- Under Hood Fuse Panel Diagram
- Power steering line sizes?
- Needing GTO engine mount brackets
- 4l80E shifter
- anyone running a turbo lsx first gen camaro
- Clean injectors and maf sensor
- Car will not start.........SOLVED!!!!!!!!!!!!!!!
- Help finding thread
- 5.7 vortec and 4.8/5.3/6.0 harness?
- 5.3 genlll oil pan problems
- Will harness and PCM from an 05 5.3 work on an 02 5.3?
- harness for conversion
- 240SX swap, AFM + crank sensor woes
- Computer for LQ9 and L92 heads
- Anyone Heard about or done an Lsx swap in a ranger....?
- 12628771 oil pan
- Data link connector...
- EGR block on 5.3 truck
- 1998 Alternator/Resistor?
- LQ9 Swap into 89 S10 Blazer
- 5.3/4l60e "for the future" build
- 2000 GMC Sonoma
- L92 with VVT/TKO600 swap questions
- Need Help 01' C5 Harness ECU wiring for S14 swap.
- L33 to 4l60E
- looking for a good source.
- Champ pan/oil filter adapter.. what filter!?!?
- 6.0 truck intake throttle cable bracket?
- Carbed mustang throttle cable?
- LS2/LQ4 into a Corvette C3
- GTO wiring question.
- home made ss silverado
- new to the LS world
- coil relocated
- Brake booster vacuum line on truck intake
- Harness Interchangeability
- 2007 denali XL L92 donor_ did I forget the TAC module???
- VVT swap oil system questions
- LQ4 and head milling
- 1998 mustang conversion started
- Best option for a 5.3 ..
- Problems with drive by wire
- anybody want a 65 chevelle?
- wanted : Coolant Pipes
- wiring harness help, power to injector control
- What transmssion did u choose for ur lsx build and why?
- thinking of going lq4 in my nova...
- LS1 Swap into 1988 Mustang
- Whats the skinny on the LQ4 engine? Going in a 94 LT1 Camaro
- 1963 impala ls swap
- L76 6.0 ltr inplant
- from truck water pump to car pump
- Mustang swap ?
- Truck harness ?
- 1967 Camaro RS/5.3 T56 Daily Driver Project All DIY
- Gas tanks for novas
- 1999 5.3L...Same as 2000-2004?
- Oil level
- mounts and oil pan
- Russell 640940 AN to quick release adapter source!!
- Vss
- Wiring and Puter Interface
- engine hoist to 5.3/4l60e combo?
- Block-off plate for automatic trans. bellhousing?
- lq9/lq4 gold mine. Everyone needs this link!!
- ..... Buy 6.0L or LS1 engine for Blazer K5???..................
- Wiring troubles
- 4th gen Lt1 swap to LSX?
- Quick question on mpg, 70 cutlass swap with lq4
- Throttle Body Interchangability??
- 67 impala ls1/4l60e headers?
- Crate engine depot pan?
- 04 gto LS1/A4 alternator clearence issue..on 2nd gen camaro
- 240sx ls1 questions
- Coolant crossover pipe modification
- ls1,4l60e swap standalone harness ??
- What else besides scanmaster to display motor functions?
- Any advantage to using newer ecm?
- LSx Into 1968 Cutlass
- Help Please
- need some 5.3 help
- Fuel line kit help
- My turbo LS1'ish focus
- please take a look.Do you know what this is?
- PCM stored mileage?
- anyone know about schwitzer turbos?
- Buyer beware:
- California Referee Questions
- WTF is going on here i'm lost lol
- To eleviate the confusion here, but still need help
- Engine harness's different?
- My 67 camar0 LS1/4l60 swap thread
- 76 Land cruiser
- Am I going toneed to notch my frame
- 5.3 into Jeep VSS Question
- O2 sensor help????
- DBW response?
- Need Expert Advise
- Turn on my E38 fans please!
- a few 3.8 v6 to ls1 ?'s
- 5.3 starter
- E-fan wiring, not using factory GM harness, have ?s.
- Intake swap
- Planning out 5.3 swap for my 79 Camaro RS
- Some AJE Fox K-Member Info
- Manual Pedals
- LS aftermarket parts interchangeable?
- Alternator is grounding the power wire?
- Tubular 5.0 k member, longtubes
- 1986 F150 with LQ9
- what year of engine/harness I have?
- new forum specific to ls-based fox body swaps
- for those that made their own harness
- Truck alternator on C5 bracket
- corvette harness?
- EGR Delete in Atlanta area?
- Adding charcoal canister
- Can I use this ecm?
- LS1 jetboat
- ls1 / cooling system
- 02 trans am gauges compatability
- Which alternator would be best for my LQ4 into an s10
- Torque Specs
- Has anyone bought one of those S & P EGR block-offs for LS1 ?
- 1968 stepside with 2007 5.3L starting system wiring???
- problems getting my 5.3 to run!!!
- L76 with T56
- starts then dies when switch is released
- swap?
