- 95 Impala tank for swap...
- convertor bushing
- harness rework...questions
- Seeking G body swap info
- Need Flexplate LS to 200-4R
- is this an underdrive pulley?
- What would cause the vette filter/reg. to blow?
- DBW t-body fox body
- estimated ET
- A-Body Guys, Enter:
- 95 mustang 6.0 turbo
- LS1 Computer In A Sealed Box?
- Does anyone make an extension harness for the LS1 PCM?
- Harness Question
- Any new ideas for swaps?
- spark plug wire question
- LS1 and th350 transmission in 69 chevelle
- Looking for some ideas?
- 04 GTO LS1 fuel pump
- reworkin my harness questions???
- F-Body Harness w/ Truck PCM/MAF
- My "Bitchin Camaro" project
- C105 pin H
- PCM red connector pin 53
- LS2 KOUKI BUILD AKA "HEART OF A GOAT" 56k beware**
- 6.0 LQ9 with LS6 intake into a 68 vette recipe
- First Gen Mount Kit using stock accessories
- For the wiring impaired
- 99 Wrangler LS1
- 99 Wrangler LS1
- Ls1/t56 fox guys... What gears in the rear end?
- PCM/Harness Question for 408 lq9 w/ls3 heads in a 94 Camaro
- walbro fuel system problems NEED HELP!!!
- 5.3 tach output signal
- Help with gauges on lt1 to ls1 swap
- lt1 to ls1 swap pic's???????
- 2004 6.0 Denali Engine in 1998 Z28
- Remote oil filter? Which port is IN and which is OUT?
- carbed 5.3l th350 help
- 4wd s10 to 5.3L NEED HELP!!!!
- Best Stock Exhaust Manifolds?
- ls1 67 camaro radiator
- S10 guys.. I need some measurements
- Corvette Transmission in 1st Gen Camaro
- Any carbed LSx pics?
- Carbed intake?
- ls1 questions 240sx
- LS1 swap to LS2 or LS6
- converting a 2000 V6 camaro to a 2002 LS1 drivetrain
- Right PCM for the eng/trans combo?
- drive by wire inop???
- Any ls1 fders go forced induction?
- Need an F-Body oil pan, exhaust manifolds?
- Someone with the 5.3 Vortec. HELP FAST!
- My Procharged LS2 M6 1996 Impala SS
- LS1 Swap into Blue SN95. Build thread.
- LQ4 in a 64 Chevy Pickup, Need Advice!!!
- more track updates 4-16-08 on the 94 ls1 mustang
- LSx into a..... NASH?
- Fox guys with a Turbo 400??
- Swapping rear gears
- 94' volvo planning
- why are all bolt in crossmembers crap?
- Need some help piecing the rest together
- Any of you carbed LSx guys!
- 5.3 LM7 into 87 El Camino
- Adding both oil pressure and oil temp guages
- ls1 240sx stuff
- A few questions (harness, bHousing)...
- Wire removal on SN95 for LS1 swap, pics inside.
- LS1 hybrid idles at 950 RPM - seems high??
- Connector pinout picture for LS2 Cam and MAP sensors
- 02 V6 F-body to V8 9" car
- Finally starting to come to a close
- New LS Swap book- Need some pics
- More Amigo Madness
- Source for wiring harness?????????
- ls1-67 camaro front clip questions
- I'm Dropping in an LS1 into a 4door 04' 3 series BMW!
- LS2 GTO HEADS ON A LQ4 how will it work?
- MIL stays on scan tool says off
- Yes, another LS1 into an F-body, with a few twists...
- 78 Mgb?
- Update on my 87 Camaro 5.3 build
- LS1,2,?? into G body
- Autometer Guage Questions, for LS1 into SN95
- 3.8 to LS1...whats involved?
- t56 hose connector on pass side
- Need height of LQ4/6.0 truck intake
- GTO LS2 into Iroc
- fuel filter before walbro pump
- My 86 C10 6.0/4l80e swap
- My conversion project - an old Volvo
- Will headers require o2 extensions?
- Timing chain question/windage screen
- Designing headers in SolidWorks
- What 4L60E tranny for a-body swap?
- '69 Firebird ideas
- LS2 battery light hookup
- 6.0/LQ4 carb torque curve?
- 04 truck PCM Pin Diagram
- PCV system on 6.0l lq9 in thirdgen
- ls1 s10's/colorado's please chime in..
- whats wrong w/ the 5.7?
- what do I do with the coolant pipe that exits the throttlebody?
- SWapping a 98+dash/gauge into LT1Thirdgen, cluster issue?
- 86-92 Ls1 IROC Z
- Quick 5.3l and T-56 question
- Steam Vent Hose Question
- ok guys need help, no injector pulse, no spark, no fuel pump
- Sleeper of the century???
- Looking for some recommendations from fellow Conversion and Hybrid guys.....
- What shifter for 4l60e (and ls1) in SN95 Mustang
- LS1 into 64 Malibu SS "A" body car
- My '51 Merc (some pics)
- Ls1 chevelle headers?
- looking for 2001 Camaro colour wiring schematic
- 1999-2000 LQ4 6.0 Engine Fitment 4l60E
- ls3 in FRC
- radiator hose lookup
- v6 to ls1 swap
- 84 ss monte
- where to mount inline fuelpump on 69 camaro
- Almost ready to start 68 LS1 Firebird, what jets for Holley HP 750?
