View Full Version : Conversions & Hybrids
  1. Is there a how-t0-thread on making ur own harness?
  2. TCC Wiring
  3. DBW question
  4. HELP! Dynatech headers burning plug wire
  5. Thanks to LS1tech.. 2 years later 408ci
  6. LQ9 engine builds... opinions needed
  7. thinking of a 5.3 swap into a 79 trans am, need help!
  8. LY6 in a '76 GMC
  9. LS Foxbody Throttles
  10. 67 camaro steering linkage clearance
  11. wiring connector help needed
  12. 5.3?? or 4.8??
  13. 5.3l dies when put in reverse
  14. just double checking will this fit with no issues?
  15. CSR TStat housing heat question?
  16. F body power steering hose routing
  17. ls motor on alcohol
  18. LQ4 or LQ9 with PRC 2.5 5.3L heads..
  19. Radiator set up for 87 C/K w/ 5.3
  20. new retrofit oil pan
  21. Acc drive questions?
  22. factory engine wireharness delete on g-body??????
  23. G-body ecu wirning
  24. Tuning a ls6 porsche 944
  25. 7.4L swap please help
  26. 07 trailblazer ls2 into 00 fbody questions
  27. HELP. LY6 timing covr bolt torque
  28. 69 camaro ls1 - first start-up video
  29. 04 GTO alternator or volt signal
  30. Best way to put coolant in system?
  31. Camaro or Corvette Accessory drive system?
  32. BMW M3 LSx conversion - Engine weights
  33. LQ4 wire to cable conversion for throttle needed
  34. lt1 to ls1 worth it? please help gm family
  35. question on ls1 pcm cooling fan control...
  36. LQ4 AC hook up to Chevelle stock AC
  37. 98 blazer
  38. Used LS Motor. How many miles is too many?
  39. It's ALIVE! (sort of.. Error code help??)
  40. Bosch Relay Connectors, Looking For Large Wire Versions...
  41. Wiring Help Needed Installing F Body Cluster with 03 Truck Computer
  42. HELP.....looking for g-body oilpan that clears co
  43. chevelle / nova guys. turbo hotside available
  44. my custom intank walbro setup
  45. Final bits of 1978 Jeep CJ7 LM7 swap
  46. s14 vs s10
  47. 2000 BMW 525i
  48. 1969 Chevelle fuel pump in tank?
  49. 2006 ls into my 72 blazer...
  50. How to stay broke: IS300 + LS1 turbo
  51. Need advice
  52. Custom Fuel Lines (Looking for Info)
  53. Thinking of a swap (5.3 into '93 Caprice Wagon!), have some questions.
  54. What hose ends for A/c in 97 v6 with ls1
  55. Serial Data Signal
  56. porsche 928 ls1 engine (tachometer) :(
  57. No coolant flow?
  58. Gauge cluster reset
  59. LT1 to LS1 Full Swap
  60. Ls3 63 Nova Wagon
  61. E-Z out saved my @$$
  62. LSX miata vs. LSX datsun 280z?
  63. LQ9 LJ Swap - Any reason not to?
  64. Autokraft pan bolts?
  65. 67 camaro hydroboost..,... having whoa problems
  66. 71 Nogo slowly getting a boring lq4/4l80 build
  67. LS1 swap ?
  68. how to clean/flush cooling system...
  69. 85 lq4 t56
  70. Classifieds Link: '07 Tahoe Engine Harness
  71. 67 Nova L92 it is alive!
  72. lq4 coolant crossover tube
  73. Anyone have a NON spring loaded LS1 belt tensioner?
  74. DBW + No VSS = Problem?
  75. Bank 1 not firing intermittently... very frustrated
  76. 99 sonoma zq8 LQ4/4L80E
  77. is bigger always better??
  78. Truck intake manifold.
  79. LS1/T56 in 69 Camaro
  80. new mast motorsports oil pan ???
  81. Pics of Kwik Alternator/PS brackets
  82. intro thread
  83. 350z conversion with an auto?
