View Full Version : Conversions & Hybrids
  1. LS1 air cleaner & housing into a 96 Z-- How To
  2. should i waste my time on a ls1 intake?
  3. ls6 intake Q
  4. Another fuel line ?
  5. LS1 Celica up for sale
  6. 95 trans am ls2 conversion check it out!!!!!!!
  7. ? about switching to FI but keeping the victor jr
  8. For those of you with the Taurus fans or 2 speed fans, step inside
  9. What gauge wires are these?
  10. fbody + diesel?
  11. my cutlass on street tires at the track !!
  12. Question about Fuel Line sizes G-body; 5.3 ltr
  13. Part number for PCV valve boot??
  14. Fuel pump heating up??
  15. Anyone have audio files of a thumpy cam in an LS motor?
  16. What should I do?
  17. Lsx + t5 = ??
  18. Corvette LS2 Pan with 6L90
  19. Clutch line HELP
  20. ls1 swap into a 2000 gmc sierra 5.3?
  21. New hybrid forum
  22. What acc. drive?
  23. Ran into a problem with Corvette Mounts and Truck A/C bracket
  24. Help with no start
  25. LSx Rootibaker
  26. fuel pump question
  27. What kind of mufflers to use? 68 Camaro - LS1 (pics)
  28. 65' Chevy II 5.3 th400 swap
  29. Where to get Fbody exhaust flanges?
  30. Quick cruise control question (DBW)
  31. 400+ whp w/ single 3" exhaust?
  32. carbed 5.3 made it to the track
  33. My LS1 Monza goes 11's
  34. 6.0 H/C/I + T56 iroc-z almost done!
  35. threaded inserts on intake
  36. 67 mustang hybrid starts
  37. Do I need to fuse the power for the ECM(computer)?
  38. lsx in an 85 iroc
  39. LS into a Jeep Cherokee (XJ)
  40. A-body swappers unite! gimme the old yay or nay...
  41. Another newbie Question (kinda long)
  42. BRP headers with Carshop 1"set back mounts--anyone tried this combo on 67-69 f body?
  43. 94 Jeep YJ going from Ford 5.0 to GM 6.0
  44. the 5 wire hook up...need some help
  45. lq4 wiring
  46. Trans dapt on 2nd camaro
  47. F-Body Motor Mounts in an A-Body
  48. mustang swap help
  49. My LS2 FC build thread
  50. swap and inspection questions?
  51. 04 GTO Tune Speedo Fix
  52. 92 Maro LS1 Swap
  53. LS2 Or LS3 Conversion into a 1998 Camaro Z28
  54. ls foxbody question
  55. Question about trans mount
  56. 5.3 Head Porting Questions
  57. Doing a Swap on a Budget Question...
  58. DBW question 98 corvette donor?
  59. 1968 camaro lq9 6.0/4l60e frame off build
  60. 68 Camaro LSX Headers
  61. Will Hooker 67-69 Camaro LS1 swap headers work with the AutoKraft oil pan?
  62. LQ9 possibly?
  63. X pipe Or H pipe for my swap
  64. Just pulled the trigger on a engine for my swap
  65. (Not LS1) Need motor mounts for LT1 65 skylark swap.
  66. ls1 truck harness questions
  67. 71 chevelle 5.3 buildup suggestions
  68. Crank Pulley Swap
  69. hybrid help! making a 95 a 99
  70. ls1 foxbody mustang
  71. harness question
  72. Cooling Fan-system for LSX swap- Most reliable?
  73. LSX conversion questions
  74. LS1 in 93 LT1 body - exhaust adapter kit??
  75. 6.0l lq4 oil pressure gauge??
