- Reward $$$$$ Stolen 84 GMC LS1 Conversion
- Recommendation- MAF/Air Cleaner, etc.
- what electr. speedo's work with T56 ?
- Need to decide on which LSX to use! BMW.
- truck ECM and 4L80E
- power steering pump specs
- what are the dimensions of the ls1 engine?
- lsx into eldorado
- LS2 and torque management
- PS and R&P fittings and lines
- Cool eBay car: 32 Ford with LS1/T56
- 5.3 vs 5.7 questions for swap
- Engine Swap and CA Smog?
- what does tis vacuum hose go to?
- Colorado-need LS-1 guru to help with Jeep conversion
- 3rd gen swap guys...header removal from the top???
- S10 LSx people...
- Remote clutch bleeder?
- s10 cooling (hoses)?
- 62 impala ls1 swap
- FAST XFI LSx Engine Management System Complete $2495 Shipped Plus $300 Gift Card
- LSX into LT1
- s10 guys look 2001 ls1/4l60e with new wireing harness
- 2.5" vs. 3" exhaust
- LS1 swapping into G-body
- 240sx truck accessories?
- Search not working, LSx headers in 1st Gen F body
- Fittings
- Mustang tank/baffle inside not secured?????
- Norris Motorsports Warhawk Block and LS7X Heads Received - Project Moving Ahead
- LS1 in 1965-66 Mustang
- Coolant Sensor adapter... what size?
- flywheel for 5.3
- LS2 harness for retrofit in 69 Camaro
- 1st Gen Camaro DSE Mini tub kit
- my car
- Cold air system
- 62 nova swap?
- Have corvette motor mounts been tried for an S14?
- S14 LS1 question regarding RB crossmember
- LT1 to LS1 Swap
- 5.3 Vortec into '73 Toyota Land Cruiser buggy
- thirdgens and ls1s
- Thirdgen Guys, Stock Tank....Pressure?
- Nissan 240sx speedo
- plate above oil filter
- Toying with selling my conversion
- Fuel system for ls1 jeep swap...
- Mustang swaps - Which fuel pump?
- anyone use wait4me for harness work
- wire harness help
- Mustang or Crown Vic???????????
- this may sound dumb
- missing accessory brackets & oil pan
- LSX swap racing league/series.
- What are the limits on idle for Calif Smog check?
- fuel level necessary for evap to run properly
- ls1 w/ 700r4 or th350?
- OMG Need LS1 Pulley Bracket P/N
- Our LS4/4T65E Fiero conversion
- gm 10sline clutch w/ ls1 work?
- carbed LS1
- Cadillac swap
- ls1 trike
- ls1 into 65 triumph tr-4a
- !st gen conversion/suspension?
- 2nd gen 4Runner conversion?
- 92 s-10 ls series info
- 69 Praking Lights Wiring Question
- HELP from any stang swappers
- Turbo LS1 starion (conquest) build has started
- what manual bellhousings will bolt to an ls1?
- Couple pics of my LS1 notch
- My thanks to you guys for your help
- Weight of Aluminum BBC VS LS2
- LS1 power steering
- purge and evap line
- wtb- evap tank with harness
- car intake/truck injectors?
- LS7UMI % throttle at idle
- Electronic throttle body parts
- Ls1-Stang pics
- 1932 Ford Roadster, LS1, T56, C4 Suspension C6 Z06 Brakes, 345 Rear Tire For Sale
- FPR and Water temp sender questions
- Im starting a 90 mustang coupe ls1 swap.
- anyone seen a ls1 Ford Probe???
- lm7 size
- Final Jepordy Quiz ... 572 Crate in a C6?
- Post with oil pan dimensions?
- ls1 6 speed in 86-93 s10
- 4L60e to 80's chevy T-case
- GM ITT plastic fuel line service parts
- ls1 in 3rd gen? whats it take?
- my malibu wagon
- Audi a4
- Harmonic Balancer Cover -> Balanced?
- Have a couple of questions- Gbodies
- Which 240sx for ls1 swap
- best place to buy LSx motor plate?
- MAF question
- Question on dual fresh air inlets
- truck/f-body alternator electrical interchange
- A few questions about 4th gen camaro axles
- 3rd gen Trans Am fuel line question
- my car
- Do I have the wrong Harmonic Balancer?
- manifolds
- k-members
- 240sx s14 swaps
- ls1 s10 forsale...make an offer if u dont like the price
- 4th gen steering column
- Fiero conversion project for sale...
- temperature on lsx motors
- headers long tube 1 3/4x3"
- help please.....
- Triangle Flange for stock exhaust manifolds?
- Took the LS1 miata to the track
- LS1 Flywheel
- Electric Fan Activation Temperatures?
- Sanden 508 Compressor Use Question...
- how much is a ls1 240sx
- LSX Conversions..