- harness wires
- map sensor
- ok, im about to push this thing into a wall
- Fuel Pump Question For 84 Buick Regal
- '04 GTO into '91 FBIRD starts, wont run?
- transmission to engine bolt size/thread
- Harness/PCM for GenIV
- Trouble with gauges after ls1 swap?????
- ls1 in 67 camaro wont run with o2 sensor hooked up
- DBW harness to a cable TB?
- Swap LS1 with T56 into a 1982 Firebird?
- LS1 swap in Porsche backfire need help
- LY6 to 2004R
- Looking for some connector and pin information
- PCM fan question
- Info. on wire harness
- wiring up in tank pump (fuel rated wires?)
- 6.0 swap into 85 GMC
- 1946 Coupe Build Progress
- Engine wiring issue.
- 70 chevelle LS327 (ya i know its 325)
- (Project) 5.3 S10 Build
- ? about distributor drive
- will a be happy with a 5.3 on the bottle?
- Fox Body Swap from a 4cyl Car?
- 69 ls1 chevelle pics
- The retroitfit
- 99 5.3 or 08 lmg 5.3?
- 96 mustang Gt lsx swap
- Took me about 5 days..
- video of Some pulls in the 240
- need help with 05+ stang ls1 swap...
- Which bell housing for 5.3 with a 4+3 trans
- my 89 hatch lx 6.0l how fast
- Anyone deal with SPS Engines?
- LS/A body/Powerglide=what mounts,pan,flywheel?
- Cruise Confusion
- screw in air bleed upgrade anyone?
- Check out the vid. my 94 z28 with ls swap at track
- Carb set-up 5.3l in '86 c-10
- another fuel pump ?
- windage tray ..options?
- First start today, some codes though
- lt1 to Ls1 Conversion
- 700R4 behind a LY6
- Oil pressure sender info
- 1994 camaro 5.3LSX/TH350 swap 56k is dead
- Removing stubborn harmonic balancer bolt
- 2007 ly6 and 2000 4l80e
- Mass Air FLow Sensor
- f-body swap
- Ls headers in a stock clip nova
- Oil level sender?
- Lq4 with diesel 4l80e
- jeep wrangler 5.3lsx tranny issues
- Update on 95 rcsb LSX swap. NOW 6 speed!
- Delayed power on accelaeration with LS1 swaped S10
- ls1 or ls6 conversion help.
- 2000 LQ4/4l80E question
- nnbs silverado 4.3 to 5.3 swap
- No INJ pulse or Spark
- project x
- 3rd gen for ls1
- Turbo 6.0L/4L80/NP205 in 84 Burb
- ls1 t56 in 67 camaro need help !!!!
- Got my 5.3L and new parts
- E30-LS1 -- Hot Rod
- t56 behind a lq4
- LQ4 in a T-A
- 94' Impala-SS
- ls1 into my 91 c1500 swb
- Atlas I5 Wiring Help
- I had an audi lying around.. and a 5.3...
- Finally an Engine(LM4) What the hell is...
- 65 malibu wagon pro touring racecar
- Moroso Water pump Adapter
- fuel tank, pump with procharger
- police interceptor parts?
- 2003 silverado
- 1985 gmc s15 ls1/t56 project for sale or trade
- Is there a website that sells exhaust pieces??
- LSX +T-56 into......A Grand national.
- ? About Dorman Billet Fuel Fittings...
- LS1 and Vortec a/c compressor
- Read It & Weep!
- G-Body Malibu Wagon Computer Location?
- Req; Anyone got the 04 GTO wiring diagrams ?
- balancer pulley bolt
- Oil pan part #'s???
- manual valve body 4l60e
- Camaro floor shifter questions
- 2001 5.3L fuel plumbing question
- Transmission Line Clamps by oil pan area
- 1997 GMC K1500 LS1 Swap Info Needed..
- oil pan?
- guys w/ls to th350/400. what are you doing for tuning?
- What harness/ecu do I need to get
- Ls1 intake on lq4
- 3rd Gen LS Conversion K-member Question..
- LS2 swap into 96 1500
- 6.0 and fbody pan - how many quarts of oil?
- Single Turbo LS1 Notch Build *videos*
- painting an ls1?
- 1969 camaro with 2008 Zo-6 drive train and wiring?
- ls1 flexplate bolts
- Should I pass on this used 5.3?
- 19166568 pin outs needed
- LS1 in my C3 1975 vette
- need input on lq4 swap
- 4l60e years?
- 67 mgbgt ls1/4l60e
- LS1 race parts and conversion parts Hewitt/Waco Tx
- putting 5.3 ls motor into 95 3.1L 5speed camaro
- Project ls1 74 Impala
- E67 4l80E Need Help and Information
- Anyone know what size fittings are used on older GM steering gearboxes
- ls swap alternator buzzing??
- FWD to RWD conversion
- what do i need to put a ls1 m6 in a 79 malibu?
- wiring pinouts for 02 5.3?
- 02' LS1/T56 into 70 chevelle?
