View Full Version : Conversions & Hybrids
  1. Ls2 & 4l60e
  2. Stinkin Pink Wires!!! -plz help me finish this swap-
  3. pics of my 6.0 swap to 70 chevelle
  4. 98 Grand Prix GTP RWD conversion with LSx/T56
  5. Power steering pump interchange through LSX motors
  6. 1992 Firebird LS3... Video....
  7. What do I need to make it run???
  8. Where can I buy 3 1/2" to 4" 90 intake elbow?
  9. Neutral Safety/Clutch Pedal Position Switch?
  10. Anybody have a GM partnumbers for 98-02 Fbody accesorys?
  11. LS1 S10 guys please help
  12. tbss wiring harness in camaro
  13. 99-02 schematics
  14. lsx in a 96 camaro
  15. If you did your own fuel system, please come in
  16. ls2 to a 1970 deville convert
  17. Some help please on a conversion
  18. I finally got my engine, now I got some questions...
  19. I need help!!!!!!!!!!ls1 in 67 camaro
  20. LS1 into 1999 Pontiac Grand Prix??
  21. LS2 or LS3 Swap
  22. S10 Wiring question
  23. 4th Gen Fbody motor mounts in 1st Gen Fbody.
  24. Need a mellow-sounding muffler -- !
  25. Fuel tank: sealed or vented?
  26. MIL & TCC Q's
  27. Wiring harness questions
  28. 1979 c10 silverado
  29. OBDII swap into OBDI car
  30. Sponsor for external Walbro pump?
  31. Bad ass third gen build
  32. 5.3 starts but wont run?
  33. LSx into Jet Boat??
  34. Another LS1 S10 build.
  35. DBW pedal mods for chevelle
  36. Moroso 20140 pan install ?'s
  37. Wiring up underhood fuse block
  38. coolest coil covers ever
  39. Instrument panel on a 87 S10
  40. ls1 master, which line is for the front brakes
  41. 78-81 guys. Where did you mount your PCMs?
  42. LSX Conversion in 73-77 GM A Body
  43. 1st gen camaro update and question
  44. 74 nova 00 ls1
  45. Thanks, '70 Impala running!
  46. LSx in a 97 Z28
  47. LSX/t5 question
  48. Any interest in my Edelbrock 7118 carb kit?
  49. Motor Mount Plates
  50. how do i test the crank sensor & circuit? injectors & coils not firing
  51. Any successful 4th gen LS1 dash (w/cluster) swaps??
  52. 06 Rubicon Ls6(gm Crate) Conversion
  53. in the middle of swap please help!
  54. A/C Cycling Sometimes, Sometimes Not?
  55. Help me check my order list?
  56. LS1 into 84 vette need info-wiring harness,ect
  57. updates of the ls1 94 v6 mustang
  58. sbc to 4.8 LS motor all info is BIG help
  59. Anyone Need A New Ls1 Conversion Swap Car?
  60. why not?
  61. inline fuel pump options
  62. Just your average Ls1/T56 stripped RX7 With Plans of Racing
  63. Bastard motor
  64. You think you hate it now, wait till you drive it.
  65. ls1 fox price build am i close
  66. My ls6 RX7
  67. Alternator wiring '01 F-body
  68. 5.3 into 94 camaro
  69. skip shift threads
  70. Mast Motorsports L92HO/6L90E Powered 1968 Short/Wide---Hot Rod Power Tour Long Hauler
  71. s13 240sx ls1,ls2 swap questions
  72. My LS2 V8 Miata on SPEED Channel
  73. mustang swap ?
  74. I need expert swap advice
  75. 70 k20 4x4 5.3
  76. 68 Lemans LS1 T56 swap
  77. 2nd Gen swaps
  78. Disassembling an alternator?
  79. Functional Shaker Scoop on 2nd Gen TA
  80. Header Flange
  81. LS1 in '82 Firebird
  82. f-body clamshell motor mounts
  83. LS! install in a 95 silverado 1500
  84. Oil Pan Help Requested
  85. after 7 months of sitting by...
