View Full Version : Conversions & Hybrids
  1. need help with these connectors
  2. LS2 in my caprice
  3. issue with 98 auto ls1 harness on 02 5.3/4l60e
  4. Minimum circuits for swap
  5. Potential LS1 Swap Filter
  6. ls1 oil pan for 69 camaro?
  7. LS2 into another GM A-Body
  8. securing fuel lines
  9. 98 auto ls1 wiring harness on 03 5.3 auto swap complications on the trans
  10. My 1966 Lemans getting LSX
  11. Truck Water Pump Steam vent question?
  12. 1977 Chev Monza Spyder LSX454 underway
  13. windage tray
  14. Need a little wiring help.
  15. My LS1 Air conditioning retrofit
  16. valley cover
  17. Alternator Plug Identification
  18. Help prevent me from being Nickel and Dimed to death
  19. LS3/4L70E into C4 Codes/Problems
  20. The one and only, GMW! (Now with the baby turbo) PICS
  21. Thermostat
  22. fuel system diagram
  23. ECU for drive by wire
  24. LS pulley setups
  25. Bagged LS1 Nissan Hardbody Rat Rod
  26. Any no what power the maf?
  27. 4l60e vs. 4l80e size.
  28. What hoses?
  29. Drive By Wire pedals
  30. Edelbrock mounts which crossmember?
  31. Accessory, Mounts, and computer questions
  32. 6.0L out of 2007 Van?
  33. 68 impala/LQ 4 swap EVAP Purge Solenoid
  34. 2004 gto bcm,
  35. mounting the ECU
  36. IAT Intake Air temp question
  37. '87 IROC What to put in?
  38. HydroDynamic Rock Crawler
  39. Impala/caprice lq4 swap
  40. Q's for LS1/4L60E G-Body Owners
  41. Why are people keeping thier non-OD tranmsssions with thier swap?
  42. MAF/throttle body position, close or not?
  43. wrong or upside down motor mounts???
  44. 67-69 f bodies and 68-74 novas, please help
  45. mounting TV cable on ls carb intake
  46. Car runs for 5 seconds then dies
  47. Swap wiring question...
  48. heater core need to be aluminum?
  49. Ls1 dodge ram!!!
  50. Thinking of adding a ls2 engine to a camaro 93' a few questions
  51. Cleaning up a swap motor?
  52. 1998 Mustang LSx progress pics
  53. Digital Dashboards
  54. Simple LS1 harness
  55. My Datsun Hybrid Project
  56. Looking for vendor
  57. Wire harness questoin ls1 into 95 ta
  58. jeep 5.3 witout 02 sensors
  59. g body headers
  60. Anyone converted a C5 6speed to a Auto?
  61. 2nd gen swap tranny question LQ4
  62. 1994 V-6 Camaro Combination Switch Pinout?
  63. Correct flexplate
  64. E36 M3 - LS3 New headers finished..
  65. Turbo 5.3 s10 build...
  66. New Venue For My LS2
  67. utility of this tube?
  68. header info
  69. 94 formula/ 98 powertrain AC question
  70. Looking for 9's... which turbo?
  71. need help on running issue,working on car right now. thanks
  72. AWD Conversion???
  73. Transmission Conversion Problems
  74. Cam Position P0342 Trouble After Swap
  75. Ls2 v.s. Lq4
  76. Big Brake conversion on non ABS car. OXYMORON?
  77. Engine wont fire please help
  78. BRP HotRods' oilpump girdle
  79. 2010 Camaro Fuel Rail covers?
  80. How to get the oil, temperature, and volt gauge to work?
  81. 06 GTO swapped into 69 camaro
  82. Fuel Line: Dual or Single
  83. 1986 SS Monte LS1 Swap
  84. foxbody starter wire issues
  85. Swap header for a 71 Chevy truck??
  86. PCM Under the hood... How hot is too hot
  87. If anyone is looking for a done car, selling my 66 Chevelle
  88. s-10 with 5.3 issues
  89. Trans/Axle Alignment
  90. Fuel system arrived, tough time with the fittings...
  91. 5.3 turbo into SN-95, which alternator bracket?
  92. bolting trans up. 6.0 to th400
  93. 2003 auto wiring harness and computer, wish it were for manual
  94. 2nd gen swap questions
  95. How does 04 GTO PCM turn on A/C
  96. g-body mount question
  97. 25.5 Mustang Coupe project.
  98. Motor mounting problem
  99. What will run my cable speedo?
  100. tranny swap questions
  101. 2000 Corvette Alternator Connector
  102. ???? About Pulse Generators
  103. lh8 pan on third gen ls1 swap
  104. 2003 5.3L in 64 chevelle fuel system question
  105. Fuel Filter fittings options
  106. What is the most HP out of a carbed 6.0L with factory heads
  107. Finally got my 71 camaro ls6 running **VID**
  108. Rear GTO Oil Pan bolts
  109. T56 67 Camaro queston
  110. Whipple ls1 67 Camaro
  111. Mustang, LSx, and Powersteering pump...
  112. Need help with speedometer and pin 50 in ecu
  113. ls1/lt1 in my 87 fox
  114. Oil Pickup tube Question
  115. MSD 6012 cam sensor fail
  116. PRND Inputs?
  117. 2009 chevy silverado pinouts
  118. c400 connector location
  119. Swap ??
  120. Re-wiring 93 mustang body.
  121. Can I use factory guages with the conversion?
  122. 5.3 alternator question
  123. LS 7 powered kit car at the Ring -video
  124. Ls Swap into 64 Impala
  125. Is it possible?
  126. lq9 in a 86 buick regal
  127. 76 Camaro Alternator hits...CraP
  128. 5.3 swap in 86 K10
  129. Turn a LQ9 6.0L into a LS2 Motor
  130. Shit...
  131. oil pressure pin for a 98 corvette PCM
  132. ECU Pinout questions
  133. Removing Mechanical Fan?
  134. Will this work?
  135. gm tech 2 w/candy WON'T preform code 316 crank position relearn???