- Car Shop 1" adaptor plates in 3rd gen...
- help no spark suddenly
- 6.0 LQ4 into 68 vette, questions
- LS1 without power steering on 240sx
- Flexplate
- A-body vs G-body headers.
- 6L80/6L90 into 68 Camaro does go....
- LS1 Thirdgen Headers. Need to make a decision
- truck accessories/harness/computer on an LS1
- corvair with ls1 swap??
- LS1 in 98 chevy truck ???s
- Which ECM do I need to get??
- St. Louis area LSx Swap Shops?
- corvette fuel filter/regulator question
- Pics of the Amigo
- Please Help P0654
- old 4.3 to 6.0 and tranny?
- first time to the track in the ls1 94 mustang
- lq9 into 2000 ram air and now having problems, need help asap
- Car only runs for about 3 seconds.
- question about fbody fuel rail, truck coil packs
- NO CRANK! 96 Camaro to ls1 swap.
- Starter noise
- Since "Fair" didn't think to do it ...
- LS1 valley cover/knock sensor - any need for them?
- Strange starter problem....
- 1971 Chevelle LS1 6 Speed swap From the Beging
- Gas tank questions
- LS7 + 1932 Ford Pickup
- Complete LS2 Engine kit for LS2/LS7
- Speedo Hookup
- LS1 headers Diameter?
- Flywheel Problem
- 6.0 into Buick Skylark?
- TPS sensor required?
- Wiring 02 LS-1 to 96 LT-1 Z28
- How hard would it be to....
- 99' Silverado Wiring Harness for LQ4???
- LS1 in 69 Chevelle intake question?
- GTO Oil Pan -- do the ports in the aft LH end need cover??
- New OEM tach issue can't find info
- 02' vette alt using 02' f-body harness/PCM into 02' sonoma
- Need some headers for Jeep
- LS2 Steam Vent
- NEED help with motor mounts
- check this out
- Finally figured out Alternator wiring!
- ABS Brake Module Needs VSS Input-Where From?
- correct connector for t56 vss connector??
- ECU Pins, where to get
- adding pins to harness
- idler pulley source or part #?
- Fluctuating oil pressure... any advice??
- The size difference between a LS1 and a F20 Honda Motor
- Also what degree angle should the engine be sitting at?
- A Body Guys, Show me your AC compressor Mounted with notched Frame
- drivshaft
- Something im working on for the LS1 into LT1 F-Body guys.
- Ideas for A/C and fan relays in Chevelle?
- sm465 to a 5.3??
- LSx engine swap in 1999 Sonoma Tach ?
- BMW E36 Track Car - LS1/T56 - Cobra 8.8"
- 57 chevy & accessory drive ?
- 1996 2dr Tahoe with 00 corvette LS1 in it For Sale. 93k
- LS2 and a 4L65E in a 67 Chevelle.
- Isuzu Amigo swap
- Autometer tach and a pull-up resistor?
- 1970 Chevelle w/ LS2 TKO500 Progress.
- LS1 Accessory Drive Non A/C Setup Question
- swap help
- Any shop recommendations for stock LS1/A4 in Festiva
- Anyone using a GMPP programable trans. controller?
- Advice on an S14 240sx LSX swap
- Porsche
- 300z and 240sx guys please chime in....:)
- a body front suspension
- FS: NIB '00+ Corvette Filter/Regulator
- Mark's LS1 2nd Gen Camaro build
- Fuel Gauge Question
- another new conversion, no spark
- fuel pump mounting
- Who sells PCms without needing a VIN?
- Oil pan alignment
- turbo ls1's, not in camaros- what do you guys do?
- Not your everyday LS1 swap
- Chevy II Ls1 pics!
- Few questions. LS1-T56 into SN95
- LQ9 - Jeep - 3" Single Exhaust = Good Idea?
- 3.8 swap wiring
- Wire diagrams for 06 Montecarlo SS 5.3
- Harness help
- Project: Insanity
- Throttle Body Compatability - Different FBody years
- Looking for the schematics for a 2004 5.3 engine harness
- fan wiring/relay question
- Truck AC compressor
- manifolds or 1 1/2 tube shorty headers
- alt. help please
- first gen camaro springs?
- 5.3 Vortec swap in a Jeep XJ?
- 5.3 into 69 chevy c/10
- 5.3/6.0L into a 1994 Trans Am.
- My ZLSX
- hyralic clutch delimma
- LS1 T56 Swap into 67 Camaro problems
- smallest lsx swap
- LS1 in a New edge ('99-04) Mustang
- My 3800 V6 is starting to annoy me... drivetrain swap difficulty?
- 99 F body V6 pump same as an LS1 pump?
- Torque converter switch?
- I want to put a LS1 in 1967 firebird
- RX7 Shell F/S..Perfect for an LS1
- The tach on my car doesn't read right.
- 4.6 mustang motor
- XAT's LS1 Swap
- New A-body EFI tank
- 1938 lasalle witha ls1
- Help With Lt1 To Ls1 Swap A/c!!!!
- thread size identification ques
- Rx7 swap FS
- Any first gen mustang swaps out there?
- MSD 6010 users
- carbd ls1 turbo set up
- local dyno day vid
- please help me with this
