View Full Version : Conversions & Hybrids
  1. Hooker swap headers and mounts
  2. LS2 into LS1 car.
  3. question on 5.3
  4. A few Chevelle parts
  5. ls2 into 1998 Mercedes Suggestions and Advice please :)
  6. 69fbody Stainless steel works headders-> will they fit?
  7. I need help...02 Corvette DBW + Fbody 4L60E...which PCM OS???
  8. Shifter Question! You A6 6L80/6L90 Conversion Guys COME IN HERE!!
  9. Anyone swap a lt1/t56 into a mkIII supra?
  10. Fan wiring questions
  11. look how i got my vent line. this ok?
  12. Vats! Help!
  13. 1966 GTO-LQ9-T56 build
  14. Where can I get 1 7/8" Primary Header Flanges?
  15. Possilbe motor purchase without ecm/harness, any issues?
  16. Miata differential upgrade options for LS1..
  17. Vans with DBC
  18. LS/4L60E in a '47 Chevrolet Business Coupe
  19. 67 camaro wiring ls1 harness
  20. ls1 c1500 Chevy VPS problem ?
  21. LS1 trackday /sprint car first timed outing -6th place overall!
  22. Heidt's 70-81 Subframe goes LSX with BRP
  23. Basic ECM reprogram, what to ask for?
  24. reverse lock out wiring question
  25. List for a donor vehicle.
  26. Car an truck pin layout
  27. Painting Alum Ls1 Block for 63 Chevy II
  28. 04 gto alternator in LS1Miata - need help
  29. LQ-4 water pump question
  30. LM7 in a Jeep runs rich
  31. Auto trans choice for 67 Chevy II
  32. dash question
  33. Harness Question
  34. VSS Question...
  35. Need help with a few wires
  36. 79 Trans Am advice?
  37. ????????? Paint
  38. 408 needing accesories etc.
  39. need help identifying conectors in harness!
  40. MSD 6010 Question
  41. firebird '94 engine swap -- Information??
  42. 94 Mustang LQ4 Swap Build Thread
  43. another LS swap in the future? maybe!
  44. L76 swap into 97 SS.
  45. Autokraft Oil Pan Install
  46. Cold air intake - 1st gen camaro
  47. Cowl induction under a 68 vette hood
  48. oil pan and header help please.
  49. Replacing stock variable a/c compressor with something else???
  50. Post your G-Body 5.3 Conversion here please
  51. Trying to sell my 2nd gen install kit
  52. e36 LS1 swap?
  53. Ls1 and t56 out of Gto into 88-90 Rx7
  54. For Sale, Complete LH8 oil pan kit, brand new in box!
  55. few more pics of my 84 camaro on a track day
  56. 1991 camaro ls1 swap, what headers
  57. Need help wiring in ECU
  58. LS? Zx2
  59. f/s corvette calipers
  60. MSD-6010, no fire!
  61. What do you use to clean your wiring harness? Car wash soap and water?
  62. GTO Oil Pan Help
  63. C5 t56
  64. LS1 Foxbody... need some help
  65. LS2 Carb. ground cable from Home Depot/Lowe's??
  66. Turbo LS1 Fox nearing completion!
  67. Should I stick with a 1999 PCM and harness or try to use something newer?
  68. turbo v8 bug, running too hot
  69. 1998 firebird LS1 into a 1996 V6 Camaro
  70. What does the VSS reading tell the PCM?
  71. lq4 question
  72. Which OIL PAN?
  73. 02 sensor question
  74. Rear Engine Combo, LS1 & Audi 01E 6spd
  75. What Can I expect?
  76. Insurance!
  77. 5.7 to Ls1 Swap
  78. cam only carb'd setup with 6010 box
  79. F-Body vs Vette A/C pulleys
  80. corvette reg and fuel line question
  81. 6.0 into F-body
  82. 84 C10 a/c help needed
  83. A body motor mounts and exhaust
  84. Beretta Z26 5.3L fwd swap
  85. A few swap items for sale
  86. Air Intake Tubing Size/Fitment
  87. Anyone have a pic of A/C bracket on a 5.3?
  88. drive by wire throttle? How bad is this swap?
  89. VSS issue
  90. LS1 Remote oil Filter
  91. DBW Confusion
  92. Speedo with cable x box, 4l60e, speartech
  93. DBW startup problem
  94. Gen 2 fuel pump location
  95. LS 6.0 help please
  96. 6.0 ly6
  97. LS1 Miata - PCM & Harness help needed!
  98. Alternative to Abbott Cable X ???
  99. let me see your air intake setups
  100. need exhaust manifold advice (240sx)
  101. Using a 99-02 truck ecm...will the fans work?
  102. first gen camaro L92 victor question
  103. 6.0 conversion runs pig rich
  104. lsx fox which headers?
  105. Help with LS2 P/S Pulley
  106. 5.3/4l60e/np208 lots of questions????
  107. What???
  108. Gauges HELP
  109. Computer & Harness Question
  110. Ls2 gm performance harness oil pressure
  111. LS powered Vega.
  112. saving the live of a harness?
  113. Inline fuel pumps
  114. what gauge cluster can i run
  115. 72 forumla stock gauges
  116. current performance adapter harness help
  117. AC setup on GENIV engine swap to 1997 Tahoe
  118. Pressure!
  119. Moroso 20140 Pan
  120. Anyone using the stock F Body throttle cable?
  121. How hard to put a ls2 into a 1971 z28?
  122. 99-04 mustang swap questions.
  123. few questions mustang swap almost done
  124. 1991 ls-10
  125. In the middle of modifying LS1 wiring harness. Question on something...
  126. A/C through e38 pcm LS7
  127. C5 donor to _???__
  128. 6.0L vs. 5.3L
  129. aje k-member,kooks,and stock suspension?
