- Help with part numbers?
- 64 chevelle transmission crosmember
- How hard to swap LS1 into v6 Firebird
- ls1 extension harness?
- ls1 mounts for a 67
- 1967 Chevelle LS2 ?'s
- 69 Chevelle SS 6.0L
- A4 Main Plug diagram
- Socket for oilpressure sensor
- Where did you get your harness?
- Some questions after starting 5.3 for the 1st time
- msd 6010 timing graphs
- 6.0 LQ4 into Third gen
- v6 to ls1 $
- Corvette LS2 exhaust manifolds in 1st Gen FB
- Ebay swap harness????
- LS3 in third gen
- Smaller power steering pully?
- fuel pump relay control?
- 3 pwr steering lines on a LQ4?
- how to modify the shift lever on a 4l60e for a ford shifter
- How much am I giving up??
- Looking to put a 53. or and LS3 in to a 97 Toyota Carolla
- ls2 firebird swap
- Will 5.3 headers fit on an LS1?
- First start-up
- '82 Vett
- Fuel Pump Wiring
- Question On the Engine Sense Fuse
- First Mock-up of carb manifold w/TBI..6.0L
- Custom pre-made driveshafts..
- GP on F-Body LS Swap Headers - Edelbrocks
- FS: BRP Power Rack & Pinion Kit for F-Body
- Looking for adapter plate for LSx to 240sx 5 speed
- LS376 (carbed ls3)?
- My carbed 6.0 in my 78 malibu
- What kind of Shorty Headers to use?
- Is tuning Software Required?
- lq4 alternator question
- JEEP grand chero ls1 swap?
- Milk Truck with LS1!
- lq9 in rx7?
- Phil at BRP Hot Rods
- Stupid windage tray question.
- Anyone ever use these headers?
- Injector wiring, polarity?
- PICs of engine bays
- Wiring a carbed 5.3 in '81 C10
- Ok fox swap guys....get your T-56 set-up here!
- Which LSX for Budget Build?
- 98 3.8/4L60 --> 98 LS1/4L60....help!
- Plumbing LS1 for rear radiator?
- More Drive by Wire Questions
- 99 LS1 into a 94 LT1 car
- WTT/WTS: C5 Accessories/BRP adapter plates
- need straightforward answer. cts-v t56 on trailblazer ss ls2
- LS2 A/C problem
- 02 ls1 motor in a 98 chasis, need help with wires
- Alright One last electrical question.
- Will this pump work?
- LSx NEWBIE NEEDS INFO
- New Swap Idea-Weird-Dumb-Just Plain Cool
- 5.7L 350 vortec in 1981 chevy c-10 custom deluxe
- Which fuel pump should buy??????????
- LS7 in SS truck
- 5.3 Vortec in a 97 Jeep Wrangler: Engine Issues
- Using Stock Air Compressor with Vintage Air Kit
- Help me decipher my wiring harness (Lots of pics)
- ls1 from 84 into my 86?
- Plate between T56 and bellhousing?
- Idea (1949 Anglia)
- Swaping V6-V8 Chevy Silverado
- its alive
- Wiring Harness Auto ---> Stick
- A/C compressor mounting
- engine mount plates FS
- Trade Fbody for GTO Oil pans
- Finally the new engine have arrived.
- Custom fuel cell questions
- Need help smog reffing ls1 motor in lt1 body
- LS6/T56 swapped S-10
- Bending AC Lines
- Any views on this wiring harness?
- My 1968 RS Pro-Touring Camaro Project
- 2nd gen. camaro motors mounts for ls1 swap
- which 4L60 do I need
- 93 Camaro Lt1 to Ls1 what hard parts need to change.....
- Official Project "In Motion" Thread
- Altenator?
- ls/carb-i just cant get it to run right-revisited
- Aftermarket Clutch resevoir ?
- Building your own headers. theory and advice help needed
- Way to go GM performance parts
- A body fuel lines
- Trying to help... ABSOLUTELY STUNNING IN PERSON!! 1997 240SX LS1 M6
- LS2 brackets on LS1
- LQ4/LQ9 flywheel for Tremec 3550 Transmission
- Drive by wire TAC module pinouts
- Easy tranny Q for the pros
- GP On A-Body Swap Headers - Edelbrocks!!!
- will a lt1 t56 bolt up to a ls2?
- how much psi and volume can the vette filter take?
- fuel rail help
- Jagsthatrun
- Anyone use GTO oil pan with fbody dipstick?
- what do i need
- Anyone using GKI vette filter/regulators and having problems??
- Project FlightRisk; Mustang + LS1 = 6.50's
- About to order my LH8 oil pan assembly
- What do these connectors do?
- custom firewall question
- Early 4L60e & '04 LM7?
- 07 Ls2 + 94 Rx7
- Help with LSX Swap in 70 Chevelle
- Need Help Picking a Cam
- 3.8 to LT1
- ls1 into 1989 suburban
- Exhaust pipe size
- Rebuilt T56 having reverse trouble!
- Trans bell housing bolt size?
- ???????????????Which TV cable should I get Ls1 swap?!!!!!!!!!!!!!
