- 87 Turbo Buick 6.0L w/ 70mm Turbonetics
- best fuel pump to run
- motor mount set back plate measurements?
- transmission won't shift. wiring?
- VSS signal? HELP!!!
- New Guy calling G-body owners
- Conversion IAT sensor
- LsX to half hybrid conversion
- What is a C5 corvette P/S pump shaft size?
- Wiring questions: Need help ASAP Please.
- Lq4 in 52 Chevy Truck project
- F-body backing plates vs Vette
- Ls1 runing to cool
- LS1 will not go over 3300 RPM ???
- Which Oil Filter for Autokraft Oil Pan
- LS6 Porsche 964 build
- quiet high flow mufflers
- What coolant overflow/catchcan do I use with LS radiator?
- 68 impala-lq4/4l80 swap
- need help with parts list for a 66-67 ls1 swap
- Temp sensor question
- New to LS1's my hybrid Porsche 911 (10/3 need help vid last page)
- one radiator fan or two?
- Air inlet diameter
- L92 fox mustang build
- Carb cfm
- Looking for Alternator Brackets
- Coolant Temp Sending Unit for Gen I SBC Car
- Hotter Thermostat for LS1?
- Identifying L92 heads
- Videos RIPPIN it up! ...at the AIRPORT too!
- awd to rwd conversion
- 2004 caddy XLR. LS swap
- 351 headers in a fox swap ?
- L92 Partial VIN or Casting Date
- Fuel rail covers on a camaro?
- sooo how about some input on AUTOKRAFT
- Fuel line plumbing with corvette fuel filter/Reg....
- LS Coolant Temp Adaptor any good?
- alternator
- 93-97 camaro guys GET IN HERE!!!!
- Source for Vintage Air Front Runner System
- lm7/4l60e swap
- 5.3 swap into a 67 camaro question
- whats all needed to swap a ls1 into my envoy?
- buy tuning software or get mile order tune
- Can some tell me what sensor this is?
- what are the pros/cons on having o2 sensors?
- 4L80E driveshaft needed
- retrofit kit from edelbrock
- Need some advice on brakes!
- preparing for a 5.3 M3 swap....check my work.
- LS3 DBW with a TV cable - Possible?
- ls1 6.ol iron block into a ls2 goat??
- will swap crank with a stock pcm?
- will 2010 camaro intake /coil covers fit ls1?
- injecters.
- screeching!!!!!!!
- alternator wireing problam??
- What idle MAP pressure have you guys seen on higher lift cams?
- The coolest car at Goodguys Texas
- What PCM/harness to use
- Nova Done... Almost Pics and Video Inside...
- Can u guys post pics of ur custom harness installed?
- something for the near future
- Questioning ability to do a swap, please enlighten me
- LQ4 conversion in a 69 camaro wired but nothing?
- Coolant line
- Possible vaccum leak?
- starter for a 5.3
- were to get good blowthru carb?
- Carbed cam opinions
- Need a little help/advice on truck fuel rail options
- Chevy Vega 5.3
- Fuel Rail Covers (What Fits?)
- lq9 ---> c5 vette
- For sale / advertising
- hydraulic clutch or no?
- Seeking rail info!
- bcm pinouts for 2007 denali
- Recommendations for Simple PCM/Harness
- Oil pressure
- What temp do you guys have your electric fans turning on and off?
- ls1 fox roller f/s
- LS1 E36 M3, wheels back on the ground
- which ls engine to choose...?
- VVT LY6 into my 1994 Firebird Formula
- A different type of conversion.
- ls7 valve springs
- 6.0 short fan clutch???
- 97' Z28 need some help
- LS1 into 55 buick
- LS-1 4L60e into 72 Camaro need help ordering fuel sys parts
- 4l60e, which cables needed ?
- BRPhotrods
- LY6 on its way
- 83, Malibu wagon. In tank fuel pump?
- Check out this action shot!!! My Chevelle LS1/T56 swap.
- boreing a 5.3
- edelbrock engine mounts and headers?
- witch radiator and cooling fans to use
- question on power steering hoses???
- 1999 and 2000 gauge cluster
- max safe bore LQ4
- Intake help?
- fuel pump
- My project for sale :(
- Pinning for z06 MAF/IAT connector???
- Conversion Track Times
- flywheel and balancer
- LS7 alternator wiring
- LQ9 Drive Setup
- Loss Of Oil Pressure Shuts Off Fuel Pump???
- radiator hose p/n
- Thanks Cash for Clunkers
- Which clutch?
- Who's going to Goodguys at TMS this weekend?
- Transmission kickdown for th350?
- valley cover
- Searched, didn't find the answer
- 5.3 z28 or 5.3 ss roll call
- Ls1 swap in 71 chevelle w/6 speed
- L33 in Porsche 911
- LSX454 Crate Motor Availability?
- oxygen sensor wiring question
- Problem with conversion using 2005 LQ4, will not run off idle
- quick question - electric fan
- a/c wiring info needed...
