- msd controller for carb
- Tensioner Pulley Location
- 4th gen master/booster in 92 camaro
- 72 Olds 350 Cutlass
- Lexus IS300?
- does "Mr.Know-it-all" know this?
- LS1 in a cherokee???
- Ever heard of a Mazda Navajo LS1(or other) swap?
- sbc in a fox-body, please help
- ls2 - 69 Camaro - NY
- Picked up my motor set tonight.
- Crankshaft Pulley Removal
- 2nd and 3rd only in 4l60E trans?
- Gen III Land Cruiser
- Fuel pumps/regulators- carb feeds
- LS-1 into 2nd Gen F-body Mounting
- Porsche 914 LS6
- any wiring harness from a v8 engine 99-2000 will work on ls1?
- Lamborghini Dress kit for LS1
- 6.0 L 408 going in a 67 camaro. looking for someone to install
- Without PCM, these works?
- Need Transmission Help!!!!
- modifying an oil pan
- '99 5.3L Into '96 S10 4x4 V6??
- Mallory 5110FI pump
- throttle body mod for TV cable
- LS6 in my 56 Chevy
- drop a LS6 in my 56
- post swap pre-reprogram hp?
- Block mount locations?
- Foxbody conversion parts...
- GTO Oil Pan
- Project LS14-T
- Low profile individual runner intake for LS motors
- LS1 to LS6 swap....any advice??
- BCM and fuel pump relay question
- How many S13 LS1's are there?
- rear end
- Fuel Pressure Regulator help....
- Chevelle guy: MWPE Firewall smooth kit
- More 240SX Clutch Master Questions...
- LS1/ 4L60E trans crossmember for 1968 Camaro....
- LS1 motor plates.
- FS:Eldebrock LS1 ignition control box for carb set up
- LS1 power steering pump with older steering box.
- 5.3 valve covers and headers
- Video of radixed 72 K/5 in the snow
- wiring harnesses?
- I Need A Computer/pcm/ecm
- engine stumbles and dies if altenator is connected?
- LS1 and T-56 SWAP INTO 71 RS CAMARO
- Analog speedo, oops
- S14/S13 LS1 swap.... driveshaft and rear??
- Carbed 6.0 combo ??
- Infiniti G35?
- skip shift
- Starting my S13 LS1 project.
- Chevelle Pro Touring Guys, New Hotchkis 68-70 GM A-Body TVS Kit Available
- LS1 powered DeLorean
- Good sites for E36/46 BMW
- Need your advice Chevelle 71
- Engine advice for offroad truck
- 69 Chevelle Swap
- LS1 swap over an 94 LT1 camaro
- length of stock fbody clutch line
- Entire Engine Wiring Schematic
- How to make up a 5.3 & NV3500 5 Speed?
- LS2 into a 3rd generation camaro
- 95 LT1 in 95 V6 Compatibility Questions?
- Corvette Fuel Filter/Regulator and Quick Disconnect Fittings
- frame building
- Any body know? LS1 install
- Have a Olds Motor/Trans/Rear..
- Converting a LT1 to a LS1
- PCM connector pin part number
- LSX conversion - harness info
- Info on Swapping LSx into 93-97 Fbodies?
- AC system on 98 Ls1 swap
- Quick Engine Mount/Boss quesstion
- Mercedes Conversion anyone???
- Best car for conversion
- How does a 496 compare to a LS1
- 1976 camaro / 02 LS1 swap
- Help with Walbro fuel pump fittings
- People running 4L80E's please come on in..
- LT1 Into Intrepid
- Help with Russel Fittings
- Attn Rob, Relay Wiring
- Video of my TT LS1 Volvo Wagon!!!
- Did I order the wrong k-member? MUSTANG
- Which mounts for 69 camaro?
- Chevelle T56 clutch bleeding
- 79 T/A rear end rebuild
- Welp the Camaro's gone
- anyone have a LS1 F body evap tank they are willing to sell?
- Any 1st. gen ls1 700r4 swaps
- pics of progress on 69blackwidow
- ls1 in my 94 truck
- Rx7
- 71 blazer conversion
- oil pans
- 94 LS1 swap Fuel sytem setup
- Fuel system Q
- Corvette Alt. bracket
- built a new exhaust for the 240
- mercedes ls1???
- Racing season has come to end...
- Taurus 2 speed cooling fan
- neutral safety wirring
- Tranny Cooler ?'s
- Test fitted the motor today
- obd1 to obd2 adapter (lsx swap)
- Flywheel help please 92 K15
- ls1 f-body accessories vs. corvette accessories
- 3rd gen radiator questions LS1 swap
- SS 454 Chevelle Convertible/LSX T56 hits the streets
- Antique/Classic Insurance
- S10 TBI swap...
- firebird / camaro ls1 fuel tank/line question
- Guy's need some help on conversion. (newb)
- ls1 size compared to Ford 302 and gen1 sbc
- Picking up a Notch
- mustang vs. rx-7 vs. 240sx
- Which year does smog test exempt kick in in Cal? 74 or later?
- 4th gen camaro fuel tank on first gen
- First Gen F body guys whats your 1/4 and MPG?
