- plug #230
- Vacuum source with LS1??
- LS1 swap for an lt1 car
- 5.3 and TKO500 in a '66 Chevelle
- 6.0 first Gen question
- Cheaper motor?
- List Your Conversion Gas Milage....
- first gen s10 guys...
- Help with an LS1 into an S14 240sx
- header help
- banjo bolt...
- what are people using for springs on 1st gens?
- Speartech! Where are you!?
- Yet another wiring question
- I need Help picking out a cam
- 2001 ls1 into a 1998 car help!!!!
- using a muncie with a LS/LQ motor...
- LS swap Mustang cpe track times.
- Switching to LS1 in LT1 car
- Final Steps for A/C - Relay/PCM control? Electronics gurus?
- 2nd gen ls swap
- Ford Lightning swap?
- Tach problems 89 Camaro
- Gauge question for conversion
- Fan Relay Question in Stand Alone Harness
- Pulling engine
- few diff harness q's hopefully easy...
- 67RSSS' project spreadsheet
- 1971 Chevelle LS1 H/C Pics and Vids
- LS2 Chevelle Project.
- Throttle By Wire
- 95 Z28 to 99 LS1 Conversion Guide...:)
- Wiring question
- ALDL connector
- Fuel Pump???
- Stock fuel pump relay wiring question
- Ls6 intake gaskets?
- Pics of my 66 nova ls1 M6 C4 conversion.
- C4 owner opinions Dana 44 halfshafts allignment?
- sbc mustang wiring issue
- 67 camaro speedometer ?
- Recommended Oil Pump
- LS7 is alive
- Dana 44 fuild "so many choices" which do you run
- GM LS1 swap manual $9.36!!!!!!!!!!!
- Look at this sweet deal on corvette fuel filter/regulator $37.93!!! $38.34 on ebay!!
- C100 Plug help needed!!!
- Ls1 no spark
- Couple of stupid questions...
- LS13 project
- LS series iron block???
- ls2 accessories onto gen 3 block!!
- What connects to the pitman arm on a 67 camaro
- Power steering line question....
- Oil pressure range 2002 LS1
- My LS1 300ZX
- GM quick disconect fuel fittigs , where can I find them?
- More Ford infidelity-
- My LS1 S14 Build Thread
- Starting on a 67-72 GMC 6.0L pickup
- 1998 3-wire Temp Sensor
- Rx7 Headers
- operating temp range of LSX??
- awesome conversion on ebay
- 1957 Bel-air LSX
- Getting Autometer Gauges. What works and what doesnt?
- BUILT LSX Stroker into a 95 Z28
- Track times
- LS into 74 Camaro/ 59 Suburban
- Colling system problems
- Camaro 3.4 question
- Ls1 swap into sn95 Mustang
- LS1 into a 00' Sonoma/S10
- Another LT1->LS1 Conversion (pics)
- downsizing the wire harness
- Might sell my bu wagon
- swap parts
- fuelling issue- can you give me advice
- Engine/trans angle question.
- Fuel pressure issue
- 98 Temp sensor pin out?
- Practice pictures
- my 240sx/ls1 swap PICS
- 1984 LS1 Vette FS
- Any other probs with S&P modded oil pan? PICS
- A-body LS-x swap guys, read this before you get started!
- Rack and Pinion. ?high pressure side?
- Brake booster blockoff?
- Oil Pressure problems
- 1st gen 4" cold air induction pics
- Newbie here. . . just thought I'd post pictures of my Chevelle LS1 Conversion :)
- Do I even need to install cat/converters?
- wiring schematics key
- Pedal Assemblies
- 5.3/4L60E into a 68 elcamino??
- 2nd gen LSx conversion
- Exhausting question, clock is ticking for me
- link to garage sale with some nice conversion items for all makes....
- AC wiring?
- Location of cats
- Finally, Some Progress
- ls1 in 69 camaro wiring alternator
- Need Help -ASAP
- How small is too small on the return line???
- 0-60
- lt1 to ls1 wiring question
- AC Hookup Questions
- ls6 vs ls2-7 front accessory interchange?
- Harness to ECU pins
- Smaller Bellhousing
- ‘69 LS1 C-10 Pace Truck build
- Help on motor swap LS1+miata
- My Fiero/LS6 project is now on Ebay.
- My LS1 E36 BMW 357i
- 6.0vortec into 4th gen f-body possible???
- Exhaust manifold help NEEDED on home built turbo setup!! (pics inside)
- 2003 6.0l 4l80e into 95 Silverado Conversion Questions
- viper v10 swap
- 5.3/6.0 swap into 89 Suburban
- nissan 240sx (S14) with Modded GTO pan (tons of pics)
- Power steering reservor question
- 98 3 wire temp sensor connector
- GTO LS2 package in V6 Bird?
- It started!!!!
- 5.3l S10
- FS: Mock-Up block, heads, oil pan, etc.
- Pics of Fox Mustang and Chevy II conversions
- Ls1 conversion- power estimate?