- LS7 oil pan for 69 camaro
- quick question msd 6010
- oil pan windage tray
- for you LS swappers looking for a front-sump oil pan...
- i know this is the wrong place to post this
- DBW harness ok to use for my swap?
- LS1/2 swap into an '03 Mustang GT
- Longtubes for 72 camaro ls1m6
- header question
- ls1 thunder lsx harness
- Let me get this straight (oil pans).....
- exhaust manifold studs
- ls1 mercury capri build almost done!!
- Foxbody EFI 6.0L LQ4 & T56 swap
- 67 Nova stock clip conversion
- S&P early mounts header in 67 Camaro
- what is a LY6
- 4l60e issues
- turbo lq4 02 mustang gt For sale
- LS1 into 85' C4 Corvette starter wiring question
- LH8 GMPP Muscle Car Oil Pan 4 Sale
- L33 Conversion in a '90 Miata
- L92 guys - where do you get your tach signal from?
- connector ids
- Ls1 51 Chevy truck rat rod.
- lq9 swap, what cam?
- 66 Chevy II w/stock clip???
- How far can you go on the stock 98 return style FPR?
- parts for sale
- Rear Differential Mystery?
- how does a PCM pull a 0522, 0523 code
- g-body with LQ4. What exhaust manifolds?
- LS2 fuel rail covers
- Got Banned at the Corral....
- different release bearing
- AMC Pacer with LS
- VVT / Corvette acessary drive
- Which one do I want?
- scrapping factory harness so I need advice.
- Inline fuel pumps
- Moroso oil pickup, possible problem?
- Project PT-57, 1957 Chevy Pickup C5/C6 Corvette Suspension
- Porsche 911 LS1 Swap need Help!!
- newb
- LS1 Power Steering Delete for Hot Rod Question
- 1994 ECSB 5.3/4L60E swap
- LS2 TB to MAF Elbow Help!
- Red Connector Pins 20,21,50 Wiring gurus need help!
- ls2 hp number with a carb set up
- ID LQ4 from vin or casting numbers
- Malibu 80
- 5.3 L33 cam specs...marine use????
- Lt1 or LSx in Audi A6?
- What wiring harness for LQ9 into thirdgen f-body?
- Lsx into 1st gen lightning??
- 1967 camaro idle 3000 rpm
- VSS for fox body ls1 swap
- 67 Camaro LS1 Swap Project For Sale
- LSx mounting to a D&D t56
- 1968 cadillac convert lsx powered?
- LSx in a Volvo 940?
- '87 c10 5.3/4l60 swap
- My LQ4 Fox build
- fuel system question
- Thinking about the 5.3 swap into the 94Z???
- Just another 5.3 IROCZ swap
- Need planning help for 4runner swap
- Kenne Bell supercharged colorado
- Nova LQ4 swap
- motor mount kit/headers
- going to scrapyards, need TAC and Pedal options
- Edelbrock Headers / GMPP conversion pan ?
- Dyno Day TOMORROW!!!!! Taking bets....
- Location of engine Vin Number
- Conversion Wiring Help
- 72 chevelle wagon with 570hp ls1
- FUN, QUICK and EASY LS engine conversion
- 90 ohm fuel sender wired to pcm?
- 63 Chevy Truck Project Help
- What do I need to pull from a corvette?
- Anyone ever put a 98 PCM/harness in a 99+ car?
- water pump options?
- LS1 in a 2000 Mustang
- LS1 Intake, what would it cost me?
- BMW e36 LS1/M6 Conversion Project
- L33 lsx fd rx7
- 96 LT1/700R4 into 66 Tempest wagon?
- Range Switch Wiring
- Need your input. 66 Belair Wagon / LS1
- Relocating coil overs or..
- Casting Failure on Non EFI Victor Jr
- Which pin needs power on stock harness to bypass security (Vats off in pcm already)
- Need Electronic to mechanical speedo conversion
- Fiero manual steering box/rack?
- 5.3L swap questions
- Quick question about wiring the DLC
- Where can i get 5.3 to ls1 fuel injector adapters.
- LS1 install 56Nomad
- Mounting corvette fuel filter question..
- 4l80E trans available...
- Flywheel fitment question
- Carb'd ls1 into 95 rcsb silverado
- 77 Nova with 5.3 (motor in, and running)
- starter wiring - is msd's wiring diagram correct?
- 66-67 chevelle ls1 plates which style do i need? i added pics
- external fuel pump location problems
- Carbed built SBC into F-body
- Orientation of Fuel Pump Relay
- New Stainless Works Swap Headers FS
- L92 head guys
- newb question on ground bolts
- Leftover Truck Intake etc.
- Porsche 944 5.3 Advice
- LQ4/200r4 VSS ??? What to use?
- C6 Corvette Ignition Button?
- Water temp sensor question, HELP!!!!
- v6 to v8 fuel pump problem HELP PLEASE
- painless wiring - coolant temp, wire cut off
- Ford to Chevy universal joint?
- Fuel Pressure 40PSI?
- my LSx 1968 VW beetle...VIDEOS.
