  23. competition rock crawler(jeep) buggy - need cam vs torque converter advice on 4.8L
  24. G body with TKO?
  25. New guy, new project
  26. setting engine angle
  27. Project "Homegrown" -65 Nova LS2 and KB s/c-
  28. A body tie rod clearance?
  29. Help FAST!! please
  30. lt1 and ls1 radiator difference (transmission line)
  31. ls 6.0 help
  32. Starter Question
  33. Where is everybody mounting the PCM on First Gens?
  34. Noob needs help locating VIN
  35. my dyno numbers, sheet and video inside *Now with 10 bolt carnage*
  36. Swap - starts and dies 3 seconds afterwards
  37. LS1 Jeep TJ headers
  38. Temp sensor question; ohms, and thread pitch.
  39. 69 camaro ls swap oil pan trouble
  40. Conversion guys, did you buy a wreck to pull from or piece it together?
  41. Anyone have dimensions of the stock clamshell mounts?
  42. Another noob from so.cal
  43. lq9 belt driven accessories
  44. What tranny bolts to a 5.3 Impala engine?
  45. Not getting full throttle with pedal on DBC
  46. Chevy II build 6.0 gto
  47. Chevelle almost complete
  48. updated pics of my 84 z28 LSx swap #2
  49. 90 ls lx convertable
  50. Do I need a fuel pump inertia switch?
  51. converting r-12 to 134
  52. Radiator hoses for L92 part number
  53. 95% done with 96 mustang ls1 swap....few questions. ...PLEASE HELP
  54. 5.7 iron block build advice
  55. LS swap on a budget questions
  56. WTB: Need some DOD/AFM lifters
  57. MAF sensor wiring
  58. Project esCamaro
  59. VATS module
  60. 1st gen mustang: build thread!
  61. Anyone ran into this problem w/th350 sbc converter and LQ9 Flexplate?
  62. LSX swap into a 1964 Chevelle L98 4L70e
  63. F Body Exhaust Manifold flanges
  64. 5.3L in a 1941 Art Deco GMC Truck
  65. Well she is done and heres the video
  66. Spectra gas tank pump failure?
  67. Voltage?
  68. New CA smog law. Bad news!
  69. which o2 sensors?
  70. Truck Alternator Wiring (Yes, I've searched!)
  71. ECM differences
  72. sound clip from my LS6 kit car
  73. Been a long time...
  74. Alternator Issues
  75. dumb question: can i rotate the stock fuel rails?
  76. steering box / alternator clearance issues in a g-body
  77. 2000 ls1 A4 harness to M6 ?
  78. Coolant Flow Direction
  79. Heater Hose block it off or not
  80. Bypass Type Heater Valve
  81. Pics of Trans Tunnel Cuts for T56
  82. SCT SF3 Power Flash Hand Held Tuner # 3416V
  83. Alternator wiring question
  84. What does the "charge indicator control" wire do? (connects to alternator)
  85. AC not blowing cold, compressor engaged not cycling
  86. shorting sump on my 5.3 pan..can it be done????
  87. 67 ls powered camaro with tremec or 6spd?
  88. charcoal canister question
  89. HotRod style 240sx LS1 headers
  90. My sub $4k Ls mustang build (quick vid too)
  91. Trying to see if these Hookers will clear on my Nova
  92. What gages run off of the standard ecm output of the ls engines
  93. 1985 Monte Carlo 6.0 LQ4 swap
  94. Geo tracker is completed
  95. BRP Mid-Length headers 64-67 A-Body
  96. Going from a th350 to a 4l60e, what are my options for my speedometer for my 72 cheve
  97. GTO power steering pump
  98. $400 Tailshaft adapter a MUST!!!??? What the?
  99. 2004r stall?
  100. auto to m6
  101. Carb LS ?
  102. How big is your Edelbrock
  103. MAF or no MAF?
  104. More O2 Sensor Questions
  105. c1 corvette ls swap without new frame
  106. low cost recal, electronic speedometer?
  107. 6.2 powertrain in A body
  108. Wont start... a few questions
  109. Trying to get my car started w/o MAF
  110. 6.0 TWIN TURBO LQ4 Aerocharger!!!!
  111. Is my 2001 6.0 an lq4 or lq9 ?-from a pickup
  112. New - Ford 76 F-100 with a 4.8 Vortec
  113. 4.8L to 383 Build??
  114. pics of my ls swapped 84 cutlass
  115. Which suspension spring to buy for my fox body ls1?
  116. Help!!! Ls1 no-start.
  117. classic instruments - calibrating speedometer??
  118. gto oil pan
  119. need pinouts gm 19166569
  120. 69 chevelle
  121. need c5 pedastals for my rx7 swap
  122. Whats it take to keep her cool?
  123. ls1 3rd gen
  124. water temp gauge (autometer)
  125. oil pressure wire...
  126. 67 camaro help.....
  127. 87 IROC 5.3/w th350 budget build
  128. Help me out! Mustang swap guys with aje mounts
  129. How far can a 5.3L be bored out?
  130. 400 - 425 HP on 87 Octane - 6.0L (or 6.2L V8)
  131. 5.3/6.0 into a 85 fullsize bronco
  132. 1986 dodge conquest project!!
