View Full Version : Conversions & Hybrids
  1. Carb size opinions
  2. Converting GM part to Inverted flare fitting size?
  3. 91 Fox Conversion
  4. DBW - Reduced throttle/power manual shift
  5. help! 06 5.3 vortec
  6. Cooling Fan wiring...Help
  7. help with 98 to 02 conversion
  8. 82' Imapa Needs a New Engine!
  9. Help!!! Truck won't stay running
  10. Turbo foxbody guys come in!
  11. tci flexplate with SBC converter
  12. factory ECM and harness or all aftermarket
  13. LS1 into 99 BMW Z3M Coupe
  14. Conversions ls1 to carb.. need parts and info
  15. pics of my ls1 fox
  16. 72' C/10 pickup
  17. 1990 Sierra TBI wanting to convert to LT1
  18. 67 camaro ls1 t56 mpg
  19. buying the autokraft pan
  20. LS1 second hand value and parts needed for swap to another car?
  21. putting a ls1 intake on a 5.3 need help with something
  22. My 300zx ls1 swap
  23. Tranmission Lines for Swap
  24. buick swaps
  25. quick headder ???
  26. Pro-Touring 68 Acadian (Nova) with L92
  27. th350 trans kickdown with a ls1?
  28. 09 nissan gtr, anyone heard of swap?
  29. help with starter on ls1 mustang
  30. 98 'vette LS! into 1997 Trans-am?
  31. Project sinisTAr - '78 Trans Am
  32. LY6 into a 79 C10
  33. 1991 isuzu pickup swap
  34. Another G-Body
  35. almost there, having brake line issues
  36. I am looking into buying a 74 BMW 2002
  37. LS1 brackets on a 6.0???
  38. Fuse/relay block for standalone harness
  39. Ls7 injectors vs resized stock ls1
  40. Tach problem on a swap in 97 camaro
  41. 5.3 71 nova
  42. v6 to ls1?
  43. Ls1 Miata
  44. 1972 "Heavy Chevy" LS1 Frame-Off
  45. ls6 vs lq4 hard decision
  46. pics of project ls camino.......
  47. need quick answer on TB before i buy. (noneSS)
  48. 67 Chevelle Wagon 6.0 project
  49. Factory F body Fuel Rail with lq4 coil packs?
  50. Wiring Harness Merging Company
  51. engine/driveline mounting angle?
  52. Noob with Question....
  53. coil pack wires
  54. lq4 swap in 2002 ss help
  55. BRP Chevy II LSX Conversion and GTO Pan for sale
  56. radio power problem
  57. How close can the MAF be to the throttle body?
  58. 6.0 in a 68 Camaro
  59. 0 mph VSS - 10 volt DC on output????
  60. wiring question
  61. 1968 OLDS 442 LQ4 swap
  62. 5.3l 1989 240sx Winter Build
  63. Project Hellraiser: 1988 RX-7, LS1-T56
  64. Well now I've done it...
  65. oil filters
  66. Any recomended racing shifter?
  67. Another LS powered Nova
  68. 70 Chevelle LS2 Melba Toast
  69. A Few Gen IV 6.0 Questions
  70. lq4 swap with gto headers, fox
  71. AJE Mustang Turbo headers FS
  72. 5.3/TH350 swap need help planning
  73. I want to see some LSx/T56 Swapped SN95s!
  74. New (and last) video of my M3 Swap
  75. Cant get ASP relocation idler bracket to fit?
  76. 5.3 LS1 Engine questions
  77. Ls1 Mustang Transmission Crossmember
  78. Headers
  79. Headers
  80. 98/99+engine and body harness
  81. Eg Hatchback Honda Civic With LQ4 in it
  82. Thinking about selling. What's it worth...
  83. cam selection
  84. BMW Ls speedo signal
  85. 1996 camaro. V6 to LS2 swap?
  86. Teaser vid of 73 Nova LS1 T56 w/ 70mm Turbo setup
  87. Southern Air e-fans
  88. replacing LT1 rag joint shaft with LS1 shaft
  89. Anyone using aluminum fuel line?
  90. Starting problem! Need help
  91. Speedo help
  92. How? Disable A/C and Power Steering
  93. 1998 Sonoma LS1 6-Speed Swap
  94. 1982-1992 Fbody BRPhotrod headers ??
  95. HELP!!!!!! ls1 to th400
  96. Freakin swwweeet!
  97. Adapter plate setback?
  98. Fuel Pumps keep failing
  99. NEW GUY 91 mustang lx 6.0 LQ4 have a few questions
  100. v-6 body swap question
  101. LS Turbo Kit in a First Gen Camaro Maybe ??
  102. Idle relearn anybody???
  103. pcm for 05 escalade LQ9
  104. A/C idle up ecu pin
  105. 99 WS-6 into 94 V-6 droptop
  106. 1999 BMW 540i E39 LSX LS1 Conversion
  107. starter and altenator questions
  108. Oil pressure problem
  109. *vids on pg 5* 6.0L LSX/T56 in a 1991 Z28 convertible
  110. Carbed guys what plugs are you using??
  111. Please help, swap questions!!!1
  112. Injecter swap
  113. Carb Intakes?
  114. AC line fitting with LS pressure switch port
  115. s10's using BRP/Muscle Rod headers?
  116. 5.3 iron block swap into V6 camaro
  117. is this fuel pump kit good?
  118. Specific V6 to V8 (LSX/LQX) questions.
  119. LS1 + T56 + C4 = Good times!
  120. Anybody have any feedback/experience with LS1wiringharness.com ??
  121. ls1 in an 88 fox.. In progress.
