- Looking for Diy header advice
- 1966 Caprice (think Impala) 6.0 Swap
- Carb to EFI
- repinning PCM hard???
- LY6 with L76 intake
- Autometer Tach Reading Incorrect
- help mating t56 to lq4
- Ebay Stand Alone
- Fuel fittings
- K member question
- Question for the G-body owners
- Mix & match accessory drives?-1 style alternator bracket mixed with another ac & ps?
- have any of you heard this
- clutch pedal setup
- Where to buy Walbro GSL 392 external pump kit
- LT1 - 2 holes above oil filter??
- what wire is this?
- Lm7 + ????
- A/C problem (or ???)
- need connectors
- DBW Response?
- PCM Mods/Tuning Questions
- Long tubes for a '74 C10
- Help on a leaking theromostat and neck
- lt1 6sp pedals
- 95' LT1 powered by '02 LS1...Question inside...
- stock f-body exhaust manifolds... which ones are not cast iron?
- Camaro 67 Ls1 headers and steerings for best clearing and ground clearanse
- Smog Question - Evap Canister
- Wiring Harness
- Is this engine/harness combo compatible?
- patriot head package vs. CNC porting
- Throttle cable recommendation for A-body swap
- LSX 1986 camaro
- What Do You Think?
- 1981 CJ5 Jeep - 5.3 Swap - Power Steering Pulley Issues
- tube size to an question
- LS muscle car oil pan kit, anyone use it?
- LS2 swap
- Head bolts torque specs
- Interior wiring
- LS1 to a 6.0L
- LS1-F85 hits top speed record
- 68 C20 maybe LS 5.3
- GTO LS2 Oil Pan Assy
- LT1 to LS1 converison
- LSx F150?
- Engine stumbles during acceleration
- Help!!! Stop and look at this!!!!!!!!!
- Need some help w/ carbed 6.0 cam choice
- 98 Wrangler pics
- Yet another 240SX Swap
- 650 Code?
- 70 Camaro LS2 / 6 speed
- Starter works intermittently--any ideas?
- modding oil pump pickup tube (f-body)
- LS swapped yota
- 6.0 swap
- Wiring Harness For LT1 to LS1?
- LS1 ac in an lt1 car
- speedo sender with dakota digital
- mp t70 "1970 chevelle" pics
- 99 model 6.0L swap wiring harness
- Radiator and fan for '56 Chevy with stock core support?
- LS6 or LS2 intake for 5.3?
- New LS1 conversion does not want to start--any suggestions?
- ls1 into 69 GTO (fuel tank)
- 2005 Silverado 5.3 to 4L80E
- ls1 crank pulley onto ls2 crank
- LS1 Swap for a 55 Belair
- Running an LQ4 without o2 and maf?
- OBDII port wiring question.
- LS Carb setup height...
- Anyone here seen an ls1 transplanted into a 04 Mustang?
- Questions for those using CSR 911LS1 thermostat housing
- My SN95 LS1 T56 Mustang project
- help with carb set up on LS motor
- my 70 chevy k5
- Exhaust?
- ground wire/negative battery plan
- ls1 in a 02 v6 camaro
- L92 in an SN95... Questions
- Overheating issue
- removing head to fix
- L33 Datsun 510
- Neutral safty switch
- LS1 in Fox transmission questions, Keep 4L60e or go with TH400 or Glide?
- 85 Monte SS LS1/T56 pics
- 6.0 liter oil pan
- Fox Body 6.0 lsx build
- Another LS1 240Sx
- GM Artwork - "LS6" & "Heartbeat of America"?
- LS1 into a 94 LT1 camaro...
- Cruise on DBW 2004 5.3
- LT1 swap wiring tard.
- Wtf?
- Hot floor pan!
- (5.3l) LS engine swap into a 72 chevelle ss
- need help with wiring 04 gto harness
- 68 LeMans - LS1
- Transmission options
- LY6 - Vacuum port???
- POwer steering reservor cap?
- if only using one fan, which on high or low
- 1981 Chevy C-10 SWB
- 5.3 Struggles
- LS1 to older over drive tranny
- 1989 Chevy Silverado 1500 5.3 swap
- Alternator warning lamp
- Do car and truck balancers interchange?
- 96 3.8 bird to 00' 6.0 swap??
- Fsm?
- 4l80e surging
- Going from a 5.3 to a 6.0, Any Changes Needed?
- Swap items for sale
- exhaust question for ls1 swap
- 1968 GTO LS1/T56 Conversion
- Looking for an upper radiator hose
- Lean condition at wot
- LS1 into an 82 Malibu Wagon
- First fire attempt a dud :P
- Fuel supply system cost big $$$
- front wheel/tire size ?
- Civette's new swap LSx WRX
- water temp sender
- thinking about selling my procharger lsx transplant kit
- Cooling Fans and relays?
