- conversion wiring
- this is my body donor for ls1 swap!!! 4 grand in seattle
- Swapping ls1 into v-6 4th gen?
- Pics of PCM mounting
- Wiring and Fuses for Radiator Fans
- 69 camaro ls1 swap help needed.
- Working on my harness, have a few questions
- Finally got her painted
- RX7 swap possibility
- Ls1 T56 Chevy II clutch setup!
- After market balancer??
- hooking up parking brake to pcm
- 5.3 in 99 camaro, which starter?
- lt1 in 65 skylark. Do I need a new oil pan?
- 6.0 swap
- Mustang u-joint?
- what wiring harness and PCM can be used?
- Big or small block engine mounts for F body?
- msd 6010
- LS2 w/ cable throttle body question.
- DBW question
- E67 pinout and CTS-V schematics
- Corvette fuel filter
- 98 ls1 into a 93 caprice
- Wiring Harness Options 6.0 Retrofit
- Which motor mount frame stands do I have? (67 F body)
- Another soulless FD RX7
- My 3rd gen IROC swap
- Nova 1966 LS2
- 4l60-e?
- aje motor mount dimensions
- 69-2002 ls1 help needed.
- Soon to be ls swapped 88 mustang. Looking for suggestions/opinions
- Oil pan problems
- LS1 Header Tube Size
- LS1 / Gen1 F-Body swap headers
- Killer '64 Twin Turbo LS6 Impala
- DBW wiring
- carb'd 5.3 in a 93 gt
- do it yourself LS2 harness conv.
- Chevelle LM7 swap for under $3000
- LS2 conversion no throttle
- where to find out wiring year and model?
- 91 IROC-Z LS1 & T56 Conversion
- LQ4 into 66 Chevelle
- electric water pump tapped for coolant crossover line?
- longshot - anyone with an LSx in a 39 Ford coupe?
- 05 GTO LS2 & M6 into 92 Camaro
- 66 Mustang
- LS6 jetboat
- Need help with engine serial number
- Cracked Edelbrock Victor Jr
- This belong to someone here? '67 Chevy II Pro Street LS1
- Stock LS1 Spark Plug of Choice?
- '71 Nova 6.0 Conversion
- pics of miata with motor plate???
- 4.8 + 5spd 4X4 into 3rd gen
- Wiring my swap, 1994 mustang
- ls4 into a 240sx
- LS1 in a 1960 Nomad Needs ECM
- LS Vega
- bolt a 4L60E to an LS6?
- ls motor in a 62 chevy II
- G-body swap questions
- camaro help
- LS1 powered 2001 Blazer Xtreme?
- Some pictures of the Talledega Grand Prix track this weekend.
- msd 6010 box
- Looking for a specific wiring thread!!!
- Differences in versions of 4L60E's
- msd 6010
- sbc swap into rx7
- LS1 swap into 02 Honda S2000
- 86 Elcamino LS1 Swap G body.....which oil pan has best ground clearance????
- Will this Radiator leak ??
- Mini-starter
- bbc to ls1/lt1 car??
- LT1 to LS1 swap
- Fast Eddie - LS1 miata race car
- Good harness mod writeup
- How much will it cost
- LS1 6 speed into 67 A- body
- Will a stock f body oil pan work on a frist gen camaro if it has no rear steer?
- 6sp ls6 swap in 97-03 540 bmw
- Project L33 Cherk
- Finishing wiring help ls1 swap
- 6L90e swap 1st gen fbody
- 1966 Chevy Nova SS ls1 gasser style video
- what headers 64-67 abody
- Stupid ? but IDK about intake bolts
- LS3 A6 into C5
- 6.0 in 70 chevelle
- LS1 in a 97 Firebird
- Source for super tight tuck headers?
- 6.0 Mustang Engine pic
- Cats....Yes or No
- What offset headers?
- T56/LS1 swap in a fox body?
- LM7 Conversion question
- Cam gear install question
- Pair of interesting swap adapters...
- Help LS1 engine into 91 Iroc Z
- Vintage Air & Two Speed Fan Question
- Polished EGR plates for LS1 intake...
- I think I have a DBW harness - should I convert it or trade it?
- ls1 nova(do or dont....???)
- 4000 pulse or 8000 pulse/mile
- Clutch difference LS-1 vs LS-3
- Frame building questions
- waterpump
- Converter(un lock) lock up switch question
- newbie questions, sbc to ls conversion in my Ultima
- I need a charging/start schmematic for a 2004 gto
- LS1 Swap help
- Barry Grant Fuel Filter
- C4 Ls1/T56 twin turbo
- anyone running stand alone trans controllers?
- Wiring harness questions
- torque arm mount not the same, input needed.
- 1994 Mustang Gt Swap
- LS1 swap in LT1 WS6 Ram Air
- will 4l80e fit in s10
- Are these the right parts?
- LT1/ 2nd gen Firebird
- MSD 6010 Buy direct from msd or go F.I.
- 87 Shelby Charger
- 06 escalde dash cluster.