  122. Best torque and mileage?
  123. T56 swap info needed
  124. Power steering leaking at the gear box
  125. 4L80E in 67 camaro
  126. no fire input please???
  127. Realistic 5.3 swap price into third gen Camaro
  128. What coolant expansion tank worked for you?
  129. 700r to 6.0
  130. harness question
  131. AC Refrigerant Pressure Sensor
  132. BRP/Muscle Rods at LSx Shootout
  133. question 05 z71
  134. headers ideas for g-body ???
  135. Pontiac Phoenix 5.3 swap
  136. another rx7 from lt1 to ls1
  137. Looking for Mustang swap info
  138. Lsx notch...what to pull off an f-body
  139. Tach half-off
  140. WTB mustang swap headers
  141. where to get a oil cooler?
  142. What gauge setup do you all use?
  143. Cadillac Catera swap?
  144. a new beginning
  145. non-setback mounts in Nova = FAIL
  146. Which head gasket for LQ9?
  147. Can this be done?? Cruise control/dbw/05 ggto ls2
  148. 67 Chevelle 5.3 finally runs
  149. OMG ordering parts
  150. LSX454 in 67 Camaro??
  151. ls1 harness question?
  152. LS1 and LS6
  153. LS1 and LS6
  154. Another LSX Notch!! Got a few questions...
  155. 6.0 Headers
  156. Newbie install questions
  157. Budget 6.0l swap in a 92 S-10
  158. 2001 Ls1 donor motor and a 408 for turbo?
  159. IAT sensor
  160. Dynatech mustang lsx swap headers
  161. Tach not correct
  162. 06 gto ls2, A4- 1969 camaro
  163. Switched to a 408
  164. quick conversion mount question
  165. 83 RX7 - Change of Plans for me, no more Nissan KA-T
  166. Hedman Hustler Weld up Headers
  167. What cam for lq4 in a chevelle
  168. New project with a new car!
  169. Tach output looks DEAD.
  170. crank it
  171. Question on '98 stand alone harness
  172. 78 c10 update
  173. 6.0h in LT1 Camaro
  174. what year ls1 intake for lq4?
  175. 4.8 swap in a second gen camaro
  176. help me wire my 5.3, jeep wrangler
  177. mismatched swap: is this worth it?
  178. mismatched swap: is this worth it?
  179. Whats the average 6.0l HP ?
  180. Engine will not stay running at idle...
  181. Picked up a clean 85 IROC today, LH6/6L80 swap planned
  182. LS Engine/Tranny Alignment 67 Camaro
  183. affordable ls headers for mustang
  184. LSX 4.8 into a 79 Z28
  185. Compatibility of C5 clutch master to Camaro LS1 slave?
  186. 799, 243 5.3 and ls6 heads
  187. wiring harness ??? and o2 sensors
  188. LS1 Conversion into a 95 Camaro V6 Direct me to where I might need to go!
  189. (Carbed) Fuel Pump Problems...
  190. LM7 Hesitation at WOT
  191. 85 Cutlass w/LS1. Turbo Question
  192. heads
  193. Best 600 hp crate engine options?
  194. 944 Ls1 Tech Question
  195. buying junkyard engine tomorrow.advice???
  196. feul sysdtem questions
  197. Wiring???
  198. started but wont now, help please
  199. Wiring?
  200. Vin numbers and the engine
  201. Camaro fuel tank in a Miata?
  202. LS1 start up procedure?
  203. Carbed LQ4 W/msd 6010 question(F-body MAP)
  204. MAP Part Number
  205. ls1 accessories on 5.3 l59?
  206. s10 LS1 Long tubes from SBC s10 headers?
  207. Are O2 sensors needed?
  208. parts to install carbed ls1 in 72 chevelle
  209. Electric fan question??
  210. who to use for harness and ecu
  211. converting a LY6 to DBC
  212. 07 lq9 24 or 58 x crank sensor? = which pcm
  213. 87 vette, ls1/t56 master cylinder ?
  214. gauges
  215. Will stock manifolds work for my swap?
  216. o2 sensor pic request
  217. 3rd Gen Ls1 swap
  218. For Carb guys
  219. specific LS1 short headers
  220. 90Mazda RX-7 04 GTO LS1 implant
  221. lsx power. 5.3 or 6.0?
  222. DBC Van Years...
  223. Recommendation Needed for What to Delete (or not) in Stand Alone Swap Harness
  224. Ls1 in a ford truck!
  225. 06 corvette LS2, am i missing anything before I dive into this
  226. LSx (L33) / T56 in lightweight kit car..
  227. 5.3 Swap in 84 Chevy 2WD
  228. need help on 98 LS1 hybrid
  229. L92 into 3rd gen.
  230. DBW to Cable?
  231. V6 Fbody, swap to V8
  232. 6.0 and 5.3 the same size?
  233. oil pan kit
  234. Issues with vehicle not starting
  235. Carb to EFI gas tanks
  236. swaping a gen4 5.3
  237. chevelle install ?
  238. just got my LY6
  239. v band sealing and tuning
  240. 240sx LS1 drift car
  241. Dist. Conversion Parts List?
  242. FS. NEW S-10 LT's 1 7/8"
  243. msd 6010 with truck coils
  244. 87 Turbo Buick 6.0L w/ 70mm Turbonetics
  245. best fuel pump to run
  246. motor mount set back plate measurements?
  247. transmission won't shift. wiring?
  248. VSS signal? HELP!!!
  249. New Guy calling G-body owners
  250. Conversion IAT sensor
