View Full Version : Conversions & Hybrids
  1. LS swap clutch fork hits firewall
  2. header kit questions....
  3. Auto meter Pro-Lite tach doesn't have 4 cyl mode... now what?
  4. Converting...and mileage
  5. fuel line questions
  6. got a good deal on corvette regulator
  7. tube headers or cast iron ...???
  8. Mustang K member
  9. Another fox body...
  10. Ls1 Sensor ID Help!
  11. LS3 MAP throwing code P0641
  12. 1974 chevelle 5.3 swap fuel system and accesories help
  13. Convert Lt1 to 12200411
  14. is there any safety hazard on braided brake lines vs. hard brake lines???
  15. power steering hose...
  16. Project Time Warped Build Thread
  17. LT1 to LS swap questions
  18. 2001 6.0L fuel rail ?
  19. Spring clamps
  20. Can't communate with bcm?
  21. Help from the El Camino/G Body Folks
  22. Temp Sensor
  23. Exhaust
  24. fuel rail on ls1 for a 69 camaro
  25. crank voltage what's that?
  26. will the lt1 trans bolt up to a ls1
  27. 4L60E fitment ?
  28. what is this?
  29. Lets Talk Gauges
  30. Look for LS powered S10 on Pinks All Out
  31. 1967 F Body LS1 Swap Radiator What is everyone Running???
  32. Throttle cable?
  33. LS2 ECM harness help needed
  34. 89' IROC-Z LSX 383 Swap +AFR+T56 in 30 days or less!
  35. New bcm install
  36. BRP Muscle Rod's LS swap header's a joke
  37. L92/Ls3 wiring diagram 2007
  38. ls1 swap into 69 camaro help
  39. Ken's49 GMC project
  40. D.b.w question?
  41. Where to buy the connectors to make coil harness extentions
  42. Rear O2 sensor and cat delete?
  43. Headers & A-body
  44. LS Swap into 97 Chevy Truck
  45. 6.0 in a '47 Diamond T truck.
  46. Anyone recognize this pump?
  47. DO I Need to notch my frame?
  48. F-body Radiator Mount Question....
  49. Cruise Control on 2002 6.0L
  50. intake question
  51. ls1 79 camaro headers?
  52. harmonic balancer
  53. Colorado LS swap
  54. Project Resurrection
  55. LQ4 Swap questions?
  56. Z-gate shifter
  57. Trail Blazer LS2 accesory question in 69 camaro
  58. Can motor mounts be a work of art?
  59. Alternator
  60. L92 VVT Harness options
  61. 76 Camaro RS
  62. cts-v t56 swap
  63. diagnostic port... only one wire?
  64. a few ls1 s10 swap questions
  65. Not running VSS = engine dies?
  66. 5.3 swap question
  67. *Help* How to correctly measure engine angles on sloped floor.
  68. first gen f body oil pan
  69. Front plate engine mount?
  70. Do I need to move my Alt for my swap
  71. Drive Accesories
  72. Big Favor...chevelle brake line question
  73. Carbed 6.0 nova conversion??????
  74. 1967 camaro ls1 mpg
  75. twin turbo s10
  76. LS2 into a Chevelle with Speartech Harness, cutting the firewall....?
  77. 5.3 Truck TAC Module Compatability
  78. cam selection
  79. Wiring question and convert my mechanical fan into electric fan
  80. fuel line questions
  81. ls1 starts but something not right
  82. chevelle oil pan?
  83. EFI harness & ECM recomedations
  84. New Project Car
  85. vette oil pressure sending unit manifold...
  86. ls1 swap will not fire!!!
  87. Radiator help. Lower outlet too small for LS1???
  88. Need schematics for 04 GTO AC wiring
  89. engine problems helpppp
  90. Gas tanks II fuel Pump Senders
  91. how wide rear tire on 72 nova
  92. tach signal output wire????
  93. foxbody 6.0 LS SWAP
  94. Fox questions/discussion
  95. 91 mustang ls1 swap help?
  96. 4l60 trans wiring?
  97. Instrument Cluster LSX Decal
  98. Cali vs Federal LS engines
  99. New PB tonight!!
  100. Gas Tank Question
  101. LS6 Intake - vacuum line routing help!
  102. aje 4l60 trans crossmember (foxbody)???
  103. 1985 chevy 4x4 oq9 or lm7 swap
  104. newbie, with a newbie question.
  105. 6L80 Shifter
  106. LATEST Video LS2 V8 Miata March 2010
  107. Will a 2007 Denali alternator work on my s10?
  108. Ls6 Engine Harness
  109. Wiring 07 Monte Carlo SS pedal
  110. pcm tune
  111. 300zx
  112. cable TB on dbw truck intake
  113. headers for 72 Nova
  114. Guys With Holley Carb's...
  115. LSx accesorries fit Vortec
  116. finally got it done
  117. Oxygen sensor plug
  118. 68 vette, 6.0 LQ9, Richmond 6 speed build
  119. door panels...
  120. aftermarket wheels on a 3rd gen.
  121. Drive Accessories and brackets
  122. Oil Pan for 1969 Chevelle????? Any suggestions?
  123. Brake Switch to PCM - what's it for, and do I need it?
  124. 4L80E Park Neutral Safety Switch - leftover wires?
  125. Power steering issue
  126. 48-57 chevy trucks with LS engines???
  127. Lets see some pictures of your carb'd Ls's!
  128. Question for all you LS swappers out there.
  129. Heater Delete
  130. 4l60e trans lines???
