- Motor plates
- LS swap into ford truck question
- Spectra Premium Fuel Injection Tank No longer available?
- selling my lq4 motor and turbo setup out a 02 gt. Includes fuel system
- need a little help
- Conversion price points?
- any newer swaps using the MSD EFI module?
- 2 69 Camaro LSX Conversions
- How painless is a painless harness for a lsx swap
- 70 Chevelle 5.3 with 4L60E begin
- twin turbo gbody?
- LS3 Z-VETTE Build thread
- Turbo LQ9 in a 70 Buick GS
- Has anyone modified MAC mustang 1 3/4 long tube headers for a swap
- Best standalone harness..
- which clutch for LS1 swap in a Honda S2000
- Coilpack relocation
- throttle body question
- ls2/4l80e in fox????
- ELEC. fans + LQ9 Truck motor = Impossible?
- Neapco u joint # 2-1153
- 6 liter swap gas mileage
- 04 Gto ls1 in a sandrail - no start
- 5.3 in a 71 Chevy truck??
- Another wire harness ?
- Help with power brake conversion on 1st gen, ATS clutch bracket still works right?
- glide on a ls
- Need Help With Fuel Delivery......
- please help dbw to db cable convertion?
- going ls1.. whats my 355 sbc worth
- LS swap into mustang
- vats?
- 69 Camaro update
- pulling wires from C2 fuse block?
- Steam vent/Radiator hoses/Overflow tank.... help!!!
- 04-06 GTO Fuel Pump/Pickup help
- LT1-5.3 Swap
- any tampa area motor installers
- ls 5.3 into a 68 firebird-exhaust
- Changing vin in ecu?
- MAP sensor 5.7 LS1 versus 5.3 Vortec....any differences??
- Do I need the stock oil pressure switch for the engine to work?
- FS: 1967/68 Camaro/Firebird Rock Valley EFI tank
- Stock 5.3 Fusebox diagram
- Where is the PCM orignally located on a 5.3 Silverado??
- Fuel lines for LS Chevelle swap
- decided on the CTS oil pan
- How do you splice 5 wires into 1 wire on your engine harness?
- ls1 83 foxbody mustang swap
- firebird
- V8 Swap S10....
- 5.3 which accessories 89 S10Blazer 2WD
- SS LS1/6spd identification
- trans adapter????
- I need fuel line advice!
- 1960 parkwood conversion
- th400 cross member
- ls1 replica longblock
- Green 59 - "Crank Voltage"
- Is a 15A fuse enough to power an LS1 DBW PCM?
- Headers and mounts for a 88-98 Truck
- LS1 conversion
- camaro headers on a fox body?
- Corvette power steering pump -an fitting?
- Finding parts to add distributer to LS
- Parts/Installation Tips
- Wiring up a LS1 Gauge cluster in a 94 Z/28
- Autokraft pan with a corvette windage tray
- drive by wire vs. cable throttle---throttle response
- 4L80E tranny to fit mustang shifter
- Z32 300zx - LQ9 swap
- Chasing head bolts
- Just another turbo 5.3 in a lt1 bird build
- Another MLPS switch question
- power steering pump questions for lq4?
- Need fuel system help/advice
- Questions / preferences
- How Do I figure out if I can do Cable throttle with my ecm?
- LS2/LS3 valley cover seals/gaskets??
- Emissions on LSX conversions in CA or NJ?
- Reverse Lockout
- Starting a second LSX 3rd gen Camaro swap - '89 IROC-Z
- Best Carb for LS?
- 68 Nova 4L80E
- What mounts work for me?
- Ls1 miata
- Some ls1 parts for u lsx project builders.
- New formula project!
- need help what is good cam for 4.8lsx
- Auto meter gauge swap
- LS1 to t45 5speed Pilot bearing
- LS6 Intake Question
- TR6060 & LS3 in a 69 Camaro
- what dbw pedal can i use?
- fastest single turbo ls1 notch back?
- anyone in socal to swap my cam?
- Need Advise 6 Speed for an LS3 in an F-Body
- My Daily driver S10, 5.3l
- My 95 S10 Nitrious 5.3 Drag Truck project....
- New Modified Magazine../Super Street? LS Conversion
- New Modivied Magazine../Super Street? LS Conversion
- Thinking about a DD Third Gen Nova...
- 68-72 a body.What kit works with an f-body oilpan?
- Truck harness
- ls7 on F-body
- Which MAF's are 5 wire w/built in IAT?
- Fuel Shutoff in accident?
- LS fox header pics.
- DBW / TAC wiring questons
- LS1 Powered BMW 325i
- need longer shifter cable
- Some exhaust manifold measurments
- adding to the collection, Typhoon 5.3/4L80E turbo build
- 1963 Impala Convertible LQ4/80E Swap
- alternator relocation
- 89 Notch which mounts?
- Move that Alternator??
- Weight differences in 5.3 Truck engines versus old school chevy?
- Any alternatives on bypassing VSS...
- 2002 5.3 PCM Pinout ?
