View Full Version : Conversions & Hybrids
  1. 6.0 Chevy
  2. Finally Alive .....
  3. Ls1 into 88 S10 questions.
  4. ls1 or ls2?
  5. 10 lbs of LS2 in a 5 lb BMW - 56k forget it
  6. 2002 5.3L Throttle Control system delete?
  7. 2002 LQ4 harness on a 05 LS2
  8. 1994 gmc v6 swap to v8
  9. Ls2 vacuum informated needed
  10. '02 ls1 in '71 Chevelle....I need some guidance
  11. my transmission is leaking from what looks like a T fitting
  12. Schoenfeld headers on '71 Chevelle?
  13. 67 camaro wiring
  14. ls1 240sx Speedo Converter
  15. Engine Temperature? Can this be right?
  16. What fan for ls1 wiring harness?
  17. Updated pics from BMW Z3 conversion project
  18. Fast intake and NW 90mm, what else do i need?
  19. 5.3 harness
  20. 07 Z06 brakes for sale
  21. LS1 swap in 1990 silverado?
  22. Pin outs and wiring for different OS/PCMs?
  23. LS conversion for D-Body Cadillac Coupe DeVille
  24. Which LSx models and years come with close ratio tranny and conventional throttle?
  25. 2004 corvette motor help
  26. 95 A4 bolting to a 2000 LS1?
  27. how hot does ls1 get till fans go on, i need rad. hose advice too
  28. s10 guys need a harness have new currnet performance harness cheap
  29. Fitting 2000 Z28 interior into a 70 Chevelle El Camino
  30. ABS fault = UK MOT failure
  31. Ever heard of this ebay seller?
  32. corvette filter and reg
  33. cheap LS1 hybrid car for sale
  34. remote oil filter kit
  35. Ls1/Ls6 engine swap motor mounts 55.99!
  36. LS1 in a silverado???
  37. L82 swap
  38. Truck tb to ls1 intake?'s
  39. Map Sensor/Brake Booster Relocator?
  40. Chevelle LS1 swap headers in a G-body?
  41. LS1 from ebay? into a genII camaro? your knowledge pls
  42. how about some sticky/folders for each popular swap?
  43. Will a 6.0 auto harness work on 5.7/6speed?
  44. Jeep wrangler ls1 start up video!
  45. Temp sensor - can I tap the threads in the head?
  46. 6.0 in el camino/g-body swap
  47. New motor in an F-body, best way to go?
  48. C5/C6 Rear End Conversions?
  49. heater core coolant flow?
  50. starter trouble, which stud is +?
  51. i need some info
  52. v8 tj conversion started...
  53. What timing pill in my edel 7118 box?
  54. People really do put LSx's in EVERYTHING!
  55. Interesting LS1 Engine compartments
  56. electronic throttle quit working
  57. Anyone in Phoenix?
  58. No Spark!
  59. started ls1 in blackwidow for 1st time
  60. Driveshafts? What are you using?
  61. 4.8,5.3,6.0?
  62. 1971 Chevelle Twin Turbo (pics)
  63. BACKWARDS!! Lt1 into an LS1!
  64. headers
  65. ETC Throttle Body, Pedal and TAC on EBay
  66. Welding oil pan on the block
  67. stupiest question on this forum....
  68. Cruise control in a conversion?
  69. LSx/th350-400 flexplate questions
  70. S14 240sx to LS1 Wiring
  71. S10 lower hose w 4.3 radiator
  72. Pics of my swap
  73. wiring up the ls1 starter?
  74. Ls7 oil line routing
  75. Anyone need the GTO pan?
  76. 81 C-10 LS1 swap
  77. help! autometer temp reads way off!!!!
  78. LS1 fuel pressure
  79. LQ9 conversion
  80. Fuel pressure build up on input at rail???HELP????
  81. I am the proud owner as of today of a 2000 LS1/t56 WS6 Trans Am!
  82. ls1 /4runner
  83. finishing 5.3 into '71 need help
  84. CARB. LS1 Is a 95 S-10, anyone Done it?
  85. wierd question
  86. 1st Post-Bought LS1 Today
  87. Pan Dimensions!!
  88. radiator hoses in 1st gen
  89. What steps to part out a car for ls1 drivetrain
  90. LS1 engine and T56 tranny in 87 El Camino
  91. 2nd gen
  92. Completed E36 GMW.. 1993 357is
  93. DOD with a stick
  94. 4L80E woes
  95. Running Right
  96. For Sale : '91 LS1 Mustang Coupe <-------
  97. Think these might be good headers for a conversion?
  98. Corvette vs. GTO front accessories
  99. Hooker mounts....Alternator clearance issues
  100. Will I be throwing CELs?
  101. Part numbers for fuel system
  102. mustang chassis wiring help
  103. $1200 a good deal on a clean RUNNING 89' FC RX7 GTU 13b-5speed??? Has 104,000 miles
  104. My LS1 swap is COMPLETE...well..almost
  105. Speartech question
  106. the best place to buy a 6 speed(t56)?
  107. Remove voltage regulator + wiring (1970 ElCamino)
  108. Plugging Oil Pressure Switch
  109. 1st gen header question
  110. LS1 Plug wires with headers....
  111. My 383 Chev powered Holden Torana
  112. Mazda RX7/350
  113. Ls1/chevelle Turbo mount question.
  114. Video of my LS1 swaped 240SX (aka 346SX) 0-60-0 Runs
  115. Another 3rd gen camaro LS1 swap
  116. Dash help!
  117. What brand of Hose end fitting is this?
  118. Sensor in the oil pan, will I miss it?
  119. New engine/old trans
  120. V6 to Ls1
  121. want to use my D & D T56 with LSx ?