- Custom valley cover
- 1994 Z28 Lt1 To Ls2,ls6,or Ls7
- Twin Turbo 71 Chevelle Pics
- LS1 to TH 350
- Happy Thanksgiving All!
- Northstar in C5/C6 or LS1 F-Body
- ls1 into 90 vette?
- LT1 to LS1 T56 swap
- Custom LS7 Valvecovers!
- 99+PCM with 98 harness?
- 69 Camaro Brake Booster Clearance
- LR4 --> LS1?
- Oil level sensor question
- anyone here have a FBody header handy?
- 4l65e wiring??? please help
- Need some help with LS2 starter
- PGN: 2000 Jimmy from Pleasanton,tx
- Ls1 swap headers for mustang... Will these work?
- F to Y body accessory swap
- LS1 motor plate
- 6.0 In 72 Vega RaceCar
- Q's about conversion wiring (clutch sw. and tank level)
- '04 Mustang GT 6.0/4L60e swap questions...
- 04 2wd Silverado wire diagram
- 69 camaro LS radiator/fan/w dccontrol pics
- quick question on ls1 project
- LS1 PS pump or orig Chevelle pump?
- Any '60-'66 Chevy truck swaps done?
- s10 shifter cable/4l60e?
- sensors question
- do i HAVE to get ls1 camaro/ta wiring harness?
- What kind of spark plugs and gap size are working well with carbed LS1?
- Intake options/advice?
- 5.7 Ram Jet '02 S10 Blazer 4X4 Conversion
- 05 5.3 into 86 z28? smog laws (ca)?
- 67 RS/SS getting a little LS2
- 2nd Gen Camaro LS1 Long Tube Headers
- 2000 5.3L tubro s-10 project !!!
- Pictures of my new LS1-powered Rx-7
- Anyone did a LS1 swap into a 300zx??
- 5.3 or 6.0
- lsx 2 fox motor plate
- for all you gtech fans
- Can someone explain the differences in the LS-1 fuel rails for me?
- For Sale: SFC's for 67-69 f-body
- trans bellhousing bolt question.
- Anyone with Novas? any websites?
- Carbed LS1 guys please HELP
- My LS1 RX7 Build
- Whats a good offical reference on LSx emission systems?
- LT1 to LS2 conversion
- v8 swap into v6
- tranny cross member
- Should I go efi or carb'd?
- Question about venting a carbed LS1
- LSx into S chassis, clutch idea
- Reading ODBII data. Homemade scanner/tuner.
- in order to use ac with ls1 in wrangler, cut frame?
- Help convertign OBD-1 to OBD-II
- T56 shifter over a bench seat 71 Chevelle
- LS2 Datsun Z Testing Traction!!!
- Which Engine GTO, FB or CTS-V in 68 FB
- LS1>Toyota alternator questions
- Edelbrock 7118 carb kit problems and questions.
- ls6 into 2000 camaro help
- 1990 supra
- Wrangler guys
- malibu worth
- 'Vette accessories in 1st gen F-body?
- OK I'm cornfused here
- A/C question?
- takeout / junkyard engine or from scratch?
- Carb setups
- venting fuel tank?
- Fuel EVAP needed?
- 5.3 truck motor bolt to a 4.3 4l60e in an S10?
- just playing with the idea
- Gm parts...best prices?
- LS7 + BigStuff3
- ls1 s13 240sx completed
- 4 speed to a 1999 vette ls1
- '74 GMC sprint
- New and need advice...
- 1.75" to 1.5" radiator hose adapter?
- Took my Camaro out for a spin
- S10 Swappers - Better Brakes?
- Ls1 350z
- LS1 focus
- 1993 RX7 R1 w/ LS1 T56 in for sale section 442 RWHP/408RWTQ 10.9 1/4 mile
- With all the oil pan issues, why not go dry sump?
- LSX MUSTANG 05+ Vid
- New thread about my LS1 mustang... NEED HELP!
- HOw much is a 71 Chevelle Ls1 T56 conversioin
- help: trying to find computer & engine harness off a 2000 or 2002 m6 T/A
- Volvo LSx swap
- Flywheel Torque Specs?
- 5.3/5.7 Hybrid
- LSX into mid 90's Jaguar
- Updating a Tahoe
- Question On ls2 Swap
- regal 1/8 mile times
- stang lsx motor plate and headers mass produced
- 6.0 into a 73-87 truck header question
- wiring help.. 3.4L V6 to Ls1
- M6 wiring harness
- Ecotec + T56?
- Clutch Line conversion Fitting solved!
- New GM 454 LS Based Engine Available...
- It's started
- BMW E36 or E46 Chassis
- Got the car today e36 BMW
- Battery wiring question (starter, ground, alternator, etc)
- LS1 into LT1 car?
- Ls1 In Shelby Or Ac Cobra
- Fox LS1 swap headers....
- LS1, 4L80E, range rover, questions etc etc
- LS1 coilpacks/loom/brackets- suppliers?
- What is this called?
- HELP!!! LS1 into 78 Camaro mid install issues
- Just thought you folks would be interested!
- Anybody done an LS-1 into a 73-87 Chevy Truck
- 1986 Jaguar XJS w/ LS1
- Photo's of Steward Reverse Rotation WP