  86. Small engine, big power!!! (LC3)
  87. 99 Wrangler LS1
  88. 85 camaro ls1 swap
  89. magnus v6 to ls1 writeup
  90. LQ4 in 1995 impala SS
  91. '76 Datsun + LS1 pictures
  92. Possible StingRay Project - Input Wanted
  93. LS conversion alternator wiring?
  94. Wrote a 3rdgen fbody specific swap manual
  95. Any major differences with a 1st gen S10 LS1 conversion?
  96. O2 sensor pigtail for harness
  97. Maggie in a Fox Body?
  98. '94 Nissan Pickup
  99. My 98' Camaro v6 to v8 swap LS1 swap
  100. 1988 iroc-z/28 6.0L swap WITH TILT TRAILER FOR SALE!
  101. Ok so what oil pan for LS1 in 55-57 Belair?
  102. IT RUNS!! ls1 in 1964 buick wagon...
  103. LS2 Mechanical Throttle Questions
  104. Pinouts (or better yet, wiring diagram) for '07 or '08 L92?
  105. Winter projects FINALLY done!
  106. EGR Truck manifolds for a boat application
  107. pinouts for an 01 gmc sanoma 2.2?
  108. alternator question
  109. CNC Clutch Master Cylinder?
  110. Is there anything I am Missing????
  111. wiring up a 99 dash to speartech mod harness
  112. LS! corvair starting issues.
  113. Anyone know how to hook up kickdown tv cable to 700r4 to ls1?
  114. step by step s10 ls swap?
  115. braided hose for clutch
  116. new car too me...1964 vette
  117. S&P compressor and bracket kit for sale
  118. Cruise Lever for 70-78 F-body w/ LSX for sale
  119. O4 GTO alternator not charging
  120. Second Gen weight reduction?
  121. 1975 Mbg + Ls1 / T56??
  122. EFI w/ no cats = fuel smell?
  123. harness power question...
  124. muffler question
  125. LS1 into 87 Camaro
  126. Anyone have??
  127. Lq4 And T56 In A Fox Body Swap
  128. Upgrade bottom end?
  129. LSx Optimal Header Type
  130. non liquid gas threw injectors?
  131. 240sx+lsx=cool,but add T76 and sy/ty=Nuts?
  132. LS1 in a 52 Studebaker Truck
  133. Looking at a LSX Block..
  134. will a 97 engine harness work with 93
  135. ls1 ls2 swapwhat has to be done
  136. help with DBW
  137. trans-am into corvette?!?!?
  138. Help me decide/Cost analysis
  139. Looking for some pics
  140. Intake question.. LS6 or a truck manifold?
  141. question about "Scan Gauge11"
  142. Cooling fan won't come on
  143. Dyno'd the LS1 Miata
  144. LQ4 in a 97 Dodge Dakota?
  145. that little plug
  146. My 62 Impala Project
  147. DBW trottle is dead
  148. 168 tooth 5.3 flywheel part #
  149. need help
  150. 73 Z/28 LS1 swap - back in action :)
  151. 98 LS1 into 79 Chevy Impala
  152. LS1 in a 2000 chevy silverado classic
  153. 4.8 in 89 formula with 6spd
  154. hide your harness
  155. exhaust flange
  156. 3rdgen Guys HELP!!
  157. Feedback from purchaser's of McLeod Kit to move T-56 Shifter forward
  158. anybody need an S&P modified Fbody oil pan?
  159. vette regulator, which is the inlet and return?
  160. 2002 ls1 4l60e into a 1972 Camaro (looking for the least expensive routes)
  161. 5.3 Fuel system question
  162. Need Help With Fuel Problem!!!!
  163. Steering Column HELP!! CHEVY II aftermarket front
  164. phill99's mustang survey :D
  165. 1st Gen F-body with late Vette drive train.
