- 67-69 f bodies and 68-74 novas, please help
- mounting TV cable on ls carb intake
- Car runs for 5 seconds then dies
- Swap wiring question...
- heater core need to be aluminum?
- Ls1 dodge ram!!!
- Thinking of adding a ls2 engine to a camaro 93' a few questions
- Cleaning up a swap motor?
- 1998 Mustang LSx progress pics
- Digital Dashboards
- Simple LS1 harness
- My Datsun Hybrid Project
- Looking for vendor
- Wire harness questoin ls1 into 95 ta
- jeep 5.3 witout 02 sensors
- g body headers
- Anyone converted a C5 6speed to a Auto?
- 2nd gen swap tranny question LQ4
- 1994 V-6 Camaro Combination Switch Pinout?
- Correct flexplate
- E36 M3 - LS3 New headers finished..
- Turbo 5.3 s10 build...
- New Venue For My LS2
- utility of this tube?
- header info
- 94 formula/ 98 powertrain AC question
- Looking for 9's... which turbo?
- need help on running issue,working on car right now. thanks
- AWD Conversion???
- Transmission Conversion Problems
- Cam Position P0342 Trouble After Swap
- Ls2 v.s. Lq4
- Big Brake conversion on non ABS car. OXYMORON?
- Engine wont fire please help
- BRP HotRods' oilpump girdle
- 2010 Camaro Fuel Rail covers?
- How to get the oil, temperature, and volt gauge to work?
- 06 GTO swapped into 69 camaro
- Fuel Line: Dual or Single
- 1986 SS Monte LS1 Swap
- foxbody starter wire issues
- Swap header for a 71 Chevy truck??
- PCM Under the hood... How hot is too hot
- If anyone is looking for a done car, selling my 66 Chevelle
- s-10 with 5.3 issues
- Trans/Axle Alignment
- Fuel system arrived, tough time with the fittings...
- 5.3 turbo into SN-95, which alternator bracket?
- bolting trans up. 6.0 to th400
- 2003 auto wiring harness and computer, wish it were for manual
- 2nd gen swap questions
- How does 04 GTO PCM turn on A/C
- g-body mount question
- 25.5 Mustang Coupe project.
- Motor mounting problem
- What will run my cable speedo?
- tranny swap questions
- 2000 Corvette Alternator Connector
- ???? About Pulse Generators
- lh8 pan on third gen ls1 swap
- 2003 5.3L in 64 chevelle fuel system question
- Fuel Filter fittings options
- What is the most HP out of a carbed 6.0L with factory heads
- Finally got my 71 camaro ls6 running **VID**
- Rear GTO Oil Pan bolts
- T56 67 Camaro queston
- Whipple ls1 67 Camaro
- Mustang, LSx, and Powersteering pump...
- Need help with speedometer and pin 50 in ecu
- ls1/lt1 in my 87 fox
- Oil Pickup tube Question
- MSD 6012 cam sensor fail
- PRND Inputs?
- 2009 chevy silverado pinouts
- c400 connector location
- Swap ??
- Re-wiring 93 mustang body.
- Can I use factory guages with the conversion?
- 5.3 alternator question
- LS 7 powered kit car at the Ring -video
- Ls Swap into 64 Impala
- Is it possible?
- lq9 in a 86 buick regal
- 76 Camaro Alternator hits...CraP
- 5.3 swap in 86 K10
- Turn a LQ9 6.0L into a LS2 Motor
- Shit...
- oil pressure pin for a 98 corvette PCM
- ECU Pinout questions
- Removing Mechanical Fan?
- Will this work?
- gm tech 2 w/candy WON'T preform code 316 crank position relearn???
- Looking for LQ4 info
- can i use the variable compression A/c compressor?
- ly6 harness.gas pedal plug in?
- lq4 p.s pump hook up
- using MSD graphview for vacuum advance
- 93 f body clutch pedal/slave same as 02?
- L92 oil pressure sensor
- Wanted: Alternator pigtal from f-body
- 383 engine swap 87 trans am?
- Mustang guys with AJE crossmember....
- Starter Flange Broke & Cracked my Block
- What are the best factory heads for 6.0L??
- a/c makes my car start?!?! WTFFFFFFFF!!!!
- Ls1/t56 69 ta vert
- LS3 swap into a 97 Camaro
- two problems i can't solve!
- High mileage swap advice???
- do I have a fuel problem?
- 350 Hp + ~2800lbs... oh LS1 How I love thee
- Is it possible to use a pedal from another vehicle?
- 73-87 ck ls swap
- Air Intake Size
- fox body headers n driveshaft for ls1-dfw
- Corvette C5 Instrument Cluster swap
- whats the difference?
- Anyone ever make their harness from scratch?
- L92 in a Fairmont questions
- 96 T/A to a 98-02 T/A upgrade
- AC Compressor Question
- fan question
- gmpp intake port matching
- Blew up PCM while cranking engine..HOW!
- Anyone sell exhaust manifold flages to bolt to stock LSx exhaust?
- Fuel Tank Pressure Sensor Solutions (And Fuel Level Sensor)?
- Finalizing my wiring, please confirm pins 20 & 57 are constant hot.