  131. Lq4 into 98 z28
  132. LSX into a Dodge Ram, Anyone try this yet?
  133. Looking for '98 LS1 ECU Pinout
  134. Fuel Filter
  135. sn95 ls1 6 speed swap in progress
  136. Aje lsx motor mount? ..
  137. 2" LSX Swap Headers for 82-92 Cars
  138. Truck Fuel Cell Location?
  139. Pre 78 Midwest Challenge - Domestic Cars
  140. Few questions on Vette style filter/reg
  141. 240sx ls1
  142. Radiator Hose T - steam line part number????
  143. MSD 6012 question
  144. Corvette fuel line help?
  145. Camaro LS3 brackets?
  146. Edelbrock LS XT Manifold Dyno Test
  147. Flex Plate
  148. LS3/L92 into 1968 camaro heater hose
  149. sn95 mustang LS1 swap
  150. New engine / manual trans in '79 C10
  151. pro touring 93 s10 build
  152. What flexplate behind an LM7 with a TH400
  153. dyno numbers!!
  154. gto intake tube for my swap?
  155. Ls 4.8 ?
  156. 200r4 converter for sale in classifieds
  157. 6l60e or 4l60e out... question...
  158. lsx datsun people come in
  159. Fuel pump?
  160. 96 camaro LT1 and A4 into 96 Camaro 3.8 M5
  161. **** HELP**** Build almost done but.....
  162. 5.3 maf wiring
  163. Pinout LQ4 2004
  164. 99-00 LQ4, 98+ 60E, & LT1 converter??
  165. bmw considerations
  166. wiring harness modification question
  167. LQ9 rail mounted fuel regulator enough?
  168. 99-00 LQ4 w/700r4 , flexplate options?
  169. 300ZX LS1 swap
  170. 99 ls1 into a 98 3.8 fbody
  171. truck harness and fbody cluster?
  172. LS1 3rd gen first day at track
  173. GM Performance Parts harness?
  174. LM7 into a 92 Firebird
  175. hooker full length headers on 72 nova
  176. B.O.P. TH400 onto a ls 5.3
  177. 69 nova headers fitment
  178. L92/LS3 into 68 Camaro Newbie needs swap help!
  179. Long oil cooler lines, LS6 pump...-8?-10?-12?
  180. 2003 4.8 into a 2000 GMC Sierra 4.3 truck
  181. URGENT : i have a LS (lq4 6.0 ) flexplate bolt question
  182. Drive by wire issue (weird)
  183. O2 sensor codes
  184. A body guys
  185. LS1 conversion .. which trans to use?
  186. Grinding noise when accelerating hard!?!?
  187. homemade engine mount plate
  188. Rack & Pinion Fitting Sizes
  189. An Exhausting Question!
  190. Almost there
  191. Clearance prob with F-body water pump
  192. 6.0(best head gaskets)
  193. lsx-foxbody driveshaft length questions
  194. Fuel Pump issues
  195. chevelle just cracked another tranmission case...
  196. Where can i get an fittings for stock rails, and basic ecu tune?
  197. 5.3/th350 in lt1 car what tranny crossmember?
  198. Water pump plug size?
  199. oil leak with engine just sitting (Autokraft pan)
  200. Spectra EFI tank ?
  201. which adapter for gauges??
  202. Can you mix brass, steel, and aluminum pipe fittings?
  203. 1996 Firebird 3.8 harness plug id??
  204. My 1962 Belair project
  205. Plumbing an accusump
  206. quick fan relay question
  207. Dash options, What do you think?
  208. Transmission options for LQ9
  209. LS motor in a Lincoln Mark VII
  210. 66 Impala sedan 5.3/4l60 air ride
  211. 2000 silverado 5.3 remote start wiring?
  212. C4 LS2 oil pan clearing????
  213. Fuel line question: AN compression fittings, any count?
  214. changing trottle body
  215. '87 c10 with 5.3/4l60e
  216. LSx TTY bolts.
  217. 240lsx swap questions and advice.
  218. Who sells ls1 water pump spacers?
  219. LQ4 into '98 Trans Am
  220. G-Body info needed.
  221. 04 LQ9 Harness Help!!!
  222. Truck to ls1 intake....am i really going to lose torque?
  223. Block hugger headers, how tight are they?
  224. where to get ls2 style camshaft gear and bolts
  225. Standalone harness
  226. LSx 67 Camaro help
  227. choosing a motor for drifitng
  228. tranny to engine bolts?
  229. G-Body C5 Vette Frt Brakes w/ Blazer ZQ8 Spindles (w/ drawing)
  230. S10 wiring
  231. 1962 Impala Convertible
  232. Carbed Vacuum
  233. cam sensor location on ly6
  234. No cruise control??
  235. Is it possible to use the stock fusebox?
  236. Will theese mounts work?
  237. pcm question
  238. Smaller Type II P.S. pump pulley
  239. OPTIMA Batteries to sponsor the OneLapCamaro in the 2010 One Lap of America!!!
  240. Bat Wing oil pan
  241. 73-87 C10 ls1 swap guys, what headers have you tried that did or DID NOT fit?
  242. Help with ls1 gauges in foxbody
  243. Alternator question
  244. 67 Camaro ignition switch wiring?
  245. Wiring harness help; multiple components through one fuse
  246. EFI w/ GMPP Carb Intake
  247. what crossmember for t56
  248. ECU question
  249. Need some help 1989 GMC 1500 -wanna go 5.3l swap -few questions
  250. msd 6010 mounting ideas??