  76. O2 low ref Q
  77. It Started-86 elcamino
  78. Need help on ls2 going into 02 camaro.
  79. ls2000 ls2 honda s2000
  80. Retro Fit Oil Pan
  81. Wrangler pics
  82. Parts compatibility question
  83. Bolt sizes/lengths
  84. Gen IV Wiring Questions
  85. tuning a blow thru carb
  86. Speedometer calibration Error
  87. tb and maf question
  88. Quick 2006 LM7 ECM Wiring question
  89. Schwartz Performance 65 Tempest- LS3
  90. Contemplating a new LSx build, Rat Rod, Twin Turbo 6.0
  91. LS1 300zx Manual?
  92. my 240ISHH build thread
  93. does ls1 ac compressor take straight 12v or resisted?
  94. 5.3 Into FJ40 Land Cruiser
  95. Need a few wires you removed from your harness!
  96. cold air intakes!
  97. transgo hd2 fix low range?
  98. TAC connectorsq
  99. Air Conditioning not getting power
  100. Going from LS2 to LQ9- Sensor question
  101. Radiator Options 64 A-body
  102. Where to buy wire and realays and such for the swap?
  103. GenIII+ stock exhaust manifolds ($ budget)
  104. schematics
  105. 5.3 into 79 trans am
  106. Bench tune needed if dyno later?
  107. LS Swap To El Camino
  108. Doug Thorley headers
  109. DBW: can it run standalone?
  110. G-Body people with LT`s inside
  111. 68 camaro LQ9 turbo build
  112. LQ9 horse power rating
  113. “Ménage à trois”: 1961 Cadillac 2dr body / Impala SS rolling frame / LS power
  114. Relocate Alternator where AC was?
  115. 69 C-10 LQ9 swap, left me stranded - fuel pump wiring question
  116. Autokraft oil pan and windage tray.
  117. fastener sizes and specs
  118. Help--Wont start
  119. 67-69 F body parts
  120. swap questions
  121. Another Connector ID Request
  122. LS1 to LS2 for F-body part list
  123. Edelbrock & Russell swap parts
  124. 5.3 and 4L60E w/ ecm & harness into a '90 S10, 4cyl, 5 speed
  125. ls1 oil pan
  126. need help from the mustang guys
  127. speedometer hook up?!
  128. how to bleed clutch?
  129. 93 LT1 to LS1 Wiring Harness Conversion How To
  130. what kind of master cylinder bracket for 1965 malibu?
  131. Carb'ed & Cammed: low vacuum...
  132. G body Motor Mount Difference
  133. Need Coil Harness
  134. Yet another, BMW E-36 LSx conversion...
  135. 64 Imp SS 5.7L LS1 swap - pics
  136. Penske (Rental) 6.0L engine???
  137. ls1 power steering pump to mustang rack and pinion
  138. NEWBIE+LSx SWAP=OH GOD PLEASE HELP!
  139. GTO fuel rail covers....
  140. NEWBIE+LSx SWAP=OH GOD PLEASE HELP!
  141. oil pressure sensor /temp sensor
  142. stainless lpp ls truck header ????
  143. Ls1 Isuzu Pickup
  144. Need Help Quick
  145. L76 conversion question
  146. LY6 into a 94 firebird retaining VVT
  147. '00 GT 6.0 swap
  148. truck water pump with ls1 intake
  149. What parts do i need from my donor car?
  150. LQ4 in an 80 Trans Am?
  151. LS2 in a 37 Ford
  152. 3 wire -> 1 wire Oil Pressure Sensor?!
  153. Newbie LSx GMC Jimmy swap Questions..
  154. Moroso oil pan, thoughts?
  155. PCM and Harness choices. Which is the best?
  156. 4L60E into Park?
  157. drill mod on a third gen?
  158. Mazda RX-8 LS-1 swap
  159. LS1,1996 ford F-150, 4l60e swap
  160. exhaust questions for A-body
  161. Another stupid coolant crossover-steam pipe question
  162. drive by wire question
  163. useing the tach and speedo in 2nd gen TA
  164. ls1 tacoma shifting problem
  165. Road race/drift Conquest swap
  166. 1966 Nova...LS1 Install...Pictures Inside.
