- PCM information overload
- P/N for truck throttle cable?
- jeep wrangler radiator question
- Lq4 ????
- this is an awesome conversion!
- trouble ?
- HELP! JB Weld + Cast Aluminum Oil Pan?
- A Few Questions About Auto or Manual
- th350/ LS1 in 1st gen camaro?
- harness help and ??
- camaro V6 to LS1 help !!!
- Gas tank for an A body?
- Oil Pan Clearance issue - 68 Camaro
- ls1 into s-10
- Looking for an L92/6L80E or LQ9/4L80E donor vehicle but no luck
- Mallet Pontiac Solstice LSx conversion transmission/flywheel/clutch setup….
- '69 Camaro LS1 - Head swap almost complete (pics & vid)
- 350, Lt1, or Ls1
- TT LSX into 3rd Gen
- 99 s10 ls1 t56 tranny to a late model 350
- Story of our LS1 swap into 67 Camaro
- LS1/T56 into C3 Hydraulic clutch help
- '88 Firebird, LS2 dyno vid!
- Patriot headers contact
- High rpm stumble
- Want to swap in a 97 gmc sierra-5.3 or 6.0?
- Some updated progress 62'
- LS2 and LS7 For Endurance?
- 96 cobra ls1
- Ls1 Third gen guys
- Another fox body LS1 conversion
- guage cluster wiring
- Question about Ls1 and T-56 in a '91 OBS Short w-base chevy truck?
- Where to get grommet for 1.5 inch hole?
- thermostat question
- 4L60E trans fluid
- My Turbo LS1 RX7
- Difference from an LT1 to an LS6 or LS2
- how to bolt up a booster in a 1st gen?
- 2002 LS1 into a 69 Camaro
- 1965 Tempest 327 I wanna Drop a LS1 (where to start?)
- Added New Pictures
- summit twist tite???
- what rad. and fans for a s13 lsx swap?
- does anyone have a closeup pic of their 4.6/lsx engine mount?
- one more chevelle swap
- LS1 in 00 mustang GT
- 6.0 into a 55 chevy 210
- LS! swap into 68 camaro Update
- Startup Video of the 55 LS1 truck
- LS2 into a 98 and up V6, easy?
- Finally fired the 6.0!
- i would have never thought it possible......
- Ls2-4l80e Chevelle **UPDATED WITH PICS**
- Change wires in the ecm connectors
- Another new valley cover
- s10 LS1er's what upper rad hose
- AN Fittings for Radiator and Heater Hoses
- ls1...eerrr SBC rx7 *56K* Danger to manifold
- Finally! Some videos!
- fuel line
- egr delete or no??
- 3.8L V6 to LS1
- Wiring help
- ls1 or ls2 into an 01 xc Silverado?
- ls1 to ls2 swap
- 4L60E to T-56 question....
- Hard Mount People
- gen3 in mitsubishi mighty max pickup
- 240SX S14 completed
- fuelline rupture
- Help fitting 5.3L in offroad buggy
- 5.3L with a 5speed I have some questions
- 84 - 87 Corvette control arms on 1st gen Camaro
- LQ4 Longblock
- oilpan ?
- S-10 LS1 headers?
- Spy Shots - Ultima Twin Turbo - Twins
- Does VSS have to be hooked up on a six speed?
- TT LS7 Ultima Can Am
- LS1 Conversion Questions
- Another LS1 FC Rx7 on the road
- Engine Choices?
- 2400 vs 3000 stall???
- Chevelle Mount Issues.
- 300zx 5.3ls Single Turbo, project
- my conversion harness for sale
- Where to buy adapter for clutch line. t56 pics inside
- Good Guys Event
- Harness Connectors
- Truck/van harness tach/speedo signal
- fuel pump question!
- Fan CFM to cool LS1
- 4L80E swap info
- 05 5.3 in my 66 truck and my autometers
- Good idea or bad idea? 4th Gen stuff in a '68/'69 Camaro or '69 Firebird
- LS6 into a Lt1 car
- Headers for LS7 in a first gen Camaro
- LQ4/4L60E to 71 A-body info needed
- ls7 trans am
- Does anyone make a swap kit for a 240? / need your opinions
- Transmisson will not shift after conversion
- 80% complete swap looking for new home
- non baffled tank?
- ls1 supra
- 5.3L cooling needs, '63 C10 truck...
- TH350 for 408
- Anybody buy/sell a non running parts car in Calif?
- 5.3 swap cj
- 99 V6 firebird to a LS1 roughly how much
- 96 Tahoe LS1 PICS
- bmw master enough capacity for T56 slave ??
- 98 LS1 into '88 Formula, tach help?
- PCMAmerica harness kit
- ls1 in 68 c-10 pickup
- My dads LS1 Miata
- It's Alive!
- cooling system
- 69 Camaro, 5.3 oil pan, and wiring
- Another harness question
- Y'all see the fake Ardun covers in the HR Shabby Chic Article?
