- MAF connector?
- PCM mounting options
- Inexpensive Gauges
- what to do with the rest of the c2 wires
- LS3 swap into LS1 CAR.
- Lq4 in ft.lauderdale fl
- limitations of a 5.3
- Engine start up with out ignition wiring
- connector source?
- removing wiring for electronic transmission
- Can someone confirm these diagrams for me?
- ly6 alt ?
- My Next project YOU decide!!!
- Can someone point me in the direction of were to get universal plug wires
- How do you plug the empty holes on a PCM plug?
- L33 Swap Help in 96 ZR2
- Project LSX Toyota P/U
- In the market for GMPP LS3. Who to buy from?
- Info on running only "high" speed fan?
- anyone here do a wiring conversion
- Power Steering Line Diagram
- BUDGET Has anyone used LS1 gauges, column, ac....
- L99/4L80E 67 Chevelle
- the merv
- ls1 to lm7 swap ?'s
- 2001 bmw e46 swap info needed
- Anyone use an ISIS wire harness?
- 1987 Camaro Z28 LS1 Swap Intro!
- Sbc with ls1 T56 guys.....Electric speedo?
- questions about th400 in 69 camaro
- LS1 with a York Compressor OBA
- fox to TTLSX
- LQ9 pin out?
- 5.3 Conversion WIRING HARNESS
- Pass Valve Cover on Driver Side
- t56 crossmember and hooker headers question
- 6.0l ?
- Cheap basic tune...Indianapolis, IN area...mail order???
- 5.0 to LSx motor mounts...anyone make them?
- cam recomendations
- ls1 Nova running
- O2 sensor confusion
- oil pressure
- does anyone know mpg for a carb 6.0
- How much of the wiring is necessary?
- LS2 /T56 into my -89 Iroc
- help with tach
- ECU and Harness from Truck
- Has anyone here use ATS bellhousing adapter to a BBC ?
- the lsx 93 z28 in camaro performers
- short starter body
- LS2 into BMW. Radiator plumbing question
- 3rd gen Camaro stock guage question!! Hlp!
- 98 harness and computer
- Accessory Bracket Question
- E46 Track only conversion
- baltimore area guys that have swaps on the road
- 70 Camaro 4L60E help
- LS^ Valley Cover?
- driveshaft angle
- LSX Datsun 510?
- dual or single plane?
- carbed, procharged ls1 valve train recomendations
- how to tell what year 6.0l? what years to stay away from?
- 2004r/flexplate
- O2 in the primary or collector - what say you?
- shift indicator lights 4L60E
- Twin Turbo Ls powered Zephyr - Stuff out of my mustang
- Plug and play L92...
- Vacuum port?
- Exhaust?????????
- accessory question?
- Ports above oil filter?
- bellhousing bolt question
- A Body swappers????
- How do you get that grey cover off the PCM plug?
- radiator hose(s)
- cheap turbo ideas for stock lq4? gt4202? hx35?
- Oil Pan For 1969 firebird.
- Front Mounting a C6 6L80E transmission
- 93 3.4 Camaro A4 to LS1 A4 swap wiring NEED HELP
- 88Lx mustang 5.3 swap
- LS1/Vortec pcm's and harnesses - what can be used together?
- painting my hybrid...
- 5.3 swap Question
- In-tank fuel pump in custom tank
- options
- 66-67 a body, what size front wheel/tire are you using ?
- auto shift linkage with 84 suburban
- Engine swap: will this pass emissions as a v6
- 6.0 into a 94 Camaro
- Turn the intake manifold on Ls1 180 dgr ??
- 67 Camaro 5.3 swap.... HELP PLZ
- 99 z28 for $1000 for a A body conversion, what to take off?
- Msd 6012 58x reluctor
- 63 nova
- Minimum requirements to start up a 5.3l
- clutch queston?? slave??
- 5.3 with a muncie 4spd?
- OEM evap connections
- oil coiler
- Selling Vic. JR carb intake and MSD box for LSx to carb conversion
- F/S: Kooks Fox Swap headers
- 4.8 Question !
- Another A-Body Going Sideways !
- GM quick disconnect fittings
- Need info: LSx into a 1998 Blazer
- 02 fuel pump in 68 tank
- 3rd gen LS1 headers
- electric fan question, yes I searched first
- 1997 camaro ls swap info
- Flordia trooper mustang
- Blown Ls1!! New ls1, used/new ls3? any suggestions for new motor?
- Nordstrom's Wiring Harness?
- 5.3 luv truck..
- 04' Mustang build...
- 2004 GTO PCM and 99-02 F body harness... compatable?
- 1985 944 Porsche with LS1
- third gen headers
- LS6 Miata Build-Up
- L99 Factory Take Out Engines!!
- Wanted 70 camaro Spectra EFI tank
- Fuel plumbing?
- help! on map sensor
- Important Fuel question!! Help plz!!
- ls1 with ford c4
- BMW E30-LS1 Swap Details!