  136. Looking for LQ4 info
  137. can i use the variable compression A/c compressor?
  138. ly6 harness.gas pedal plug in?
  139. lq4 p.s pump hook up
  140. using MSD graphview for vacuum advance
  141. 93 f body clutch pedal/slave same as 02?
  142. L92 oil pressure sensor
  143. Wanted: Alternator pigtal from f-body
  144. 383 engine swap 87 trans am?
  145. Mustang guys with AJE crossmember....
  146. Starter Flange Broke & Cracked my Block
  147. What are the best factory heads for 6.0L??
  148. a/c makes my car start?!?! WTFFFFFFFF!!!!
  149. Ls1/t56 69 ta vert
  150. LS3 swap into a 97 Camaro
  151. two problems i can't solve!
  152. High mileage swap advice???
  153. do I have a fuel problem?
  154. 350 Hp + ~2800lbs... oh LS1 How I love thee
  155. Is it possible to use a pedal from another vehicle?
  156. 73-87 ck ls swap
  157. Air Intake Size
  158. fox body headers n driveshaft for ls1-dfw
  159. Corvette C5 Instrument Cluster swap
  160. whats the difference?
  161. Anyone ever make their harness from scratch?
  162. L92 in a Fairmont questions
  163. 96 T/A to a 98-02 T/A upgrade
  164. AC Compressor Question
  165. fan question
  166. gmpp intake port matching
  167. Blew up PCM while cranking engine..HOW!
  168. Anyone sell exhaust manifold flages to bolt to stock LSx exhaust?
  169. Fuel Tank Pressure Sensor Solutions (And Fuel Level Sensor)?
  170. Finalizing my wiring, please confirm pins 20 & 57 are constant hot.
  171. LS1 GEN III LS7 warhawk started...Finally
  172. fuel rail
  173. 4th Gen T/A seats into 2nd Gen T/A
  174. in search of 11's N/A
  175. Gen 3 F Body - LQ9 Questions
  176. No oil pressure on my new engine!! HELP!
  177. AJE motor mounts, what is the difference?
  178. 4l60e or 4l80e
  179. Swap body harness LT1 to LS1???
  180. quick q - intake manifold plug on edelbrock intake 7118
  181. ls1 swap in 69 camaro an want to do brakes upgrade
  182. alternator stuff for lsx swaps
  183. chevy II 5.3 swap
  184. LT1 swap into Chevelle - Cooling system problems
  185. which mustang headers for lsx swap??
  186. starter solenoid...
  187. crank angle relearn, with out break 5v wire
  188. Bought a c4 vette. Need some advice on this swap.
  189. Tell me this is going to fit.....
  190. LQ4 brake vacuum source... anything but factory nipple available?
  191. Best $120 EVER SPENT?!?!
  192. front accessories g body 5.3 question?
  193. clear powdercoat
  194. LH8 pan..
  195. Looking for help..converting a foxbox to ls1
  196. 1959-1964 impala rear end housing strenght?
  197. 1989 notchback
  198. Electric fan setup
  199. vacuum line question....
  200. idler pulley bolt. spacer needed?
  201. Vacuum Booster Connection on 69 Chevelle
  202. 1969 Chevelle Ls Mounts
  203. LS Mounts for 70-81 camaro
  204. Engine wont get out of it's own way
  205. LS2 harness with BCM help needed.
  206. Oil sending unit problems facts/myths which one?
  207. 4th gen fbody rear end in gbody?
  208. Best longtube for 1st gen lsx
  209. Walbro external pump ?'s
  210. 2005 GTO LS2: Where is the fan connection on the harness?
  211. 454 LS2 engine is in the car and fired up.. video
  212. 84 s10 ext cab lq9/t56 swap questions
  213. Three wire alternator not charging.
  214. Do I need VSS with TH400?
  215. DBW & DBC 2003+ PCM's, internal pictures, serv. & hwd no's.
  216. 2000 Camaro exhaust manifold flange?
  217. motor mount assist
  218. Exhaust movement
  219. 99 Corvette M6 Harness into S10 4L80
  220. LS1 BMW E30 racecar project
  221. 6.0 carbed forth gen.
  222. PCM Question - BMW/LS1
  223. Anyone have some ls7 exhaust manifolds handy...? Need a quick favor
  224. LQ4 into a 95' camaro V6
  225. coolant steam tube?
  226. Where to get sending unit flange?
  227. temp sender sits back in the adaptor
  228. my lsx 408 into my 94z28 or sbc350
  229. LS6 or 6.0 or hold out for LS3
  230. 67 Nova L92 swap
  231. 1967 Camaro 2005 GTO LS2: Wire fans off ECM?
  232. 98 TAC module for drive by wire question
  233. 4wd vs 2wd Tune?
  234. LQ4/4l80 El Camino Build
  235. Where to get the tool to pull the pins out of the coil connector?
  236. Oil pan swap?
  237. radiator hoses that fit chevelle radiator
  238. Off Set Shifters for T-56 swaps
  239. Black S-Dime Project...
  240. msd 6010 box question
  241. New 5.3L swap harness advice needed
  242. finished ls1/t56 s10
  243. Eldebrock Swap Headers
  244. 73 corvette 5.3 help
  245. Smaller power steering pulley?
  246. Modding a Truck harness help
  247. 5.3vortec in a 240sx wireharness help!
  248. The Blue Lagoon - BMW e30 - LS1
  249. Direct fit Heavy-Duty LS T56 Hybrid for Heavy/Powerful conversions
  250. did caddy use LS motors?