  84. Fuel rail hits #5 coil
  85. Will an LS3 water neck and thermostat work on water pump from an LS1 Camaro?
  86. My 1985 C10 LS6 build!
  87. First start - no dbw pedal response??
  88. 1999 6.0L reluctor wheel question
  89. Exhaust Wrap Kits on my LT
  90. Slightly different twist on 5.3 vs 6.0 question...
  91. I was hoping not be in a 'car wont start' thread, but...
  92. o2 sensor delete??
  93. Holley fuel pump for LS1.
  94. LQ4 into Jeep...intermittent codes?
  95. Has ANYONE ever swapped a 8.1L 496 LS motor into anything???
  96. Alternator Question
  97. Fuel pump for LS1 going into 69 chevelle?
  98. '84 Mercedes 380SL LS1 + Auto Conversion
  99. fuel tanks and fuel filters
  100. Computer program options for 5.3l swap?
  101. 1969 Nova Ls1 T56 - 95% complete
  102. SSMC Guys
  103. LS1/4L80E/4x4 Swap Into 89 K5 Blazer
  104. update on the 98 mustang LSx with T56
  105. How to Pacify the A/C hi-lo pressure switch for the PCM?
  106. T56 swaps - shifter Boots
  107. Anyone put a C5 or C6 drive-by-wire pedal in a 4th gen f-body?
  108. 87 IROC 5 speed & LS2 Will it work?
  109. Dynatech or Hedman LS swap headers
  110. LQ4-need more HP
  111. L33 and T56 Upgrades and Advice
  112. 2000 LS1 in 98 firebird
  113. What are these?? (and do I need them?)
  114. 5.3 or 6.0?
  115. wiring help and a plug wire question
  116. LSX swap wiring question (TCC switch)
  117. 2000 Celica LS4 maybe a reality....
  118. Newbie needs infomation
  119. 1995 TA LS1 Swap Fuel Line Question
  120. 2ndgen trans am ls1 4l80e swap
  121. LS1 Miata No Spark Driver Side
  122. Intake Elbow
  123. Who wants to see LS power in a 1960 CJ5?
  124. Pan Gaskets??
  125. L92 2009 escalade wiring harness diagram
  126. LS engine water flow at idle?
  127. 5.3 into an 87 4wd Chevy p/u!
  128. 95 impala ss wiring
  129. Can I make the 2 wire LS2 knock sensor work with the 2002 f-bod PCM 1 wire harness
  130. power steering pump question
  131. lq9 in a 98 3500??
  132. 71 Chevelle L76 TKO swap
  133. Removing extra wires from a 99' LS1 harness
  134. no spark
  135. Help with headers
  136. Frustration, fuel problems with '56 conversion
  137. 79 silverado 5.3 swap, need help
  138. 6.0 swap need headers and egr delete
  139. 1978 Jeep CJ7 with 5.3 LM7
  140. turbo mount to cage in malibu?
  141. 67 Chevelle 5.3 finally drivable
  142. 1973 RS Camaro LSX Swap
  143. Who's Using Fbody cluster's in Foxbody's... Need pictures...
  144. Trying to get the aftermarket temp sensor work for my LM7 - swapped into a 67 camaro
  145. I REALLY need a 2002 TAC module
  146. ls1 swap
  147. Low fuel pressure
  148. Looking for 1/2" Dorman type fuel line fitting
  149. Cheap Mobile 1 oil
  150. Quick steam vent question
  151. ATT:FOXBODY LSX / AJE TRANS X-MEMBER USERS i have a question
  152. BRP Hot Rods Contest
  153. another 6.0 coupe
  154. Ly6 or LQ4/LQ9
  155. how does this cam look for a carb aplication?
  156. Wrecked my Z28...easiest and/or cheapest conversion for my LS1/4L60E?
  157. Where is the d@#% code?
  158. "NEW" BRP Hot Rods Website
  159. PCM question
  160. Corvette Acc. on a TA?
  161. Which flywheel do i use in my ls1 swap?
  162. Planning LS swap into Jeep 2005 TJ Unlimited - Instrumentation Questions
  163. 77 Monza 6.0 with LS3 heads
  164. trans issue
  165. Couple questions on fox mustang swap
  166. 93 RX7 with a VAT problem, wont start
  167. ls1 camaro 2gen conversion headers question...