  122. Few Questions
  123. Can a 06 GTO engine and six speed bolt in my 94 trans am?
  124. Finally some progress on my third gen
  125. Fuel rail question
  126. Fuel pressure reg/filter - lines??? Conversion help?
  127. where does the 4.8L fit in the LS family?
  128. Wiring Harness help?
  129. LS1 El Camino
  130. High-revving problem
  131. Project nearlyt complete
  132. What to do about this cut harness?
  133. Fan and Fuel relays
  134. looking to swap
  135. what stall would you recommend?
  136. LS1 PorVette - Endurance Race Car
  137. Early Classic 5.3 Engine Mounts?
  138. manual lq4?
  139. Newer GM A/C Systems-Hose Fittings Source?
  140. Bout to start a 5.3 project
  141. info on a/c
  142. horsepower help?
  143. 67 camaro fuel question
  144. Gauges
  145. Looking for a -02 6.0/80E harness
  146. pcm and 4L80 connector for sale
  147. S-10, quick questions
  148. 2000 v6 to LS1
  149. 280z ls1 swap
  150. Idle and Running Problem
  151. coversion ? about ABS
  152. Wire Harness on Ebay
  153. have ls1 oil pan & pic up & race tronix crank adapter
  154. Drive by Wire or Cable?
  155. about to attempt the swap...
  156. Should i buy a ls2 or save money and get a ls1.
  157. Would it be worth it to ?
  158. First impressions...LS7 FD3S
  159. Custom A/C system
  160. Some Questions about the 5.3
  161. LS1 Impala SS, Can't find one!!!
  162. Autometer tach and speedo ?
  163. 240/LS1 swap questions and wiring
  164. power to transmission
  165. 4l60 to t-56???
  166. 87 lx swap??
  167. What belt do I need?
  168. Need 2007 5.3L Flex-fuel O2 Sensor Part Numbers
  169. is it possible to make a 98 inside harness work for a 99 on up engine
  170. LQ4 harness to an LS1?
  171. Porsche 944 LS1
  172. LS1 Mustang Brake Booster Question
  173. Any one in need of a 6.0L truck block for conversion
  174. Anybody looking for LS1 longblock
  175. Any 4.8L?
  176. 5.3l questions
  177. transplanting a ls1 into a lt1 camaro
  178. LSX Mount Conversion Plates
  179. T-56 into LT1 caprice
  180. LS engine dimensions?
  181. Quick Fuel line question
  182. how hard? LS1 '79 Fiat Spyder
  183. Product proposal
  184. BMW E30 LS1/T-56 Questions!!
  185. 5.3L Swap Into 1969 C10
  186. Anybody ever wired up a 2000 Trans Am Dash Cluster in their swap?!?! Help Please!
  187. anyone replaced the output shaft in a 4l60e?
  188. The beast from across the pond .. LIVES
  189. Need Help!
  190. write up on swap???
  191. Nearing the completion
  192. ex-SS-ve 93 LS1 Pics!!!
  193. 96 s10 blazer
  194. -an power steering fittings
  195. A few conversion parts for sale
  196. Car opinions?
  197. Starter solenoid activated when turning key off
  198. ls2 in s-10 who can do it
  199. help need coild harness part number
  200. 4L80 tow/haul
  201. Engine harness modofications
  202. LS1 Coolant Temp
  203. taking the ls1 offroad, what should i be careful with
  204. hydraulic throw out bearing fitting question
  205. 5.3 starter question???
  206. what size headers?
  207. Exhaust manifolds - LS2 6.0L vs. Escalade 6.0L
  208. Belt question
  209. LS1 and Chevelle AC setup
  210. Budget LT1 T56 into Miata
  211. tranny swap question
  212. ls7 swap
  213. Mid Engine Swap Thoughts
  214. LS1 into my 94 Z
  215. manifolds/headers
  216. Whats the best rust remover and preventer for my 67 camaro
  217. ls2 swap in caprice wagon
  218. factory harness?
  219. 4.8/5.3 in V6 truck question
  220. Emi?
  221. 6.0 into a '82-'93 S10: Which oil pan?
  222. what intake to use?
  223. drive by wire to cable swap?
  224. +wire going to battery from alternator, what kind of wire?
  225. n e one dyno'd the typhoon yet?
  226. Carb swap guys...wanna sell your fuel injection parts?
  227. heater hose water flow direction
  228. conversion pic's and questions
  229. Smaller alternator?
  230. Speartech
  231. Driveshaft Question
  232. Car runs rough AFTER car goes into closed loop.
  233. all the ls1 vacuum ports, which are important to be connected? and to where?
  234. LQ4 for swap..
  235. Truck A/C compressor sensor?
  236. LS1 To Tremec
  237. Norris Motorsports Wilwood Brake Kits and Hooker Conversion Headers Special Inside
  238. gauges
  239. Finally some Pics
  240. Camaro swap headers
  241. corvette fuel filter
  242. Started my 84GT to LS1 swap
  243. returnless rails
  244. Question about the ECM.....
  245. Hand held tuner for LS1 swap??
  246. Hydraulic line for fuel line
  247. 1st gen Unisteer banjo bolt clearance - engine too low?
  248. motorplate AND kmember? LSX fox.
  249. 5.3 won't rev
  250. LS1 fuel system question?
