View Full Version : Conversions & Hybrids
  1. converting r-12 to 134
  2. Radiator hoses for L92 part number
  3. 95% done with 96 mustang ls1 swap....few questions. ...PLEASE HELP
  4. 5.7 iron block build advice
  5. LS swap on a budget questions
  6. WTB: Need some DOD/AFM lifters
  7. MAF sensor wiring
  8. Project esCamaro
  9. VATS module
  10. 1st gen mustang: build thread!
  11. Anyone ran into this problem w/th350 sbc converter and LQ9 Flexplate?
  12. LSX swap into a 1964 Chevelle L98 4L70e
  13. F Body Exhaust Manifold flanges
  14. 5.3L in a 1941 Art Deco GMC Truck
  15. Well she is done and heres the video
  16. Spectra gas tank pump failure?
  17. Voltage?
  18. New CA smog law. Bad news!
  19. which o2 sensors?
  20. Truck Alternator Wiring (Yes, I've searched!)
  21. ECM differences
  22. sound clip from my LS6 kit car
  23. Been a long time...
  24. Alternator Issues
  25. dumb question: can i rotate the stock fuel rails?
  26. steering box / alternator clearance issues in a g-body
  27. 2000 ls1 A4 harness to M6 ?
  28. Coolant Flow Direction
  29. Heater Hose block it off or not
  30. Bypass Type Heater Valve
  31. Pics of Trans Tunnel Cuts for T56
  32. SCT SF3 Power Flash Hand Held Tuner # 3416V
  33. Alternator wiring question
  34. What does the "charge indicator control" wire do? (connects to alternator)
  35. AC not blowing cold, compressor engaged not cycling
  36. shorting sump on my 5.3 pan..can it be done????
  37. 67 ls powered camaro with tremec or 6spd?
  38. charcoal canister question
  39. HotRod style 240sx LS1 headers
  40. My sub $4k Ls mustang build (quick vid too)
  41. Trying to see if these Hookers will clear on my Nova
  42. What gages run off of the standard ecm output of the ls engines
  43. 1985 Monte Carlo 6.0 LQ4 swap
  44. Geo tracker is completed
  45. BRP Mid-Length headers 64-67 A-Body
  46. Going from a th350 to a 4l60e, what are my options for my speedometer for my 72 cheve
  47. GTO power steering pump
  48. $400 Tailshaft adapter a MUST!!!??? What the?
  49. 2004r stall?
  50. auto to m6
  51. Carb LS ?
  52. How big is your Edelbrock
  53. MAF or no MAF?
  54. More O2 Sensor Questions
  55. c1 corvette ls swap without new frame
  56. low cost recal, electronic speedometer?
  57. 6.2 powertrain in A body
  58. Wont start... a few questions
  59. Trying to get my car started w/o MAF
  60. 6.0 TWIN TURBO LQ4 Aerocharger!!!!
  61. Is my 2001 6.0 an lq4 or lq9 ?-from a pickup
  62. New - Ford 76 F-100 with a 4.8 Vortec
  63. 4.8L to 383 Build??
  64. pics of my ls swapped 84 cutlass
  65. Which suspension spring to buy for my fox body ls1?
  66. Help!!! Ls1 no-start.
  67. classic instruments - calibrating speedometer??
  68. gto oil pan
  69. need pinouts gm 19166569
  70. 69 chevelle
  71. need c5 pedastals for my rx7 swap
  72. Whats it take to keep her cool?
  73. ls1 3rd gen
  74. water temp gauge (autometer)
  75. oil pressure wire...
  76. 67 camaro help.....
  77. 87 IROC 5.3/w th350 budget build
  78. Help me out! Mustang swap guys with aje mounts
  79. How far can a 5.3L be bored out?
  80. 400 - 425 HP on 87 Octane - 6.0L (or 6.2L V8)
  81. 5.3/6.0 into a 85 fullsize bronco
  82. 1986 dodge conquest project!!
