View Full Version : Conversions & Hybrids
  1. coolant flow direction ???
  2. Another fox body build
  3. LSX Fox body swap...
  4. Good deal donor car in GA
  5. Dead fuel pump
  6. starter wiring
  7. MSD #6010 users turning 7k and more?
  8. fox swap radiator?
  9. Question Lt1 to Lsx swap Related.
  10. Engine identification
  11. Ls2 Swap into Triumph Wagon. One of a kind!!
  12. s10 ls1 swap and built 200r4/ls1 swap
  13. Fuel system leak
  14. G-Body Engine Stand Removal?
  15. New GM Oil Pan Kit with part number
  16. Carb ls1 Foxbody throttle cable
  17. Radiator hose splice
  18. tach and engine temp connection issue
  19. BMW E39 540i Engine Swap Questions
  20. 67 Chevelle LS1 Radiator?
  21. Anyway to read knock sensors with a carb setup?
  22. Tranny Dipstick Fitment and starter fitment
  23. 4.8/5.3 with ls intake
  24. 4L60E in a 72 Elcamino
  25. Cruise Control w/TBW-ETC Question
  26. What kind of MPG? 77 Camaro with 4.8, 4L80, and 2.56 gears
  27. LS1 into my 1987 turbo 2 RX7 !!
  28. Header\exhaust manifold measurements
  29. 2000 firebird and a supercharger
  30. Walbro pump problems
  31. Borg Warner Turbo s475 1.10 a/r 650$
  32. Help motor won't start
  33. AJE k memeber fox body swap
  34. corvette accessory drive
  35. C4 ls1 update (new pics)
  36. GBody LS1 Swap header questions
  37. What did you pay for a complete 5.3?
  38. Anyone planning on LT1 to LS1 conversion, look inside
  39. WHAT THE HELL!! c4 swap problems
  40. vette accessory belt diagram?
  41. Gas Tank Opinions?
  42. f-bodies inc - bad experience with wiring book
  43. MAF wiring question
  44. Miata LS1 swap price??
  45. what temp is stock for coolant relays
  46. Need Help Hot Wire Mod???
  47. Ultimate Sleeper---PRIUS
  48. NEW PB with my lsx v6 mustang
  49. Ignition Switch Wiring
  50. LT1 to LS1 swap help
  51. 2007 5.3 into 1948 Chevy 5 window pickup
  52. Recent pictures..55 almost finished.
  53. Advantages of 5.3 over other, bigger options.
  54. Lookout California Drivers
  55. project 6.0L s10 pics
  56. Project cheap and go fast?
  57. An Fitting Part #
  58. Help - MAP hose?
  59. LS2 Alt. and W/P belt out of line
  60. Whats a good cam for a ls1 thats in a sand rail??
  61. LS2 carbed fuel pressure PSI??
  62. 67 camaro Ls1 brake problems
  63. couple of LSx cooling system questions
  64. Which aftermarket A/C for 69 Camaro
  65. crank spacer preferance question
  66. S10 Fuel Tank Question!
  67. LS3 Alcohol Funny Car/ Altered
  68. WIRING an ls1 into 240sx
  69. Carb Guys: Timing Question
  70. Map Sensor Question (carbed)
  71. Need some local help
  72. LS1 Starts then Dies after 3 seconds
  73. 6.0L into a 67 Firebird. Few questions
  74. My 2nd swap. 86 Trans AM finally on the road!
  75. my 6.0l 72 c-10 build
  76. harness/pcm compatibility question
  77. Wirng question
  78. 70 Chevelle. Want to put some sort of LSX engine into it
  79. LS4 into a 01 impala
  80. Recomendations on Radiator
  81. Will an LS1 and t56 fit into an (old) 2002 bmw?
  82. L92 Intake Gasket #1222-2
  83. Question about ECM
  84. connector identification please...
  85. Engine Change Checklist
  86. got my harness now what
  87. steam vent / hose into lower radiator hose?
  88. Taking a stab at an LS engine in my '99 Sonoma
  89. LT1 into 2nd Gen F-Body (automatic V6) question
  90. what radiator hoses for a body?
  91. Choosing the right LSX engine
  92. edelbrock headers wanted for ls1
  93. Aftermarket fuel rails with vette filter/reg?
  94. 4l60e/4l65e/4l70e >>> 6l80e/6l90e
  95. Iat
  96. Physically removing CAGS Solenoid
  97. Foxbody chassis harness questions
  98. Exhaust Flow Question
  99. Street rod swap/Tall accesory drive ?
  100. mating a 392 hemi to a LS1 style T56?
  101. edelbrock retrofit kit
  102. 6 speed
  103. Interchangeable coil sizes.
  104. My homemade ac comp. brackets a body ls 2
  105. Stock radiators ok in LS swaps?
  106. Engine Shipping
  107. 77 Camaro Gen III Swap: Power steering pulley hits steering box
  108. Nuetral Safety Switch Hook Up\'72 Camaro
  109. Ls1 Fox Swap Questions
  110. Where to order compression fittings?
  111. Need help LS1 into 71 cutty
  112. 3 wire vs. 5 wire maf
  113. What are you L92 VVT guys doing for a harness?
  114. 66 Chevelle Conversion with Factory Air
  115. Lsx in a C-Class??
  116. Custom Air Intake Plumbing,,, Post Your Pics
  117. Timing on LS motors 29 or 36
  118. 97 4.3L --> 02 4.3L in Blazer
  119. 67 chevy II swap. i searched!
  120. 5.3 maf trouble
  121. LS376/480 in 73 Camaro
  122. project silverbullet almost done. pics inside
  123. stock fox k-member?