  166. has anyone EVER seen an LS1 swapped into a mopar???
  167. Worth buying a T-56 setup?
  168. Edlebrock/MSD controller for f/s
  169. Fuel system alternative
  170. who here has used motor plates for their swap?
  171. Maybe a repost...Supra motor in Classic Camaro!
  172. gm performance parts harness
  173. LS1 in a 68 Chevelle
  174. help with fuel!!!!
  175. Canīt get any oil pressure
  176. LS3 Harness Questions
  177. RX7/forged 370/TC78
  178. Oil filter F-body pan
  179. first launch video 1965 olds rocket
  180. 5.3 L460e swap,engine dies when shifted from park?
  181. SN95 to ls1 swap how much??
  182. ???transmission for sale???
  183. 2nd gen camaro 5.3
  184. Need some conversion help
  185. Check engine light wiring?
  186. Doing some clean up on the 63 / LS1 swap
  187. 6.0 Lq4 Relucter Wheel???? 24x Or 52x
  188. "2-way oil sensor connector"???
  189. Does anyone have pics or info on the gmpp acc drive yet?
  190. 4L60E trans oil fitting
  191. would love some input diagnosing ticking engine
  192. LSX Vs. aftermarket EFI small block in 72 monte carlo
  193. lt1 in a 280zx?? help!
  194. LS7 questions
  195. DYNO Results ! 68 Cutlass / LS1 / A4
  196. 2nd Gen Conversion Fuel Delivery
  197. ac ? on '68
  198. The Chevelle runs
  199. Anyone here done a natural gas swap?
  200. 900 hp AWD LS7 Weber Sports Car
  201. Throttle body to MAF hose
  202. LQ4/LQ9 oil tube pickup bolt torque?
  203. does vats disable the injectors and fuel pump?
  204. Video of Nissan 240 w/ LS Magnacharged power!
  205. Custom radiator & Meziere water pump, what inlet size?
  206. HELP! Motor will crank but not fire!
  207. Custom Power Steering Reservoir?
  208. Help with part numbers?
  209. 64 chevelle transmission crosmember
  210. How hard to swap LS1 into v6 Firebird
  211. ls1 extension harness?
  212. ls1 mounts for a 67
  213. 1967 Chevelle LS2 ?'s
  214. 69 Chevelle SS 6.0L
  215. A4 Main Plug diagram
  216. Socket for oilpressure sensor
  217. Where did you get your harness?
  218. Some questions after starting 5.3 for the 1st time
  219. msd 6010 timing graphs
  220. 6.0 LQ4 into Third gen
  221. v6 to ls1 $
  222. Corvette LS2 exhaust manifolds in 1st Gen FB
  223. Ebay swap harness????
  224. LS3 in third gen
  225. Smaller power steering pully?
  226. fuel pump relay control?
  227. 3 pwr steering lines on a LQ4?
  228. how to modify the shift lever on a 4l60e for a ford shifter
  229. How much am I giving up??
  230. Looking to put a 53. or and LS3 in to a 97 Toyota Carolla
  231. ls2 firebird swap
  232. Will 5.3 headers fit on an LS1?
  233. First start-up
  234. '82 Vett
  235. Fuel Pump Wiring
  236. Question On the Engine Sense Fuse
  237. First Mock-up of carb manifold w/TBI..6.0L
  238. Custom pre-made driveshafts..
  239. GP on F-Body LS Swap Headers - Edelbrocks
  240. FS: BRP Power Rack & Pinion Kit for F-Body
  241. Looking for adapter plate for LSx to 240sx 5 speed
  242. LS376 (carbed ls3)?
  243. My carbed 6.0 in my 78 malibu
  244. What kind of Shorty Headers to use?
  245. Is tuning Software Required?
  246. lq4 alternator question
  247. JEEP grand chero ls1 swap?
  248. Milk Truck with LS1!
  249. lq9 in rx7?
  250. Phil at BRP Hot Rods