  83. stock Ls3 fuel pump in aftermarket tank
  84. Need some cam help for an lq4 4x4 swap
  85. R4 Compressor Bracketry-Who Makes It??
  86. LS swap into a 67 Camaro help!
  87. lsx mustang (need tips)
  88. throttle cable ls-x into 72 chevelle
  89. Tell Me I'm Not Crazy
  90. 97 Lt1 going into a older camaro.
  91. Need info for LSx Swap into a 72 Chevy SWB 4x4 Pickup
  92. lq4 powered 72 caprice coupe restoration
  93. L92 Pass Upper AC compressor bracket Vintage Air
  94. Contact Info For Monte Carlo John Please?
  95. finally got around to painting the 67 before the ls-fest
  96. fuel level gauge question
  97. need someone with aftermarket gauge experience
  98. Fox body guys, what are you using for a throttle cable?
  99. C4 corvette - 5.3 "LSX" engine swap project [PICS]
  100. no oil pressure
  101. LS1 with T56 in XJ6
  102. how do you get the injectors into the intake??
  103. Have new fusebox for engine install (89 Camaro)
  104. driver and passenger door switch questions
  105. 1969 chevelle LS1
  106. ?s on AN fittings
  107. mustang guys with aje crossmember
  108. driveshaft question...
  109. 5.3L LM7, drive by wire, on my engine Run stand
  110. swapping a tci 6x into my fbody...shifter wiring question
  111. Mazda RX8 LS1/t56 Swap
  112. need help...dbw to dbc???
  113. 97 V6 auto going to gen 3 motor
  114. 1993 c1500 swap help
  115. Now I've gone and done it...LSx Astro van coming soon
  116. How to get codes from check engine light
  117. How to lighten 74 camaro
  118. engine harness problems
  119. carbed LQ4 w/LS3 heads
  120. JZ Motorworks/LHX pan baffling
  121. Brake pedal hiem joint size???
  122. LS1 Into 95 FZJ80 Land Cruiser
  123. Cruise Control (DRW)
  124. Check out the two Twin Turbo set ups
  125. Budget E46 Track Only Car
  126. Putting a 6.0 in a ski boat
  127. Correct belt routing for alternator/wp only with truck accessories?
  128. 3 wire coolant temp sensor...difference???
  129. temp guage ? on 89 suburban swap
  130. 5.3 to 6.0 swap turbo silverado
  131. 5.3 to 6.0 swap turbo silverado
  132. 70 Camaro RS LY6/4L65e build
  133. 240sx hatchback lsx
  134. Cheap Shorty Headers
  135. Any other way to hook up for tach signal?
  136. Stock LS1 aluminum drive shaft. Worthy of modifying for swap or too weak?
  137. Oil Cooler Plate Help with Dynatech and Autokraft
  138. pics needed
  139. LS sonoma
  140. tac module to pedal pigtail
  141. if the motor is ran hot...
  142. 1971 Chevelle/ls1,4L auto swap
  143. speedhut gauges
  144. 5.3 swap in to third gen camaro Q's??
  145. 1 piece front end?
  146. Fuel Pressure in 99 Tahoe LQ4 swap help!
  147. LQ4 in a 83 camaro
  148. need dimensions for autokraft oil pan
  149. LY6 with T56 in 2000 Trans Am?
  150. recommendations on conversion?
  151. truck accessories (a/c comp) with edelbrock engine adapter plates
  152. truck accessories dont fit in my jeep swap!!
  153. Fuel Pressure problems
  154. Malfunction Indicator Light....
  155. Alternator getting relatively hot!!
  156. carbed blow through!!!!!!
  157. 3.8l to ls1 swap
  158. Ttruck/camaro intake pulley relocate belt part number????
  159. What gauges for 72 Nova
  160. 2nd Gen install kit on a 1st Gen, Will it work?
  161. Coolant temp adapter to use stock gauge
  162. power steering fitting
  163. Real world experience with your Abbott Cable X. Please tell.
  164. !!!HELP!!! Swap almost complete car wont start!