- GTO Automatic Transmission Controls Schematics (All Years)
- PCM/tranny question
- LS2 350z project begins...
- 93s10 with lt1/t56 swap...
- 84 camaro lsx swap
- How hard to swap ls1 into a 3.8 car
- Fuel Pump Conversion
- ac questions for conversion
- Cheapest Gen III headers for 84 C10 P/U?
- 1984 Silverado is FINALLY Alive
- Custom CNC machined valley cover
- 2007 motor in a 2000 silverado 1500 truck
- Linkage problems/solutions for aftermarket shifter?
- Factory Five GTM 5.3 instead of LS1
- does ARH make a swap header for the 87-93 stang?
- Info needed
- Where can i get a GTO oil pan and pick up?
- Alternator questions
- Truck oil pan question.
- FS 5.3 twin turbo swap everything...
- Wiring questions
- Confused about AC with conversion
- 1956 Belair 4 door build.
- My LSX swap game plan..
- LM7 into Jeep Willys MB
- 94 Trans Am Change Over
- LQ4 wiring questions
- 5.3l in a 65 mustang
- 6.0 M6 67 camaro
- Anyone with and LS1 in a 1965-70 Chevy B-Body?
- oil pan fitment, fox ls1 conversion
- Frame measurements for a 1964 Buick Special
- LS1 or LS2 ???????? ..................
- My Nova's LM7 Transplant
- Check Engine Light
- Help me pick an intake/cam
- Brake fittings - quick question
- lt1 t-56 able question
- What should I charge to put an LS1 in to an LT1 f-body?
- Starting problems After tranny swap
- Chevelle or Camaro for new project?
- Whats the best way to put an older 4-spd behind a ls
- I found a 5.3 combo, should I buy it?
- LSX Mustang Sticky?
- Want to buy 2000+ ls1 + t56
- 6.0L 64 Impala
- MAss area fabricators needed$$$Olds bravada needs lsx engine swap
- Attention Massachusetts fabricators..$$$$$$$
- New dual exhaust on the Miata, and 1/4 mile time
- need pin-out diagram for an '01 LQ4
- Corvette 2002 LS1 Swap To LS376/480
- What do I do next?
- ? on cam selection
- Brembo Calipers off Dodge SRT8????
- swapping LQ4 into '91 Camaro, have some questions
- LSx powered late model Nissan 300-ZX, aka Z-32
- What is the name of this fitting?
- LSx swap in a Shelby replica body????
- questions about a 5.3 into 94 z28
- looking for relay diagrams
- starting wiring harness few questions
- help engine has no power
- T56 with carb, wiring??
- Simple wiring questions
- ls2 in a 02 trans am
- How much clearance between exhaust manifolds and other parts?
- 4.8 info
- LS1 into is300, e36 m3, porsche 944
- carb,tpi,lt1,ls1into a 3rd gen?
- edelbrock headers 69 camaro
- 305 700r4 to 5.3 60E 87 Chevy 4x4
- A taste of our own medicine
- found a book on swaps
- ls1 controller
- Fox manual trans options?
- my thirdgen finally lsx powered!
- any pics of the ls1 swap with a maf in the mustang?
- need some answers???
- speedometer
- ls1 in a 96 tacoma
- LS1 in 72 TA
- 97 to ls1 harness, almost complete, few questions
- Wiring Harness for LS2/58x
- wiring cooling fans to e38 pcm in l76
- How to find circuit load
- Fuel pump circuit not working
- factory ls1 cars
- No brake switch = No electric throttle?? WTF?
- 1970 chevelle lsx swap questions!!!!! HELP
- cts-v t56 into rx7? Help!
- LS1/t56 Z32: Grocery List??
- Universal dual 3'' to 4'' Y pipe?
- ???anyone have PINOUTS to the BIG INTERIOR HARNESS.....
- Neutral Safety Switch Questions
- T56 hydraulics setup
- exaughst for 1968 Camaro LS2
- 89 caged notch 6.0 swap
- New to LS1 need advice
- What is the deal with head gaskets?
- what upper radiator hose did you use?
- TAC for '06 LQ4 motor?
- Advice Needed
- LM7 Swap into 95 caprice.
- O2 sensors
- 68-72 gm a-body swaps
- Header selection
- McLeod 8710-01 modular bellhousing...
- Swapping a 5.3 into a 2000 z28 ?
- LT for an LS
- 6.0L in a S10
- wanted: t-56 foxbody mustang interior pictures
- what to use for pre filter
- First trip to the strip in the Chevelle swap
- Ls motor in a 6 Nova
- LS1 into 78-87 ElCamino
- LS1 in 93 v6 camaro body - quick steering q
- Walbro 255, custom tank ???
- LS2/T56 in 1st Gen. Camaro VSS question
- 2007 corvette pinout help
- Fabricating a GTO Vortech for a WS6
- ? for those who have remote mounted coils...
- Help with 99-02 cluster in 98 car please!
- best fuel set up for ls1
