- I NEED 04+ YOKE for 4l80
- ls1 knock sensors on gen IV engine
- Big LSX in 69 Camaro
- 67 chevelle lq4 6.0 finally running
- TAC trouble
- cleaned up the engine bay
- custom plug wires
- kwik performance A/C bracket....feedback
- Vintage Air GEN IV and LS PCM drawing
- wont stay running - wiring issue?
- which oil pan gasket?
- 240sx questions!
- Fan/Relay troubleshooting help Please
- Is this an LS1?
- corvette gauges
- my 2000 S10 LH6 5.3l swap is done!
- Project 5.3 in Jeep JK
- 200R4 Flexplate New Part Number
- LS1 in a 240
- 1963 chevy impala with 5.3
- "Y' shape cold air intake
- Post your G Body Combo's and E.T.
- Height of Frame mounts
- LS1, LT1 rad., B&M trans cooler, TH400 - routing lines
- time for a change
- getting parts together for 69 camaro, LS1 swap
- thanks to the guys who helped on my A/C setup info
- 2004 LS1 GTO harness connector identification
- 6.0 with auto tranny in 90 mazda b2200 std cab
- Muscle Car/LH8 Oil Pan Capacity
- Message center??
- wiring harness
- A few conversion wiring questions!
- Cadillac CTS-V oil pan
- Recirculation Actuator Control to fan control
- ls2 90mmtb on an ls1 w/dbw
- 5.3L engine conversion questions
- A4 guys, what you using to shift??
- good parts for sale,,in my chevelle,swap,
- MSD 6010 dudes- MAP table?
- G-Body LQ4 swap headers..NEED HELP
- accelerator pedal and tac module
- just wondering
- Dakota Digital Dash on Carbed LQ4 G-body Cutlass
- lm7 is wining the battle.
- Finishing LS1 swap and run into trouble
- 98 Z28 into a 95 camaro v-6
- Help me determine what year LM7 this is.
- Salvage guy unsure, need LY6.
- Compression ratio
- Duramax Camaro
- oil filter adaptor for champ / autokraft pan?
- A/C compressor shut off using PCM?
- Swap
- oil pressure gauge
- LQ4/200r4 Bellhousing Bolts?
- switching over to f body intake from truck intake....?
- CSR Thermostat housing HELLLLLPPPP!
- 1990 Mustang LX Hatch, LS1 Swap
- Small Air Cleaner?
- Hooker Super Comp swap headers and motor plates fs
- LS3 harness help
- need info on the msd box
- relay harness
- ls1 foxbody nearing completion but have a ? about some wires
- my lsx swap
- Procharger and A/C in an A body
- brakes question
- Anyone know, Swap out a Volvo Pentar for LS1?
- LS1 Guru's? 5.3/6.0/6.2 questions!
- Home made tight clearance AC bracket / tensioner
- Another turbo 5.3L fox notch drag car
- Wiring help, 5.3 truck harness into s10
- confused on vacuum ports
- 93 s10 Blazer lq4 swap started
- 5.3 in a 69 f-body intake question.
- EVAP Issue- LT1 2nd gen Firebird
- WTB CTS-V pan kit
- LS1 to LS2 camaro WILL NO START NEED HELP!!
- Turbo thru GM intake.
- bolt sizes for head at front/back of engine
- Fuel pump noise
- oil pan install?
- In line fuel system for Studebake Avanti LS1
- headers (pics)
- The TRANNY TRASHER has struck again
- Bout time to start my build, 88 S10 4cyl to 5.3 turbo glory
- Heated O2 Questions
- low oil preasure fuel shut off
- 69 Nova LS1 Swap
- Help with headers
- Lq4/lq9
- ls1 into vega
- DBW - no throttle at all after install....
- pulling water pump pulley
- Electrical/Wiring Guru's Please Double Check
- 04-08 Grand Prix/MCSS/Impala Thottle Pinout
- Smaller diameter LS3 flywheel
- turbo guys. these the perfect up and forward headers?
- ok to wire aftermarket gauge power here?
- crazy idea LSx into 60-70s Toyota?
- Second time @ the track for 5.3L 96' S10
- 93 Trans Am LS1 conversion help and advice needed
- 64 Chevelle what combo works
- a body ls1 headers
- What's a good source of GM part numbers?
- Turbo help
- Wiring harness question
- How much is too much to cut from the Oil Pan?
- 5.3L with T10 in 1981 Trans Am
- PCM mounting brackets... what are you guys using?
- LSx into Foxbody in Cali (smog)
- Mustang L92 conversion that runs 9's
- Another "wont start" thread (sorry)
- mixed harness for firebird
- LS2 mechanical clutch
- fire damage LQ4
- '56 Chevy - brake booster too big...what to do?
- Help 4l60e 5.3
- Wiring Help 2004 Truck Harness
- Throttle linkage (LS1 Mustang)
- swaping 1990 s10 with a 6.0 LQ4 what do i need
- tach will not work
- A-body-LS Friendly Center Link
- 85 Buick Regal 5.3/6.0 swap cam question
- switching MAFs?
- proportioning valve help
- LS1 in an E31 8 SERIES BMW- How much would a shop charge for install?