- External inline fuel plumbing
- Re-ls2 oil pans
- 98 Ls1 Alternator Wiring Problem
- Need help please
- T56 slave problem?
- remote ford starter solenoid
- Radiator outlets
- Anyone know the water pump heater outlet hose U loop part #?
- '86 Silverado Shortbox LS6 conversion
- 6.0 Escalade motor with bbk intake?
- How Much For '69 Camaro Roller/Project Body?
- How hard is it to transfer an LS1 engine out of a camaro into a 92 Caprice?
- GTO Front sump oilpan swap issues
- I Like Cars.
- Few Questions...
- LS2 402ci into a 2000 4 X 4 ?
- Can somebody verify '02 SS T56 gear ratios for me?
- 1989 Z24 with LS power
- What Starter?
- LS1 + 93 300ZX, Will it fit?
- 85 f150 project
- LS1 into a 240SX.
- does anyone know specific differences 02 Fbody vs. 04 Goat?
- z06 trans and rear end swap
- Where to connect steam tube LS2/LS7?
- Motor Mount Help
- trying to decide where to mount my pcm
- shopping in angst or no big deal?
- Cruise Control Arm for Electronic Cruise/PCM
- Well I have to settle for a LT1 M6
- LS1 in a 1965 Mustang...
- LS1 in a 65 Mustang...
- Looking for convers. mounts for 66' Impala
- 89 240sx LS1 swap
- Z-bar to LS1 Template
- mechanical water temp sensor
- ls1 int lexus is200
- modifying a ls1 harness to a street rod
- 2002 LSx Truck 5.3 into 91 C1500
- LS1 Miata driving videos
- Evap block off for truck manifold
- LS motor to Th350
- Lincoln LS...
- T.p.i
- LS1 S10 Burnout Video
- Finally got my project engine!
- LS Pilot Bearing Size
- Ford Fairmont + Turbo LS1
- removing wiring from the donor vehicle
- ** Yet Another S13 240sx Powered LS1 Swap **
- TAC module plugs
- HELP! Identify these wires 2003 5.3 harness
- Which motor mount kit for my F-body 2gen?
- '99 Fbody fuel pump asembly
- TPS C5 corvette help
- TT402LS1/ 71' Chevelle update
- How much room?
- clutch cable
- How much room?
- LS1 with richmond 6 speed
- LS1 into LT1 Fbody Help
- Fbody vs. GTO Accessories placement
- Just got back from dyno. Have a few issues.
- deck top dyno
- shifter boot
- ls1 fox body guys..... what tranny cross member?
- s10 ls1 guys......
- Anybody wanna make me mounts and headers for mt s13 swap?
- will any headers fit for my ls1 jeep wrangler swap?
- engine install
- R34 Skyline Twin Turbo Ls1 Drift Car
- How to remove an engine harness from F body
- Ls1 in toyota 4x4
- Which motor mount kit for my A-body?
- SC400/300 Mount Kit
- LS1 swap into 73 Z/28 update
- heater hose water temp adapter
- FD Ls7 Rx7 at New Tech
- Viper Engine in an F-body?
- 6.0l in a 3rd gen camaro
- 4 cyl Fox LS1 swap.
- pacesetter long tubes
- LS1 S13 Nissan 240sx swap..header info
- LS1 Versus SBC Oil Pans
- need 70's water temp sender for ls1
- LSx in a BMW 5 series (E39)
- Finally got my harness
- Progress on the LSX Harness Conversion
- Oil pressure and water temp gauge
- what would you guys do for headers?
- Any front bracket/drives for alt. only?
- truck intake to ls6 intake write up
- Lets talk about the S&P modified oil pans for 1st gens...
- stainless works headers (From Sticky Section)
- ls1 in a v-6 car?
- Engine bay mock-up trick
- What thickness steel for motor mounts
- videp
- stock air boxes lying around? for sale
- CRX Swap
- Shifter mod/relocate options?
- The ABC's of putting a LS1 in my 1969 Corvette
- aftermarket oil pans, how to close up bell housing
- 240/LSx fuel system questions!
- Quick walkaround of our Miata
- 6.0 Backfiring
- Some more pics of the Corvetter filter/FPR
- ls1 in a fox body, blah blah blah
- 3.8 turbo mustang with a glide
- Thinking about putting an LS7 into my e46 M3
- 240 swap guys
- Which ones can be connected to one fuse?
- LS1 for my 66 nova
- Ls1 with th400
- Drove the LS1 Coupe Today!!! *PICS*
- LQ4 / LQ9 - Request Vehicle List
- Getting started, questions. 67 ElCamino/5.3L
- 2nd gen a/c questions
- 57 Belair LS1
- are there any finished gtm's?
- temp sender adapter (might have good news
- Good M6 harness
- rx7 build
- LS1 swap into my Transam
- truck harness
- LS1 in a 96 Impala SS