- How Much Are Complete Engines Costing From the Junk Yards?
- 6.0L LQ4 with Denso A/C Compressor Question
- what's needed to fire my ls1 up?
- mounting PCM in a fox
- 2nd Time Conversion
- walbro fuel pump...
- Stock 2002 LS1 parts great for swap
- Aftermarket oil press guage fitting?
- LQ4 + Z31 Turbos
- LS1 + TSi=
- Dynoed my LS14. Running way rich...discussion on how to fix it.
- Japanese Car, American Muscle
- The LS1 mini cooper lives!!!!
- 2nd gen camaro conversion?
- Ohm range F-body fuel level sender
- 240sx manifold/header solutions
- ls1 clone ??
- ls1 in homebuilt aircraft!!!
- left bank lean
- LT1 to LS1 swap A/C question
- quick question about swaping t56
- Coolant Sensor Leaks
- "LS6 cam, how do i know?"
- GMPP front accessory kit part #?
- ls1 in 65 el camino
- Swap adapter plate pics
- ls1 motor/dash swap into lt1. Help please!!
- accessory questions
- lt1 conversion into a truck with a vortec
- The BADDEST Evo VIII on the planet
- LS1 swap fuel rail ? & part number
- just finished my custom intake
- Fast Intake with NW TB. what ECM is needed?
- LS2 or LS6?
- MAP low voltage ....
- newbie...with a ls1....but not in your typical car
- Is a ls2 gto oilpan the same as ls1 gto oil pan
- lt1 in 88 s10
- problem with new style GM fuel connectors
- New guy question
- LS1 swapped into an EVO!
- Motor mount plates
- LS1/First Gen Camaro Hooker motor adapter plates
- Which T56?
- LSX Fox
- Truck Manifold 1st Gen
- 6.0 L swap into a 97 tahoe 4x4 auto
- 93 Del sol ls1 swap
- Round 2 on my 87, Custom ehxaust, crossmember, installed cutout. LOTS OF PICS!!
- 95 Camaro V6 conversion to 99 LS1
- Trunk manifolds facing forward with C5 accessories?
- What year wiring is the best to convert???
- no spark/fuel
- Relocating A/C
- slave adapter...
- Brake question
- We are in trouble!!!!!!!
- Gas Gauge?
- LSx accessory bracket setups
- LS1 into 77 C3 windage tray question
- Who here has bought a donor car for the drivetrain?
- Questions about 5.3 carb in 89 Mustang
- scan my ride harness?
- Quiet exhaust suggestion
- MAF or not?
- 5.3 fuse box
- putting an LS2 into a 94 t/a question
- difference in exhaust manifolds
- My friends 87 Formula
- Project LS2
- Softer mounts for 240 swap
- Finally! Pics of my 5.3L 1950 Chevy truck
- External Fuel Pump Reccomendations
- Trans Mount
- 1967 RS Camaro LQX Swap and Resto Project
- TIP: LT1 Camaro fuel system mod for LS1 swap
- Bigdog's Wagon
- Ls6
- Anyone running a T5 behind their LS1????
- 66 malibu 5.3 finished
- LS1 kit car project
- LS1 swap into sn95 mustang...wiring question
- Transmission position indicator?
- ls2 in thirdgen Headers Questions???
- Need help with 240Z rack & pinion swap
- O2 sensors help with wiring them to engine wiring harness
- Wiring Diagrams and Connector diagrams 2004 GTO (my gift to ya'll)
- Automatic or 6-speed
- good info on Bosch O2 sensors, to determine which is yours.
- Need Parts For 69 Camaro LS1 Swap
- F-body Intake on LQ9
- Basic questions not shown above....
- rwd celica ls1?
- Troubleshooting - extremely rich running V8
- LS1 into 91 chevy truck
- HELP!!! ASAP!! how do i hook up a low voltage warning light to an ls1? sandrail swap.
- 700r4 kickdown kit
- Oil pressure sender help!!
- Gas Ohm to Electronic Guage?
- My Donor LS1 Has 95K Miles
- A/C Question for an S10
- 63 Impala 5.3l conversion
- Best Ls1 motor mounts for 67 camaro that offers optimal engine position
- need a pulley mount size on alt bracket
- stainless works headers with S&P mounts
- Drove my LQ4 powered 81Z this weekend.
- resistance reading on LS1 fuel level sender???
- Current Consumption
- 1st Gen F-body Converters inside please
- LT1 M6 to Truck LS Engine Conversion?
- Does anyone have a part# for WalbroGSS340 in tank pump for G-body elky??????
- Its Alive!!!!
- s-10 radiator
- Few pics of 55 with ls1 swap
- Intake swap
- Difference in camaro floors on automatic vs manual
- couple crappy vids of my notch......
- ls2 swap in third gen camaro
- Knock sensor plug different speartech harness??
- wiring help 66nova -04 GTO LS1 I have all the donor wires and boxes
- It's running again
- Help Problems Mounting LS1/240sx