  167. Importance of proper oil pan selection
  168. 5.3 Truck Accessories -Power Steering Pulley
  169. Stupid Water pump question!?
  170. turbo headers for ls g-body swap for sale
  171. Help me complete ls2 into ls1 SS Camaro parts list.
  172. Old Chevy accessory drive system?
  173. Carb and/or MSD6010 tuning...
  174. my fuel injectors. Need help with them
  175. Lq9 power steering ?
  176. My LQ4 turned out to be a LQ9
  177. different engine mounts
  178. LS engine mounts in 71 Firebird?
  179. My LS1 Swap is Complete! (Into a 97 Trans Am)
  180. Edelbrock 7118 box with intake, header flanges, fbody rad
  181. Chevelle swap
  182. Value question
  183. For sell, complete LH8 oil pan kit brand new in box
  184. 5.3 in a 96 t/a
  185. help with wiring PLEASE HELP!!
  186. coolant sensor 3 wire
  187. A body Oil Pan from Pace
  188. Third gen ls1 need help
  189. Ford PS Rack Problem!
  190. cylendar 1 firing only
  191. Need Help with 6-speed in 78 malibu
  192. My LS1 Mustang build
  193. ls1 oil pan 2002
  194. carb + stumble....
  195. I need help from the E36 swapped people!
  196. 1992 Camaro RS, LS1/T56
  197. Sourcing "raw materials" for a build/swap
  198. Engine angle too much??
  199. OBDII Benchtop Test
  200. Need help wiring LS alternator!
  201. G body lsx radiator hoses? Part #'s please
  202. Truck wiring harness Q's...
  203. Will a escalade 6l80e fit to my Corvette LS2 engine? what do I need?
  204. The old "sleeper" gets a facelift
  205. ls1 89mustang a/c
  206. Ls1 into 66' Chevelle
  207. Corvette TAC and Pedal....LS2 throttlebody / Gen IV truck Tbody problems
  208. ls in a 1966 Bel Air wagon
  209. Anyone running the Trailblazer TC from the I6 motor in their conversion?
  210. 6.2 in 80 suburban no tach?
  211. flexplate and coil questions
  212. Hooker swap headers and mounts
  213. LS2 into LS1 car.
  214. question on 5.3
  215. A few Chevelle parts
  216. ls2 into 1998 Mercedes Suggestions and Advice please :)
  217. 69fbody Stainless steel works headders-> will they fit?
  218. I need help...02 Corvette DBW + Fbody 4L60E...which PCM OS???
  219. Shifter Question! You A6 6L80/6L90 Conversion Guys COME IN HERE!!
  220. Anyone swap a lt1/t56 into a mkIII supra?
  221. Fan wiring questions
  222. look how i got my vent line. this ok?
  223. Vats! Help!
  224. 1966 GTO-LQ9-T56 build
  225. Where can I get 1 7/8" Primary Header Flanges?
  226. Possilbe motor purchase without ecm/harness, any issues?
  227. Miata differential upgrade options for LS1..
  228. Vans with DBC
  229. LS/4L60E in a '47 Chevrolet Business Coupe
  230. 67 camaro wiring ls1 harness
  231. ls1 c1500 Chevy VPS problem ?
  232. LS1 trackday /sprint car first timed outing -6th place overall!
  233. Heidt's 70-81 Subframe goes LSX with BRP
  234. Basic ECM reprogram, what to ask for?
  235. reverse lock out wiring question
  236. List for a donor vehicle.
  237. Car an truck pin layout
  238. Painting Alum Ls1 Block for 63 Chevy II
  239. 04 gto alternator in LS1Miata - need help
  240. LQ-4 water pump question
  241. LM7 in a Jeep runs rich
  242. Auto trans choice for 67 Chevy II
  243. dash question
  244. Harness Question
  245. VSS Question...
  246. Need help with a few wires
  247. 79 Trans Am advice?
  248. ????????? Paint
  249. 408 needing accesories etc.
  250. need help identifying conectors in harness!