- LS1 GEN III LS7 warhawk started...Finally
- fuel rail
- 4th Gen T/A seats into 2nd Gen T/A
- in search of 11's N/A
- Gen 3 F Body - LQ9 Questions
- No oil pressure on my new engine!! HELP!
- AJE motor mounts, what is the difference?
- 4l60e or 4l80e
- Swap body harness LT1 to LS1???
- quick q - intake manifold plug on edelbrock intake 7118
- ls1 swap in 69 camaro an want to do brakes upgrade
- alternator stuff for lsx swaps
- chevy II 5.3 swap
- LT1 swap into Chevelle - Cooling system problems
- which mustang headers for lsx swap??
- starter solenoid...
- crank angle relearn, with out break 5v wire
- Bought a c4 vette. Need some advice on this swap.
- Tell me this is going to fit.....
- LQ4 brake vacuum source... anything but factory nipple available?
- Best $120 EVER SPENT?!?!
- front accessories g body 5.3 question?
- clear powdercoat
- LH8 pan..
- Looking for help..converting a foxbox to ls1
- 1959-1964 impala rear end housing strenght?
- 1989 notchback
- Electric fan setup
- vacuum line question....
- idler pulley bolt. spacer needed?
- Vacuum Booster Connection on 69 Chevelle
- 1969 Chevelle Ls Mounts
- LS Mounts for 70-81 camaro
- Engine wont get out of it's own way
- LS2 harness with BCM help needed.
- Oil sending unit problems facts/myths which one?
- 4th gen fbody rear end in gbody?
- Best longtube for 1st gen lsx
- Walbro external pump ?'s
- 2005 GTO LS2: Where is the fan connection on the harness?
- 454 LS2 engine is in the car and fired up.. video
- 84 s10 ext cab lq9/t56 swap questions
- Three wire alternator not charging.
- Do I need VSS with TH400?
- DBW & DBC 2003+ PCM's, internal pictures, serv. & hwd no's.
- 2000 Camaro exhaust manifold flange?
- motor mount assist
- Exhaust movement
- 99 Corvette M6 Harness into S10 4L80
- LS1 BMW E30 racecar project
- 6.0 carbed forth gen.
- PCM Question - BMW/LS1
- Anyone have some ls7 exhaust manifolds handy...? Need a quick favor
- LQ4 into a 95' camaro V6
- coolant steam tube?
- Where to get sending unit flange?
- temp sender sits back in the adaptor
- my lsx 408 into my 94z28 or sbc350
- LS6 or 6.0 or hold out for LS3
- 67 Nova L92 swap
- 1967 Camaro 2005 GTO LS2: Wire fans off ECM?
- 98 TAC module for drive by wire question
- 4wd vs 2wd Tune?
- LQ4/4l80 El Camino Build
- Where to get the tool to pull the pins out of the coil connector?
- Oil pan swap?
- radiator hoses that fit chevelle radiator
- Off Set Shifters for T-56 swaps
- Black S-Dime Project...
- msd 6010 box question
- New 5.3L swap harness advice needed
- finished ls1/t56 s10
- Eldebrock Swap Headers
- 73 corvette 5.3 help
- Smaller power steering pulley?
- Modding a Truck harness help
- 5.3vortec in a 240sx wireharness help!
- The Blue Lagoon - BMW e30 - LS1
- Direct fit Heavy-Duty LS T56 Hybrid for Heavy/Powerful conversions
- did caddy use LS motors?
- 240sx ls2 pics / build
- Anyone welded up EGR on exhaust manifolds instead of blocking off?
- Part Number
- 3RD gen ls1 guys in here
- dorman steering coupler
- Fastest Single T4 Turbo LS Mustang?
- Turbo Buick 6.0L w/ TC70 Turbo
- is it wise to remove the EGR system? and how do you do it?
- exhaust coating
- Any one here running Hydroboost? having some problems
- Just saw this on the S10 forum
- Couple of exhaust questions
- Wiring/Tranny question.
- I need help !!!lq4 conversion
- 2006 LQ9 pedal assembly
- chevelle hood clearance
- Anyone use Moroso GEN 1 solids with their adapter mounts?
- really need some obdII help
- An older conversion
- LSX + Original AC 67-69 Camaro or 68-74 Nova
- 1990 mustang swap 6.0-t56 magnum
- dbw not working help please
- Hurst Hairy project, need thoughts
- mechanical temp sending unit - ok to drill/tap this plug?
- '51 Pontiac with 4.8L/4L60E, spring dust off
- best way to remove...
- Intake foam seal
- LSX with TH350 MPG?
- what color gray to refinish the engine bolts??
- Fox swap, truck exhaust manifolds
- fuel injection gas tanks
- What 4L60E dip stick for 70 Camaro
- Anyone know the Part# for the terminals in the pcm connector.
- 5.3 Jeep YJ question
- Wiring solutions?
- Power Steering Pump outputs - GTO, F-body, Corvette, CTS-V, Truck etc!
- egr block off plate
- what dipstick for a chevelle
- Which wiring harness for a Ls Swap?
- Just getting started on a ls1 car
- Difference between the GM 6.0's?
- 06 LQ9 & 02 pedal assembly??????
- 70 Chevelle SW headers