- Power distribution
- Manual tranny options for LSx
- Changing set ups, complete 67-69 f body LS1 swap for sale
- 5.3l, vss, & th400
- 70 Chevelle and a 67 Camaro I'm working on.
- LS2 in my LT-1 f body
- Grab your tape meausure
- GTO oil pan, pick up, dipstick, windage tray
- help with ls1 mustang will not start!!!!
- Corvette Fuel Filter/Regulator with Speed Inc Rails?
- Almost ready 70 chevelle
- 00 ls1 motor and tranny in a 70 camaro
- 1990 Chevrolet 1/2 ton 2WD RCSB
- 5.3 sitting a long time?
- Fox Racecar Conversion.....
- New swap oilpan
- GM compatible temp sensor 1/8" NPT?
- speedometer
- Ok found an engine now what?
- Factory Elec. Speedo to TH400
- PROJECT: LS1 RX-7 Build
- LS6 intake on LQ4
- SEMA and California agree on titling specialty vehicles
- Which Accessory Drive Setup for 69 Camaro?
- Carbed 6.0 IROC-Z 10.22@130
- Remote PS Pump Reservoir ideas
- STICKY? Where to get an LSx engine? Look!
- Alternator????
- Generic 240sx motor mounts
- +99 Plastic tank plastic line delete
- Conversion Trouble Shooting
- LQ4 Swap - What to keep from donor truck?
- 5.3L Engine Wiring Harness on a Pontiac Firebird?
- Trying to perform LSX swap on a budget...
- 5.3 Alpha pan w/T56
- Not an Ls1, but an lt1 into a 2000 s-10 zr2
- Spectra fuel pump questions...
- 6 wire or 9 wire DBW? Help!
- 5.3 in a 87 grand national
- Ebay Seller that rewires ls1 harness?
- wiring questions
- water pump fitment question for LS1 miata
- it's runs
- LS1 swap into 79 wiring questions
- need info on swapping 5.3 into 98 TA
- LS1 alternator wiring
- Not sure where to start with the wires?
- CTSv Clutch master conversion
- 8.1L Vortec/Allison 5sp install into 56 Ford Victoria (info Needed)
- LY6/6L90 flexplate
- ls6 swap into 98 camaro
- need help picking which engine for 86 fox
- LS2 with GMPP harness quit on me-HELP!
- 97 ws6 to 2000 z28 swap
- Ok Got a prject and sticking with it 95gt LS1
- B-body conversion - GM full size 77-96
- ..... How will this shifter fit in this Trans T56?
- Carb tuning with a WB, after idle what next?
- mounting the ecm in trunk
- my ls2 monte project
- ls1/4l60e Iroc swap
- lq4 oil pan
- ls1 miata on spray
- 58' Chevy Pickup
- 6.0 Swap brings new life to Pro Street 85 S-10
- LSX in a front wheel drive?
- building a mid 60's car
- ..... Any fox body with T56 trans?
- wire harness
- magnacharged third gen
- LT1 T56 to LS1
- Need help with '99 T/A cluster
- What is this connector?
- LQ4 Power Steering Pump Lines
- Setting pinion angle.
- drive by wire????
- Unusual temp problem
- How are yall
- Can I put this cam in a 5.3L truck engine?
- Exhaust setup
- ls1 in mustang help with fuel pump wiring
- Help keep me from making a big mistake
- 66 nova wagon twin turbo duramax diesel
- Chevy II Nova Ls1 Header
- Which motor mounts for my El Camino?
- oil pan for 1968 impals?
- LS1 in 67 vette
- Transmission to engine bolt sizes?
- The yota lives.
- Toyota Pickup LSX Swap
- Aftermarket speedometer and 2004 LQ4, confused after search
- car will not start?
- 96 camaro rs swapp to v8
- quick ect sensor wiring question
- G-Body performance?
- ANOTHER CA swap dilemma (emissions)
- 84 El Camino Swap
- 2010 Lacrosse LS swap?
- Name that car. LS swap cantidate?
- need some help with the LS1 fox (wiring, tune)
- Experiences with LKQ Autorecyclers?
- HELP! LQ4 dies when pedal is pressed too quickly
- my 5.3 1970 k5 blazer,monster style!
- Need lq4 wiring help!
- is a smaller radiator ok?
- need an extra computer
- 5.3\4l80e conversion
- LS1 swap info needed
- LM7 vs L59 visual differences? E85
- Inline fuel pumps good for DD?
- help identify year of 5.3
- LS1 RX-7 dies at idle or very light throttle
- Standalone Wiring harness
- Will this cooling routing work?
- What swaps use the Trailblazer SS AWD pan and parts?
- Trans & Converter?
- Engine years for swap
- ls2 tacho help
- Aje fox k-member question...
- My Swap: 1988 RX7 - LS1/T56 w/ single turbo
- 2010 camaro motor/6spd.. conversion potential
- LS1/Porsche 911 Swap