  124. New swap problems
  125. ls1......in a 240sx
  126. msd 6010 timing accuracy
  127. Carb'd LS2 accel pump size
  128. Special One peice engine cover LSX 454
  129. ls1 fuel tank ideas
  130. LQ4/ 1995 Impala SS Problems
  131. question about '91 Mustang LX 4cyl as donor car!
  132. Question on MAF's
  133. 5.3 or 6.0 swap
  134. C100 Connector and O2 Sensor Wiring
  135. transmission wiring?
  136. shortening c6 dirvetrain?
  137. First gen fuel sender not working, possiblly nicked sender wire? Where does it run?
  138. 67-72 chevy W/LS1 Gauge Help
  139. Evap solenoid
  140. selling s10 project.
  141. Selling my LS1 project car. 90 LX NOTCH Mustang
  142. Gauge hookup question.
  143. Some help 08 frontier
  144. 84 ss 6.0/mp122 and 4l80e swap
  145. Help Gauges not working
  146. Pulled LS1 drivetrain from 04 GTO...what else should I grab?
  147. ? using magnertic pick-up for tach/speedo
  148. dfw area ls1 mustang ?
  149. Who has converted to lever style e-brake on their 1st gen?
  150. 1972 Monte Carlo Gen III/ Conversion questions
  151. header progress pics
  152. LS1 z-car
  153. have a chance to buy a lq4/lq9 complete with wiring harness
  154. Starter problem
  155. ls1 into 1995 TBI Chevy truck
  156. Problem With Starter and GTO 6-Speed
  157. 98 f-body accessories on a 99 onward harness?
  158. ls2 coil harness wiring diagram?
  159. 79 elco swap to 5.3 lm7
  160. 98 starter and flex plate ??????
  161. A/C parts needed
  162. Need some help
  163. 70 camaro edelbrock headers bung location?
  164. 88 Jeep Comanche 5.3 build
  165. GM # for exhaust down pipe flanges
  166. 1972 Chevy Pickup 2001 LS1 Help
  167. LS1 Porsche 911 Conversion
  168. Radiator for a Retro fit LS1
  169. fbody wiring harness newb question
  170. quick k-member question
  171. 77-85 Caprice/Roadmaster peeps I have q's
  172. Does PCM need oil pressure reading?
  173. LS into a 94 caprice wagon?
  174. o2 sensors, do you have to??
  175. Alternator help - keeps dieing -72 nova
  176. LQ9/LS1 Into a 93 LT1
  177. 5.3 c10 will not start after running 1 minute
  178. Accessories - just brackets?
  179. 70 c-10 headers question
  180. oil and trans dipsticks
  181. 66 GTO conversion
  182. I need pinouts for a 99 or 2000 LM7
  183. 1996 silverado ls1 swap
  184. 1969 impala ls1 install questions
  185. Anyone know what this module is and/or does?
  186. LS1 swap Oil pressure sender issues.3 wire??2wire??1wire??
  187. Any one swap an ls1 into a 94-95 mustang gt?
  188. help please! question about ecm's
  189. SBC 350 in Firebird
  190. nelson's performance harness or speartech??
  191. Jet power ;)
  192. ls1 t56 on a sbc 350
  193. Anyone want to trade oil pans?
  194. Debut: USA-LS3RX7 Built by TTP Motorsports & Hotlap Motorsports
  195. New GTO Engine in 67 GTO? Anybody done it?
  196. How To Connect TKO 500 to LS VSS
  197. 4WD and 4WD low with 2000 5.3 and 4l60e
  198. going carbed, gauge question....
  199. what to do? lq9 swap g-body
  200. Cam Question
  201. ls1 swap on 86 V6 camaro questions
  202. msd6010/laptop port question
  203. belt stretch question
  204. i sent my harness to lt1350.com, lt1wiring.com BAD
  205. ls1 foxbody
  206. Urgent Wiring Help Needed
  207. Reverse Rotation P.S. Pumps? Who Makes Them?
  208. Oil amount for 4l60e
  209. LS2 intake/TB options
  210. carbed S10 project for sale.
  211. were to get motorsets?
  212. Whats The Best Tranny?
  213. PCM connector terminal part number inside
  214. Interesting idea....
  215. truck intake on 1st gen fbody
  216. why k&n sucks
  217. Something not seen here before MGB LS1
  218. Harness/ecu for turbo swap car
  219. 5.3l overheating problem
  220. Engine in but have mounting problems
  221. mounts
  222. stock compression w/ a turbo?
  223. Anybody using eldelbrock carb
  224. dash gauges hookup in non f-body ?
  225. **99-02 computer for sale (automatic)
  226. Swap almost done!!
  227. Drive By Wire questions...
  228. question on DBW gas pedal
  229. slave cylinder fitting
  230. 1970-1979F150 5.7(LS1) or 5.3 install.
  231. Nublet Question....is there a off-the-shelf kit for fox/notch mustangs?
  232. 4l60e
  233. angled plug wires
  234. questions for 240sx ls1 swap
  235. Identifying year of LQ9?
  236. Speedo/VSS Issue?
  237. vss question for lsx in 97 s10. abs sensor?
  238. LS2 Carbed w/QTP (LS1 Headers) Starter
  239. lexus gs400 ls1 swap?
  240. Budget 5.3/4l60e 240sx Build
  241. FlexFuel Identification by VIN?
  242. looking for coilpack main connector harness
  243. 88 montecarlo 5.3 truck
  244. 400 crossmember
  245. Sorry everyone
  246. 5.3L Heads
  247. Very Cheap Thrills - LS6 Toyota Pickup
  248. towl/haul quite working
  249. Torn between two drivetrains
  250. LS1 in a 81 Malibu