- LS2 Starts sometimes
- Blocking off the nipples anyone
- 5.3 into Lt1 car... few accesory questions
- Another conversion comes to life!
- O2 Sensors: Are LS1 and LS2 the same?
- truck acc. in a Gen 2 camaro
- LQ4 Th350 Do I still need Spacer?
- Does anyone have a used G.M vette filter/reg that I can try?
- this cant be right
- LQ4 Oxygen Sensor Question
- 4L80E tailshaft damage due to wrong cooler fitting!
- Ls1 Fc Rx7
- Need wiring help!!
- Recommendation for gas ECU#(may try E85 in the future)?
- 71 nova worth swapping 454 for lsx truck motor?
- Newest project----69' camaro!
- dakota digital help
- programing an msd 6010 box
- quick question
- 1983 G Body wagon LS motor swap
- Can I get some quick Opinions/Help?
- Buick Reatta?
- Old car, new engine, emissions testing?
- F Body Oil Pan for sale
- Is there a smaller throttle body?
- Need drive by wire 10 pin connector
- FREE ECM Flash from Painless Performance
- lt1 to ls1
- 2-inch or 3-inch diverter valve?
- ls1 cutlass
- GM part number....What is this?????
- 2001 LQ4 Stand alone harness
- Exhaust and the referee
- 4" cutout on a third gen?
- LT1 to standarts SBC
- LS Swap Fuel Problems
- Car dies
- Please post the info you should provide a tuner when considering a conversion.
- power steering lines
- Drive by wire harness issue
- draining the block
- water pump question
- need some wiring pics!!
- C5 LS-1 in a '72 Maverick
- th400 set up for lsx
- '06 corvette engine with a 6 speed harness and a '05 4L60E trans, what to make work?
- Porsche Cayman LS7 conversion thread at a P-car site. Very interesting.
- FS:GTO Oil pan w/windage & pickup
- any s10 guys have manual brakes
- Steering column and driver seat.
- 1966 chevy"2" ls1/th350
- Can anyone tell what Bellhousing this is?
- Need help with a ls1 swap into a 90 300zx.
- need help
- quick disconnect size on LS1 fuel rail
- 5.3 (Baby LS2) in a BMW
- LQ9, LS1 intake, C5 exhaust, which cam?
- 1994 trans am swap to ls6 or ls3 HELP!!!!
- Where are people buying vette filter/regulators?
- LQ4 Heads Stuck-won't come off!
- Radiator hoses A body guys help!
- Does anyone have a part number for Datalink connector???
- Speed signal not present??
- how do you explain ls1?
- need some wiring help with my ls1 in the 70 camaro
- ls1- getting the fumes from the gas tank to the TB... ??
- 5.3 or 6.0?
- Cng
- VSS Hook up
- 2nd gen headers?????
- hawks 3rd gen headers?
- Need help!
- 1985 4wd Chevrolet 4.8 retrofit questions
- LSX into my mustang with my TKO600
- Header help on my swap!
- Who's flipped the ats mounts... lsx in a 70 velle
- cooling fans
- do i have to cut the floor to fit the t56 on the 67?
- TKO 500 5 speed or T56 6 speed
- Gauges
- does someone make a thinner water pump pulley? for clearance
- LS1(98) to LT1(97) Cluster Wiring.....
- carbed 5.3 with th400 in 67 camaro question
- Guy's with MSD 6010
- What ecm should i convert my L92 to?
- camaro gen 2 + LQ9
- msd 6010 cd
- coolant on header bolts?????
- Ls1 fox swap come in need help?????????????????????
- ls1 in 99 camaro
- Finally made it to track
- Connector C100 G pin, Connector C105 B pin
- edelbrock headers
- LS3 swap
- pics of 3rd gens lsx based swap
- LS1/LT1 Into a 82-91 Camaro???
- Progress Pictures
- msd 6010 users-chips vs laptop timing
- cooling issues.. many details.. help me diagnose!
- Heads up on a clean 56
- 3rd Gen Corvette swap
- Can you use an automatic transmission cooler as oil cooler?
- first gen camaro question
- Why the !$&@ is thing blowing vette filter/regs????
- Cheapest place to buy new GTO pan setup?
- Crossmember mods
- Stock V6 SN95 Fuel Pump enough for Stock LS1?
- ls3 wire harness for crate engine install
- Kugel Clutch/Brake Assembly for sale.
- 68 camaro rack and pinion question
- 5.3 Vacuum port required
- 00 Camaro LS1 pan to trade for a rear sump GTO pan
- FS: LS1 Fox Body Swap Driveshaft
- LQ4 598, 595 do I need valve reliefs
- Possible wire issue. Can't go past 3000 rpm
- V6 to LS1 (93-02 4th Gen)
- ls1 in to 4x4 s10 need mounts
- 95 Impala tank for swap...
- convertor bushing
- harness rework...questions
- Seeking G body swap info
- Need Flexplate LS to 200-4R
- is this an underdrive pulley?
- What would cause the vette filter/reg. to blow?
- DBW t-body fox body
- estimated ET
- A-Body Guys, Enter:
- 95 mustang 6.0 turbo