  168. need help on lq9 going into 70 camaro...
  169. Pic/info request Turbo Ls1 into early f body/nova
  170. I really need Help LS1 into 1968 camaro with T56
  171. L92 wiring harness
  172. Realistic easy horsepower upgrades to a 5.3?
  173. Electric cooling fan melted relay
  174. LS Early Nova Swap
  175. Need advice on project...
  176. Converting to right hand drive
  177. radiator/fans in nova lsx swap
  178. y5mgisi's LQ4 swap thread. **more questions**
  179. LSx x-bodies?
  180. LS1 Smog configuration (wtb)
  181. 3000gt ls style swap?
  182. 4L60E tranny problem
  183. Newbie question-LS1 in to 911 swap
  184. Edelbrock 6706 swap plates ?'s
  185. anyone know how to test a coil?
  186. Exhaust Bolt Issue
  187. Valve cover adapters
  188. T56 into 1998 Mustang
  189. Need template of mounts for ls1 in 1st gen camaro
  190. Mast Motorsports Carb Style Intake Throttle Body Adapter
  191. Projekt Wrekt: 1969 Camaro w/ Carb'd LS1 & T56
  192. 00' Firebird V6 to V8 LS1 Swap
  193. LS1/t56 73 Corvette 12/1/10
  194. L-92 motor change in sandrail
  195. what power steering hoses will i need?
  196. Fuel pump choice. 5.3 na for now, then TT.
  197. LS1 In a Mustang
  198. Supercharged LT1 in a 1970 Monte Carlo?
  199. LS1 In a Mustang
  200. Starter problem??
  201. Passenger side alternator installation.
  202. wide band questions
  203. TJ LSX Conversion
  204. 79 C10 5.3/TH400/12Bolt Completed Pictures
  205. Volvo 240 LSX Swap
  206. What does your ls based fox body weigh?
  207. 5.3 into 75 chevy truck
  208. Looking for LS1 swap shop near Savannah
  209. 2nd Gen Camaro guys, need some input on a Track only 6.0L stuff
  210. carb fourm
  211. Autometer oil pressure sending unit
  212. Dropping Denali 6.0 into 70 cutlass suprem,need help with shopping list.
  213. '07 LQ4 into a 1992 jeep cherokee.
  214. WHAT PART # for vic jr gaskets????
  215. 93 mustang GT LS1 swap
  216. '94 T/A 6.0/T56 Build
  217. turbo 5.3 in second gen camaro (need advice)
  218. anyone run the MS3 cam with a carb????
  219. G-Body Swap
  220. Please help... PCM not getting power
  221. Looking for 2005 truck wiring diagram
  222. Mustang K Members: AJE vs the rest
  223. Emissions?
  224. Autokraft LS3 Oil Fiter Adapter Modification
  225. I love my LS Swap!
  226. What lower radiator hoses are being used on a LS1 in a 71-72 Chevelle
  227. Lengthening Harness
  228. Wiring diagram
  229. Pinion Angle?
  230. Manual throttle body on DBW harness
  231. LSX 454 / 2004R into '70 Chevelle SS
  232. Help serious wiring problem 1969 camaro with LS2 long post sorry
  233. LS3, TH400 Kick Down question...
  234. LS3 1968 Oldsmobile F85 Swap
  235. 5.3 4l60e Times
  236. LQ9/T56 in 1999 Mustang GT? Questions...
  237. older 6.0 in mustang
  238. g body crossmember?
  239. Power steering Question
  240. 1994 S-10 Pro Street 5.3
  241. 67 Camaro - Dad and Son build
  242. 62-64 Impala Fuel Tank Options?????????
  243. LQ4 Express Vans vs. Trucks
  244. G8 GXP for 65 A Body swap?
  245. Dynatech headers shop visit
  246. 2000 Camaro LS1 Radiator questions
  247. 6.0L with carb intake and Fast EZ-EFI
  248. Voltage Issue?
  249. S10 LSX swappers/Charcoal cannister
  250. GTO Salvage Resale Value