- LQ4 running poorly please help
- Single Turbo Ls1 in a 1997 wrangler
- 4.8L 1995 Firebird
- Cruise Control in LS1 240sx
- 427 LSx TT Terminator...
- The only swap I haven't seen.
- need first startup advice
- 1997 Jeep Cherokee LS1 conversion
- 1967 Camaro with Carb'd 5.3L LM7 + T56
- S14 l33
- Vats
- gauge cluster help asap please
- Fox body lsx swap parts f/s
- 1965 El Camino
- Truck Harness - LS1 Alternator Wiring Help
- Overheating / coolant question
- help me finish my car!
- Abbott Cable X is kicking my tail
- Problem with lq4
- erratic tach and loss of fuel pressue
- DIY S14 Motor mounts?
- 240 project!
- Good news/bad news 2004 GTO LS1/6speed
- 5.3L L59 with backfire on accel
- Air conditioning
- LSX-T56 w/ BigStuff3 EFI in '57 Chevy
- my 5.7 fox coupe build
- It's ALIVE!!!
- WTT: converted M6 harness for untouched M6 harness
- Factory LSx engine in Colorado/Canyon???
- new track times for the S10
- Power Steering Control Valve
- trickey64
- Another LS6 Miata, NB chassis, track only
- Taurus fan wiring
- 67-69 camaro gauge help pwease!!!
- Exhaust layout experiment - 4 videos for comparison
- DIY Brake Lines
- LQ4 performance upgrade suggestions
- hey team, you gauge guys
- lq4 problems
- making_4l60e_transmission_fit in an A-Body
- factory truck engine harness retrofit?
- Truck Alternator Wire to LS1 alternator wire?
- photobucket find!!! Corvette!!!
- LQ9 into a colorado
- What needs to be changed in ECU after a swap?
- Trying to hook up "old" Sun tach to my LS1 conversion.??
- anyone done a t5 on a ls2
- What are you using for a main power relay
- Metric Reducers for gauge installations 16mm & 12mm
- ls1 powered z car destroying alternators?
- LQ4/TH350 - Torque converter question
- 04 gto motor in 72 camaro help
- What are you doing for gauges? (A-body)
- tcc 04 gto
- My Magnacharged 6.0 Cutlass at the dragstrip
- C100 Plug pink from pin G help
- Little help? What is it worth
- first magnacharge lsx mustang
- LQ9 AC onnto 94 caprice??
- Need insight.
- NEEDING HELP QUICK!!! 6.0 conv. question.
- fuel system question
- Any purchase from Mast Motorsports
- Need help with LS2 DBW
- Which Kmember for SBC in a fox body?
- My G-Body swap 78' Bu
- ls1 conversion for my 67 firebird
- IRAQ soilder need help with swap
- ls1 into 240sx attempting to go smog legal in ca
- need help with a lt1
- LS6 Motor & 6speed in 2001 v-6 Camaro
- ls7 rx7 at the track
- ls1 swap to a 94 v6 firebird
- rx7 v8 running problem?
- help me select a wideband air/fuel meter
- Drilling F-body alternator mounting boss on iron block
- Does anybody sell a gasket kit for the LM7?
- late model radiator in a 1st gen. Camaro
- EastCoastEngines,AutoComputerTech,musclesportsandi mports,Jeff Robert "Fruad"
- G-Body using Camaro Oil Pan Notched?
- corvette valve covers fit?
- 1977 astre
- Coolant Line to Tb
- F body front runner set up on 6.0 block
- 45 degree flare to -6 AN adapter?
- Power steering fitment question
- Ground Circuit Wiring
- Truck manifold fuel rail connector problems - recommendations?
- Alternator Bolt Pattern Compatibility
- L92 Water Pump Question (need parts guy help)
- BCM use with E38 PCM
- LT1 fuel pressure regulator question
- where is my TAC?
- tcc 04 gto
- my 240sx turbo ls build
- what jets in your carb?
- Strange idle problem
- ac low pressure wire
- Help with LS starter please. . .
- 91 mustang ls1 coupe fs
- lq4 6.0 240sx swap
- How hard is it to swap an ls2 intp my 98ss?
- modify the stock 99 harness
- t6 turbo ls6 FD3s Rx-7 with cobra irs custom mounting
- torque converter bolt part number
- Start with LS1 then switch over to LS2 later?
- wire colors
- pcm question
- Lil help..Colorado Truck Forum
- someone kick me dead in the butt
- Camaro accessories while keeping VVT on L92
- anybody done this yet?
- 2002 4.8 no fire
- Will F-Body or Corvette accessories interfere with truck intake/TB?
- new life for my Fiero LSx swap project
- ls7 into 2006 silverado?
- LS6 into 72 Olds 442
- Block hugger header clearance
- Big Stuff 3 Standalone Complete with wiring harness NEW - for sale -
- Block hugger headers in a 1st gen anyone?
- Question about 6.0 into 07' Tahoe