  165. LS motor in 86 Monte Carlo SS
  166. Best cluster for Corvette C4 with 4.8?
  167. 1979 Ford Failmont (4.8/Big Turbo/TH400)
  168. New, first LS engine, Swapping into Jeep, lots of ?'s
  169. ls3 480 el camino video
  170. fuel pump
  171. No spark after LS1 swap? Checked everything I can think of...
  172. LQ9 into a 68 Firebird
  173. OBD Port Connection to PCM 5.3 '03
  174. My quest to solving my fuel tank dilemma
  175. Best gen III oil pan for oil control?
  176. Chevelle long tubes???
  177. ls1 temp gauge
  178. 317 heads
  179. temp gauge
  180. Shifter hole size & boot for t56 install
  181. LQ4 alternator pigtail?
  182. Good places to look for wrecked donar F bodys?
  183. wich heads to use?
  184. Engine and tranny swap price
  185. just bought an 04 gto intake
  186. Firebird -68 pictures
  187. Corvette accessory drive in fbody ?
  188. Hotwire Kit??
  189. Oil Pan.
  190. LG Motorsport / Kooks Collector hybrid headers
  191. ls1/t56 07' tacoma xrunner
  192. ls1 in a 57 chevy
  193. sn95 swap
  194. Compression of 2004 6.0L
  195. 91 s10 5.3 turbo swap
  196. f body brakes on 67 chevelle
  197. Ls1 to ls7 z06 swap
  198. have a question about 1970 impala
  199. Possibly WTB LSx/T56 A or F Body
  200. 4L60E doesn't shift WOT
  201. F-body Heater Hoses - in and out?
  202. lookin for oilpan that clears crossmember on my g-body....please help...
  203. run or not to run a fuel regulator
  204. Relocating coils
  205. Those who have done your own standalone
  206. LS2/T56 into a 70 Chevelle By Deserttaco
  207. 3rd Gen, Lq9 swap Fuel pump question
  208. dbw or dbc ecm and wireharness ??? how can i tell what it is??
  209. So the junkyard screwed me a little
  210. Where to buy L92 rockers and stands used?
  211. Best electric fan set up for the street.
  212. 2002 Tahoe service manual?
  213. Using the 2005 LQ9 harness in my swap, how do I handle the throttle body?
  214. A body motor mounts/adapters ratings & opinions
  215. Prepping an old gas tank for in tank pump
  216. LY6 6 liter tach wiring
  217. LS1 harness for engine dyno
  218. LQ4 Motor Swap
  219. 2000 LS1 harness to a 94 Z28 M6 Camaro...
  220. One wire alternator hook up PLease help
  221. Truck MAF sensors
  222. 2010 Summer project
  223. Is $1200 delivered for a '05 LQ9 complete w/accessories and harness a greatd deal?
  224. Swapping 2005 LQ9 into Fox Body. Please help.Lots of ?'s, please try to answer some!
  225. Nissan 630sx 383 LS1 in a 240 (more pics)
  226. Where in socal are people getting there ls motors for swap?
  227. cooling fans not coming on with A/C
  228. whats the difference between ..
  229. 5.3 is overheating, no water in top radiator hose, help?
  230. 4l60e transmissions, which years are correct for genIII engines?
  231. Automatic AND 6 Speed harness?
  232. V6-V8 Swap
  233. Recommendations for fuel system?
  234. LS1 Swap
  235. Dakota Digital dash panel (PICS!!)
  236. 67 Nova L92
  237. Finally Running
  238. alternator wiring
  239. 5.3 in a c4
  240. crank position sensor when did they change from the 24x? to 58x?
  241. Pan and k Member question
  242. Want an LSX in my C4 Vette
  243. TPI to LS1 (tons of questions) sorry!
  244. LS2 Starter/Altenator Wiring??
  245. Any other Manuals aside from a T56?
  246. Fan wiring
  247. 4L70E/4L60E tranny cable into 68 Camaro
  248. 2nd gen swap
  249. Ls3 g35 swap
  250. 90 Formula GETS TEASED (LS1/700r4)