- Help - need mini start length
- Wiring truck harness
- Calling all 67 chevelle Guru
- Intake Manifold Questions
- Fuel Issues / Starting to get my ducks in a row
- Swap Parts in FS Section
- water temp. location
- 92 Camaro RS LS1/T56. videos added
- 92 Toyota Supra 6.0lq4/4l80e
- 6.0L questions
- another 5.3 in an 85 c10
- Shifter relocate HELP
- Instrument cluster signals
- What is the guage thickness of the stock engine harness wires?
- New body style 5.3 wiring question
- Vortec Max....Good Motor....Good deal??
- 64 ss 5.3 4l65e
- best LS pan for my 69 Chevelle?
- stock mustang shifter with th400???
- Anybody using plastic/Aluminum radiators in A-bodies?
- Truck alternator wiring
- Nostalgia looking built LS2 in 69 Camaro
- 5.3 flywheel question
- Picked up an LS1 FD....
- Need Gen III bolt size
- wrangler JK, 5.3 no throttle dbw
- Lincoln Town Car
- 5.3 at a reduced price!
- LS swap but keep original gauges 84MCSS
- Has Anyone: LT1 To LS1 Swap Using LS1 Body Harness?
- LS1 Harness into LT1 Headlights
- Conversion LS1 Harness to Lt1 Fuel Pump
- re-working wire harness
- question how to convert a 00v6 camaro to ls1
- Best way to put Gen IV into 1999 Z28
- Wiring neutral safety switch with AAW harness and stand-alone
- PCM Reflash
- ls based engines in mustang chasis
- Need help with injector part numbers
- Didn't someone do a Procharged LSX in a Fox Mustang???
- lq4--ls2 clone...gen3 into gen4
- Found something for anyone with f-body acc. frame issues!!
- ls in fox alternator? with no ps.
- MSD 6012 question
- ls swap
- fox ls1 swap trany question
- LS1 in my 55
- 08 4.8 Harness
- Anyone used these Edelbrock Headers?
- lsx miata question
- Lsx miata
- Any experience with the new retro LSX oil pans
- 1986 MK3 Ford Capri (UK Car)
- Mustang 6.0/L92
- Skyline R33 getting LS1 / t56
- Possibly thinking about a LSx in a S10.. looking for some information
- LM7 in a 99 S-10, Guage help?
- Merry Christmas everyone!
- 5.3 wiring harness
- Questions about LS1 power steering hose attachement to a older 76 gearbox
- 81 Zephyr -Big Pimpin-
- fox body guys help
- Pics of the LS6 Tj
- LQ4: cold air vs complex intake routing
- alternator hookup CONFUSION
- Are my valve springs shot?
- will a ls3 w/p fit a lq4 with stock acc
- Im needing some advice
- Strange power issue
- anyone make Homemade Solid motor mounts?
- 70 chevelle- ly6 /4l80e vvt boosted
- Modded oil pan - losing 2.5 cups capacity??
- Compression Fittings
- Anyone Good With EFI Live???
- ANY help
- LS3 L92 dual plane carb intake
- PCM connectors
- post pics of your turbo fox
- engine harness
- hydroboost with drums only?
- LS7 into a solstice
- Stock ls3 cam
- ls1 maf to 5.3?
- Twin LQ4s in 30' Scarab on the cheep!!!
- 1984 Corvette "LS1" Engine Swap/Build
- Bolting 4l60E to 5.3 Problem
- Non LSx (yet) fiero need help
- G-body insight
- To anyone in KC looking for an engine, I DO NOT recommend Midway!
- AFM or VVT with a manual transmission
- LS conversion...engine & trans opinions?
- ls1 monster questions
- 5.3 in a 98 blazer questions or info
- Anyone know of a good source for trans tunnel/firewall heat shiedling(self adhesive)
- What ECM????
- Short Style Oil Filler Tube
- map sensor & 6010
- When did trucks start having DBW TB
- 2nd Gen. Camaro Owners
- Finally, it runs !!!!
- ls1 swap into 94-up firebirds air intake
- Jeep XJ 5.3 finally tested (video)
- oxygen sensor help!!!!!!!!!!!
- Exhaust flanges
- ok guys need help a.s.a.p Found a harness i need to know what all to pull.
- Need PNP (park neutral switch) wiring diagram or pin outs
- ARP LS1 rod bolt install into a 5.3L, need help
- How are you cleaning and detailing your 5.3 engine?
- best fuel rail ??
- rx7 7.0l v8 twin turbo build
- My 67 Camaro 5.3/t56 Writeup
- 2002 firebird swap
- Accessory Bling: Pulley Covers, Chrome, Billet, Paint, Etc.
- PCM for 5.3L to 4L60E tranny
- GMPP Distributor front drive users...come in.
- Anyone ever think about doing an LSX swap in a Porsche 944?
- Car Craft Magazine announces Engine Swap Drags Event
- 5.3 Idle Issues
- Engine controller choices..GMPP...speartec etc.
- PCM Tach output to original gauge question
- first start w/magnacharger
- 5.3 f/s
- Temp sensor questions?
- th400 or 4l60e
- Questions for the Fox guy's
- Bolt in LS1 swap kits for 4wd Silverado, K5 and GM trucks 1973-1987
- best radiator for a 67 camaro with 5.3
- LS1/4L60E E30? Has anyone done one yet?
- junkyard engine problem
- L98/L76/LS2/LS3 conversion - Knock Sensor Errors