  133. stock Ls3 fuel pump in aftermarket tank
  134. Need some cam help for an lq4 4x4 swap
  135. R4 Compressor Bracketry-Who Makes It??
  136. LS swap into a 67 Camaro help!
  137. lsx mustang (need tips)
  138. throttle cable ls-x into 72 chevelle
  139. Tell Me I'm Not Crazy
  140. 97 Lt1 going into a older camaro.
  141. Need info for LSx Swap into a 72 Chevy SWB 4x4 Pickup
  142. lq4 powered 72 caprice coupe restoration
  143. L92 Pass Upper AC compressor bracket Vintage Air
  144. Contact Info For Monte Carlo John Please?
  145. finally got around to painting the 67 before the ls-fest
  146. fuel level gauge question
  147. need someone with aftermarket gauge experience
  148. Fox body guys, what are you using for a throttle cable?
  149. C4 corvette - 5.3 "LSX" engine swap project [PICS]
  150. no oil pressure
  151. LS1 with T56 in XJ6
  152. how do you get the injectors into the intake??
  153. Have new fusebox for engine install (89 Camaro)
  154. driver and passenger door switch questions
  155. 1969 chevelle LS1
  156. ?s on AN fittings
  157. mustang guys with aje crossmember
  158. driveshaft question...
  159. 5.3L LM7, drive by wire, on my engine Run stand
  160. swapping a tci 6x into my fbody...shifter wiring question
  161. Mazda RX8 LS1/t56 Swap
  162. need help...dbw to dbc???
  163. 97 V6 auto going to gen 3 motor
  164. 1993 c1500 swap help
  165. Now I've gone and done it...LSx Astro van coming soon
  166. How to get codes from check engine light
  167. How to lighten 74 camaro
  168. engine harness problems
  169. carbed LQ4 w/LS3 heads
  170. JZ Motorworks/LHX pan baffling
  171. Brake pedal hiem joint size???
  172. LS1 Into 95 FZJ80 Land Cruiser
  173. Cruise Control (DRW)
  174. Check out the two Twin Turbo set ups
  175. Budget E46 Track Only Car
  176. Putting a 6.0 in a ski boat
  177. Correct belt routing for alternator/wp only with truck accessories?
  178. 3 wire coolant temp sensor...difference???
  179. temp guage ? on 89 suburban swap
  180. 5.3 to 6.0 swap turbo silverado
  181. 5.3 to 6.0 swap turbo silverado
  182. 70 Camaro RS LY6/4L65e build
  183. 240sx hatchback lsx
  184. Cheap Shorty Headers
  185. Any other way to hook up for tach signal?
  186. Stock LS1 aluminum drive shaft. Worthy of modifying for swap or too weak?
  187. Oil Cooler Plate Help with Dynatech and Autokraft
  188. pics needed
  189. LS sonoma
  190. tac module to pedal pigtail
  191. if the motor is ran hot...
  192. 1971 Chevelle/ls1,4L auto swap
  193. speedhut gauges
  194. 5.3 swap in to third gen camaro Q's??
  195. 1 piece front end?
  196. Fuel Pressure in 99 Tahoe LQ4 swap help!
  197. LQ4 in a 83 camaro
  198. need dimensions for autokraft oil pan
  199. LY6 with T56 in 2000 Trans Am?
  200. recommendations on conversion?
  201. truck accessories (a/c comp) with edelbrock engine adapter plates
  202. truck accessories dont fit in my jeep swap!!
  203. Fuel Pressure problems
  204. Malfunction Indicator Light....
  205. Alternator getting relatively hot!!
  206. carbed blow through!!!!!!
  207. 3.8l to ls1 swap
  208. Ttruck/camaro intake pulley relocate belt part number????
  209. What gauges for 72 Nova
  210. 2nd Gen install kit on a 1st Gen, Will it work?
  211. Coolant temp adapter to use stock gauge
  212. power steering fitting
  213. Real world experience with your Abbott Cable X. Please tell.
  214. !!!HELP!!! Swap almost complete car wont start!
  215. LS motor in 86 Monte Carlo SS
  216. Best cluster for Corvette C4 with 4.8?
  217. 1979 Ford Failmont (4.8/Big Turbo/TH400)
  218. New, first LS engine, Swapping into Jeep, lots of ?'s
  219. ls3 480 el camino video
  220. fuel pump
  221. No spark after LS1 swap? Checked everything I can think of...
  222. LQ9 into a 68 Firebird
  223. OBD Port Connection to PCM 5.3 '03
  224. My quest to solving my fuel tank dilemma
  225. Best gen III oil pan for oil control?
  226. Chevelle long tubes???
  227. ls1 temp gauge
  228. 317 heads
  229. temp gauge
  230. Shifter hole size & boot for t56 install
  231. LQ4 alternator pigtail?
  232. Good places to look for wrecked donar F bodys?
  233. wich heads to use?
  234. Engine and tranny swap price
  235. just bought an 04 gto intake
  236. Firebird -68 pictures
  237. Corvette accessory drive in fbody ?
  238. Hotwire Kit??
  239. Oil Pan.
  240. LG Motorsport / Kooks Collector hybrid headers
  241. ls1/t56 07' tacoma xrunner
  242. ls1 in a 57 chevy
  243. sn95 swap
  244. Compression of 2004 6.0L
  245. 91 s10 5.3 turbo swap
  246. f body brakes on 67 chevelle
  247. Ls1 to ls7 z06 swap
  248. have a question about 1970 impala
  249. Possibly WTB LSx/T56 A or F Body
  250. 4L60E doesn't shift WOT