  130. It's alive finally.
  131. starts, won't run
  132. Thermostat ls motors
  133. Nissan 200(240)sx with 2004 GTO LS1+T56
  134. Driveshaft lengths?
  135. Power Loss LS1 Intake On A 2005 LQ4
  136. 99 LS1 into 98 Camaro - Need Help Dash
  137. What length of drice shaft.
  138. F-Body Fuel Pump Dimensions
  139. Anyone know A/C Shop that works with those crimped hose ends ?
  140. Travel Question Mounting Clutch Master
  141. Turbo my old daily driver/ shop truck?
  142. How close is too close?
  143. sbc s13 coupe questions?
  144. Isuzu question
  145. Aftermarket plug and play harness.
  146. fuel rail fitting part number
  147. G-body wiring
  148. 3 Wire ECT sensor
  149. gto dbw pedal with 03 truck pcm?
  150. Manual to Automatic transmission harness swap.
  151. looking for some input
  152. Corvette regulator filter question
  153. 1969 Chevelle with ZO6 LS6 4 speed
  154. 1964 Chevelle - 5.3 LQ4/4L60E
  155. Accusump; Wiring for Solenoid
  156. Flex plate adapter part number
  157. LS1 or LS2 intake manifold for LQ9?
  158. Programming 5.3l pcm
  159. Ls Motors
  160. LS2/3 thermostat housing
  161. Fuel lines and EGR for my 87 camaro
  162. adapter harness or stand alone for ls1
  163. lpp truck headers??
  164. Electric fan advice please!
  165. 5.3(lm4) aluminum block in a C3 Corvette:Swap Thread!
  166. 72 Chevelle LY6 Cam Only Dyno #'s
  167. whats needed to run a th400 behind a 5.3 LM7
  168. Need help! 4l80 swap in an ls1 86 camaro
  169. New Motor Start-up
  170. VIN code for 5.3 LM4?
  171. is it normal(ls2)
  172. question about buying my ls motor?
  173. Question about fuel rails
  174. New uk member looking to do swap into Jaguar
  175. 5/16 vs. 3/8 fuel line in LS1 swap
  176. Automatic trans clearance in first gen F
  177. Corvette fuel filter adapter
  178. starter will not turn over
  179. V6 to LS1 or 6.0 Swap
  180. Cant fill new gas tank fast..
  181. LS1 C3 Vette guys!
  182. Adding sump to stock fuel tank
  183. Impala SS AC Questions
  184. ls1 in to a fox body swap questions
  185. Y-Pipe Pressure Test
  186. Complete LS1/LS6 Victor JR, MSD 6010, demon carb, fuel pumps, for sale
  187. F-body Injector plugs
  188. LS2 into 99 Mustang
  189. anybody have a 99-02 a4 harness for sale
  190. coolant sensor location
  191. 6.0 lq4 coolant hoses
  192. Ack! Electric problem (blowing alternators)
  193. LS1 Third Gen owners step in
  194. Those with Facebook and LSx conversions...
  195. Is there a definitive answer to LSx into E46?
  196. f-body pacesetter long tubes on a g-body
  197. 11.92 for my Monte SS LS2 on Tues.
  198. need help with 4l80e shifter cable
  199. truck VS fbody ECM on a 6.0 harness
  200. 87 Iroc Z LS1 Swap
  201. which donner vehicle 4l80 2wd
  202. what radiator hoses for the fox body with
  203. Quick Question on LM7 and LS1/6 variations.
  204. 96 lt1 into 95 3.4
  205. Anyone ever use a truck harness for an Ls1 swap.
  206. Need help with a/c ?????
  207. Has anyone used Russell/Edelbrock fuel system for ls conversion
  208. Factory guages
  209. truck gauge cluster
  210. LQ4 280Z running TERRIBLE!!!
  211. A few questions before I start the build. Please help me with my parts list?
  212. Lsx 302?
  213. Standalone LS1 PCM/Harness Question
  214. ls1 and t-56 g-body
  215. A Little Help Please!!!!!!!!!!!
  216. LQ4 or LQ9 how do I know?
  217. Headers and oil pan for 2nd gen camaro w/ 6.0L?
  218. does anyone know????
  219. swap prices range??????/
  220. trans am diff
  221. LS2 ECU(e40) wiring questions
  222. 98 s10 with 5.3l swap????
  223. A/C pink wire?
  224. anyone put ls1 into 94 v-6 car
  225. Headers for LS1 swap into 71-76 b-body
  226. LS1 into an RX-7 FB?
  227. 64 malibu with truck acc. a/c brackets
  228. Need 66 Corvette LS1 T56 install info
  229. LT1 into a 1985 camaro
  230. 383 Sonoma goes 10.46.
  231. Just another 3rd Gen LS swap
  232. My C1500 383 build up
  233. Cutting the floor to fit a t-56 in a 2nd gen?
  234. Question on single bolt or two bolt T56 transmission mount.
  235. what do i need to put an ls in a fox body
  236. Ls1 into 94 v6 wire harness help
  237. LS1 A-body Conversion Headers, Engine Plates & Clutch Hydraulics F/S
  238. Exhaust mani for S10 swap
  239. f-body v6 to ls1 swap. Injector wire splice?
  240. 1972 Short bed 6.0/4l80e
  241. Adding an Electric Fan to Original Chevelle Fan Shroud
  242. LS1 powered 69 Transam
  243. Fuel pump relay
  244. 2007 6.0 liter wiring help
  245. Front accy brackets & pulley's
  246. Anyone familiar with NY state emissions inspection ?
  247. coolant line help guys
  248. LS1 into C4.. headers?
  249. 2000 Dodge Durango
  250. what about an 8.1 or vortec 8100 swap?