- starter problems
- crazy tribute car
- black connector under dash
- new motor, car wont start
- BMW e39/e46 instrument cluster interface
- E40 ECM/TCM with 05 4l65e
- Coolant temp gauge 240sx
- Pinks all out in Famoso
- Headers for turbo LS1 RX7?
- 78 c10 5.3 swap
- LS1 harness questions wire gauge/type and weatherpack info
- L33 throttle body
- Good Cam and spring selection for Carbed LQ4?!!!
- Engine lift points-Help!
- 87 bird, 6.0/4l80 no start
- 1993 Mazda RX7 w/1998 LS1 Installed w/Hinsons LSX Kit Auto Trans.....
- My LS 86 Mustang...RUNS 9.60@139.9
- help with gto power steering pump
- ls1 swap 78' transam
- 98' M3 with LS1 first fire up!
- Carbed ls1 advice
- Throttle Body Modifications??
- IL - FOR SALE 1995 BMW M3 – 402 CI LS2 6 Speed Conversion
- question about a swap, OBS chevy or Dakota
- carb car - fuel pump question
- swap?
- 03 350Z 5.3 swap
- Hurt motor, time for a LSx swap.
- how do I build max torque? GN (lc2) going LSx?
- GM. muscle car pan kit.
- In need of some input for a swap
- 02 vette fuel filter not working on my hybrid
- Blowing ignition fuses.
- quick question on water temp sending unit location
- LQ4/200r4 Stand Alone Harness INSIDE
- GM Headlight switch pinout
- Some pics from my lastest wiring job 56k beware
- Help v6 to ls1
- Dynotech mustang ls swap headers
- First Time at the track with stock 5.3 in 96 s10
- Lq4 EGR intake block off. Pics.
- LS1 Notchback FoxBody = 2140 lbs complete
- HELP W/ 2004R-lq4 CARB LINE PRESSURE & KICKDOWN LINKAGE?
- header question??
- 6.0L w trans for sale
- T70 5.3 mustang?
- Throttle by wire not working and no spark
- KEVKO oil pan for Chevelle or other muscle car
- Grounding issue? (3rdgen bird/lm7/t56)
- Is this a good deal.. need answer ASAP
- ls1 gauge cluster wires
- where to buy new pins?
- injector problems on 69 camaro ls1 swap
- Pics of my now completed 67 Firebird with LS1
- Need some wiring schematics
- wich headers fit with carshopinc plates 67 camaro????
- MSD 6010 box users step inside
- 1st drive in 8 months
- Ground clearance
- truck intake or stock f body
- If you weld or use chemical cleaners, READ THIS!!
- Header Question???? what are you running?
- cheapest way to get 350hp at the rear wheel?
- 700r4 in 78 chevrolet truck vss question
- It just keeps going faster.
- DBW ECM / Cable TB
- Harness terminology
- LM7 + Z06 cam question
- 98 fuel line info at the tank
- looking for LQ9CHEVELLE
- a4 to manual 6 question...
- Fuel tank and pump from a Caprice or Roadmaster?
- AC Wiring help....again
- so my brother says ( A/C guys)
- ...... My Fox body LS1 got low hp please help me ?????
- Datsun 2000 Roadster
- 6.0 and 4l60e
- L59, l33, lh6, ly5, lmg, lc9, lmf, ls4, l76
- ecm ?(gto/l33)
- Scored!
- Fuel question
- Clutch recomendations
- Update! Chevy II Ls1 Carb T56 Distributor Conversion PICS!!!
- 92 Buick guages in a 71 Chevelle
- Looking into doin 5.3 or 4.8 s10, need answers
- Harness help
- (Need Help) Tourqe Spec
- 5.3L LM7 in a '60-'66 Chev truck...
- need measurements on z06 cluster.
- How many here keep the coils on valve cover
- whats a good cam for carb set-up
- Fox Swap Guys Come In
- Those with 5.3 thirdgens, I have ?'s
- Worst piece of crap i have ever seen
- ls2 gto oil pan
- Stuttering above 2200 RPM
- No power out on ECM fuel pump wire
- uhhh? Wire people? you said this was easy!
- camaro rs to camaro ls1
- Need help car will turnover but not start.
- Which speedometer will work?
- vacuum lines
- 5.3 Vortec in 1970 Chevelle?????
- DGR Fabrication x VERTEX | LS1 powered Lexus GS
- Are Down Pipe O2 Sensors The Same?
- 2007 6.0 questions
- Engine Choice Question
- LS1 motor mounts for a El Camino -69
- 6 cyl to 8 conversion need help
- Just scaled my 68 LS1 protouring nearly 50 50
- 13 pin connector on 4L60e? (TH400 swap)
- turbo turd s10
- Want to put intank fuel pump in a 20 Gallon tank
- 78 Caprice Henry's LS1 car - Alive Again - vid
- Its alive!!!!!
- GTO AC Compressor vs Vortec truck compressor??
- My '62 LS1 Nova starts right up
- brake switch wiring...ok to leave alone?
- Need help 98 corvette wireing harness OBD-2 port
- Anyone want to trade LH8 pan for stock Fbody?
- FS: 55-57 side mounts and poly mounts
- truck intake clearance.....