- 89 s10 ls1 might be for sale
- H Pipe Or x crossover
- Cruise control
- Ran my wagon today
- question about sensors
- ls2 240sx vs. z06 c6
- ls1 into a g-body drag car....roughly how much $
- Is a LQ9 a Gen III or IV?
- lt1 to ls1, k-member?
- 69 Deville with a 472.....
- Brand New Street And Performance Modified Oil Pan W/ Pickup
- something showed up today
- conversion mounts
- 4l60e to 4l80e ?
- Re-sealing the PCM connectors
- Aluminum 5.3 out of an envoy
- New GMCOPO Retrofit oil pan
- ls1 turbo 400
- 570sx (s13) Swap Progress
- 4th gen into 3rd gen ???
- LT1 to LS1 Face swap
- Need opinions on this motor I'm buying. What should I do to it prior to install
- !EVAP Delete using 4th gen fuel tank.
- LS1 into 1965 car
- Project pics
- Eliminating smog stuff?
- 4.8/5.3 vs 5.7/6.0 debate
- steering hose question
- This could intrest some of you
- New Guy
- 240sx and Manual Steering racks
- LS2 vette pan swap ?'s
- ls1 in bravada awd
- carb progress
- NEED 5.3 truck windage tray??
- Jeep wrangler ls1 swap blog, check out my progress
- SC 3800 reardriveconversion into 87 Shelby Charger
- Ls1=lt1
- Carb intake with injectors vs LS6 manifold
- LS1 into 1966 mini cooper update
- swap idea... sr20/rb26 in an F-body
- 5.3 LSX swap, worth it?
- LS1 shop recommendation, NorCal?
- LS1 S10 Conversion
- truck fuel rails w/ corvette regulator
- Fuel injection fuel hose
- Corvette C3 with LS1 and sidepipes chime in please
- Fuel Setup help for my LS1 conversion
- will this tranny fit
- 3 wire maf to 5 wire maf conversion diagram?
- 78 Trans Am
- carbed timing
- LS1 in a 96 Camaro
- 240sx with LS2 swap vs Evo9 with 20psi
- B body swap parts
- transmission -an fittings???help
- CAS plug location?
- LS-1 with a carb
- What o2 sensors do I need
- ported oil pump??
- Carb conversion progress.....56k warning....
- Anyone put an ls1 in early 4th gen f-body
- 5.3 in a 73 truck
- LSX into a 93 Silverado??
- WALBRO inline fuel pump
- 5.3 swap into S10
- LS2 swap into ls1 camaro?
- does anyone know what this connecter is?
- oil pressure sesnsor thread
- WTB LSx FOX
- PICS of 91 ls1 s10. m6 cammed
- t56 clutch line
- in need of 5.3 pan bad...u got one??help
- 6.0L turbo into a Buick GN
- how many with LS1 in a 88-98 OBS chevy truck
- Bmw 91' E34 LS1 Conversion
- Advanced VSS Th-350 Question
- Why not 6.0 truck acc. and oil pan in an LS 71 Chevelle???
- vss sensor th 350
- Anyone With A 4l80e In A Chevelle ?
- still trying to find a complete evap cannister
- Speartech electronic throttle pedal
- 3.4 - ls1 t-56 6 speed question! PLEASE HELP!
- Updates on my LS1 Fox
- Ls1 s10 with new asa cam installed
- ls1 240sx auto or stick?
- Help with speartech harness
- 98 LS1 M6 wire harness options
- Need ideas- plumbing coolant air separation tank
- Penny Lives! Behold the power of the LS2
- Carburated LS1
- Picture of LS6 Dip Stick
- Choices for gas tanks in 73 Camaro
- Which pedals with M6?
- Anyone used the Lokar shifter setup?
- Finally finished the car SICMARO
- today is the start of the conversion
- 1973 Mercedes 450SL
- Motor Mount Plates
- New Project 951 Widebody.
- Converting Drive by wire harness to Regular
- s10 guys oil pan ??? help please
- LSx into '87 G-Bod (Olds)?
- crosspost from pcm forum on GTO ecm
- Need help on engine swap
- 4l60e to a t56
- Aluminum Radiator for Conversion
- New LS2, E38 PCM + 4L60E = trouble ????
- 2nd gen camaro new pics
- LS1 Fox Mustang Guys
- Reward $$$$$ Stolen 84 GMC LS1 Conversion
- Recommendation- MAF/Air Cleaner, etc.
- what electr. speedo's work with T56 ?
- Need to decide on which LSX to use! BMW.
- truck ECM and 4L80E
- power steering pump specs
- what are the dimensions of the ls1 engine?
- lsx into eldorado
- LS2 and torque management
- PS and R&P fittings and lines
- Cool eBay car: 32 Ford with LS1/T56
- 5.3 vs 5.7 questions for swap
- Engine Swap and CA Smog?
- what does tis vacuum hose go to?
- Colorado-need LS-1 guru to help with Jeep conversion
- 3rd gen swap guys...header removal from the top???
- S10 LSx people...
- Remote clutch bleeder?
